The woofers don't care so much, because bass is not directional. (That's why you can put a subwoofer almost anywhere). The tweeters, however, are very directional. You'll be cheating yourself pointing them at your ankle. It's really worth the extra effort. Hyundai did it, and they were using cheap speakers.
If money is a problem, sell the 2 dust collector amps on E-bay, and use the money to buy seperates. You'll be glad you did!
Co-axs should be fine for the rear. Spend the money up front. After all, that's where you usually drive from, isn't it?
The instruction book states it plays AAC, MP3 and WMA formats, with no information about acceptable fixed or variable sample rates.
My experience is that the radio will not play AAC encoded discs. It will recognize the disc, and cycle through the tracks, but will not play.
Performance is poor with variable rate WMA, with several skips per disc, and erratic restart when switched to FM or switched off.
Fixed rate WMA is somewhat better, with only a few skips, and no restart problems.
MP3 seems to work well
The radio was changed once, without any change in performance. The recorded bit rates were between 92 and 250 K, and the disc were closed on recording. The symptoms are consistent with several discs of the same type. . The WMA discs work fine on several other brands of players. I have had only one opportunity to check an AAC disc in another automotive aftermarket player, but it worked. All AAC disks play fine with Winamp and Nero decoders on a computer.
Does anyone have a similar experience or have an idea of why it's happening?
Hyundai customer service and the dealer have no information available.
1) Where is the amplifier located?
2) What are the specifications? Power output at least
I am trying to upgrade the factory speakers and would like to know what kind of amplifier (if any) is there. According to the description of my car, I have the lx with 6 disc changer, sub woofer (both I can identify) and a mystery external amplifier.
Thanks in advance for the help,
JT
Thanks in advance!
Are they wired in phase. This means that they both have the positive wire connected to the positive speaker terminal, and the negative to the negative. If one is out of phase, they could sound weak.
The original plastic cone that the Hyundai speaker was attached to the door with may have made the factory speakers sound "bassier", and was probably removed by the installer.
There may be a band-pass filter, somewhere in line between the radio and the back speakers. This is commonly a small piece of electronics, along the line of a resistor or capacitor, which is typically used to block low freqencies to tweeters, because too much low can fry a tweeter quickquick.
Last but not least, check the rear fader adjustment on the radio, it may need adjusting.
If you ask your install shop these questions, I'm sure they'll know what you're talking about, and be able to help you. My rears sound good, but don't forget, I am running an amp to them. However, to be honest, I am still not totally happy with the bass/treble/midrange adjustability of the Hyundai radio, and am planning to add an EQ into the circuit ahead of the amp.
I have bought it already, it is a Pioneer DEQ-7600 15 band digital EQ, and I plan on installing it under the HVAC controls, where the little drop down door compartment is now. This is where the KDM (Korean Domestic Market) Sonatas have their radios, so I know a standard DIN chassis will fit there.
What do they have where our radios are? Why, a 7" NAV screen, of course. They keep all the good stuff for themselves!
So looking for the part and supplier, and if you know, how it plugs into the radio/what button do you push on the radio to make it work. Thanks!
The configuration on the 2006 LX, 2007 Limited and SE as well as the 2008 SE and Limited is the same: Infinity Head unit individually shells out 120 watts and connects to the Infinity Amplifier (Power is 240 Watts and is located beneath th right front psgr seat. This goes out to the 7 spkrs comprised of 2 front tweeters, 2 spkrs in the front doors, 2 rear door spkrs and finally to the subwoofer on the rear deck. Finally, the total power output: 360 watts!
Enjoy it!
Can someone help me? :confuse:
Im really lost....n im gettin fustrated cus im riding in silence every where i am....
can somebody help to plug up my speakers or even see whats the matter...
I had an amp installed at circuit city after I couldn't find a hole in the firewall. I insisted they show me what they did, and basically, they found the spot where the clutch cable would go through (if you had one of the 2 or 3 manual cars they build).
The hole is not open from the factory, so the CC installers just drill it out with a small bit. Make sure you put tape around the bit, real close to the tip, so it doesn't go any further into the engine compartment than you want it to.
Last but not least, your amp's ground wire should be as thick as your power wire (8 gauge). Otherwise, your amp's not getting all the juice it needs, and won't really "bump" those speakers, or worse, feed them a distorted signal (best way to blow out speakers). Good luck, keep us posted!
ps: The 8 gauge wire (red) goes to the Positive battery terminal (with it's own fuse, of course). The ground wire for the amp (negative, black) (you really shouldn't use that skinny wire here, I know you want to) can be screwed to any good metal ground you can reach. It doesn't have to go to the battery, as a matter of fact, noone does that.
I know the 06/07 have nothing.
Furthermore, if the answer is no, how difficult is it to setup the 30 dollar FM adapter for MP3 players? I don't wnat to have to mess around with taking out the stereo or anything. is it as simple as plugging it in and selecting a frequency? As I recall, the iTrip was pretty bad, so Im a little skeptical of this option.
Jason
Nashville
It's very curious that the three that behave this way were all downloaded on the same day, and I have not had trouble with any other of my hundreds I've played so far.
I'm not done troubleshooting this, and will post my findings when I figure it out (or not).
I find it very curious/confounding that the only MP3s that display this behavior were all downloaded on the same day. It has nothing to do with the date of download either. Amazon permitted me to re-download them days later and they are exactly the same. The pre- and post- saved files are dramatically different binary files, so I couldn't find any obvious eyecatcher to tell me what may be the problem.
It isn't the song manufacturer (although I first suspected Sony's DRM) as I have songs from those companies that work without the problem.
If I find out any more I'll post it here.
Anyone have any similar experiences?
I would be most interested in any further data from thumkf
When I resaved them in my audio editor, my default was 256kbps and then they played fine.
Now, this is purely a guess: since the higher sampling versions eventually *did* play after a 40-second (or so) delay, I'm now wondering if the player is smart enough to convert them from 320k to 256k (thus the delay) and then play them at the newly-converted sampling rate.
Jason
There is a TSB about it. The part number for the cable is 08620-2L000. It's a special iPod cable that plugs into both USB and Aux. It can fully integrate an iPod nano to the stereo. Make sure the nano has the latest firmware and use the latest itunes version for your pc. There is a TSB that mentions it.
It's a dealer aid used for common complaints.
It's actually $12.95/mo, unless you get a multi-year plan. I would suggest against that right now, since them and SIRIUS are going to merge very soon. If you already have XM, additional receivers are only $6.99.
I have XM in three cars and two boats, and think it's a great alternative to FM radio. I just wish they didn't have to compress the audio so much (It's comparable to a 64k MP3).
Your local Hyundai dealer.
Thanks for any help.
-Alpine 9856 CD/MP3 player (with direct connect iPod - digital sound, not modulator - wire hidden and run into center console, where iPod stays)
-Boston Acoustics S95 x 2 in rear deck, powered by head unit
-Boston Acoustics SL60 component set in front, powered by:
-Rockford Fosgate 325.2 punch amp
-No sub
-Sheets of Dynamat in front doors (noise and vibration killer to improve stereo sound)
Have read a bit about ESA & if I understand, it is a communication protocol.
http://www.pcper.com/article.php?aid=476
So is Hyundai saying that their USB connection is not ESA, or are they stating that the device you plug in must be ESA??
I plan on using just a plain 1 or 2 gb memory stick for tunes. Curious if anyone has had any problems, or damaged a memory stick by leaving it plugged in all the time.
I want to add an amplifier and sub box to the trunk, does anyone know if the single factory sub is being driven from an amplifier or just the stock radio and is it only recieving an Low Frequency signal?
I would like to tap into the factory sub line signal to drive a new amp and sub (instead of replacing the deck and running rca cables back to the trunk)
Will this be a problem if I use a high input converter?
R
I was wondering if anyone can tell me how the iPod works when connected via USB to a Sonata with the DVD Navigation system. What appears on the video screen? Do you get full song/artist/album info? Can you select your different playlists? What functionality over the iPod do you have? I have a 30GB iPod Video.
I was not impressed with the Jetta hookup. You can only see the first 5 playlists and it does not display any song information on the radio display. I'm hoping the Sonata does a better job.
Merg
