However, on three occasions now, my ignition has locked up, and I cannot turn the key. I only had this problem once with my old car (a Pontiac) and I simply fixed it by giving the steering wheel a little nudge. The same is with this car, since when I give the steering wheel a nudge, it unlocks. However, the problem continues to reoccur, and while it is quick and easy to fix, I want to know why it continues to do this, or if it is normal. I think it is caused when I don't park with the steering wheel straight, but it seems as if no one else has the problem. Also, are there any ways that I can permanetely correct this problem? I love my new Honda, and I hope on keeping it for a real long time. I just want to know why my ignition locks up on some occasions.
it should not be locking up as tallman1 indicated... that should only occur if you take the key out and turn the wheel till it locks.
Using the air conditioning should not change the level other than since the whole system runs hotter after extended use therefore the total volume of the coolant will be slightly greater due to higher temperature everywhere in the system--i.e., the radiator is hotter.
Well the noise returned on my 2006 Accord SE and its back in the shop again as of this past Monday. I just brought it back home on Wednesday night of last week, so I could not go back right away, nor did I use the car until this past Sunday - so I would say they never fixed it the first time around. The dealer service is awful (from the service writer to the "technicians" to the service director who never returns mu calls, so when i get the new car survey, I will note this on that section of the survey - for whatever its worth. If they are not able to fix, I'll have to get Honda corporate involved and perhaps seek recourse through CA Lemon Law (I think there must be four documented repair attempts). Anyway, anyone have any thoughts on the following:
The car experiences a popping noise when warmed at low speeds 5 to 15 mph - when coasting - sounds like from the left, front wheel well area. The noise appears more pronounced when going up a hill. They replaced the left wheel bearing. Do you think its a strut, the cv, or the springs isse affecting the TLs? or the RSXs. Maybe, I need the spring silencer tubes? Can the plastic under the front wheel weel be making that noise as well? Suspension bolt not on tight enough? The noise is not brake related, nor related to the 2003 TSB dealing with faulty welds. The more that the car is driven, the louder the noise is - ie on a 1 hour road trip versus a 5 minute trip.
Any help is appreciated. I just don't want the hamburger helpers at the dealer to change any more parts that are not necessary. I may wait a bit and see if the problem fixes itself since the car has less than 1k miles on it.
Happy Fourth!
Mrbill
With this bad luck, I drove my car to Pep Boys and Sears and they didn't have the tire. I went to Goodyear Tire at 4305 Jonestown Rd, Harrisburg,PA, since it was a Goodyear RSA P206 55R16 89H tire.
Since the car is new, I told the sales guy that I wanted the same exact tire. The sales and technician who was the same guy, 069 David F., told me the tire was in stock. He sold me the tire and replaced it. I never even bothered to check to see if the tire was exactly the same. I trusted the guy which was a mistake. I should have looked at the tire before I drove away from the Goodyear dealer. I have driven the car for 2000 miles since I bought the tire and one day when my husband and I swapped cars, he noticed that the back of the car looked lopsided and uneven. He told me something was wrong and that I needed to bring the car to the Honda dealer to check the balance. I said that was strange since the side that was higher had the new tire. I looked and sure enough the tire was different. Not only did I get a nail in the tire which costed $162.55 to replace, the sales guy sold me the wrong tire which could ruin my new car. I told the guy I wanted the exact same tire and he even said that a replacement tire needed to be exactly the same too. How much bad luck can a girl take!
The morale to this experience: Even though I was upset about the nail, I should have still checked thoroughly the tire I had bought and made sure that it was exactly the same and never ever trust anything that salespeople say. I thought car salespeople were bad, I think repair shop people are THE worst. This confirmed that repair shop people just want to make money any way they can.
I am sorry to hear about your problem. ------This is why I purchase all my tires from the dealer. First, I know that I am going to get the proper size / quality tires for the vehicle. ----- Second, if a problem arises with regards to performance, alignment, balance or the quality of the product, I just go back to the dealer, hand them the keys, and "let them figure it out"! I have all my service performed by the dealer, (brakes, tires, oil & filter changes ---etc.) Since I do a lot of driving, I have "on - going" service appointments scheduled in advance. I work with one service advisor, and if a problem develops while I am on the road, I simply call my advisor, and add this issue to the next service appointment, (if it is not an emergency). Should the issue need immediate attention, and I am in the area of the dealer, he takes the vehicle in ASAP! The dealer also provides a loaner or a rental. I work with the dealer, and the dealer gives me high quality / outstanding service. I also believe in factory extended warranties. I always either break even with the cost, or come out ahead! --------- Best regards. ---- Dwayne
Just bought an '04 EX Coupe (tonight) and didn't realize the passenger door lock "button" is missing. Power locks still work. Any idea if this is an expensive fix?
What I would like to do at a minimum is to connect/splice in a 3.5mm stereo connector suitable for iPOD that would be selected by CD/AUX button on my radio.
Does anyone have a pinout for this connector?
How does the radio know there is or there isn't an AUX device connected?
I do not want to use FM transmitter to connect iPOD to radio.
Any and all help is appreciated.
This has happened in the past, once when the car was still in manufacturer's warranty. The dealer could find no problem and said we must have had the AC controls set incorrectly. It has happened again a couple of times, but it seems if you shut car off and back on a little later, it works.
However this time they checked freon and found it was low. My experience with low freon is that the AC should still cool a little bit, but not blow extremely hot air.
I think there is something else wrong with the AC besides just low freon.
Anyone have any ideas?
from '98 on, with the EX trim.
thnx in advance
you can always start the car if you find your working the vacuum for extended periods (which I highly doubt you would be).
my only concern would be the construction of the male plug. look into your 12V recepticle and note the seperation between the center contact and the shell. now examine the male plug. what you want to avoid is putting in the plug for the vacuum into the outlet at a gross angle (i.e. you want to push it straight in so the tip of the male plug can't short out the female outlet).
also i'd advise you to insert the plug for the vacuum when the car is off (key not in the ACC position or car not idling) since you have to either turn your key to acc or have the vehicle running to get power to the outlet.
taking those precautions will avoid blowing a fuse by accidently shorting the center contact with the shell with the tip of the male plug. this is probably an issue which only occurs with badly / cheaply designed devices with lousy male plugs but it doesn't hurt to do it in a less risky manner.
may your hand vacuum and accord become good friends.
There are a number of units designed for this purpose, specificically for the Honda radios. I have a USASpec unit in our Odyssey that works great. It has an Ipod connector that plugs into the dock port, so it even charges the unit, and it also has a set of RCA jacks.
P.I.E. also makes a number of options, some of which are cheaper but have less functionality.
ANyway, with any of the units, you just have to get to the back of the radio to plug it in, and off you go.
Look on Edmunds. I think there are some threads about using an ipod. If not for the Accord, there are certainly some under the Odyssey thread list.
Car continues to idle roughly for the first 1-2 minutes after starting - but usually only when really cold (after sitting at least 4-5 hours). This morning, after two weeks of otherwise happy motoring, it coded again and the idiot light came on on the dash.
Mechanic downloaded a: (1) P2195 Code, which is the REAR AF-11 (bank one sensor one?) Air/Fuel Sensor indicating its stuck on the lean setting, and (2) stored a pending P0301 misfire code for cyliner #1. Code conditions indicated that idle was at around 926 rpms at the time it happened, suggesting that its consistent with the misfire that happened when I started the car cold this morning.
Anybody got any ideas here? Is it a lazy sensor? A fuel pump issue? An O2 sensor issue (kinda what an Air/Fuel Mixture sensor is anyway, isn't it?)? I like my mechanic but I'm seein' just too damn much of him lately. Besides, this car has ~$50 miles on it and shouldn't be doing this.
Also, so nobody seeing this for the first time wastes their energy: We've eliminated bad fuel (over a 100 gallons from different suppliers during 6 week course of problem), bad plugs (pulled one from each bank - they're fine), cleaned the EGR tube and replaced the EGR valve with a new one.
Any and all new ideas welcome - this is becoming REALLY frustrating for me - I'm in my car 30k+ miles per year and I don't have time for this.
Don't apologize though, it's a simple mistake...although the rest of us here ARE perfect...
I've been getting a really loud thunking noise when I put the car in reverse backing out of the garage the first time of the day. It happens right when I go from (P) to (R) and it doesn't happen on subsequent shifts all the way to (D)Drive. Do you know what could be causing this? It doesn't happen after the first time and it doesn't happen everyday. Like maybe 3 to 4 times a week. This is not the click(clack) you hear when you put it in Reverse like many new Accords have but this is a loud thunk like the sound of someone closing their hood (doing the 15-20 inch drop, noise)
Any ideas? It doesn't happen on subsequent shifts from (P) to (D) during the day. :mad:
It was brought up by a few people in a Honda Accord Problem and Solution forum which was closed by the hosts when they decided to split up the P+S for the Accord based on a range of model years:
http://townhall-talk.edmunds.com/direct/view/.ef98496.ee997a9
FWIW: just hazarding a guess here - that seems like a bad motor mount perhaps... specially if you feel it in the pedal but not in the steering wheel.
I just bought a brand new accord and my family noticed that it was leaking fluids on the drive way. I called the salesman and he told me not to worry b/c the car is brand new and that it is condensation from the AC. So I let it go for a few days. Then I noticed the fluid is green and greasy. So I take it to Honda service and they told me there is a leak in the head gasket and that it is very unusual b/c the car is brand new. So I demand that they replace it b/c I paid for a brand new car, not a damaged one. They have to take the engine apart to repair it and they told me it would be at least a week, which translates to 2 weeks! The service manager is a total jerk and he says I have to contact the corporate office if I want the car replaced, but he said that they don't usually do it for a 'minor repair'. This to me is a big problem, after they take the engine apart and put it back together, who knows if there wont be other problems. So now I've been trying to contact the corporate office. This has been a nightmare! The whole point of buying a brand new car is so I don't have to deal with these problems, but of course it's not the case. Please let me know your thoughts on this!!! I think I deserve a new car, that's what I paid for right?! :sick:
if they end up fixing it, and you plan on retaining it, push for an extended warranty at no cost. akso if they have your car for this period, i'd think they'd make a payment for you.
A girl (talking on her cell phone) rear ended my wife, and my car was not fixed until 2 months later. Be happy that it's not damaged, and just 2 weeks, instead of 2 months. That's life.
1. When pressing the pedal it feels, AT THE VERY BEGINNING of its movement down, a slight "grinding" vibration, as if the pedal (or is there a cable?) needs some lubrication.
2. When releasing the pedal, half way on it's movement up, I can hear/feel a subtle CLICK.
...Anybody have a comment? Thanks.
Are you being sarcastic about the "great bump in power and performace"? If not, I can't imagine what you are referring to.
If you break-in your car without redlining it the first 600 miles (I didn't go past 4k on the RPM myself) and then you leave the factory oil in for 5k miles then you car is going to give you more power. No sarcasm at all bro. Not sure about the I4 but the V6 is all about this and yes, I am finding this out by surprise too but I do know you and only you control how much power you can ultimately squeeze out of your car! You control this not the car!
blown Head gasket person: My integra had this problem too but it was because I put stop leak in it at around 70k miles and it never ran right after that. But that was because I I broke a hose and the gasket blew again. If you fix it right (from the dealer) you should not have any overheating problems ever again unless:
Aluminum block engines are sensitive to overheating but it usually never happens since you always have coolant and the condition of your hoses is always good.
1. You run out of coolant in your car while it's running and it overheats again.
2. The condition of your hoses deteriorates and one of them breaks while you're driving. One of you radiator hoses breaks (upper or lower or maybe one of your heater hoses) and you drive on it (even a few hundred feet) then your head gasket could blow again.
Other then that you are good to go if they do the job right. Get a guarantee in the form of an extended warranty. Simply get an extended warranty from them to ensure this and you're good to go. No worries.
QUESTION: ---- Did the engine overheat? If the answer to this question is "YES," I would want a NEW engine, (not a repaired engine), or a replacement vehicle. If Honda does not want to give you that solution, then let Honda give you an 8 year 120,000 mile "0" deductable extended factory warranty on the vehicle, (at NO CHARGE to you.) If they believe that there is nothing wrong with the engine, let them "back it up" with an extended warranty! --------- Best regards. ----Dwayne
You've got to be kidding. You must live in the land of OZ. Because only the Wizard himself, could get you that warranty. Are you a munchkin?
(Having said that, I will try that nice guy approach cuz they got everyone by the balls anyway
