Tires. At 30,000 and faithfully balance and rotating every 5,000, the fronts started to scallop. I feel the camber is off by factory specs. I think this contributes to the vehicle wanting to wander left and right down the road if there is worn groves on the highway. I am going to bring this up to my Mitsu Dealer and see what happens. By the way, the camber, I feel, is tilting the wheels to much inward at the bottom of the tire.
But I had to wait a day, and lose a days work to have the morons provide me a new battery under warranty.
Gotta love a maker who thinks customer service means giving me the business.
Another reason that I dispatched mine.
Glad that you at least seem to have half the problem resolved -- with no issues. Hope it stays smooth, ask if the tires aren't hosed due to the other stuff that they had to replace?
A Rally Good Time!
Should have there been a noise when worn? Yes. Unfortunately, that noise would be metal on metal noise, thus the pad was totally gone, and rotors damaged. They do not have a wear indicator noise maker.
Get a second opinion. Shop around for a better deal. May not find one.
I think I will get another opinion, but I don't have much time. Will I cause even more damage if I don't get this fixed soon?
Will it cause more damage? Possibly. Could start to damage the calipers that hold the pads. More cost. Right now I would say you don't have much front braking which is dangerous. Need to get them fixed ASAP!
Anyway, they called me and told me to come pick it up. No charge. Under warranty. For they also had to replace both upper control arms. The bearings were shot on both of them.
SO, I had a talk with the mechanic, and found out that he has replaced several. A common problem on the Sport. Said Mitsu is working on a fix, but have been dragging there feet and keeping it hush, hush. (Oh boy!) He has not replaced any on 2001 or 2002 models yet, but he said the arms do not look any different. I have 31,000 miles. Said he has seen them go as long as 70,000 on ones had to replace. This is a problem on all Sports since they have been manufactured.
My Sport has been a good unit so far. If I had to pay for the cost, the mechanic said it would be around $100.00 - 150.00 cost to do both.
MY concern is that Mitsu. has been caught on a cover up of defects a couple of years ago. Thought they would have learned. Maybe they have and are replacing these at a no charge. But I doubt it.
If you are having front end vibration or excessive tire wear, I would get it checked out. I hope someone for Mitsu. Headquarters reads this and gets the lead out to correct a known problem.
I still feel this is a quality rig, but has some bugs, like most vehicles.
Should Mitsu. warranty the tires. Probably. But you know they won't or even pro rate them. The little clause on all vehicle manufactures that the tires are covered under the tire manufacturer warranty. But, if the vehicle causes the excessive wear, the auto manufacturer should cover them. I know in some cases they have. Just depends on the dealer. Do not know if the dealer just pick up the cost and did not pass it on to the manufacturer.
Steve
I'm only on Edmunds Town Hall's SUV sites (with my co-host Tidester). If you see me elsewhere, it's a pale imitation :-)
And there's lots of insurance related discussions in the Finance/Warranty/Insurance Board if you can't get enough action in here.
Steve
I had one of the MSs that shook pretty badly at certain speeds, and it ultimately did not make me feel that my family was safe in it.
It also got overcrowded relatively fast -- maybe that is one reason I went to the Suburban.
Lastly my 2000 MS LS cost exactly $8 per 6 mos less than my 2002 Sub LS, which is bigger, cost more and is newer, so I suspect that the Ins. co feels the Sub is a safer auto as well, by the way my mileage went down only (if you can say only) about 2 mpg in each case -- not much for the added size gain and safety.
DO not get me wrong, I enjoyed the MS, but the shake became more than I could tolerate, and service was a fight all the time -- warranty service that is.
Get you feel best meets your needs, the Garage (whereever it went) has much data on the shake thing, the service thing and lots of happy MS owners.
Good luck with your decision.
It can be a great vehicle, and they may have resolved the shake problem -- if so that already makes it better than 00 was.
Help... Has anyone dealt with the problem? Help!
hi everyone, i'm new at this townhall and i'm from the city of angels.
-AR
I was able to get that deal (I no longer have mine, see earlier posts), ON THE PHONE from several dealers.
And the one I went owned up to the phone price.
I have a '02 montero sport, recently I notice a rattling noise coming from the ac compressor (I think) when the ac is on. I have not talked to the dealer yet, Just wondering if any one out there
might have the same situation.
Has anyone else experienced this? If so, what did you do?...drill new holes?
I began having similar problems, but not as pronounced as you describe, mine was a '00 LS 4WD model, bought in MD (though I live in VA). My advice is use a different service company and or find a good local mechanic.
Also look up service bulletins that may help you.
There is some inherent problem with some of these autos, I have never found a solution.
We traded ours in on a 02 Suburban as we needed more space and the ability to get out of our own way (more power) among other things.
I have never regretted making the decision to lose that Mitsu, and I was a generally loyal Mitsu person, with 2 others prior to that and a Dodge that had a Mitsu engine.
Good luck, and if you are considering Stohlman for service, I never ever had good luck with them and had to submit 2 formal complaints on them on service issues (with other Mitsus, not the Montero Sport).
A Suburban. Yes it is not the same, but the shakes at speed are a danger, and they are gone from my automobile.
Good luck and safety to you with yours.
Chip Stewart
cstewart@lexpharma.com
Get the ones you like even 265 75 16's for example cause they'll fit, my 265 70 16 AT tires made the ride seem more stable and a little less susceptable to going with the crown in the road (causing a drift to the left or right - good for drainage, bad for sports).
Slight vibe at 47 mph's, luckily I rarely travel that speed and have adopted varied lane choice on the highway to even out the ride and lessen arm fatigue. If you're still under warranty, you may want to have your control arms replaced prior to purchasing new tires.
Good Luck.
The added play in the wheel was also an issue. Whether or not the arms caused the scalloping of my tires (see my previous posts) or vice versa, I'm still not sure.
This should be covered under your warrantee. Let us know how you make out.
One added feature to the 2003 model, is that it has a 1" higher roof. A feature that would be nice for taller people.
Thanks in advance.
