-June 2024 Special Lease Deals-
I had a very similar problem with my 95 accord. I was ready to replace the window motor for the driver door...until I saw what a pain it looked like it was going to be. I hated evry time I had to pull up to a drive through! Guess what fixed it? A $5.00 can of CRC Silicone Spray! I generously sprayed the entire rubber window gasket inside the door from top to bottom that I was able to reach with the spray (don't get it on your paint!). Then I sprayed some on a rag and wiped it around the edge of the window glass. The very first time I tried it, it worked like brand new!! I know it sounds too simple, but it sure would be worth the $5.00 can of silicone spray : ) When I saw how good it worked, I did all four windows!
let me know if it works...or at least helps.
pcnashville.
Follow the instructions there and you'll get your error code. Not sure on your vehicle mileage but I would guess it's above 100K (hey, our babies are getting old now) and if you aren't noticing drivability issues I'm betting on an EGR code or something along those lines. Be sure to post what you get though.
The Haynes manual is decent for basic maintenance and a bit more, but if you are interested in the real nitty gritty you might want to consider the service manual from Helm Inc. The service manual combined with a Haynes make for a formidable combination!
Good luck!
About EGR, could I inspect the system without a vacuum gauge?
cheers
Some have even plugged the port with the diaphragm up to see if the valve could hold vacuum as well but again, a gauge is a cheap investment you will get use out of.
If some of that didn't make sense please forgive me, I need sleep!
it makes sense, i will try it tomorrow. In case there is too much carbon around. Do I have to do the EGR port cleaning manually? or I could bu :lemon: y any 'magic liquid' at autoparts? :lemon:
This link is for a 95 model Accord engine, but it gives you an idea what "EGR port cleaning" means, and how to do it. Hope it helps
http://members.troublecodes.net/hondadude/95AccordEGR.htm
I checked the EGR valve, drew vacuum on hte thevalve and the car turened off ...so valve is ok. one of the hose to the air intake (between the air filter and the throttle body) had no clamp around and was a bit out.
since elroy toldme to check that link. I looked around and i saw dirt around the threottle body and air intake hose. so next step is to clean that region in and out.
The interior (overhead) lights in my car works only when 3 of the doors are open (i.e. FP, LR, RR). For some reason when I open the FD door my interior lights do not come on, nor when I put the key into the ignition switch and open the door there is not warning signal. Anyone out there is able to help?
probably you have another switch broken in the closed position as well.
1. drew vacuum from the EGR , car stopped.
2. checked vaccum FROM the solenoid valve , no vaccu,
3. checked vacuum TO the solenoid valve, ok there is vaccum.
4. there is power getting to the solenoid valve same voltage as the battery. (It was around 14 Volts!! is this ok value for voltage with the engine on?)
Any other place I should look? thaks!
Then the flow is restored. With the passages blocked, the valve is basically out of the equation. Be carefuly after cleaning the passages though, as deposits left may clog the valve. Not that this really matters, you just may have to remove and clean the valve a time or two as the deposits work themselves through the system.
cheers
I chased a code 12 (1992 I4) for a month before taking a small drill bit to the output port. No more light! The ECU expects the EGR valve to rise within a limited time. If it's slow, you get an error.
14 V sounds a tad high. Are you sure the voltage is applied to the solenoid all the time? That might imply an ECU issue, or wiring problem. It should also stall the car, unless the solenoid is toast. Have you measured the resistance across the sol. leads?
-Greg
I will follow your recommendations tomorrow. But I remember I checked the solenoid voltage and there should be 12 Volts feeding the solenoid at all time. Why should it be hotwire?
14 Volts I measured on the battery poles. I found out it is ok . Voltage should be higher when the car is running due to the charge coming from the alternator
Anyway, this is the link you will be interested in for cleaning the egr passages. Let us know how you make out!
http://www.tegger.com/hondafaq/misc/t2t013.pdf
-Keith
i'm looking at a 2002 schematic, not the same i know, but it implies that when you turn the headlight switch from OFF, to PARK, to HEAD, two relays pick up (one for both the L and the R headlight assemblies). downstream of the relay contacts is a 20A fuse for each headlight.
when you turn the stalk switch to HEAD, immediately, power should be applied to both relays, closing the relay contacts, supplying 12volts to the low-beam filament in each headlight assembly.
then, when you select your high-beams, an additional circuit is completed to also apply power to the high-beam filaments.
now, if this '02 circuit is anything like the '93, your observation implies that the headlight relays for Right and Left are working. Your Headlight switch on the stalk is also working, and finally, the fuses downstream of the relay contacts feeding the L and R headlamp assemblies are both good.
otherwise, you wouldn't be able to have ANY lights H or L.
so, i have to ask...
is it possible (and this is a wild guess and assuming the circuit is like the '02), that you had one bulb (low) burnt out and that you were driving that way for some time (it can happen) when the other burns out, and then and only then you noticed you had a problem with the lowbeams?
you can remove the bulb and look on each and see if one of the two filaments is bad, or use an VOLT/OHM meter set to measure resistance / continuity and see if the filament is broken.
or, even more simply, you can go down to a local auto parts store (NAPA, Autozone, Pep-Boys, etc) and ask them to help you replace one headlight bulb to see if the low-beam in the replaced bulb works, then if so, put another one in on the other side.
let us know.
and an interior one, though I doubt this is applicable for what you are looking for. Also, I'm pretty sure this is missing some items but I think the under-engine one is the one that's important in this case anyway:
good luck
On the steering column, the lever was pushed forward into highbeam position the entire time. So, when I put my lowbeams on and saw the light on the dash for highbeams I was confused - and turned my lights onto parking lights, thinking that was where my lowbeams were. Real stupidity :P Of course, I didn't figure this out until going through both fuse boxes and replacing both lowbeam bulbs.
Don't worry, we ALL have our moments. The option is whether or not we admit to them
Also, my brake pedal has recently begun to go straight to the floor on occasion. This particular problem only occurs when the A/C is running. I just pump the brakes once or twice and they return to their normal state of operation. Any ideas?
Check for a vacume leak going to the brake booster or the booster itself. When the engine is not running, the brake booster is not in operation. If you spray carburetor/injector cleaner on the vacume hose it makes the leak easier to find. When you spray the leak it will make the engine idle change, then you've found your leak. Good luck
HELP!
http://www.autocomputersupply.com/index.asp?PageAction=VIEWPROD&ProdID=241
http://www.enginecontrolunit.com/ecu.htm
http://techauto.awardspace.com/transmission.html
Most likely the blinking D4 and sluggish performance mean the car is in "limp-home mode" which starts you in second gear. Pull the codes from the trans computer and any from the main computer and work from there.
$200 isn't a terrible price for the TCU from a place that repairs and resells but I got mine from a yard for only $75. Just make sure it's a match as someone else mentioned.
good luck
Should I go to another mechanic? Pet boys or autozone or somehting else and get it fixed? :confuse: :lemon: :confuse:
