General Motors discussions
1146147149151152558
    Yeah I agree all of those would be good chices. I think GM needs to bring more cars to the Zeta platform. The Velite and many RWD sedans could use that platform. ;)
    Rocky
  • sls002sls002 Member Posts: 2,788
    The Mustang was the first "pony" car on the market. It was well liked at the time. The Camaro and Firebird were GM answer to the Mustang, but the real hot cars at GM were the GTO and 442.
    The basic problem with the zeta platform has been weight. The Camaro was going to weigh in at 4000 lbs, which is a bit too heavy. I think that if the weight problem can be overcome, then a number of sedans are possible, but again, the platform will have some limitation on the range of vehicles that can be supported. The Camaro will be a shorter wheelbase (110 inches) and short body. Sedans would be longer, but I would guess that the upper limit might doom a large RWD Cadillac on this platform.
    The point here is that if they want to use the zeta for a Chrysler 300 style sedan with a 120 inch wheelbase, can they build a 110 inch wheelbase coupe too?
    The Velite could be another Reatta. I owned a 91 Reatta. I don't know that Buick can sell a roadster. With the Solstice and Sky, does GM really need yet another Roadster? The XLR is a good top of the line model, and the Corvette is cheaper, so I think putting some other roadster in the mix will just reduce profits.
  • andre1969andre1969 Member Posts: 26,120
    is cool, but IMO it's just too big and bulky to be a ponycar. In some ways, it makes me think more of the '70-74 Challenger/Barracuda (and new Challenger concept) type of car than a ponycar. While the '70-74 Challenger/Barracuda were considered ponycars, they went against the grain in that they were based on a midsized car platform, rather than compact. That made them bigger, bulkier, and heavier. A Duster or Demon with a 340 or 360 back then was probably a better ponycar contender than the Challenger/Barracuda, even if they didn't look as menacing.
    Up close, the Camaro sits up very high, and it's wide. It's almost like they took a pre-downsized 70's full-sizer, chopped the roof, took about a foot out of the wheelbase, but preserved the width, and the weight. While the roof of the car is low, this is not a low-slung car.
    Going back to the real thing, I prefer the '67-69 Camaro to the '67-69 Mustang. However, fast forwarding to today, I think I like the new Mustang better than the Camaro concept. The Mustang, while heavy and a bit large-ish, still seems like a modern update of the original. The Camaro seems like a caricature of the original.
    I'm not sure on what the limits are on platforms pal. I'm sure it's a case by case basis per platform. I was excited about the Zeta, and then GM limited it's use. Hopefully the Sigma II will spawn a few desirable cars like a Velite, RWD Caddy DTS, RWD Buick, RWD Impala, etc etc. You would think GM would use the Zeta for Saab's also :confuse:
    Rocky
    Well IMHO, the Camaro is perfect in size. I'm sick of all these small, sardine cracker jack VCR's on wheels they call cars. The Challenger is going to be big also. The Mustang drivers will be intimidated by the Camaro and Challenger drivers with a real muscular V-8 echoing out those dual exhaust. :shades: :P
    Rocky
  • xrunner2xrunner2 Member Posts: 3,062
    The Camaro concept is cool, but IMO it's just too big and bulky to be a ponycar.
    Right. It would need to lose weight and slim down. Maybe come in at 3200 lbs. This would help handling, acceleration, gas mileage. Wonder what the concept would like like parked next to a 68 Camaro (not the awkward 69).
    Re concept seems like a caricature of original. Make that cartoonish.
    The Camaro concept was built on a chopped sigma platform. The basic problem is that if the Camaro is to have the Corvette engine it will need a fair sized platform to support the engine.
    The sigma II platform will still be an expensive one and will still be in the current factory with limits on total production. Adding another factory (at great expense) would solve the production capacity problem, but not the cost problem.
    The zeta platform is supposed to be much cheaper than the sigma (or sigma II) and so the expectations were to build a number of vehicles on this platform. However, zeta is a heavy platform as designed by Holden.
  • plektoplekto Member Posts: 3,738
    ...but the plastics in the Aurora were even less luxurious than the Riviera's.
    Am I the only one who's finding this a bit odd? :)
    Plastic and luxurious in the same sentance... um... HOW ABOUT NO PLASTIC, GM! Or at least cover it in something that won't crack or distort.
    As for RWD, they need to follow Volvo and Mercedes' older examples. Small inline engines with timing chains and add in a non-interference design while they are at it. Dropping some aging lump like a 3800 into a car and calling it sporty isn't going to solve the problem.
    That and stickshift. Offer it on every 6 or 8 cylinder car that's RWD, even if it's a special order item. Serious drivers who want that muscle-car experience will usually choose a manual transmission if they have an option. A Tiptronic type transmission would be somewhat acceptable as a compromise, but it needs to have a proper shifting pattern instead of this up/down nonsense. Starting in second or doing a 4th to 2nd shift isn't possible with the current versions GM is making, for instance. Say you are lugging the engine in traffic trying to save gas/cruising along and need to shift into second to quickly move out of the way to dodge the car in front of you that suddenly slowed down. On my old Volvo 240 I had years ago, I could do this without a second thought. New automatics with the paddles or shifters you nudge up and down - you can't bypass gears very well.
    A 5 or 6-speed layout, even if it's just a selector joystick is worlds better. Feels like a manual. Just no clutch.
    But it's these little things that GM seems to just not think are important. Rather than innovate and take ideas from competitors and from customers, we get groupthink rental fleet mantality. People have been practically screaming for RWD in GM's larger vehicles for a decade, for instance, and GM just follows the pack like a second-rate Hollywood director who copies the latest movie or TV show trend.
    We've all seen the results. All those little things add up to a car that's just not as good as the competition. It's not bad, either, just... feels like you're buying the generic version of the real thing at the gorcery store.
    But GMs are great cars to buy used because they depreciate like rocks. Not quite sure this is what GM wants in a customer, though... :P
    I have mixed feelings on this topic. I'd rather have a slightly bigger car for safety and room reasons that a undersized cramped vehicle won't offer. It would be nice if this Camaro would allow 4 adults to ride in it. That was the biggest gripe I got from most owners is they all wanted to take the Z-28 or Trans-Am out to dinner with another couple but the back seats were ruthless to other than kids. ;) Bigger sometimes is better is all Im saying.
    Rocky
    While Rolls may cover the interior with either wood or leather, the interiors on upper end Mercedes or Audis do have plastics. The finish on the plasics is what counts though, and the finish on the dash plastics that my 98 Aurora had was quite lowend looking. My 2002 Seville has somewhat nicer plastics, and the newer DTS/STS Cadillacs seem to have plastics that are about the same quality.
    GM's automatics will skip down more than one gear if you let them do it automatically. And the RWD's 5 speed's do have "triptronic".
    The 3800 is supposed to be phased out of production around 2008.
    As the Camaro/Firebird platform aged, the cars became more like the Covette, beginning with the 82 models. I think that making a Camaro more in line with the first generation might be good. I think that Pontiac would do better to make a GTO style car (bigger) than another Firebird.
    The Buick Velite is a 4 passenger Convertible. It could directly compete with the Volvo C-70 and Mercedes CLK, and Lexus SC convertibles. Yeah GM has the Saab 9-3 but its boring and it's Swedish. The 3.6 Twin Turbo with chrome paddle shifters would breathe new life into this tired brand. The XLR is so expensive it needs to concentrate on taking MB SL sales. The Velite would be the perfect american family lux/roadster that many would buy. Buick lacks a icon car and Tiger Woods needs a vehicle that doesn't tarnish his image. Really how many people believe Tiger rolls in a Lucerne ????? The Velite is believable and with Buicks recognition with Golf, and Tiger Woods could be a great sponsor for buick by GM making limited edition Tiger Woods editions that come with custom golf packages with Nike, and TW logo embroidered throughout. Maybe Velcro golf bag holders and these limited editions get Nike Golf Bags and clubs as part of the deal along with clothing. I know it might sound stupid to some but I believe something like this would work. I'd be the first to line-up and buy one. I'd place my order right now for a copy. A few of my buddy's are upset the Velite isn't coming out also, so I'm not alone in disapointment. :cry:
    Rocky
    Would you pay $60,000 for it?
    I hope every one of those complainers went out and bought a GTO when they came out in 2004. "Pony cars" are supposed to be 2-door RWD compacts with flashy styling, not full-size land cruisers.
    The GTO whips the Mustangs butt, but lacks the exterior design execution that the Stang has down pat. ;) The GTO is also more livable as a daily driver. :P
    Rocky
    pay $60K for a Camaro or Velite Roadster ?
    Rocky
    Exactly. The original Mustang came with a six cylinder engine and a SMALL V8 was optional. Monster engines were for the bigger cars like the Thunderbird.
    The Velite. The entry level price tag to make the Camaro work has to be about $20,000. The Camaro convertible would be higher.
    If the Velite is to compete with the CLK, the price tag will be about $60,000. The base price could be less, maybe with the 3800 about $50,000 and hand crank windows.
    I'd pay a MSRP for a Velite Roadster of up to $45K. GM guys originally said about $42-44K for a loaded one.
    I believe Lutz said it. ;)
    Rocky
    Yeah, but a Corvette is only about 72.6" wide. The Camaro concept is about 79.6".
    Now if this platform is designed to also accommodate a traditional full-sized car, then I could see a need for the car to be that wide. But 79.6" is a pretty wide car. Even the pre-downsized 70's big cars weren't that wide. Anything over 80" and it has to be registered as a truck in some states! :surprise:
    LOL well we need cars to grow in girth with us americans. :P
    Rocky
    At that price level you will get the basic plastic interior, 4 cylinder engine...
    I disagree with ya on that one pal. It doesn't cost that much to make em' if the platform expenses are being shared. ;)
    Rocky
    P.S. Tell me how a Volvo C-70 is doing it at that price point ?
    The concept car was a styling excerise. The production car may be somewhat different. But, if they redo the body styling, the looks will change. An 80 inch wide body would allow a fair sized DOHC V8 under the hood.
    The 71-76 Cadillac sedans (deVille...) were 80 inches wide.
    It is not a CLK.
    The only way a Buick convertible will be profitable is if it is a convertible version of a sedan model. A Roadster is a two passenger convertible anyway.
    Roadster is a 2 passenger convertible. Hmmmm I've heard other 4 seater convertibles being labeled as roadsters in the past. Well calling it a "convertible" is fine by me. The Buick LaCrosse Super has the exact Velite front end meaning a 4-seater Roadster/Convertible could be done :D
    Rocky
    What do you mean it's not a CLK ? The CLK isn't that elite IMHO. I'd rather own a Volvo C-70 over it. Especailly when the rumored AWD "R" version see's production. :P
    Rocky
    The term "Roadster" has become a marketing word, so the advertising departments may misuse the term. However, a 2+2 style convertible might be called a roadster, but now we are getting back to the old Camaro/Firebird style with back seats that a good for small children, but not adults.
    One thing you need to try to get a grip on is that GM is not making any money. Cars like the Velite and Camaro will not make GM profitable. GM needs to make vehicles that will sell. I really do not have much hope that they can reverse the current market share slide. I really can't see GM building cars that will outsell the competition anymore. In the 60's Ford and GM built the best quality cars, while Chrysler's quality was variable. This is why Chrysler's share of the market ended up at GM. Now, GM's quality is on a par with most of the other makes, but this is not a reason to buy a GM product instead of one of the other makes. GM has maintained an above average market share because current owners of GM products tend to buy one more GM product. However, more and more GM owners are looking at the competition and finding that they like what they see.
    I'd rather have them put more money into the quality and less into paying Woods for endoresements and the right to use his initials and image.
    The CLK's are priced fairly close to $60,000 once the usual options are added. The Volvo C-70 may be a nice car, and since it is European, probably much nicer than anything GM builds in the US. But the Volvo is not quite in the CLK's class for total luxury. But then Volvo is not as expensive either.
  • 62vetteefp62vetteefp Member Posts: 6,043
    Do not hold your breath for a convertible off the LaCrosse if that is what you meant. W platform is soon gone.
    If you want a Velite it will need to be done on the Kappa. Sigma will be too expensive for a Buick.
  • m1miatam1miata Member Posts: 4,551
    Drop the wheel size down from wagon wheels 20 and 21" to say 16 and 17" and add a roll bar in the thing. Actually, make a hardtop version. They already have the Solstice and Sky, so I doubt any more cars like this are needed. Sooner or later the convertible craze usually subsides when people find out they rarely use it with the top down, or don't care for the maintenance of a soft top. Or is it a hardtop convertible?
    -Loren
    If I have money, and wanted an impressive convertible coupe, it would be a BMW or Mercedes, and not a Buick. A convertible coupe / roadster is more in tune with a racing, or sporting image. Buick luxury cars are perfect match to *yawn* golf. Would not pay more than $25K for a Buick - sorry, they are alright cars, but the near luxury status died decades ago. Closer now to a top line Chevy in class. Too many other choices in the $30K to $50K range.
    -Loren
    Then it looks like I better wait for a Volvo C-70-R version to make production. I really do live in a climate where there is lots of sunshine making a convertible practical for me. My 95' Olds Cutlass Supreme 3.4 DOHC was my first convertible and I miss it alot. Oh well like Loren says there are lots of choices out there. I will have to pay close attention to the C-70 since I won't buy the current one with the puny motor in it and FWD only. :mad:
    Rocky
    Golf isn't *yawn* :P
    Nah!! Think that road tests show that GTO not very good in handling. Mustang clearly outhandles GTO. Didn't some handling tests show Camry or some compact sedans from Korea and Japan beating GTO? GTO was a market failure like its Pontiac brother Aztek and that is why it was cancelled.
    The GTO handled pretty well for a big coupe and it also rode better than any mustang and was more livable as a daily driver. The exterior styling was a bust, thus creating a failure. :(
    Rocky
    Rather than resurrecting the Caprice line, GM could put Lucerne as top Chevy. Know that Buick/Pont/GMC dealership situation would be a problem with this. But, Chevrolet Lucerne has a nice ring to it and would be a decent offering at 22K-25K MSRP loaded. They would have to price it here to try and undercut Azera, Max, Camry, Accord top lines.
    "What this really means to all: The ship is sinking and there won't be enough life boats soon."
    Exactly - like those people who are released weren't contributing anything to the company? Why were they there in the first place?
    This is just smoke for Wall Street, and a desperate effort to balance the books this year.
    Exactly. UAW members per agreed benefits cannot be let go even if they had nothing to do.
    "The GTO handled pretty well for a big coupe and it also rode better than any mustang and was more livable as a daily driver."
    Even if you're right, and I don't agree - it doesn't matter if you don't sell any....
    The Challenger is a monster car width too. Whatever happened to Pony Cars? A Tiburon comes to mind, but it is FWD. The New Stang is not overly large, yet seems to be plumping with every new form it takes on. Where are the new designs? Did all the designs end in the 60's? No new ideas for the pony car? At least the Tiburon is fresh looking, though they stole a line or two from Ferrari's 456.
    -Loren
  • logic1logic1 Member Posts: 2,433
    I disagree. Wall Street is happy because this shows GM is shuttering out dated facilities in favor of newer here, in Korea, Mexico, etc. More importantly, it means the jobs bank, which was some 7,000 or so strong, is gone. And the jobs bank was people on the pay roll contributing nothing but their bodies in case GM needed to call them up some day.
    It was a bad contract that allowed them in the first place. I think GM voided it in time.
    I do agree here.
    With our crowded roads and low speed limits, it turns out the bling in the Mustang's nostalgic design easily outsells bland competence.
    Could have a rumble seat and be a roadster, though it would not pass any crash tests :surprise: Those granny seats were a little on the dangerous side of touring.
    -Loren
    The original Pony Car was based on the smallest platform Ford had going at the time, the Falcon. ergo, it was small.
    The Camaro was indeed wider, but still rode on a small platform.
    Dodge, however, didn't have that small a platform readily available, but needed to get into the game, so they brought out their Charger, which was as big as any other Dodge they had, actually. Then, their Challenger, which was shorter, but was still built on the big car platform, and was really, really wide for its length.
    Perhaps, they are trying to replicate the original appearance, if not size?
    Camaro and Mustang were really the only Pony cars. The rest were sports cars, in assorted flavors.
    Well they race Holden's so I guess you could modify to make it a better curve carver car. The exterior is fine as car. If they had been honest and sold the Holden line as Holden and the Opels as Opels, and just not rebadge the car, it would have POSSIBLY accepted more favorably. The is no Pontiac to make a GTO out of, and people are smart enough to know it.
    For sport and gas mileage, make the Nova again, with a nifty inline six or at the least the better 3.6 V6 with a RWD and a nice compact size. Then make the Camaro off that one. Add a smaller V8, but not the Vette engine. Keep Vettes as the premium line. As for performance wars, they may end with $4 or $5 a gallon gas some day. Even at $3+, why not get 30 MPG with a good six? Let those in need of street braggin' rights, go to the parts bin and put on blowers and nitros, or whatever turns them on to get the power. They do it with i4 engines all the time. They drag race those, what 500 to 1,000 some HP Civics, or something crazy like that! And it is more fun to do the add-on things anyway. The dealership could sell them as the factory optional blowers, or whatever they do with the Scion line of cars. Keep the Camaro and Nova as one six and one small block eight, at say 260HP & 320HP.
    -Loren
    Well in a broad sense, they all are sports cars. The Challenger and 'Cuda / Barracudas were Pony Cars and Muscle Cars and Sporty Cars, and Sports Cars. Kinda cool looking too! Liked them Dart/Duster/Demons too! Slant six to monster fast V8's - choose your weapon!
    -Loren
