Hyundai Sonata Audio Questions
Mine doesn't work does yours ????
While not an expert in this field, I don't think that scrolling is an automatic feature. If I'm not mistaken, scrolling doesn't take place in my girlfriend's 2005 Ford Focus either. :confuse:
I would hope and expect that the 2007 Sonata will be equipped with more "substantial" radio controls. Having only Volume and Mode controls just doesn't cut the mustard.
When factory XM on 2007 Sonatas becomes available, will you be able to unplug the factory XM module and replace it with a line-in for a portable MP3 player?
i have a 2006 GLS V6 which has been running fine. I'm looking into perhaps getting an aftermarket radion since i'd like to hook up my Ipod and the Hyundai stereo doesn't have this option. The thing that concerns me is the contoured faceplate. Has anyone gotten an aftermarket radio installed? Has the sonata faceplate been an issue. thanks
Installation Kit, Faceplace/Mount, Single/Double DIN (includes pocket for single DIN installation), Metra 99-7320 from bicostereo.com @ $31.13 (total)
Removal of original equipment head unit involves first removing the metal/wood trim above the center a/c vents. Start at the steering wheel with a flat-blade screwdriver into the top edge and pry outward *carefully*. There are two screws in the glovebox which will need to be removed to fully remove the trim piece. There are four screws exposed at the bottom of the radio, emergency flasher switch, and passenger air bag light. *Carefully pry out the emergency flasher switch and passenger air bag light; there are two each plastic clips which hold these two switches in the dash and they can come out easily with the switches or remain in the holes. If they remain in the holes, *carefully* grasp these with needlenose; if you don't do it, 'just right' you risk losing these inside the dash.Once the two switches are removed, there are four more screws holding the radio into the dash. Remove these and remove the head unit from the dash. Pull the head unit out far enough to detach the antenna cable and 24-pin plug. You'll either need to solder or crimp the proper wires to connect the aftermarket unit to the vehicle harness. I have no pinout information as I've not completed the install yet (awaiting faceplace/mount and wiring harness).
Wiring Harness: Scosche HY05B from buy.com, plugs into vehicle harness @ $12.62 (total).
Looks better and is safer from theft than any aftermaket replacement head unit.
That's exactly how aftermarket CD changers were connected to the factory stereos in cars in the 90's, so it's good enough for a portable mp3 player.
it blows my mind that somebody back at hyundai didn't think it would make sense to offer a simple aux in jack on the front of the stereo like just about every other car manufacturer in the uniteds states does. or atleast ad another option on for a link like the accord. i mean how many units of mp3 players have to be sold in this country and worldwide before they catch on?!?! sorry just ranting.
Since the new Elantra will have aux inputs, it might be possible that the Sonata will also get aux inputs when the new stereos get here or at least by the 2008 models.
Opinions? comments? from current owners. I going to buy a new Camry, Accord, or Sonata but it's down to details like these.
How did you make out on this project? Do you have pinout info that you can share? Thanks!
if you do get it, i recommend getting it from crutchfield, it was atleast $50 less than best buy was off the bat, and you get the metra dash kit and wiring harness free. all in all it cost me about $130 for the install, but that was including the extra charges for adding pioneers aux-in adapter ($25), and a little custom work/drilling for the corresponding cable ($40 i think?). Which I later decided I didn't like and had them change where it was routed anyway. Lifetime guarantee on the installation, and they put the stock HU back in when I want to sell/trade-in for no extra charge.
Has anyone got the player to play in playlist order?
"What For"
"Any Time"
"Cheers"
Normally would play in alphabetical order (Any Time, Cheers, What For)
iTunes creates the CD with these titles:
"1 What For"
"2 Any Time"
"3 Cheers"
Which of course, is in both alphabetical AND playlist order :-)
Any responses would be helpful.
Good luck!
How good is the factory Infinity upgrade? Can I do a lot better on my own for cheaper and without making the dash look like crap? I know nothing about cars or stereos so I'm sure I'd get this professionally installed. I looked at Crutchfield and there are so many choices! I don't even know where to start... What would be comparable to the factory upgrade that could be cleanly installed? What would it cost to have it installed? Will I have to do without a subwoofer? I don't remember seeing one without the factory upgrade? Will I still be able to use the steering wheel audio controls?
Thanks for any help from a soon to be first time Hyundai owner!
The sound system *is* pretty nice. The subwoofer adds a lot of character to the sound. I don't know if the standard stereo comes with an equalizer, but this has one.
Considering the controls built into the steering wheel, and the fact that you would need to have to pay a pro to do the installation, it may be well worth your while to "test listen" to the packaged model first.
Things to consider:
1. What do you want the stereo to do?
2. Are you ok without having the steering wheel controls because if you change out to an aftermarket unit, you'll lose those controls unless you purchase another aftermarket box that will allow them to function with your new stereo?
3. Do you want XM, Sirius or HD radio? If so, aftermarket may be the right alternative for you to keep the dash clean looking.
4. Do you need an iPod/MP3 jack?
5. You WILL lose your factory sub!
6. You WILL need to rewire your speakers as your factory speakers are routed through a JBL amp in the rear of the car that the new aftermarket unit cannot utilize!
I have been installing car stereo's for almost 25 years and have dealt with Crutchfield on a personal level many times. They are great to deal with but will cost more than others on the Internet.
It's all about what you want or need and how you answer the questions above may help you make the best desision.
I hope this helps :shades:
The steering wheel controls were important. The stereo isn't all that convenient to reach where it's mounted, especially for my girlfriend.
I was interested in HD-Radio until I realized that a lot of radios were HD-ready but that it wasn't a standard feature like FM and AM.
I would like an AUX input but I've seen other posts that make me think that adding one wouldn't be too difficult.
~Mike
XM certainly has the capability to display more characters, so the car radio builders are at fault here. I also have XM on a Yamaha stereo receiver at home. It displays the full width of the artist and song title, you can make it scroll, you can freeze it, you can make it display the genre info like "Decades" or "Comedy" etc etc etc. That sort of proves to me that the XM signal carries all of the info; the vehicle mfrs. simply cheaped out and only default to the first ten characters.
jt
http://www.hyundai-forums.com/t14984-steering-wheel-controls.htm
http://www.hyundai-forums.com/t15490-2007-steering-wheel-control-retrofit-for-20- 06.htm
1- That was an Azera....is just as simple in the Sonata???
After reading further down the that forum, there's a link provided.... I think I might buy the Sonata NF version... (what does the NF stand for???)
Sorry if there was any confusion.
My Sonata is an '05, so it doesn't have any radio controls on the steering wheel. My partner just got an '07 Sonata 3 weeks ago and some of the radio controls are on the side of the steering wheel facing the instrument panel.
http://www.hyundai-forums.com/t14984-st-40-steering-wheel-controls.htm
