to me also. Easy DIY to check.
1- Locate the FPR
2- Start engine .let run. Turn off engine.
Pull vacuum line off nipple on FPR If wet with fuel (gas)
replace !!!!!!!!!!
More info at http://www.gm-trucks.com
Ed
At about 70-75 mph I feel hesitaion, like there's not enough gas, ignition bad, or transmission. It idles fine, has get up and go from a stop. Already replaced the fuel pump a while back. As I did with the spark plugs a few months ago, and just replaced the fuel filter, I just had to change my catalitic converters, at 105,000. I do have a lot of miles, but my truck has been good to me and I want to keep it a while.. I have done everything I know. I want some input before I take it in....
I have a bad vibration at highway speeds. I already changed shocks, Bilstein, rotated tires. It's bad when I hit the brakes, BUT, I already changed the pads and rotors. Dealer already looked at it once and said everything was "good". Does anyone have any ideas, before I take it in.... Please Help...
I talked with a guy I know who stated it is under the intake manifold.
I am happy to do this job myself, but I am just wondering if anyone out ther has personal experience with removing the intakes on the 5.3, and any helpful hints before I start the job.
WHY?
In model years '99 and '00 there is a TSB out for vibrations. It is not well known and only affects 2WD trucks with the rack and pinion. The reason I know about this is that I had my rack changed under warranty with the new rack and no vibration problems. The vibrations usually started around 40-45 and lasted till about 65-70. If this is what you are experiencing, I can post the TSB for you to take to the dealer. Course being out of warranty it will not be free or cheap to do.
Good luck
I took the truck to the dealer. I had 1 TOTALLY fouled spark plug and 2 CRACKED plugs!!!! They also replace the wires. That did the trick. A week later, I traded in for a new 2007 3/4 ton Silverado. Have someone check your plugs and wires. I had 69,000 miles at the time.
It is a bunch of BS. If you ever changed your own oil, you will be able to disprove that theory. The oil filter is full of oil when changing unless GM has found a way to change the laws of physics and gravity.
I had a tranny service, and the guy told me it was an ignition problem. So today I did the wires and plugs....problem solved too!!
I also changed my fuel filter....I have 314,000 km
thanks anyway
1offroader
I have the following,
2004
Chevy/Silverado
5.3L V8
65,000mi
Oil is allways changes, just changed the
gas filter, new battery etc..etc.
When driving fast or with foot on the peddle
the car is fine. When I drive very slow and
turn the car will stall and turn off.
This only happens when Im just about at a stop
then try and turn in any direction, the car
turns off. But it starts up just fine everytime.
Have no idea of what this could be, hopefully
this has happened to someone else.
J
I am hoping this will solve the overheating problem any further ideas......
My other problem is that the engine seems to be lacking in power, the distributor was installed and set up at top dead centre, should this be advanced, or will this make the overheating worse.
Anyone have any suggestions as to what this might be?
gregC
cjn
When its warm outside and im sitting at a stoplight with the truck in drive the idle fluctuates between 400-700 rpm. I took it to the dealer but he couldn't find any problems. This only happens when its warm/hot outside. It's been happening about 2 years. Also it starts great when its cold outside, but as the day warms up the starting gets harder.
I have had the fuel injection serviced, new fuel filter. Mechanic says plugs are firing good.
Any ideas?
