2007 Toyota Camry Problems and Repairs
1910121415106
  • nissanronnissanron Member Posts: 17
    Toyota has revealed interesting information about their new transmission in the V6 Camry. See Car and Driver, August 2006, pp. 82 & 83:
    "To smoothly deliver all this newfound power, we developed the Camry's new, available 6-speed automatic transmission.2 It's so well-conceived that it actually uses 30% fewer parts than the previous 5-speed automatic transmission. And fewer parts mean less weight and quicker response. Not to mention, greater fuel efficiency. Yes, for once, less really is more."
    Footnote 2 states: "V6 models only."
  • njeraldnjerald Member Posts: 689
    January 9, 2006 Toyota Press Release
    Harnessing this engine's output is an all-new six-speed automatic transmission that uses 21 percent fewer parts than the conventional five-speed automatic transmission it replaces. This new transmission, which can be shifted sequentially, relies upon a newly developed gear train that uses a Ravigneaux-type compound planetary gear for reduced size, weight and friction.
    This new transmission also uses a quick-response, low-friction clutch pack for enhanced fuel economy; an ultra-flat, low-inertia torque converter for high transmission efficiency; a set of high-response, low-slip clutch packs and new electronic and hydraulic control systems that incorporate an intelligent shift control that learns driver's driving style and selects gears based on that style.
    As a result of this development, transmission kickdown response was cut to 0.5 seconds, more than twice as fast as the response of the transmission this new one replaces.
    I'm interested to know more details of this article....
    Is it a comparo? How'd the Camry do?
    Also, njerald points out how Toyota relased that information as part of the press release... in January.
    ~alpha
  • roman73roman73 Member Posts: 8
    Hi Everyone,
    I was reading over the many posts in this discussion. Most of them, it seems, deal with poor construction of the transmissions in the V6 cars, so Toyota will replace the faulty part, or the car altogether with a new one that is better. however for the 4-cyl 5A Camry LE, it seems the hesitation problems are a "normal part of the car's performance". Which means get used to the bad hesitations and slow downs, or buy another car from another manufacturer. Am I getting this right? Or is there another solution to my transmission hesitation problem?
    Thanks for any help,
    Roman :confuse:
  • cortoncorton Member Posts: 53
    "Toyota's obligation under the factory warranty is only to correct the problem, if necessary by replacing the transmission. On the snap ring issue, Toyota chose to offer other options, including replacement of the car. This is their prerogative, and a nice gesture, but not a requirement.
    What do you think GM, Ford, DCX, or VW would have done under the same circumstances? (I say this as having been burned by 2 of these 4.)"
    It really does not matter what another manufacturer would do in this circumstance. We're only talking about Toyota here. Just because certain manufacturers do a poor job of taking care of their customers, does that mean that all manufacturers should follow suit and treat their customers poorly? No.
    Toyota set a precedent by offering customers with problems a certain deal. I have that problem. Why can't I get the same deal? It's that simple.
    It is so easy for Toyota to make this right, and they choose not to. Therefore, they do not earn any more of my business.
    It's customer service 101. Treat all customers fairly and with respect. Toyota did neither to me.
    We all know how warranties work. Factory warranties only go so far, and usually favor the manufacturer in most cases. That is why we have Lemon Laws in most states.
    My Camry is at the dealer for the 4th time for this problem. If they do not fix it on this service visit then it qualifies as a Lemon and they can buy it back and give me a complete refund.
  • jaxs1jaxs1 Member Posts: 2,697
    Yes, test drive the car well, paying attention to the way it shifts, and decide if you notice anything that you would find bothersome.
  • blackexv6blackexv6 Member Posts: 503
    A co-worker of mine is driving a brand new 2007 Camry LE 4cyl while his truck is being repaired. Since I am interested in buying one in the fall, I asked him how it drove. He said the car had a major hesitation problem & shifting was erratic.
    What is the problem with these cars? Is it the drive-by-wire software interface or a mechanical problem?
    I bought three Hondas with V6 tranny problems and I am not going down the road again.
  • austinman7austinman7 Member Posts: 313
    TMSUSA,
    "There have been more affected units than that original estimated number but still very low incidents given the production to date of this vehicle."
    Thanks for the reply -- that sounds reasonable. Since 160 isn't the number anymore, any chance Toyota can be more specific? Would "low incidents" mean twice that, to 320?
    I'm a former Camry XLE V6 owner (2002 model) shopping for another V6 sedan to replace my 4 cyl. Accord. Right now the '07 Camry LE V6 is probably my first choice. My test drives have been very impressive.
    If the snap ring issue could be given a more specific number, and if it's now a thing of the past, that would be reassuring, at least for this issue. The RPM spike issue, of course, is another matter. It's hard to know what to make of the chances of encountering that.
  • 210delray210delray Member Posts: 4,721
    Toyota set a precedent for taking care of the snap ring issue. That's your opinion. They do not have to do the same for the spiking (flare) problem.
    Good luck with your lemon law procedure.
    Now my question is, who's gonna get your future business? (Honda's had transmission issues too.)
  • motownusamotownusa Member Posts: 836
    If the transmission issue bothers you that much, you can always wait for the 08 model which should be out in about 6 months or so. I am sure your 04 Accord will hold up pretty well for another few months. I am on my 5th Toyota ( 03 Camry ) and all of them have been close to perfect.
  • ray_h1ray_h1 Member Posts: 1,134
    "As some here have noted, this was a particularly vexing early production problem, difficult for us to match specific vehicles with a transmission that might have the suspect components."
    I've been a Toyota apologist throughout this entire episode, and continue to maintain my faith in Toyota's integrity because I sincerely believe Toyota is making every effort to put this problem behind them. (To expand briefly, I am neither a satisfied nor dissatisfied 2007 Camry owner, but a reasonably satisfied 2003 Hyundai Sonata owner. I have no axe to grind either way over Toyota's acknowledged 6-sp transmission issue.) But, on the face of it, I cannot understand Toyota's professed inability to track transmissions to specific cars. It's been an established procedure for over forty years* to computer match virtually everything to a specific car on its build date - paint color, upholstery trim, engine, transmission, axle, etc. Given that all cars are subject to NHTSA recall in the event of a safety issue, it's inconceivable to this pilgrim that Toyota can't match early "vexing" problems to specific vehicles. I haven't changed my opinion of Toyota's quest for quality, but I can't help but believe Amercian consumers aren't getting the straight story. As always, I appreciate your continued input on this forum. To my knowledge, no other automaker is quasi-officially represented on any internet forum, and you continue to field questions in spite of inappropriate personal barbs. (About the only thing that hasn't been suggested concerning you is whether you have horns, a notched tail, and cloven hooves...;))
    *My dad bought the new Dodge "Dart" in 1960. At the time Chrysler was ballyhooing in its advertising how each car was computer scripted for every part that would go into it during assembly from the dealership-submitted order forms.
    "The RPM spike issue, of course, is another matter. It's hard to know what to make of the chances of encountering that."
    Would someone look up in their owner's manual whether Toyota is specifying a transmission fluid other than Toyota T-IV in these new 6-sp trannies? The thought occured to me that a factory flub-up may've resulted in the older T-IV fluid being installed in some trannies if Toyota's gone to a different ATF formulation. In the case of spiking RPMs, that might explain Toyota's blanket trannie replacement policy.
  • blindmantooblindmantoo Member Posts: 139
    "Would someone look up in their owner's manual whether Toyota is specifying a transmission fluid other than Toyota T-IV in these new 6-sp trannies? The thought occured to me that a factory flub-up may've resulted in the older T-IV fluid being installed in some trannies if Toyota's gone to a different ATF formulation. In the case of spiking RPMs, that might explain Toyota's blanket trannie replacement policy."
    The manual states "Toyota Genuine ATF Type WS".
    To quote:
    "Using automatic transmission fluid other than (above) may cause deterioration in shift quality, locking up of your transmission accompanied by vibration, and ultimately damage the automatic transmission of your vehicle"
  • alan_salan_s Member Posts: 362
    We all understand that cars are going to have problems. The main issue is not the problem themselves, but how the manufacturer handles the problem and responds to the customer which is of primary concern. Some manufacturers refuse to acknowledge problems and make customers go to extraordinary lengths to "prove" their case way beyond any reasonable doubt, and cause huge inconvenience to the customer before acknowledging or addressing an issue (if ever), perhaps in the hope that the customer will just go away so the manufacturer does not incur warranty costs. Reduced warranty costs means greater profit. Remember, the warranty cost is built into the price of the vehicle and you paid for it. If the manufacturer doesn't incur a charge against the warranty component, they make more money on the vehicle.
    If defects become apparent "in the field" which is inevitable, these should be addressed efficiently and courteously and herein lies the difference between manufacturers.
    A lemon-law attorney told me that he hardly ever gets a case regarding a Honda . He said Honda is very responsive to customer concerns and wants to discover the problems, get the customer happy and get the info back to engineering ASAP, while other manufacturers are not responsive and just push back.
    In my experience, getting Toyota to acknowledge a problem and do something about it almost calls for an act of Congress - or a class action lawsuit.
    If you get a good Toyota and don't need much beyond an oil change you have a great ownership experience. If you get a bad one then you are on your own. I've had both experiences with Toyota. Had I received help when I desperately needed it instead of being stonewalled, I would have looked beyond the problems and would still be a Toyota customer. I am now a Toyota and Lexus free zone.
    Sad, very sad.
  • eberfuleberful Member Posts: 1
    my wife and i just purchased our second camry, previous is a 99 that is now our "second" car which means it doesn't get to park in the garage any more. we have noticed a distinct an extremely unerving flat spot/hesitation when we try to accelerate or turn corners etc. this malady is particular spooky when we try to make a left turn against oncoming traffic since the car seems to decide when to go not the driver. we have had it to our las vegas dealer twice so far for this and a couple of other problems. the dealership folks are always nice but our service writer tells us that there is not a failure or repair issue with our car. he insists that the problem is inherent with all 07 camrys because the car has no throttle linkage, instead it has a sensor linked to the onboard computer. has anyone out there had a simmilar problem? if this is present in all 07 camry's ,toyota will be out of business in a year or two from all the accidents and subsequent lawsuits. this problem is really scary and we are now cursing our luck in that we can not afford to just "trade" it in for something else. we could sure use some advise.thanx!!
    Hi eberful,
    This is exactly what happens with my new 4-cyl 07 Camry. I get worried sometimes too when trying to accelerate ahead of oncoming traffic after a turn or slow-down, because of the hesitation. I was told by the salesman at the dealership where I purchased the car that the service dept should be able to tweak some setting on the car's computer to fix the problem, although from what you were told, I guess that's not correct. Thanks for writing your post and corroborating my experience with the 4-cyl 07 Camry.
    Roman
    "The manual states "Toyota Genuine ATF Type WS".
    To quote:
    'Using automatic transmission fluid other than (above) may cause deterioration in shift quality, locking up of your transmission accompanied by vibration, and ultimately damage the automatic transmission of your vehicle'"
    Thanks, blindmantoo. I believe if I were involved with a Camry transmission replacement, I'd be asking what specific type of Toyota transmission fluid was used to fill my replacement box. If the tech or the service manager indicated "Type IV", there'd definitely be grounds for additional discussion.
    Some may think that the throttle hesitation is due to the fact that it is drive-by-wire, and not directly connected to a throttle body, but...
    All electronic throttles do not share your issue (I have one in my car from the other team - Honda Accord EX that is flawless in the throttle dept.)...I wish you the best of luck in getting a fix promptly. For now, make sure you wear a seatbelt!
  • yorkdaneyorkdane Member Posts: 6
    Corton:
    I understand your frustration. I have been reading these posts since my transmission began slipping at around 2000 miles. (yep, ran perfect until then) Anyway, I encountered the same run-around, from the car is fine, to no it's not - let's reboot the computer, to finally - we realize there's a defect, but we don't have any way to fix it.
    Well, once I received the final response, it was suggested by Toyota that I go through arbitration, which I refused, because we aren't "arbitrating" anything. We all agree that they do not know how to fix the car. I proceeded to inform Toyota (this past Monday), that I had sought legal cousel, and was beginning the process under the Texas Lemon Law.
    Today, I went back to the dealership to obtain signatures on statements of the accounts over the past month, and was told the following:
    Toyota called them today and informed them that they have figured out another test for the car. The service dept. is to drive the car with a handheld computer, that will monitor the pressure involved with the transmission shifting. If the reading is a certain number (which according to the dealership, Toyota would not tell them what it was) my transmission would be replaced.
    Anyway, I'm bringing my car in tomorrow morning, and we'll see what happens. According to my attorney, since this is the 3rd visit, this is their last chance to get it right.
    Hang in there, Corton....if anything comes of this, I'll let all of you know. :mad:
  • kdhspyderkdhspyder Member Posts: 7,160
    You have been forewarned by postings in this forum. The transmissions in the V6's have a significant probability of having problems. Toyota needs to fix it and correct the problem for those of us who have it.
    This is your personal opinion but it is not based in fact. The fact is that the reported instances here are a very very small part of the total production. If they are in fact problems.
    The internet is a wonderful tool it can be used in so many ways.
    HUH???
    80%+ of all Camry's are built in KY. A small number of fully built Camry's, w/ NA parts, come from Japan.
    The actual percentages of affected vehicles will probably never be known, as it is to Toyota's benefit to keep that type of information secret. My research on this subject has shown a much higher percentage of affected vehicles than Toyota will ever admit. I've even come across posts on another forum from one owner who had his transmission replaced and had the replacement transmission fail also.
    Has Toyota acknowledged the transmission problem? Sort of. They said that only about 160 cars were affected and that the problem has been corrected. The facts are that vehicles are still coming in to service departments with these problems that were built long after Toyota said the problem had been found and corrected.
    Statements like this are baseless unless you have specific data on the 100,000+ '07's delivered already. Your opinion is noted though.
    I do understand that you may have an annoying issue with yours and for that I am sorry but blanket generalizations are always wrong.
    With the recent recalls, ongoing issues with other Toyota cars such as the Avalon, the engine sludge problem from a few years ago, and now problems with the new 6 speed auto transmission in the Camry, I think more and more people are starting to have second thoughts about Toyota's supposed "good quality and reputation".
    This surprises me in that you seem to have a very good handle on all the major issues involving Toyota products back into the 90's which you are using to 'threaten'(?), 'scare'(?) new buyers from the '07 Camry but despite all this knowledge you yourself went ahead ( hmmmmmm? ) and bought one. Curious.
  • aburdaburd Member Posts: 23
    Toyota owners probably spend more time worrying about Honda transmission failures than Honda owners do... take a look at DriveAccord.net to see how different the tone is in that discussion group....
    Curious... was yours a KY-made or Japanese-made unit? 4T.... or JT.....?
  • tinatinatinatina Member Posts: 388
    Thanks for that website, I will now keep it as a favorite. I do own a 2006 Accord after considering a 2007 Camry. The Tranny issue (non-issue?) in the Accord died down after the 2003 model, but this thread here is very interesting. So, I'm sure that people acted just as good or bad when they had the problem as some posters here and those affected with problems tranny could either praise or critize Honda or Toyota for their actions or inactions.
  • exploder750exploder750 Member Posts: 159
    T-ransmission
    O-ut
    Y-ou're
    O-ver
    T-o
    A-rbritration
    It's shameful to read about people suffering after having paid a premium for 'perfection'.
  • lzclzc Member Posts: 483
    >>HUH??
    Huh, what?
    I said that the origin of manufacture stickers I'd seen indicated the same percentage of North American parts no matter the country of assembly. Is that wrong?
    I also wondered about the economics of shipping parts from NA to Japan and shipped back again, and speculated that that would end when the Indiana assembly opened.
    You are correct that once the Indiana plant starts producing Camrys in sufficient numbers, the importation of Camrys from Japan will end.
    My experience was totally different:
    My former '97 Camry LE 4-cylinder was purchased new, and I did all of the oil and filter changes myself, except one. Until I had the problem described below, all oil changes were done every 5000 miles, which averaged out to 3+ times per year.
    At 57K miles (summer of 2000), the car developed blue smoke on cold startup. The problem was diagnosed as worn valve stem seals, which were replaced by the local Toyota dealer (not the dealer I had purchased the car from). At the same time, the head gasket was replaced, because coolant "seepage" onto the outside of the engine block was discovered. All work was done under the terms of the 5 year/60K powertrain warranty. The oil and filter was changed at the same time.
    I had receipts of most (not all) oil and filter purchases and a detailed handwritten maintenance log, so I got no flak -- zero -- from the dealer about negligence.
    Before the work started, the dealer said he'd check for sludge without me broaching the subject. (This was before Toyota publicly anknowledged the sludge problem and extended the engine warranty to 8 years with no mileage limit in case of sludge). My engine was determined to be "fairly clean."
    Was I happy that the car developed a major problem? No, but I was totally satisfied with the dealer's handling of the problem.
    And I never had a sludge problem, with the car being sold at 111K miles only because I wanted to get a newer Camry with side curtain airbags, NOT because the car had become unreliable.
  • ykangykang Member Posts: 88
    Just wondering.. Are you a representative of Toyota?
  • faldocfaldoc Member Posts: 84
    I had my transmission replaced at about 1950 miles and it had been doing well for the past 6 weeks or so till today at about 5950 miles, 4000 miles on the new transmision.
    Unfortunately it has developed a problem with what seems like the transmission going into neutral on medium acceleration in the middle gears, revs way high for a second or so, then it seems like it shifts and of course it lurches to the extent that the front tires chirp. It did this twice or 3 times today to varying degrees and the check engine light has come on. I am going to give Toyota Motor Sales a call tomorrow and have it serviced.
    This is like a recurring nightmare. I thought the problem was taken care of, and now this comes up in the new transmission. Not quite the same as the snap ring problem but a transmission problem none-the-less. :sick:
    "Unfortunately it has developed a problem with what seems like the transmission going into neutral on medium acceleration in the middle gears, revs way high for a second or so, then it seems like it shifts and of course it lurches to the extent that the front tires chirp. It did this twice or 3 times today to varying degrees and the check engine light has come on. I am going to give Toyota Motor Sales a call tomorrow and have it serviced.
    This is like a recurring nightmare. I thought the problem was taken care of, and now this comes up in the new transmission. Not quite the same as the snap ring problem but a transmission problem none-the-less. "
    I'm Sorry to hear that your replacement transmission also has problems. You've been stricken by the problem that the transmission in my Camry is being replaced for, what I call the RPM spike problem.
    You are the third one that I'm aware of that has had an original transmission replaced and the replacement is exhibiting the RPM spike problem.
    Unfortunately, for many of us, it is a recurring nightmare.
    I posted a couple of videos of my Camry exhibiting this RPM spiking. Take a look at the videos and tell us if your car is doing the same type of thing.
    The videos are at www.putfile.com/corton and they are in windows media format. Just click on the windows media logo to play them.
    "This is your personal opinion but it is not based in fact. The fact is that the reported instances here are a very very small part of the total production. If they are in fact problems.
    The internet is a wonderful tool it can be used in so many ways."
    Do you think that everyone who has a problem takes the time to search out this forum and post here. Not hardly.
    The truth is that we don't know what the "reported instances" were/are or what the percentages are because Toyota does not release that information.
  • filodfilod Member Posts: 189
    Faldoc, I am really sorry that the replacement transmission is having a problem too.
    I have always followed your postings, and have been inspired to take a positive approach about the snap problem with the way you were treated by Toyota. I was given the impression (by TMUSA) that the problem is occurring only on early production units.
    I t looks like the 6-speed transmission is a problem across the board (whether it is a snap or spike), now with even the replacements that came from Japan. We just do not know how many of those who do not even know the forums (much much more than us I guess) are experiencing these problems.
    I will not be surprised if a recall will be issued in the very near future (for those who already bought the car, hope soon). I have the feeling that Toyota does not have clue as to what is causing the snap as well as the spike problem.
    I wonder what TMUSA will say regarding what happened to you…I guess you have opt for the 100k warranty? Can you still change your mind and just get a new car? (Although replacing it with a new car is not a guaranty that the same problem will not occur).
    Right now, it really needs a lot from Toyota to heal what is being felt by those having these tranny problems.
    This is a big problem for Toyota.
  • jrock65jrock65 Member Posts: 1,371
    faldoc,
    Is your transmission a new transmission or a remanufactured one?
    Just as a point of reference, I brought this question up several months ago and was adamantly assured by TMSUSA that it would be a long time, maybe a year, before any remanufactured transmissions would be used as replacements in '07 Camrys. They would be all be brand new transmissions until then.
    I asked the question because they put a remanufactured transmission in my '04 Accord with 4,000 miles on the car. I discovered at the time that this is routine procedure for Honda and, I think, many other makes as well.
    Just a note of reassurance -- I know it's major surgery and some of you are justifiably nervous about a transmission replacement, but mine is at 23,000 miles now and performs flawlessly. It created no other issues with the car, at least none I'm aware of. The key for me was having the service manager take personal oversight of the "operation."
    You have 23k miles on a new Camry already? Not that I don't believe you, but that's an average of 6-8k / month (assuming you bought in March). Wow - how do you rack up that kind of mileage...
    Read the post, not the title.
    I imagine when their service / returns with failed transmissions gets to the point where they are spooled up to provide remanufactured units, that that's when a customer would get a remanufactured vs. a new unit.
    Didn't this vehicle get a newly designed transmission? If so, that means new internals and perhaps externals.
    I wouldn't worry too much about a remanufactured unit once the pipe turns them out. But, if the replacements are failing and if they are new, then maybe it's a bit premature to tell - maybe the design is being tweaked.
    Until the time they appear to have the situation well in hand, I suppose an owner should reasonably expect the manufacturer to minimally extend the warranty (in a major way) on the replacement transmission, and perhaps even on the entire vehicle, but also make payments on the vehicle for the month where it is in the shop more than say a few days. Someone should not have to pay for a vehicle they are not in possession of for any appreciable period of time.
    Also, if the hesitation or flairing issue is significant, the manufacturer should place in writing that it is safe to drive if they send you on your way indicating "it's operating as designed".
    I do not speak for Toyota in any way. Everything posted are my own opinions and observations. I have had 4 trouble free Camry's since 1989 with over 400,000 miles on them so I have a strong affinity for them since thy've served me well. As noted previously I will tend to cut Toyota some significant slack based on my own experiences with the vehicles.
    When there are production issues it has been my experience, and observation here, that Toyota has jumped right on the problem and solved it right away. The issue of the rpm spiking seems much less clear than the snap ring issue so I am awaiting more findings before forming a judgement.
    I just picked up my 07 Camry XLE V6/6sp AT after they replaced the automatic transmission to correct the poor shifting/RPM spike problem. The dealer told me that the problem was corrected.
    I pulled out on the street, accelerated lightly up to approximately 40 mph, and when the transmission attempted to shift from 3rd into 4th gear, it hung up again and the engine RPM's spiked up about 1000 RPM's until the transmission finally went into 4th gear.
    So replacing the transmission in my car did absolutely no good. The problem still exists.
    So it appears that Toyota does not really know what causes this problem.
    I too have followed your posts since you first brought the problem up on TN a while back. I am sorry that a new problem has arisen. I've found your postings to be balanced, complete and informative. I hope the issue is resolved soon.
    "I just picked up my 07 Camry after they replaced the transmission.
    I pulled out on the street, accelerated lightly up to approximately 40 mph, and when the transmission shifted into 4th gear, I got a 1000 RPM spike.
    So it appears that Toyota does not really know what causes this problem after all."
    Being the owner of a new V6SE I can only hope that Toyota has learned from your unfortunate experience w/ your new car. Possibly they can now rule out the tranny as the cause of the spike - good from the standpoint that it may eliminate a major component. Now we're all hoping that you & the others experiencing the "spike" will get get satisfactory resolution from Toyota. Personally, I'm a bit peeved that TMSUSA is not addressing this issue more openly.
    I really feel for you. I'm going through a similar, but nowhere near as serious experience w/ my '05 Odyssey.
  • mesquite57mesquite57 Member Posts: 59
    So replacing the transmission in my car did absolutely no good. The problem still exists. ... it appears that Toyota does not really know what causes this problem
    corton,
    Sorry to hear this bad news. But as I suspected, and as you stated (and I've stated earlier,) they are "shooting in the dark". A NEW transmission does not equal a GOOD transmission if they don't know what's going on.
    I will be doing an oral presentation as part of an upcoming mediation through the Nat'l Center for Dispute Settlement. I highly suspect that they are going to want to change my transmission also. I'm going to fight that. You are the second or third person that has had their transmission replaced with yet another defective one.
    I'm asking for a full refund justified by many of these postings at Edmunds and Toyotanation that indicate that Toyota doesn't understand this problem.
    The clock is ticking on executing my Lemon Law rights.
    If, possibly, it's not the tranny causing this issue, what are some other common threads for those experiencing the "spiking" issue?
    As a starter, do you all have stability/traction control?
  • frodo6frodo6 Member Posts: 16
    Does this spike in 1k RPMs also occur after you have been driving long enough to let the engine warm up?
    blindmantoo,
    Yes, it's my Accord that has the 23,000 miles on a remanufactured transmission. Sorry if that wasn't clear in my post.
    I have 0 miles on my possible new purchase, a V6 LE Camry. I'm shopping 6 cylinder sedans because I like that power underfoot, and the Camry's 268 are pretty sweet. My 4 cyl. Accord is about as good as it gets with a four-banger, but it's just not the same kind of power. I kind of got talked into giving a 4 cyl. a try, and 2.5 years later I'm ready for a change. Still a very good car, though.
    (I hit the wrong message to respond to -- this is going to njerald's message, but I meant it for blindmantoo. Long day.)
    blindmantoo?
    Gee...good questions...I have VSC with mine but these are questions that TOYOTA should be asking itself. After all, they designed it. There's also the ECT unit and its software (including the "Intelligent" learning software, transaxle compensation code, engine computer, .....
    My question is: Are they even looking at this problem or do they think we're a bunch of "whiners"?
  • explorerx4explorerx4 Member Posts: 20,975
    got nuked, but it was worth it, to stop the 'walks on water' posts.
    i found the 'tn' site through google and found the posts seemed to cross posted(pasted?) between here and there.
    i really hope noone has problems with their camrys, but they do happen.
    over the years, i have been an early adopter of many vehicles, and have experienced the 'released a bit too early' syndrome many times.
  • chikoochikoo Member Posts: 3,008
    "the transmission may have trouble figuring out what I want to do (since I clearly don't know, myself!). "
    This is why we should not have adaptive transmissions.
    It is better to build a transmission that works in its very own predictable manner. The human brain is very good at adapting(integrating) the transmissions' behaviour into his/her own driving habits.
    to solve a given equation, you need to keep(assume) one of the two variables a constant in order to arrive at an answer. How can you arrive at an answer with both(all) the variables changing simultaneously in anticpation of the other?
    This adaptive transmission will work the day humans become DUMB like dummies and start behaving in a predictable manner.
