Ford Explorer Maintenance and Repair
15354565859125
  • biomanbioman Member Posts: 172
    Thank you swschrad!
    Great bit of advice!
    Even better explanation!
    Every person who drives a car with automatic transmission should keep this information in their heads because you never know when you will encounter a tow truck operator who might do the wrong thing.
  • ajmtbmajmtbm Member Posts: 245
    I have a slightly similar issue...goinf from park to drive and especially revrse to drive there is a 3 second or so delay before the gear engages. it engages smoothly, but there is a noticeable pause. dealer, of course, says this is normal. we dont seem to be having tranny problems other than that delay. the clunking i would think indicates a problem.
    Just a few dumb questions:
    *when i park my 02 Exploer, the truck will roll a bit before it stops. I told the dealer about this 3 or 4 times and he the last time finally found the problem and adjusted it. It was a bit better, but not much. Is this normal? some have told me its better to leave it because if they adjust it too tight i will quickly wear the breaks.
    *apprximately 3 second delay when shifting from reverse to drive. shifts smoothly, but a noticeable delay. again, normal?
    *is the ride on the 04's that much better than 02-03? ford catalog says its improved
    *i have had numerous door ajar switches and the brake light cluster switch replaced. is there a bigger problem here or are the ford switches that bad?
  • tweedietweedie Member Posts: 10
    10K miles.
    V8
    70 percent highway 30 percent city
    mostly flat terrain
    regular gas
    I'm getting 19 miles per gallon routinely.
    18 on a bad tank. Mostly 18.5 to 19+ 19.5 is high.
    Got 16 at intersate speeds/West Virginia Mtns.
    (This was my worst but the exception)
  • xgrovexgrove Member Posts: 8
    The 04 explorer rides like a dream - much better than earlier explorers. but mine has Michelin tires and maybe that makes a difference.
    To nybanker - thanks for the info on the fan revs
    The shift delay is really a problem , especially when backing up and suddenly it jerks into gear at a higher speed. My wife refuses to drive the car because of this. Its going back to the dealer for the third time for this problem and the next course of action is the NSTB or I will keep after ford until the trans is replaced or the fluids put at proper level. we had considered a new explorer for my wife but now are looking elsewhere because of the tranny problem.
    by "much better than earlier explorers" do you mean 2002-2003 (current design) or pre-2002?
    The ride I'm reffering to is prior to 2002
    I don't know how the ride of my 2004 compared to a new 2002 although it seems better than my neighbors 2002. but then again my 2004 is new and his has 35,000 miles. My older 95 and 98 were better than my wife's 99 and our friend's 2001. It seems they stiffened the suspension in the 99 to 01 s because of the roll over problem
  • idntnvuidntnvu Member Posts: 254
    I also have a delay when going from park to reverse, park to drive, reverse to drive, and drive to reverse ('99 XLS). I never really considered it a problem, but I noticed (accidentally) that if you go from park or reverse to 2, it will change much quicker, almost instantly, but there is a thud when it does it. About a year ago, I had a thumping problem addressed when the tranny would change from 1st to 2nd and 2nd to 3rd. The dealer changed the fluid in the transfer case, and boom...no more thumping. Occasionally, it'll still thump when I'm accelerating very lightly and it changes from 1st to 2nd, but not enough to concern or bother me.
    How much delay are you experiencing?
    I've never timed it, but I'd say 2-3 seconds.
  • tribefxtribefx Member Posts: 1
    I just purchased a 2000 Explorer Limited and the only thing I've noticed is that when I apply the brakes, I sometimes feel a vibration that doesn't seem to come from the wheels themselves. Feels more like it's coming from the engine/trans. I feel it just as the vehicle comes to a complete stop. It almost feels like the idle bogs down. I notice it more when the AC is on. If I stop very slowly... I don't feel it at all. Anyone else experienced this or have any ideas? Thanks.
     Eddie
    2-3 seconds isn't abnormally long for the valve body to adjust gears, IMO. I think it's about what all of mine have done, and do. I wouldn't fret over that at all.
  • emtpjimdemtpjimd Member Posts: 3
    Out of curiosity, I am wondering if anyone else has had this problem: On my 03 XLT w/ 16k, the driver's side seatbelt does not quickly/easily retract. Furthermore, there is damage to the plastic "housing" around the belt on the inner b-pillar from where the belt cut into it. Is this merely a problem on my car or is this a known problem?
    we dont have the retracting problem, but we had the plastic wear away on both the driver and passenger sides (looked like a notch wore out from rubbing with the seatbel). had it replaced under wrranty, and happended again. we will get it replaced one final time right before the warranty expires, but, IMO, looking at the design, this will wear out again. Just bad design. i do reccomend getting it replaced if you are under warraty-you have nothing to lose.
    02 Ltd Explorer
  • bigaldsbigalds Member Posts: 47
    Drivers side Seat Belt Not retracting on my 97 XLT Explorer, or retracts very slowly.
  • chuck1chuck1 Member Posts: 1,405
    I have had a 2002 XLT w/V6 for two years and am happy. It looks like it has developed that rear end whine at the speeds posted above. But it happens only between those speeds. Has anyone else had this where it happens only between certain speeds? If so, what has the remedy been?
    Does it get worse? The vehicle currently has 24K on it. THANKS!
  • cmartin411cmartin411 Member Posts: 42
    My remedy would be to get the differential fixed under warranty and sell it. Although, I would imagine that it would show up in a Carfax report.
    Hey cmartin,
    No a normal repair does not show up in a carfax report. I just completed a trip to Las Vegas and averaged 20mpg in my V6/XLT Explorer. As I mentioned, it has been a very reliable vehicle, minus this whine between 57mph and 63mph. So I wouldn't see any need for getting rid of the vehicle. Have you had any personal experience with this issue, or do you get rid of all your vehicles when a issues comes up? Just curious!
  • akanglakangl Member Posts: 3,282
    Some of us do. I dumped my 2004 Explorer V6/4WD over a month ago. Tranny problems and 14 mpg hwy was getting old. Nissan dealer still has it sitting in back, they won't sell it since it didn't pass the shop inspection. Techs said the tranny is shot, so they have to send it over to Ford. Truck has all of 14k miles on it.
    Currently driving a 2004 Nissan Titan that gets better fuel economy, is more useful, can tow, and so far has been a pretty darn good truck. Have packed 6200 miles on it in just over a month.
    Chuck - go back a few hundred posts and you'll find akangl LOVED her Explorer until the day she traded it too. If she would have had Ford fix the tranny, her mileage would have been better too.
    So, akangl, am I lyin? And just how much more mpg does that Titan get you than 14mpg? Be honest now..... :)
    The delay hasn't bothered me a bit. I figured it was normal, so thanks for confirming that. I noticed some other people have commented that they don't like it. Another post I read was that when you put the transmission in park, when you let off the brake, it rolls a little bit. I've never been in a vehicle with an automatic transmission that that didn't happen. The one way to stop that is of course to use the parking brake for it's intended purpose. Besides, when you put an automatic in Park, theres just a simple little pin holding the vehicle from moving. On a hill, thats a lot of weight on that little pin, which has been known to snap and send cars rolling on down the hill. Moral is, if you want to be more safe than sorry, always use the parking brake.
    Yup, I did love my Explorer, it drove nice, but the tranny problem *could not be duplicated* by the 2 service depts. I dealt with it for 5 months/14k miles, it was in the service dept several times for that issue and they all said that the delayed shifting, double shifting, and other things it did were *normal*. Must not be too normal if the Nissan dealer is unwilling to sell it like it is. Do I miss it? Nope, not in the least little bit, it was my 3rd Explorer and my last. Had one of each generation, 94/97/04.
    The Titan is averaging 15/16 mpg in mixed driving, last long trip we took it got 17 mpg hwy (with 1000 miles on the truck). I don't expect it to be great on gas, its a V8, but I did expect the Explorer to do better than 14 mpg. The absolute worst the Titan has gotten was 13 mpg, that was part towing a small trailer, a little offroad, the rest mixed driving. (that's not counting towing a 6600 lb travel trailer, averaged 10 mpg with that)
    Clearly there was something wrong with your Explorer - but your mileage with the Titan is not enough better to buy you a weekly latte, akangl. I don't understand your efforts to justify your purchase on this thread where people are looking for solutions to their problems. A Titan won't always solve their issues, even though it did yours. You had 2 great Explorers, and one with a difficult problem to resolve - so "it's your last", eh? I've enjoyed a lot of great Fords after my 74 Mustang and my 87 Aerostar which were both unimpressive cars had I maintained that mentality. I would have missed out on some real fine product if I had had that mentality.
    Sounds like you should join the "People who rant they'll never buy Brand X again" forum, and vent your issues there with other issue laden folks, and let us try to help Explorer owners with their cars over here like we did for you when you still had yours. But whatever...
    Yup, you're right, whatever.
    I wouldn't get rid of a vehicle for any issue. This one to me is big and re-occuring from my experience. I had an 02 XLT 4x4 that started the whine at 45,000 and turned it in for an 03 XLT 4x4. The 03 was whining at 32,000 and had the differential replaced. It started to make the noise again at 50,000. I never towed anything, and as you can tell by the mileage, 80% highway driving. I turned it in for an 04 F-150 Supercrew. Fortunately, these are all company vehicles.
    A friend of mine has had his '96 Z28 for sale a long time, and just received an offer to make an even trade for a '96 Explorer XLT, V6, 115k miles. The Explorer is worth a little more than the Camaro, and neither is in excellent shape. My friend's plan is to make the trade, fix up the explorer, and then sell it to at least break even if not make a little on it. He said the current problems he noted from the explorer are the door needs fixed, an oxegen sensor, a turn signal switch relay and a brake light bulb. All fairly minor. I don't think he really plans on keeping the explorer for himself, he's mainly looking to make a little money. What do you guys think? Also, what major problems are known of the '96s? I know all about the '98+, but under that I'm kinda foggy.
    When I was a teenager, I had a 66 Ford Galaxy with who knows how many miles were on it. It had a pretty severe rear end whine when I bought it. I was a teenager, had very little money....I drove the car for several years with that whine. I pumped some STP in the rear and it made it a little more quiet. My thinking is that a rear end is like a carberator of yesterday. These things never went out completely, but they would go bad and your car would run bad. Does this whine in the rear signify bigger problems ahead, or will it just whine between certain speeds---does anyone who doesn't have an axe to grind know? Is there a Ford Tech on this board?
  • gasburnergasburner Member Posts: 31
    I've been thinking the same thing about akangl's post. She was ranting about how great her Explorer was just a short time ago. It sounds like she needs to justify the financial hit for trading in a 2004 for a new 2004.
    I have been interestingly following her posts on the Titan board since I was also thinking about trading my Explorer for a Titan. However, based on all the problems she has had straight off the lot, I'll think I'll wait a bit for Nissan to work out the 1st year Titan bugs.
    The last time I recall, as gasburner mentioned, Akangl was talking about her explorer experiences, and getting it broken in and such, and now she's already traded it off? I must've been locked up in the closet again or something, lol, I missed all of that. Akangl, if you're reading, what happened to make you get rid of it so quickly? I have to say, however, that if I had the money, I'd probably have a new car every 6 months. I don't have the money though, nor do I ever see getting that much money to just throw away, (unless I win the lottery, HAH), so I guess I'll just have to settle for a slightly used car every 5 or 6 years. No biggie though, once you get a car that you like, you don't mind holding onto it for awhile. Trouble is finding the one you like!
    Developed a transmission problem that 2 service depts said was normal. It had always been hesitant to shift right from day one, but the problem got worse and worse, to the point where merging was a problem. A reflash fixed it for about 500 miles, then it went back to its old tricks. Gas mileage was horrible (14 mpg hwy/12 city).
    As for problems with the Titan right off the lot, yup, there were a couple, but NOTHING like what the Explorer did the first day we owned it. Nothing like driving in extreme cold with no heat, then have the truck overheat.
    I am not justifying trading my Explorer in, not at all, it was done for more than the issues with the truck. Yes I liked it and for the most part it was a fairly good truck, I've had worse. The financial hit was HUGE, the Explorer's MSRP was $30,655, invoice $28,006, I paid $25k after rebates. Trade in value at 5 months old and 14k miles was $16,500.
    I don't know if it was how I used the truck that caused the problems, or if it was the truck. I actually use my trucks. It had been offroad (dirt roads, not stump jumping) and had towed trailers, it was not very good about either one.
    That said, I do have to give the Explorer credit, it pulled a Chevy out of the ditch, it rescued my husband twice when he goofed his Dodge up, it hauled more stuff than probably any Explorer is meant to do. It was a good truck, just wasn't the truck we needed and had issues we didn't want to live with.
    'Nuff said.
    BTW if anyone has a Red Fire Metallic Explorer and wants some touch up paint I've got a new bottle that I'll send them.
  • alfaalfa Member Posts: 11
    I'm sorry you got burned out on your explorer.Maybe if you held on longer you may have lost more?
    Yes there are a lot of good explorer's that run well with out any problems. My shop just did a service on a 03 EB model and the owner has had it about a year and is drives like new. She also had a 94 put about 70k on it and had very few problems with it.I was thinking about buying one a few weeks ago. but after looking at the the problems that owners had posted here and the expedition section I started having second thoughts. Also I thought about resale value? I looked to see if I could get a good price on a used one ?I found over between 50 and 100 for sale only a year old with in 50 miles of me?maybe a lot of owners want to dump the fords after a short while. Why is the only one or two pilots for sale or toyota 4runners?Also A loaded Explorer EB with v8 was over 35k.Then I thought of how well a corolla with 100k on it drives. And how a escort or topaz is pretty shot after 100k
    I do think the f150s 250s and chevy trucks get some high miles and still drive well. But some of the other chevy , and fords are not as strong. Also I thought how often does are shop replaces auto transmissions on Asian Imports ( very few ) chevy ford chy ,very often.
    I work on and or test drive between 5 and 10 cars and trucks a day
    Yes I do notice some small differences the most people would not.
    For instance I have had some people tell me saturns drive well and are pretty good cars!Yes each to there own.
    But I think the are total junk!Even new they drive like crap.
    My choice was a SUV from the best most reliable Asian auto maker.
    The explorer drives well , very good style, and roomy inside.
    My SUV drives fantastic ,materials,fit, finish,performance 2nd to none.
    You lucky
  • fx4fx4 Member Posts: 72
    FYI
    2003 Explorer, 4wd, V8. Don't ask me what a hoot is, but the noise starts when the temp is 85 or above and the humidity high. "Hoot" is most noticeable when the vehicle is working it's way up through (and down too)the gears at fairly low to moderate RPM on a very hot/humid day. The noise does not occur under cooler conditions. Ford Osasis indicating the problem has been a known for some time, but Ford engineering has not come up with a suitable, economical fix. Thus, apparently no recall so far?
    P.s. As mentioned in an earlier post, fuel mileage is not much for the Explorer given the decent history for 4.6L in various other Ford products the last few years. Our 2004 Expedition NBX with 5.4L has very similar or slightly higher overall fuel mileage despite 1,250 additional lbs. for the Expedition.
    Still would rate Explorer very good overall, expect to get 200,000+ vehicle life with proper service.
    Hey, nvbanker. Got them ears on?
    Yep fx, and I think you're referring to the roar from the fan while accelerating at low speeds. This always comes up every year on these boards, once the July dog days come, because everybody's fan clutch tightens up from the high temp, and really turns that fan like an airplane. Until the forward motion of the car naturally brings more air through the radiator, you really hear it loud. Ford is aware of it, but it's functionally normal, if not perhaps a little irritating, and it's actually a good thing, because Explorers just about never over heat - noticed that? We never have that problem reported here. One reason is the bad-[non-permissible content removed] cooling fan. So Ford isn't too concerned about a fix for something that, although noisy, works really great.
    Does this sound applicable, fx?
  • wifemmwifemm Member Posts: 16
    I have a 2002 Mountaineer AWD, it's getting close to 30Kmiles and was wondering what are the maintainenance items to do?
    The biggest thing is the transmission fluid do I have to replace it? The user's manual list certain transmission models, but how do I know which one do I have. Some independent shop says it's sealed for 100Kmiles, a Ford dealer quoted $150 and try to sell me other stuff.
    If you ask, yes, of course it needs to be change, including the coolant.....but at 30Kmiles? Can someone share your opinions, thanks.
  • explorerx4explorerx4 Member Posts: 20,875
    as far as the tranny goes, how is it shifting now? i have an '02 explorer v-8. never have liked how it shifted, but it does seem better after having it changed at 30k. had a reflash done before that.
    how well do you know your dealer? being a regular (paying) customer can help, if you have a problem.
    make sure what they say will be done is on the receipt you get. take the time to read it.
    But you have several things going on with this car that you may want to take into account.
    First, it is "sealed for life" at the factory. There is no dipstick, so refilling the transmission is tricky as it must be done from below, against gravity, etc. Pretty much that leaves it to a dealer or shop with some special equipment to do that. Ford sealed it mainly because the engineers couldn't find a place to route the dipstick tube up to the top. They expect the transmission to run about 100,000 miles normally without service before it fails. It will probably run about 150,000 miles if serviced at regular intervals, so it depends on how long you intend to run the truck - you can make a decision from that.
    Aggravating factors like a hot climate or towing would cause me to service the transmission anyway, as those factors will deteriorate the fluid sooner. It's a synthetic fluid put in there at the factory, and normally it should last a long time. But heat is the enemy, and if you live in extreme climates or tow, your tranny will die sooner.
    Personally, I would have it serviced at least at 50,000, but as the previous poster said, make sure they actually have the machine that will change out the fluid for you and they do it. dropping the pan only lets out 4 quarts - that's not servicing it. It needs a pump out.
  • tenachtenach Member Posts: 4
    No way. I put a new one in my 95 and it was $2500 from a reputed Tranny place. Brand new, not rebuilt. I also had to put in an after market transmission cooler because the original was stopped up. with a 150k miles is it worth it? Mine only had 97k but it is perfect otherwise and the engine is bone dry. no leaks.
    It's my understanding the transmissions in the 2001's and up are entirely different form the earlier ones.........
  • 97xltbeep97xltbeep Member Posts: 16
    i have a '97 explorer xlt, v8, with 77k on it. what does it mean when you try to start the engine and you turn the key in the ignition nothing happens? the engine won't start, only the dashboard lights up like a christmas tree. after a few tries, with or without the brake applied it finally starts. any suggestions?
  • opera_house_wkopera_house_wk Member Posts: 326
    I have a 2,500 mile vacation that I take often with my 97 Explorer. Previous trips averaged about 19.7mpg (which I condidered quite good)and with a new DPFE sensor it jumped to 21.9mpg which included over a week of local driving too. This was in hilly country, heavily loaded with a carrier in the receiver. I replaced with the new plastic DPFE when I got a P0401 low flow code. Drilled open the old senor and found large corrosion nodules pressing against the pressure sensor disk. Remove this corrosion and the sensor is likely fine. The silicone gaskets can be reused. If you still have a metal one, it is likely going bad. Just look for the the corrosion in the port holes.
    No it's not the proverbial fan clutch kicking in.
    Very familiar with that noise. I had an 87 Bronco 5.0 EFI with 3-speed C6 that had the fan clutch lock up engaged at 150,000+ miles. Replaced the thing the next Saturday.
    The noise is very much unlike anything I or even the experienced Ford techs have ever heard. I would call it a whistle (hoot is Ford's term) and is under light load at 1000-1300 RPM. The Ford Oasis printout is numbered 17217, with effective date of 9/22/03. Just this week there is still is no fix--the above says to monitor Oasis for updates. (The local Ford tech said there probably is a fix now, but not one that is economical enough for Ford to go with). Apparently no loss of A/C function. Hoot or whistle noise starts right at 85 degrees on humid day with A/C on.
    P.s. Above 87 Bronco with C6 tranny was sweet running, good towing Bronco compared to 5.0 EFI with vacuum 4-speed transmission AOD at the time. Ford only made a few Broncos set up like this in late 87 and early 88. 5.0 EFI with C6 3-speed and 3.55 ratio actually gave more towing power than Bronco brakes and short wheelbase could handle.
    Wow....then I'm stumped! I'd be looking for a vacuum leak, or a hung expansion valve, but I'm just grasping at straws now.
    I used the very word vacuum leak at the Ford dealership. From reading of the Oasis printout, it seems that Ford may know what is making the hoot.
    Could be something having to do with the nature of R-134A?
    My 2003 had and my 2004 Expedition has the noticeable grunt/pop from compressor start-up after being parked over night or for many hours. Apparently the R-134A travels to the coolest part of the system at night and then the grunt/grinding sound comes as the compressor kicks on and the R-134A quickly starts its journey around the system. No system harm, no loss of A/C, defrost function. No repair needed or available.
    Good weekend to all!
    that grunt/pop causes a lot of consternation on the car lot, as most inventory has sat a while between movements or start ups, and nearly every one of them does that when you turn the a/c on. The explanation doesn't always give comfort to the public. Me? I rejected a car or two also, until I realized they all did it, then I just figured, Hell, it's covered if it's a problem. Never has been.
    I have a similar problem with my explorer. Sometimes you turn the key and all the lights come on, seat belt alert chimes, but when you turn the key to what feels like all the way forward, it doesn't do anything. It feels as if it's stopped, but it actually isn't. I've found that by turning it a little harder it moves a bit more and starts right up. Mine is a '99 XLS, 4.0 OHV. I've never had it not start for me, you just have to turn the key really hard. I'm a school bus driver, and we had a similar problem earlier this week with a driver being stranded twice because her bus wouldn't start, and it was because she wasn't turning her key hard enough ('96 International, for any who care, haha). I'm sure replacing the ignition could be a remedy, but if it ain't broke don't fix it. It just adds a little personality to your vehicle, hahaha.
    idntnvu
    by turning the key really hard it's like "using a bigger hammer". i don't think it's just that, because when you turn the key you can hear the relay clicking and then nothing, no matter how hard you turn that key. i took it to the service shop and of course it didn't do it for them. they told me that it could be the starter, but as long as they cannot "diagnose" the problem, they didn't do anything. as for personality, oh yeah, it's full of it- i brought it home, turn off the engine, and 5 min. later did the same thing. oh well! i guess i'll go for a second opinion.
    thanks anyway!
    I started to notice a whining noise when driving my wife's mountaineer with 28Kmiles. It's not loud but you can hear it, I have not isolated it to the rear end yet.
    I remember seeing many posts about the problem, how do I really pinpoint the noise to be from the rear end? Is the noise noticeable from outside the truck?
    Can someone pls post the exact problem and resolution from a FORD receipt? Thanks.
    My 97 did that. The starter solenoid on the fender was bad. As an engineer involved in product failure, I had to find out why. I drilled the solenoid open and found this beautiful powder blue coating on the contacts. Something I had never seen before. There could have been a bad run with this problem in 97. I just polished the contacts up and put it back together. This takes considerable mechanical skill, but a new solenoid is only about $10. Still working after two years. If you are ever stuck, you can just turn the key to ON and jumper the two large terminals on the solenoid to start the engine. Only about 12A so any piece of metal will do it. Just make sure the shift is in a safe position to start because there won't be any interlocks.
    A large paper clip works great for jumping the starter over...
    I've never paid enough attention to see if mine "clicks," and just doesn't start. I'll pay more attention the next time it does it. Sounds like it could be a common problem. Thanks!
    idntnvu
