General Motors discussions
I'm not sure, but doesn't the 3800 still get slightly better fuel economy than the 3.6 DOHC? That might be one reason for keeping it around, just for CAFE purposes.
Which 240 hp pushrod are you referring to? The 3.9? I've heard that the 3.9 was actually designed for copcar/taxi service, which pretty much demands a fairly simple, cheap, durable engine. They just offer that engine in some of the other cars to get more of an economy of scale out of it. I don't think the 3.6 DOHC would quite fit the bill in this kind of service, but you never know. After all, Crown Vics have been SOHC since 1992. And DCX offers an SOHC 3.5 V-6 in their Charger/Magnum police cars, as a slightly more fuel-efficient alternative to the Hemi. I get the aura (pardon the pun) that the 3.6 DOHC is supposed to be more of a "premium" engine though.
Yes it will.
Toyota is able to cut $5,000 on each 3.5L 2GR V6 it produces comparing to the old 3.3L V6. I don't see why GM can't do it with its 3.6L V6.
the 3.9 is a bit over 3000 (and the 3.5 is the same price).
Those prices are wholesale (so the website says). The difference is about $1500. If GM can add $1500 to the price of current cars with pushrod engines, then making a DOHC engine standard can be done. I don't think GM can save $1500 per engine by eliminating pushrod production and replacing with DOHC engines.
putting 2 valves in where 1 will work also costs more.
http://www.newgmparts.com/partlocator/index.cfm?action=getLocator&siteid=213815&- chapter=DP1ZA3&appSectionid=10&make=4&model=Lacrosse&year=2007&catalogid=1
Meanwhile, the Aura was a dumb example on my part, but the multiple choice option thing is something they've got to tame down somewhat. Toyota is just as bad in that respect. Honda goes too far the other way - "Oh, you want a stick and a sunroof? That means you need 4 wheel disc brakes and you can't have it in red. Oh, and if you wants four door and a 6 cyl you can't have a manual.".......
GM and Ford will find it difficult to lure customers away from Honda and Toyota because they are dealing with a lot of irrational people. Every time I have gone to purchase a new car I march off to Honda and Toyota because of the ratings. Every time I come away shaking my head and assume I'm not in on the joke. That fully loaded, $30,000 sticker, Accord drove like a $20,000 Ford. I know I'm not a rocket scientist but I don't understand what is going on. This time I didn't even bother with Toyota.
Ford and GM are large enough where they can serve up the mush for the masses and still have their niche brands for the rest. But they need to recognize this, do they?
Ford had it right with the Lincoln LS. Instead of tweaking what they had, they dumped it and went to the MKZ, a pre-LS style Lincoln.
GM has it right with the G6. I rented one a month ago and really liked the car. Now they just need to determine what the car does right and improve on the rest.
However, in my experience the Accord drives very different from Fusion. The engine is much better, drives more refine and has an overall better balance. Even the Camry SE is a better drive than the Fusion IMO. Fusion has a nice interior but is still a notch below Accord.
Also, just so that you'll know, calling other people irrational doesn't automatically make you rational.
- that the typical $20,000 Accord or Camry is better that the comparable Fusion or G6
- their own negative experiences with GM and Ford products
To imply that the masses are irrational is a little self serving.
I'm glad that you liked the G6 but it falls short in alot of ways.
Yeah, SO terrible they pull in $80,000
Yeah, 20 yrs later,and only if they are mint w/ Zero miles.
At the time,they were one dimensional cars.
Thank you,you made my point.
SAAB is a wannabe brand,not a real lux player.
There's a black Camry in the parking lot at work, either a 2005 or 2006, and its orange peel looks pretty bad to me. At least, it was nothing to brag about compared to a GM or Ford. Or maybe the paint booths are higher quality on some assembly lines than on others?
Lexus is made in Japan. The Toyota probably built here. Different governments, different rules.
Also has a lot to do with the age of the paint facility. It is the most expensive part of a plant and it is rarely changed. You can completely gut the rest of the plant ot build a different vehicle but you think hard about redoing the paint shop. So the vehicle built in one plant will perhaps have a 10 year old paint system vs. the same car in another plant that has a 1 year old system.
Uh...NO.
Lexus RX and ES are made here, Almost half of what Toyota sells here are also made here.
First they are built on different lines so a simplified line is not really an issue. 2nd, engines are built in manufacturing modules so everytime you want to increase volume and your current modules are full then you add a mudule. The HF V6 modules are more expensive than the HF V6. The cost savings will come through volume buys of components which may save $50/engine in cost. Also you would need less Engineering/development resources for having 1 instead of two V6's (3800 is really dead and not taking any resources). So maybe there is $50 in that cost. So you would be able to cut $100 off the $750 cost differential between the engines.
So the question would GM sell more vehicles and make more profit it they replaced the Value V6 with the high feature V6 and added $1400 to the price of the vehicles? In my opinion they would not. Perhpas they could add only $1000 to the price but I still feel in the lower lines like the Chevy most buyers would take the cheaper V6 and the $1000 savings.
No, it depends on how long. GM has built up enough stock in most models to last almost 2 months. That would be a long strike and I rally doubt the UAW workforce would do it. Too many of them are already in trouble financially with the latest housing and recession we are in. Especially in Michigan.
Nothing to do with the UAW really. That plant knows its death date. It is just making enough engines to last out the current Lucerne and LaCrosse models and then it will be gone.
In retrospect, the Grand National wasn't the most sophisticated thing in the world, but they had a lot of bang for the buck. My Mom bought a regular Monte Carlo with a 305 for something like $14K back in 1986, and I doubt it a Grand National would've been a whole lot more. I'd guess maybe $17K if it was fully loaded?
I4
I4 Turbo
V6
Supercharged V6
Compact car gets the choice of the I4 or I4 Turbo. Midsized cars get I4, V6 or Supercharged V6. This way you can concentrate on making the best engine you can and all the brands can take advantage of it. You also don't have a bazillion different engines sucking up resources.
The average buyer cares little if his Ion has the same engine as the Cobalt, as long as it is a good engine.
Despite being built at the Kyūshū plant in Fukuoka, Japan,[7] the ES 350 was not sold in the Japanese market.
I am aware of the RX being built starting 2004 or so in Canada. I thought the earlier comment was about a car.
That is where I put in the $50/engine. Would not be much more. GM sells a lot of those engines.
Sounds like they need to relax a little out there. No wonder so many people complain about poor gas mileage.
BTW here's one w/ 14K miles, which means it was enjoyed for the collector car it was.
http://cgi.ebay.com/ebaymotors/Buick-Grand-National-Buick-Grand-National-GNX-431- _W0QQcmdZViewItemQQcategoryZ6137QQihZ015QQitemZ250163862071QQrdZ1QQsspagenameZWD- VW
Anybody knows that most all American Muscle cars were straight line cars (except the vette).
For the $20K it cost in 1987, it was EXCELLENT bang for the buck.
Here's an '89 911 w/ HALF the miles on it selling for LESS than new.
http://cgi.ebay.com/ebaymotors/1989-PORSCHE-911-Speedster-MINT-Original-RARE-Lo-- Resrve_W0QQitemZ320157374200QQihZ011QQcategoryZ10156QQssPageNameZWDVWQQrdZ1QQcmd- ZViewItem
So, I guess the original owner of the GNX did well on his investment.
What arguement? The LaCrosse is a W car which has had the 3800 in the previous Regal/Century versions and the Grand Prix. When the LaCrosse was being developed the 3800 was kept as the lower engine choice for a couple reasons. It was a well known/wanted engine for Buick buyers. The 3800 was well proen.
According to Automotive news, only the RX is made domestically, and only 22% of Lexus' are made locally. Everything else lists as an Import.
Even though I don't live in NY, I have visited there a number of times and the issue is that those roads were built in the 30's and 40's and the on ramps are devilishly short -- maybe 100' long, in some cases.
You have to floor it to get up to a speed where you can safely merge into traffic.
Here's hoping for an Astra Red Line - 260HP turbo from the Sky RL -- woo hoo!
LOL, well we will see which brand is standing at the end of the day. I suppose Volvo, could become a Chinese made premium brand. :P
-Rocky
-Rocky
It's been a long time for me but the Merritt Parkway in CT is the same way.
-Rocky
Now, you are just being foolish.
I mean c'mon,what kind of nonsense is that?
Volvo FAR outsells SAAB and is actually PROFITABLE.
Please,have a little common sense?
Don't rule it out altogether, or India for that matter.
Bottom line is, because they need cash, Ford is dumping them, and both countries' auto industries are itching to get over here.
