-June 2024 Special Lease Deals-
BTW, I drive a '96 Accord LX 4-cyl Auto
thegrad
The rubber lining on the driver's door is in fact catching on my door. My remedy to this is to not open the window all the way (a bit tricky at drive-through restaurants). I saw a suggestion to use silicon spray, so I'll try that.
1. would you consider this vehicle safe for resale in this condition
2. what is this thickness of new factory brake shoe linings .. to me .063 doesn't seem to be very much.. what would be the expected life of these brakes (.063) at feeway speeds daily?
3. How much does it matter if there is play in 1 ball joint?
What would you consider this vehicle be worth on resale as is?? fixed?
More importantly ..Would you drive this vehicle as described?
or did you want to sell the vehicle to someone without disclosing the condition of the vehicle.
confused.
i don't know if it's "safe". the play in the joints don't concern me (personally) as much as the brake pad (? - was that a measurement of rotor thickness? i doubt it) remaining and the fact that one cable to the Left Rear brake is stuck.
http://www.tirerack.com/brakes/tech/techpage.jsp?techid=80
brake pad is .063 on rear shoes...
I have my doubts as to how long a set of brakes like this would last... I find it unbelievable that mechanics that do safety checks on vehicles claim these not to be a problem and pass them off as ok.
I had a second shop do a safety check on this vehicle.. the original shop only said the car required wiper blade replacement.(No mention of the condition of any other parts.. just passed inspection) I kind of think they could have at least said.. "Well , it passes but there are some problems you might want to consider)
The second shop was adamant that they would not sign a safety certificate because as far as they were concerned the car failed in 7 areas.
1. 2 burned out marker lights
2. rear brakes worn out ( said he relies more heavily on visual inspection than just a micrometer measurement)
3. upper right ball joint movement
4. LR jammed brake cable
5. Rear control arm bushings
6. Windshield chip
7 exhaust leak
My primary concern was in handing this vehicle off to my daughter attending school some 600 miles away. I wanted to ensure that whatever she was driving could be at least considered safe. Secondly I was wondering about selling it off "certified" as safe when these questions arose.
I've tore down a few engines, changed a couple of head gaskets, but never turned a wrench on a Honda, or any other import, other than routine maintenance.
Does anyone know how many hours I'm looking at to change the timing belt and water pump on my 96 Accord?
Whats more difficult to change the timing belt on
a) traditional made in the USA forward facing engine
b) foreign sideways engine
For the past month the car has been idling up and down in PARK when it's heated up. 1200 - 2500 (very fast)
Now when I accelerate in DRIVE it goes to 3000RPM or higher but won't go faster than 60KM/HR
I've been driving around at 50KM/hr with my flashers on.
New water pump
New timing Chain
New Altinator
New Battery
New Starter Switch (and that was my call, it was stalling)
Oil (synthetic) 3 times a year.
Gas Mileage GREAT !
I'm thinking new EGR Valve.
But now I'm worried about trany...
It's not fuel line, or fuel pump.. nope not that. No miss firing, purrs wonderfully. shifts smoothly (auto)
Maybe a vaccume leak..
Anywho.. taking it in tomorrow and asking for the EGR valve to be replaced. See if that works, than a vaccume leak check. Than we'll have to look at tranny.
Will inform you tommorow
Any other ideas, huge appreciated..
http://www.cybertrails.com/~bestinthewest/autotips/9091accordcomprblems.html
I think this is OK to post a link to a Usnet newsgroup hosted by Google:
http://groups.google.com/group/rec.autos.makers.honda/browse_thread/thread/b1592- - 70f4c9ac253/808ae1360d68686d%23808ae1360d68686d?sa=X&oi=groupsr&start=0&num=2
A couple of hits indicated a possible problem with the Throttle Body gasket.
google your problem. good luck.
I have an Accord LX 1995 manual transmission with ~140k miles on it. Recently the Check Engine Light came on. I
used postings in this forum and via google to find out
how to read the code. Its 41 which my Chilton book tells
me is a "Heated Oxygen Sensor heater". So either the O2 sensor has gone bad or there is something else wrong.
Any ideas?
Should I try replacing the O2 sensor? Is this a serious problem? The CEL came on 4 days ago and there is no difference in the car driving.
Chris
could someone tell me what it could be,how to fix it and how much it will cost. thanx
there are two camps i guess to servicing ATs, one that says it should be flushed, and another just drained.
i understand the concern of some who say flushing may result in debris being kicked up and placed somewhere where it may do more harm than if it just sat where it is.
from my perspective, if debris is clogging a minute passage where fluid flow is used in the process of shifting gears, i'd want it moved / dislodged. i could reason that a drain only service might leave that passage clogged, and the drivability of the vehicle would still remain sub-par.
i'm also an advocate of having the fluid changed much more frequently than every 90K. First off, my '02 schedule says so, and so have a few mechanics and fellow engineers who drive ATs I've consulted. i believe, but am not sure of this, that with the increased complexity of ATs and more gearing, regular maintenance is trending to more often servicing to keep the system functioning normally. if the vehicle is used in alot of stop and go, i can imagine the fluid's lubricity properties getting degraded.
it's a tad expensive, but worth regular servicing in my opinion.
the '02 i purchased used at just below 30K, since i didnt know specifically how it was driven, decided to have the AT serviced with a flush at a dealership at the recommendation of an independant mechanic who inspected the car before my purchase. this person had once worked at a honda dealership. i *DID* notice a much smoother shifting action after the flush; it wasn't my imagination.
As far as cost, that will probably vary quite a bit depending on where you go. I'm sure Honda using genuine Honda axle assemblies will be quite $$. I have replaced my own axles so I don't know what they would charge. Rebuilt axles run as little as $75-$100 each. Aftermarket (new) axles are a little bit more. Judging from how long it took me to change the axles, labor should be a couple of hours or less.
Mrbill
Flushing is a thorough procedure that really CLEANS the system. And it's not that expensive (I think I paid just over $100). And I also noticed a significant improvement in shifting.
And yes, I reccomend a full flush, not just a drain and fill.
Would replacing the VSS (Variable Speed Sensor) on the Transmission help the transmission from jerking into gear, or is there another sensor in the engine compartment that should be chnanged?
if the system could detect an obvious problem, it would be blinking the D or S indicator lamp.
-Keith
I don't remember EVER seeing this on mom's old 93 EX. I'd be curious to see it. Surely it isn't a manu-matic tranny? Is it a more sporty shift mode (higher rpms before shifting?)?
Sorry for my obvious stupidity on the relatively unimportant issue, but I would be interested in knowing that!
Thanks a bunch, guys!
thegrad
I have 97 Honda Accord. I disassembled the front left door panel to get my window off. Because the window is off the both tabs, it doesn't go up and down anymore. I checked on dealer and local auto shop, they all said that it had to be replaced by a new set, which it cost over $200.
Don't know anyone here has similar experience. Can I glue tab and window together? If so, what type of glue should I use for it?
Any suggestion will be appreciated!!!
Shadingding
Shadingding
Exp: 00/00/00 Comments(78) | Tell a Friend | AIM | Top
Honda is giving free service for the vehicles listed below. Give your dealer or the # on the letter a call with your VIN number to see if it is qualified. Thanks LordRamZ.
1995 models: Honda Accord V6, Acura NSX, Acura 2.5TL
1996 models: All models
1997 models: All models (except for the Honda Passport, Acura Integra Type-R, Acura SLX)
You receive:
At 50k-75k miles, you get a free emissions inspection and any repairs or replacements.
At 75k - 150k miles you get another free emissions inspection and you also get new spark plugs, ignition wires, distributor cap, rotor and oil change for free.
Emissions warranty has been extended to 14 years
You can get reimbursed if you paid for any of the above emmissions parts or repairs.
Posted: 02/21/06 4:26PM PT "
I am not sure if this is accurate or not but saw this on internet website on a www.slickdeals.net posting "http://www.slickdeals.net/#p7108". This page normally goes to archive the next day I believe.... The first word "Honda" is a hyperlink on the slickdeals.net posting...
Till few weeks ago I owned a '95 Accord V6. Thanks to this free extended warranty, Honda took care of my car -- but only when the Check Engine light came on, or something was clearly wrong with the car, as long as it was connected to emission (there is a LONG list of parts that are connected, actually):
At around 60k my car had the speedometer needle jump like nuts back and forth at high speed and the car was bucking, and Honda paid for a new Distributor and Speed Sensor.
At about 70k the Check Engine light came on, and the car was driving owefully. Honda replaced one fuel injector, and a month later it did it again, and they replaced ALL 6 of them.
I went back at 75k and got a free tune up.
Call your Honda service, ask them to print out for you the full list connected to that recall. I used to keep that list with the recall number, but left it all in my old car for the next owner to take advantage of it...
