Stories from the Sales Frontlines
For me that would work out to be about $7,500 per hour for all the blackouts we have had in the last nine years.
Ve lived in Virginia Beach for 27 years and were without power for
8 to 10 days at a time from hurricanes more times than I can count.
That meant taking everything from freezer and fridge to the dump.
No more of that for me. Now, at 2,265 feet above sea level, all I could
do was feel sorry for the folks that had to endure the flooding that
seems to still be going on.
What the battery does is absorb the higher voltage peaks and maintain voltage when it drops into the valleys of the rectified wave. Without the battery, you can get those 19.5Volt spikes through the car's systems and it can cause problems.
Check out full-wave rectification here:
http://en.wikipedia.org/wiki/Rectifier
and RMS here:
http://en.wikipedia.org/wiki/Root_mean_square
When a guy can translate a cars power source into a series of single
sided voltage (positive) waves, root mean squared and full rectified
AC signal, he's way over my head. I was amazed when they made
the radio keep playing after turning the car off (until the door opened).
If I were you, I would keep working on Richard about his will.
I had been trying to steer her toward a battery backup, but that system is much better.
Their website lets you know who sells them within x miles.
Ewww. You always returned stuff washed. It's just good manners.
I didn't want to wash it just in case they wanted to study it. Today I wore a good quality shirt that wicked perfectly...brings moisture to the surface where it can dry. The Wallymart shirt just sopped up the water and holds it.
I haven't received a reply to my email.
The shirt said "your satisfaction guaranteed".
The product wasn't satisfactory so it got returned. I showered in the morning so the shirt just had pure salt and water in it, no bacteria.
I used Irish Spring soap in case you were wondering :P
Which raises another point. Last year while in Florida I bought what I thought was Irish Spring soap at Little General I think it is called. It had almost the same package but had a slightly different name, Irish Summer or something. What a scam!
A battery is fine. 4 days? I'm thinking more like 6 hours, maybe 12 in a real crisis. So 4 days, way more than enough!
Pretty steep for a simple roofing job. I had mine done a few years ago for $2800. Of course I don't have one of those fancy mansions with peaks and turrets.
Maybe they saw all your fancy cars in the driveway and figured you could help them retire early.
Heck, I've done a few roofing jobs in my day, perhaps I should put in a bid.
Yes, but only if it has wood panel siding and is driven by a bald guy named George.
If you have any slope to your land Google "French drains" and you may not need a sump pump.
We have one in the root cellar out away from the house, but
it only comes on after a prolonged torrential downpour. My only
fear is winds above 75 mph. The last very high winds took down
my solar array, breaking the glass on one panel in the process.
You're probably right. However, in 10 months I start collecting
Social Security which should be a $1,200/mo pay bump, if it's
still solvent. I just might beat oldfarmer to that new Mustang.
Let's see---10% savings on a $35k vehicle. That's a nice inheritance of $3,500. :P
Richard
Usually no. It's just light and fluffy snow. Once every 5-10 years, we get an ice storm---really dangerous stuff if you live in the South. We are NEVER prepared for those because we simply don't have the equipment for it. I'm sure that we would get the ice dams and water then. In all of these years, we've never had a roof problem because of it. I'm glad that you shared that information with me. I learned something that I had never heard about in regard to roofs.
Richard
IIRC alternators replaced generators many years ago because they produce more power for their size than the old DC generators did. Those things were at least twice the size of the alternators used today and they couldn’t deliver as much power. You should have told the folks here that the alternator in our cars is a 3 phase generating device and its gets its power because of that design. As you mentioned the alternators AC output voltage has to be rectified to obtain DC voltage for use by our cars and even after having to do this it is still a better voltage source then the old DC generators that were in cars years ago. But as you also mentioned, the rectified peaks are greater than the straight line voltage produced by a DC generator and these peaks can over an extended period of time cause problems but usually when large current demands are being placed on the cars electrical system when the voltage regulator has to do more work. Because of this additional work the regulator can’t always keep the voltage exactly where it should be. As with any regulating device there is over and under shoot but this happens most often when the loads are the highest. That’s why I said minimize the loads to only what is essential to get you home or to a garage. I don’t recommend driving countless miles with the battery not connected.
I would contribute to the RMS stuff but do you really think any of the people in here want to get into that.
That is exactly what I wish to avoid. I asked the company owner if his entire crew spoke English. His response, "If they don't, I don't hire them." He said that most of his crew had been with him at least 10-15 years---a good sign.
Richard
Now you sound like Andres. Listen Dummy-Do-Little: You went to Dollar General, not Little General. If you want to save a buck, go to Dollar Tree. They sell the actual name brand products. Everything in the store is $1. We buy the Crest Toothpaste, Dove Soap, Jergens Hand Lotion, etc.---all for $1 each. That store saves a ton of money. They have those $5 padded mailers for $1, plus all kinds of neat things. Try it; you'll like it.
No more Wal-Mart shirts. You have better taste than that. If you can drive a BMW, you can buy a nice tennis shirt.
Richard
$2,800? I would have flown you down here, put you in the guest room, and fed you three squares a day. How's your English? :P
Richard
I agree with you in that so many people never bother to do research or get more than one estimate. I have to because I am so technically challenged. Also, I have always tried to be careful with my money. Now that I am old and finally have some money, I still want to be careful how I spend it. It's funny. My wife and I dropped by a quaint sandwich shop in the village today for lunch. We ordered two chicken salad sandwiches and two chocolate milkshakes. Their milkshakes are so delicious. The bill was $21. When we left, I complained about the price. My wife said, "Now that we can afford such things, you're still raising hell about prices." I can't help it; it's just me.
Richard
Don't forget potassium, calcium, magnesium, lactate, urea and certain other trace elements. It is a ggod medium to grow bacteria. And speaking of bacteria you may have taken a shower but you still had bacteria on your skin, its almost impossible to get rid of all bacteria.
Muy malo.
Thanks for the tip, I will keep that in mind for this winter.
From the guy who likes to save a buck...and drives a Cadillac :P
I have to say, $21 for a chicken sandwich and a milk shake is a little extravagant!
We are off to London UK on a business trip. Then to Barcelona for 3 days and a cruise to Venice, Nice, Rome, Dubrovnik and a few other stops.
Will be back at the end of the month, might be able to check in once in awhile. Hope things go well Fezo, hope Andre keeps his receipts, hope Richard's new roof looks and works well, hope you guys get the battery issue sorted out, hope the 54 Ford works well.................
Richard
Yeah, but who wants to go through lining out three or four previous addresses to use them? Although if you're a stamp collector that's a good way to add to the collection. :P
Richard
Oh, great. I can save my way to the poorhouse. It's really not that long a trip...
What ever happened to that good ole Southern hospitality? Do you really think if 'farmer' accepts the job, he'd want to eat them too. Nobody could be that hungry. :confuse:
Even in the South, everything comes with a price. :P
I seriously cannot get over that battery talk. I always knew that you were pretty smart (though a tight [non-permissible content removed]
Richard
I hope we're over that battery talk by now. Pretty much beat that issue to death. As they say, "we'll have to agree to disagree". I'm all batteried out or should that be battered?
Thank's for the complement but I'm not nearly as smart as I am a tight [non-permissible content removed], and you sure don't hesitate to remind me of that. Around my house I'm also called a wise [non-permissible content removed]. Come to think of it, I don't really like the common denominator that's used to describe me. :mad:
I fully concur. Knowing how things are done, expands our knowledge and appreciation of life and the world that surrounds us.
For instance, knowing what was done and how they did it made my appreciation of my quadruple bypass so much greater.
Big things like that, and little things like being able to pull up the weather radar, or track a piece of mail, or chat to you guys all while I'm relaxing in my boat, leaves me with a constant feeling that I'm living in the future.
Yes, let's. I'm sure we could take it a long way further face to face, but it's way too much work when using a keyboard!
It does seem a bit harsh. Perhaps I should say "cheapskate".
Richard
About four years ago, we had a rare power outage that affected a huge area. We lost power for four days and it was in the middle of winter.
It was nasty. Our store had no power except for our portable generators that wouldn't start at first and I thought my 80 year old mother in law might freeze to death in her home. I brought her hot coffee every morning.
It was miserable and a lot of people (in my opinion) really overreacted. They bought expensive generators and paid a fourune to have them installed.
We almost pulled the trigger on a small Honda generator that would have powered a couple of critical items but we didn't follow through.
That was the LAST power outage that we have had other than a couple of five minute blackouts.
Exactly. You stated it beautifully. I don't have to know how to put a new transmission in a car in order to appreciate the hard work and knowledge behind the effort. I've never been one to complain about car repair prices. The person that does the repairs went through training and has spent hours in labor fixing my car. I'm willing to pay for that training and time, plus I admire the person's ability to do it. As for $21 for two sandwiches and two milkshakes, I do complain. Perhaps that is because I know how to do both of those things. :P Again, I really was impressed by the exchange between you and jmonroe. You both are very intelligent guys, but you're not intellectual snobs. Heaven knows, I ran into plenty of those over the years at the college level. If half of those people had known half as much as they thought they did, I would have been twice as inclined to hire them at twice the usual salary.
Richard
You don't know how to replace a transmission and they let you drive? :P
I know just how to do it. Step 1 - have car towed the transmission guy. Step 2 - write huge check. Easy.
Richard
Richard
Why don't you guys just take the battery cable off and then jump start your car. Put it on youtube than we can really see what happens.
http://albany.craigslist.org/cto/2590977517.html
Richard64 - Good job getting the 3 quotes on the roof! You'll be happy with the roofer you chose.
"...Do you really think...he'd want to eat them..."
Ha ha ha. Good catch for Mr. jmonroe.
http://albany.craigslist.org/cto/2589901530.html
You are susposted to "allow" the transmission shop a generous profit of 10% on their labor while they sell you the transmission parts for their cost!
to remind people just how quick those flooded cars can be cleaned
and sold to unsuspecting buyers.
After seeing so many cars with water on the windshield filmed for
the news I was reminded...they have to go somewhere and it's not
just Halsp Worthington at the car emporium that is out to make a buck.
Turns out there is an outside spigot in the same corner of the house.
I'm not really worried about a multi-day outage. Just losing power for say 6 hours during a heavy rain.
If not here are three of different capacities.
No plugging in of the battery backup necessary as it stays connected all the time.
Pump 1
Pump 2
Pump 3
