Honda Accord (1994-1997) Maintenance and Repair
In order to make the original and highly popular “Honda Accord Owners: Problems and Solutions” forum more manageable, we are dividing that forum into “Accord generations”.
Please make sure you are in the right generation for your Accord, and then post your questions concerning any maintenance or repair item.
Thank you again for helping to make the Accord forums so great here at Edmunds!
MrShiftright
MrShiftright
Most times it starts but some mornings it leaves us without the use of a car. And sometimes trying it again a few hours later will start it up. Has anyone had this problem and what did you do to solve it?
Smarin
But then it might have some typical problems of many '95 V6 models that are covered under Honda's Service Bulletin 98-081. Check with your Honda Service.
I am not sure, but I think they will take care of it under an extended warranty that was granted to owners of this (and several other '95-'96-'97) model -- BUT ONLY IF THE "CHECK ENGINE" LIGHT COMES UP.
I'm assuming your 95 uses a lock-up converter, although not familiar with that year.
Mrbill
tank. ($-$-$-$-$!) You won't know where you really stand until you have tranny fault codes read and interpreted by a dealer or an independent transmission shop specialist.
sputers, acts like it is only running on 3 cyls had it on the scope 2 times
at two differant dealers they could not find a problem. very,very poor
gas milage. and it only does it when its in gear or under load. this is
driving me crazy. ive replased all tune up parts, cap,rotor.wires,plugs
gas filter,air filter.dont know what else to do really love the car.
hate to get rid of it. butt my old chevy pick up gets better milage. HELP
PLEASE !!!!!!
--It covers emission issues, which in reality is a LOT... I got the list and it's really long... And it gives me an extended warranty up to 150,000 miles, or 14 years... Pretty nice... I already had my Distributor and Speed Sensor replaced, and a free Tune Up at 75,000.
Do a Google on this...
BUT, as much as I understand (though not totally sure), you going to a Honda Service, complaining about the car is not gonna make them pull out service bulletin 98-081... You need to have the "Check Engine" light to come on. Again, not positively sure...
Check with a Honda Service. You've got nothing to lose.
J.e.d.
I took apart the door panel and looked at the necessary steps in service manual.
I have the option to buy a replacement actuator or a new latch with an actuator already attached.
72115-SV2-003 ACTUATOR ASSY., R. DOOR LOCK $88.45
72110-SV2-013 LOCK ASSY., R. FR. POWER DOOR $136.53
I would prefer to buy just the actuator and attach it to the old latch. (would save me about $50). Can anyone attest to the difficulty in doing this? Or is it best to replace the entire module (latch + actuator completely assembled).
Also when removing the outdoor door handle (necessary to replace the actuator), there are two bolts (accessed from inside the door) any tips in how on how to remove the hard-to-reach bolt?
I don't know, but my actuator has died in my 96 sedan (156k miles) on the right rear door, too. The dealer quoted me $220 to fix it. I left it alone.
I checked several different things including the ignition coil and fuel injector circuits, but finally replaced the distributor as a last ditch effort. After replacing the distributor nearly one year ago, I haven't experienced the stall problem again. If you narrow it down to the distributor, I recommend purchasing from Distributor King (I bought through them on Ebay). The distributor was high quality, but low $$$.
The cost of changing it now will be far less then the cost to repair the engine if the belt were to break.
Belt replacement isn't that complicated, so don't rule out going somewhere other then the dealer if money is an issue.
If your considering doing it yourself, you should be able to replace all belts, water pump, and in my case a valve cover gasket all for under $100 (non Honda parts)
Mrbill
mrbill1957 - On the other hand I would like to thank you for your response. I am hoping the 105,000 is not the exploding point!
I have done other repairs on my car and I am considering attempting this on my own.
Especially when my dealer want $500 installed.
I have looked at my Honda service manual and it seems straight forward.
Basically:
Drain coolant.
Remove all hoses connected to radiator.
Remove all fan harnesses.
Remove radiator mounts.
Remove radiator with fans attached.
Remove fans from radiator and install on new radiator.
Install in reverse order.
* Can anyone recommend an aftermarket radiator that installed easily into a 94-97 Accord?
* To anyone who has done this type of repair and run into any type of complications, any additional tips would be helpfull.
* One thing I would like to do is find a way to keep the transmission fluid from leaking out of the hose once I remove it from the radiator. I also plan to protect the fins with a piece of cardboard when installing the new radiator.
hopefully its that!
btw: i drove my 1994 Accord LX Couple until I had a failure of the Cam Shaft (not the pully, not the timing belt, but the shaft effectively snapped). I know what happens when the valve timing is instantly and completely gone in an interference design. The lights, the sound, and the visuals with the engine cover off... the effect isn't pretty.
I would have driven the car for another 150K if that bizarre failure didn't happen...it had 150K on it. it was super reliable, got great mileage, was fun to drive, perfect for my needs.
i sold my toyota corolla with 175K on it in very good condition, only stepping to a van when i couldn't get the kids in the back seat of that one, or the accord.
w.r.t. critical maintenance, i do believe in following the book that's a true assessment. guilty. it's possible for the '94 the interval might have been 60K. i'm sure i went over 10K by the book. guess i must have been doing the same sort of thing as you.
i do understand - specially if money is tight.
again, my sincere apologies.
The car drives perfectly, even after repairs from a nasty guardrail collision last year.
Any thoughts, and I mean ANY thoughts on what could be causing this would be appreciated.
I hate to do this, but the sound is kind of like a low voice going "Brrrbbddbbrr" and goes away when you pass over or drop below the above mentioned RPMs.
Thanks folks!
thegrad
happy motoring!
the same problem occurs. It makes a whining noise when I first start the car and then the noise stops eventually. The other problem is that the ABS light comes on and and stays on and the brakes don't work without a lot of foot effort. Any guesses on what is causing the failure?
To have a locksmith make me a key it will cost $120. I was wondering if anyone on here could tell me how to make the car start without a key. I don't care if the car starts with a screw driver. It is the bigest POS on earth :lemon: I bought it at an auction......need I say more. So please any advice would be much appreciatied.
SMARIN
The problem with my car is I can't lock the driver's side door since even the manual lock triggers the power lock system to also lock the passenger side. So locking the driver's lock in any way causes it to keep locking over and over again, and doesn't stop. So I haven't been able to fully lock my car for over 2 months now. Luckily nothing has been taken from inside! I'm just trying to make sure it's my actuator before I spend the $200 to buy and replace one. I'm the typical starving college student, except I just had to replace my tranny totalling $1200 and my radiator before that at $400. I really don't have money to spare on a needless repair, so I want to be right the first time. :confuse:
http://www.carpartswholesale.com. The entire process was pretty straight forward and not difficult at all. Also, while you have the radiator out you might want to inspect the front engine mount as mine was cracked. Jack up the engine enough to see if it is cracked with the weight off of it. If it is cracked you won't get better access to it.
I reccommend going to Auto Zone and having their free (at least in Birmingham, they advertise it as "Free") check engine diagnostic test done. It may help you determine the problem. They use a computer to read the warning light codes showing up in your car.
I guess that I could try another garage and a different computer. My mechanic is confounded and does not know what to make of it. It is a problem as now I don't have a warning light other than temp and I will have difficulty in selling the car with this "feature"!!
I'm confused, I thought the check engine light was on? Is the temp gauge registering as hot?
The problem has been going on for a year!! So regarding the gas cap I am doubtful...I have filled up the petrol tank many times. But I will have the gas cap looked at..Perhaps it does not close tightly. Also the light seems to go on when the engine warms up ... after a few minutes. Now in the winter, it takes a bit longer till the light goes on..
Re the TEMP GAUGE The temp gauge does not go on - it cannot, but if the engine will (hopefully not) heat up, then I will be able to see it on the gauge .. I actually burnt up my engine last year, as I did not notice the temp gauge heating up (The car had just been serviced and I suspect someone did not close the radiator cap) and I was distracted by the Check Engine light and did not see the temperature gauge going up up up!
Now about my windows they go up and down super slow one of the main reasons i believe thats the case is because the rubber linning is catching the window but its just the driver and passenger side windows the back two are fine. Cant get tint on the widows if they go up and down so super slowly rinkeled tint doesnt look good. :shades:
As far as the radiator goes, read post 46 (I think).
As far as the locks go, read back earlier. You will see that several of us have this problem. It's the power lock actuator going bad. Sometimes I have to lock my passenger side rear door manually, or try to power lock it 3-6 times before it will go.
As far as the power windows go, motors wear out and slow down on MANY cars, yours isnt an exception. Mine are slow too, but still work fine.
thegrad
The V6 has a known problem which is covered by Honda's extended warranty (discused here previously)....
If it applies to outside the USA, that's a different story...
ABS unit, starter, ignition switch, exhaust sys.(several times), and more. Just took it in for inspection & was told it will need $1500 in repairs/labor to pass. Gas line rotting along with brake lines, leaking rear tranny seal, & leaking oilpan gasket. NE area of US is rough on cars. I have 103k on the car and that's it for me. Selling the car and buying a Crown Vic.
You might try some silicone spray lubricant on the window seals. You can get a can for a couple bucks at a hardware or auto parts store. A few years ago, I had an '89 Accord DX (with manual windows). The driver's window took a lot of effort to open/close. I put the windows down, sprayed the lubricant along the seals, moved the windows up & down a couple times and repeated with more lubricant. It was much easier to open/close the windows after that.
