i think with tolerances what they are today, it's smart to stick to the recommended weight oil.
if you live in a cold climate... i'd be cautious going with off-recommended weights.
unscientifically, changing from a 5W-20 to a 10W-30 suggests it will take more time and engine effort for the cold oil to get to the moving parts of the engine on startup... this is the time when the most wear occurs right?
You need to get this fixed pretty fast, damage might already be done.....which will mean replacing the half shafts. The boots keep the grease in and the water out, which will ruin the bearings on the inside.
You actually might be better off just having the half shafts replaced anyhow, and be done with it for another 100K miles.
if there are rubber boots on a strut (i can't remember), unless there's a sign of leaking or suspension bouncing, i'd keep driving with them.
on the half-shaft or CV joint, personally, i wouldn't wait.
Hope someone can shed a light for me here :mad:
I tơok my car to the dealer for transmission fluid change and wheel alignment this morning. When I got my car back, the SRS light went on. Can anyone tell me if the SRS light has anything to do with the work done ? and is there anyway that I can reset the SRS light ? I hate to spend more for the dealer.
http://www.ozaccord.com/forums/showthread.php?t=39
If the light comes back on again, you need to get it checked out though.
Have a nice weekend all !
I have 02 accord
My air condition makes noise
I took off a cabin filters and notice a lot of samll papers
(napkins) somehow got there, I tried to clean everything I see
but is still makes noise like pece of paper got stuck on the fan, wich I can not see
What can I do
I do not see fan, how can I get to it???
Ross
Dealer has agreed to fix the problem for me for free. Apparently there was something wrong with what they called AN OCCUPANT POSITION DETECTION SYSTEM (OPDS). Anyway, if any of you has problem with the SRS light on like I do, you can refer to the link below for the recall and show it to the dealer to get it fix free.
http://www-odi.nhtsa.dot.gov/cars/problems/defect/results.cfm?action_number=PE05- 043&SearchType=QuickSearch&summary=true
Cheers !
Any ideas on what I should check/do?
Thanks, Alan :confuse:
Mrbill
Yeah I was thinking if the lines are off they can be cleaned and inspected. $100 isn't chickenfeed for a hose.
I guess bottom line would be how hard it would be to replace the hoses at another time. If they are a real pain to get at, then maybe now's the time, but if it's just a matter of going on a lift and unscrewing two fittings, then if the hoses look good now, you might wait.
On some cars that are prone to hose bursting I'd say do it but I'm not aware that your car is susceptible.
My understanding is that it won't cost the dealer anything either since Honda reimburses them for recalls, so as long as they feel it qualifies you shouldn't have any problems.
It seems like the only potential costs you could run into are if the issue isn't related to the recall/extended warranty or if the dealer attempts to charge you a fee to look at the issue. The dealer near me tries to pull this w/ me for all warrantied items (seat belts causing SRS light and transmission), but when I speak to a supervisor they waive it.
Why are you revving in neutral again?
I have a 1999 Honda Accord EX V6 which I purchased 2 years ago (I am the second owner and I keep up regular maintenance). Presently, I have almost 95,000 miles on it.
Today, almost all of the dash indicator lamps came on: malfunction indicator lamp (my mechanic told me that is due to the ERG recall, I've had problems with this for a while), the brake lamp, battery light, and door ajar light suddenly came on simultaneously and will not shut off. The car's engine also began making a loud grumbling/humming noise.
Does anyone have any clue what is causing this? I have never heard of anything like this. THANK YOU for any help!
The ECM/PCM can set a false P1149 code, which is the O2 sensor.
I found this out after I bought and installed a new O2 sensor. The front one is quite easy to change, you might want to consider saving money by doing it yourself, if you end up doing it.
I am going to Autozone to get them to pull the code.
Going to autozone is likely your first and best choice.
I have a 98 accord v6
Steering
Brake
AT transmission 7.6qt (pls confirm)
Coolant 1.98 Gal (pls confirm)
On my 99 Accord (115K miles), the check engine light came on. Took it to a local Honda specialist and he checked teh code and told me that i need a new catalytic converter.
The quote he gave me seems pretty high
699.00 - Parts
20.00 - Gaskets
120.00 Labor
Total: 839 + Tax
Can someone please give me some idea regarding what is a reasonable cost for changing catalytic converter?
also, is there anything i can try before replacing the part?
As i mentioned in my earlier post, catalytic converter on my 99 v6 accord failed. I had done a timing belt, water pump etc job few months ago. I read that improper engine tuning can cause the catalytic converter to fail.
Is it possible that the timing belt job has something to do with failure of my catalytic converter?
Thanks in advance...
My car was running fine after the timing belt job, but i did notice a drop in mileage after. Is it possible that the timing belt was running fine but the engine was out of tune and givingout richer exhuast?
