I think the only way you could get some reimbursement on the damaged tire is from your car insurance. And even with a low deductable on comprehensive coverage ($100) you would still end up paying half of the cost yourself. The warranty is for "defects", and I don't think hitting a curb makes the tire defective.
That's the radio code because the battery was disconnected. You should have a card with the code on it. It looks like a credit card. Punch in the numbers and it will work.
When do I get my timing chain done?
You have a timing belt on that model, not a chain. It used to be 90k miles but the 02 may be different. I'll bet Elroy knows.
Welcome to the forums!
I have a 2002 Accord EX 4 banger/ automatic/ 4 door. I have no kids and bought a 4 door because I like the room this car provides. I'm a former Cadillac STS owner, so there are a few of us that have come over to the Honda product that can afford a fast luxury car. A few years back when I bought this Honda used about 18K miles I was shocked how slow it was. I was determined to save some gas and the environment, so I bougt it anyway.
It didn't take long and I learned that you just have to hit the gas pedal harder and it goes, and goes well. Duh.
I've got almost 90K on the vehicle now. It has been flawless. Gas and oil. I did kill the batterey a few weeks ago, that's what my first question will be to you all:
My stock Stereo/CD changer has an error code. I've been rolling around LA/OC with no tunes or traffic reports, not good. A suggestion would be great.
Also, the reverse gear RPM on my Accord is virtually the same in "D" or "R".
When do I get my tranny service done agin (had it once already at 50K).
Thanks for the read and I hope to contribute going forward.
---Shawn
https://techinfo.honda.com/rjanisis/logon.asp
I have an 03 Accord LX I4 Coupe. I know I'm the king of off-the-wall questions. I figure it might help others out.
The timing belt (or chain) is inside the front cover of the engine, and basically is what connects the crankshat to the valves. "Timing" refers to the timing of when the valves open in relation to the piston travel. That is also where the term setting the timing comes from.
You have to take the serpentine belit off to get to the timing belt, and for sure i would put a new one on then, unless it was recently done.
Thanks to all who respond. Thanks, also, for bearing with me as I get a little mixed up from time to time.
I'm sure this is what you meant but the phrase "setting the timing" refers to the spark timing for the plugs relative to the position of the crankshaft.
I myself have a 4 cylinder 2004 Honda Accord EX that I got in April 2004. I'm at a little over 100k miles now (yea, I drive a lot). When should i be looking to change the timing and/or drive belt of my car? Any suggestions on where to go for this? I'm sure this would cost an arm and a leg at the dealer
Seems from the responses, I shouldn't count on the warranty working out, but it won't hurt to ask. This Friday or Saturday, I plan to hit Wal-mart for a tire rotation on my 2004 Honda Accord EX Sedan so I'll take my wife's busted tire with me and see if they can repair. If that doesn't work... I'm planning on going to Firestone afterwards for alignment so I'll ask one more time at Firestone for the repair, and if that's a no, I'll just buy the new tire there if they have it. Then I'll ask to get it mounted and balanced and put on my wife's car. I hope Firestone still matches online prices as I'm sure their in store price will prob be expensive.
In taking ar39's advice, I wont' rotate anything and leave the new tire on the front right.
One last question - while I was doing the tire change, and the car was on the jack, I forgot to put the parking brake on. This caused the car to slip forward twice - once while the flat tire was still on, and once when there was no wheel on at all . In falling both times, I was wondering if there was a chance something could have gotten damaged. If so, what could have been damanged.
By the way, in case anyone's wondering, I hit Wal-mart for my rotations because back in Spring 2006, I got all 4 of my tires mounted at Walmart - even though they were all bought at Firestone - and by getting all 4 mounted, I was able to receive lifetime Rotation & Balance. And I hit Firestone for my alignment because I have Lifetime Alignment from them.
Thanks for all the help guys.
The drive belts should be changed when they need it. A mechanic should be able to look for cracks and drying to make the call. That is at least not particularly expensive, since it is easy (even a DIY if you are handly). For sure, if you have to take the front of the enigne apart for a timing belt, put a new drive belt on (free labor!)
A dealer or a good indie shop can replace a timing belt. Not a particularly difficult job (if you know what you are doing and have the right tools), it is just labor intensive. So you end up with a $20 part and a $720 bill!
Oh, while it is open, throw on a new water pump (again, free labor), and see what other items are cheap and easy (such as a tensioner, or little plastic sprockets). basically replace any cheap wear out parts while the engine is open.
IIRC, The I4 Accords got timing chains in 2006 (or was it all of generation 7??), previous years (and the V6) have belts.
For 2002 models it is 105k miles. My grandmother has a 2002 LX 4-cyl. I'm no elroy, but I'll chime in anyway!
The 2006 models got drive-by-wire electronic throttle in 2006, maybe that's what you were thinking of?
To reiterate, you have no timing belt to be replaced, so you won't be looking at the giant repair bill you think you will. Other belts may need replacing at some point (not sure when) but your car has a timing chain, which doesn't require replacement.
I only repeat this to make sure everyone knows the 2.4L 4-cyl in the 2003-present Accords doesn't have a timing belt to be replaced, so don't go pay for it; I'm sure a mechanic would love to take advantage of you!
Best regards,
The Grad
Yes, that's it. After I posted that, I didn't think there would have been such a big change in the engine within a generation. I do remember being thrilled when I bought my 06 and was told that it had a chain instead of a belt. I've replaced two or three of them on my 95, and as you know, it ain't cheap. :sick:
I sure do know. I got a quote for timing belt and water pump on my '96 LX - $475. I'm at 179k miles. Eeek. :sick:
I'm debating on selling this car before long. I'll be moving to Mississippi for graduate school (no nickname pun intended ) next year, and heading off with two Hondas won't be too efficient!
((I can smell the burning transmission fluid now...))
Then you'd hear the gurgling and you'd get the Christmas tree of death, all lights lit up and that would be the end for dear old Mr. Honda just as the radiator blows up.
:P
Maybe I'll sell the '96 after all.
Anyway, back to the 03-07 portion of this forum.
Open to all responses. I've been having trouble seeing at night and wonder if they may help.
One way to avoid this, and it doesn't say it in the manual, is a small opening in the fender skirt where they need to bold the bumper on, you can put a screwdriver in there and then you can start to pry there. It should be good there.
Hopefully anybody who does it is fairly small because it's sort of a tight squeeze. I just hope that the crack fender cover, being behind the bumper won't create problems for me later. I suppose I might have to go and get a different one off of a junked out car.
Is this your first replacement? I thought you are supposed to replace those things at 100k miles?
I would check your son's alternator. I think with a battery charge your car will start----not a JUMP but a charge.
The only other thing I can think of is that when re-installed in your car, the connections on the battery where not tight enough.
Back in 95 & 96 (like thegrad's and my old Accords) timing belts were supposed to be changed every 90k. He's getting close to changing his second. I remember really pushing my second one quite a few miles past 180k. Risky.
So for the 95-96, the water pump is supposed to be replaced at 90k miles, is this also true with the newer 7th Gen Accord? Or can we expect it to last a bit longer(what I heard is 100k miles but I'm not sure)? :confuse:
Anyone know what the typical water pump replacement interval for this gen is though?
