Check out the Synthetic motor oil and Engine Oil - A slippery subject Part 2 discussions too. And check out the analysis posts in them.
Shifty has a good post from 2 weeks ago in the Slippery board; 'nuff said.
Some people say to turn your ignition on for 3 or 4 seconds before cranking the engine. This gives the fuel injectors time to "prime" and helps start the car. Worth a try (is it really below 40 where you are right now, or are you planning ahead?)
PS Mine was number 17736 for the 3.73 axle. I have my vehicle home now and the SILENCE IS DEAFENING :-)
These repairs did not solve the problems hence the call to Ford Tech. I allowed 60 days to pass and after 3 follow up calls during that time I got sick of waiting so I visited Bergey Ford in Springhouse, PA.
I described the problem to the service writer as he was unable to test ride the vehicle with me during my visit. I returned 5 days later, dropped off the car and the following day was told they could not duplicate the described problem. I returned to the dealer at 4:30 and took a ride with a technician who promptly acknowledged that he heard the noise and suspected the A/C compressor. (I did not tell them the car was previously in for the same problem an another dealer.)
I left the car overnight and waited for them to tell me of their findings. At 5:00 the next day I was told that they determined that the "air gap" on the A/C clutch was out by 2/1000" and this was probably the cause. After playing around with it for another day they solved the problem but upon returning from the road test the noise returned. It was determined that a new compressor was in order which they located at another dealer 10 miles away. The next day they replaced the compressor/clutch and at 2:00 called to say that the car was ready and the noise was gone. They also told me that when checking vehicle history they saw that Conshohocken had worked on the same problem but that they not only left the case open but cross threaded the engine block mounting hole and destroyed a number of factory hose connections.
I am crossing my fingers at this point and stand ready to file my lemon law claim if the problem re surfaces. Suffice it to say I WILL NOT return to Conshohocken Ford (A Kennedy Dealership) for service.
Jim
It sounds like a belt squeal to me, if I am reading your description right. There are a number of problems on the new Explorers including belt tensioners that don't maintain tension and A/C compressor clutch problems overloading the belt and causing slippage.
One question though, if I take it in and get a work order for it and they can't fix it or can't find anything wrong and it starts acting up again after the 36000 miles, is it still covered by the warranty or am I just out of luck? Thanks
Are you saying that you only notice this sound above 55 mph AND only when the AC is on max? you never hear it at lower road speeds?
Just want clarification before I start answering.
wow, that's wacky! Maybe it's the color socks you're wearing.
Just kidding.
The reason I was asking about speeds is because it almost sounds like it's caused by engine RPMs...which would lead me to believe that the AC compressor belt/pulleys are making the noise.
I don't know what your RPMs are at 55mph and up but maybe you could try sustaining the same RPMs at a lower speed (Put tranny in gear 2 or 3 instead of auto and try maintaining the same RPMs as when you are over 55 mph in auto)
This would tell you if the belts are slipping on the compressor pulley at high rpms.
Another possibility:
As far as the AC being on max even in cooler weather and not making the squeal, it could be that even though the AC compressor is on max, it's not really working because temps are already low enough. In other words, the fan is blowing but the compressors not drawing a load since there's no hot air to cool. If the compressors not drawing a load, then the compressor pulley won't slip on the belts.
hmmm....all these seem to point to the belts slipping.
....or maybe the socks :-)
Let me know if any of these help to pinpoint the problem.
On my 97 Explorer XLT automatic with over 200,000 miles I noticed when we let the truck decelerate we heard a horrible whir/whine from under the truck. As long as we kept the truck going and didn't go below 2000 RPMs we were fine. When we got off the highway we manually downshifted and it worked once, but then it seemed like every time the truck wanted to downshift out of a gear the noise reappeared. The engine RPMS would drop when this happened. The engine sounded fine, seemed like the transmission couldn't downshift. Worked fine upshifting, but seemed to be having issues down. Any ideas???
Woo Hoo!
Glad I could help.
Was there any "clunking" noise involved? Was the noise coming from approx. the middle of the vehicle? or the front or back end?
It made this noise downshifting between ALL gears? or just a certain one?
whining? I bought a used 2003 Explorer Limited
and it's doing the same thing. Problem is, it's out
of warranty. I'd hate to spend the money on a fix
that doesn't fix it and have the inconvenience of
being without my car. I can't believe Ford hasn't
done a recall on this, knowing it's a engineering
problem. I like my car but hate the noise!
ABS warning light illuminated. Stayed on for the remainder of the day. The next day it was off for approximately 3 hours, and illuminated
again and remained on for the remainder of that
day. Since that time it has not illuminated, and
the brakes appeared normal during the time the
light was ON. 2002 Explorer ELT, 2x4, 27,000
miles. No previous occurrance.
Any ideas out there? It seems to run ok other than needing earplugs to drive it!
PeggyLou
I went to check the transmission fluid and realize there is no dipstick for that purpose.
Sorry if this has already been mentioned but is there any way, other than taking it to the dealer, to know if the fluid is low?
He was right when he told me back in March this year about the EGR recall, so I tend to believe him.
I had the rear right axle seal replaced by him cause it leaked. No rear whine, but I do have front end whine which gets louder with the speed. I checked the front tires, but they feel smooth. I had front brakes replaced ($280 for all 4 pads, machined front and new rear rotors, with oil changed), and I think the whine comes from the brakes, as it started when they were replaced...
come to think of it I had the tires rotated too, maybe that's what it is?
Anyways, any one else heard of upcoming recall?
CUSTOMER SATISFACTION PROGRAM 02M01 SUPPLEMENT #4. CERTAIN FORD 2000 THROUGH 2003 VEHICLES EQUIPPED WITH A TUBE-MOUNTED EGR PRESSURE SENSOR - ADDITIONAL EGR PRESSURE SENSOR WARRANTY COVERAGE. *TT SUPPLEMENT #3. *MJ SUPPLEMENT #6. *TT
What happened on mine was the idiot light came on and the code read EGR valve problems. Took it to the dealer and got a new one for free. The program gives owners extra 24 month warranty on the sensor if there is a problem with it, they will replace it, and if you had it replaced already, they will refund the $$$.
In order to turn front rotors, the front hubs need to be removed. This includes removing the wheel bearings.
My guess is that the bearings were not put back on correctly...whether that be from them not being packed with grease correctly or them being tightened too much(I doubt too loose would cause a whine). This may be causing the whine from the front end.
If this is the problem, you should have them checked again because the bearings will overheat and bake the bearing grease....causing premature failure. Also, I'm not sure how the latest Explorers do it, but the auto-locking hub mechanisms (remembering my 97 Explorer and 94 Ranger)will fail to operate correctly also. (the extremme heat from the bearings will cause the springs for the auto-locking feature to change their "spring constant" and keep them from operating correctly)
Thanks for the eye opener. Never even tought of that, not to mentioned that I didn't know. I'm taking it back tomorrow.
Couple hours later they called to inform me the warranty had just expired.
This is our 3rd Exp, not to mention 3 Taurus and 1 Mustang, so I called Ford hoping to get a waiver on an owner loyalty basis.
The person at Ford listened to my story, asked which dealer the car was at, and after maybe five minutes came back on to tell me that I would first have to authorize the dealer to "tear down" the transmission to see exactly what was wrong and only after that was done would a decision be made as to whether I would get coverage. And further, I would have to document that I kept the warranty valid by doing all of the required maintenance intervals.
I called the dealer and was told the cost of taking the transmission out of the vehicle would be between 8 and 9 hundred dollars.
I told them to just change the transmission fluid. The vehicle is just over 30,000 miles but was 3 days out of warranty.
I don't know yet whether the rough upshifting is still there, haven't driven it except home from dealer. In the event the problem still exists does anyone know the approx cost of having software reflashed?
Here's the thing....if I had brought the vehicle in a week earlier, I doubt whether I would have been asked to document the maintenance since dealer initially assumed vehicle was still covered and told me at the time any problems would be fixed under warranty.
I wasn't trying to fool anyone, I had totally forgotten the exact date of original purchase.
This is the first and last time I will make this mistake.
They are charging me $270 for changing it, however I don't think I should be paying to whole amount if the bearing was not installed correctly after the brake change.
Fyi, here is coupon offered by my dealer
http://www.koons.com/28kservicecoupon.html
However, be sure that by waiting you don't end up invalidating your warranty.
