I did not use my VC for seven days - it was just parked in the garage. When I attempted to start it, the battery was discharged. Does the electronic gagets on the vehicle discharge the battery that quickly. If necessary I will put a trickle charge on the battery when I am not expecting to use the car for several days. Does anyone know how many days a car will maintain sufficient charge to start the car -- many cars are parked for days at airports. etc. Thanks,
You either have a light left on or you have a problem somewhere. You should be able to leave your Veracruz parked for weeks if not months and still be able to start it.
Here's what I would do.......at night, get inside the back seat of the Veracruz and close all your doors and lock car with remote. Wait a couple of minutes and look in the rear cargo area and front seat area for a light that remains lit. Assuming you find nothing on I would then check for dark current(you may need the help of someone electrically experienced). What you do is disconnect the negative battery terminal and connect an ammeter in between the battery post and battery cable. I would expect to see a very small amount of current flow for only the radio clock....Something in the low milli-amp range. If you see something significantly higher you have something in the electrical system drawing current.
Of course it is always possible your problem is far simpler and you simply have a weak battery(which is easy to test for with a battery load tester).
Does the dual zone in VC Limited or any other SUV sold in US include ability to restrict AC flow to feet of front passenger while keeping AC flow on face/chest of driver or vice versa?
My wife has no tears in left eye secondary to 9 hour brain surgery five years ago to save her life. Result: she avoids breezes/air flow onto her face in car, because it causes pain in her eye and can introduce airborne dirt/specks onto eyeball surface which everyone else reading this message can wash off with an application of tears and a blink of an eyelid ..............on top of that, we've struggled 15 plus years with the garden variety "it's hot in here" "it's freezing in here" on interstate highway trips........ :mad:
have searched for answer and even asked salesperson last Wed in Nashville and have no definitive answer........
The Dual-Zone functionality in the Veracruz Limited has a 'Mode" button which selects where the airflow is directed, such as feet only, face and feet, feet and defrost, defrost only, etc. This "Mode" selection is SHARED by the driver and the front seat passenger. However, the upper level air ducts (2 each for the driver and front passenger) can each be independently turned on or off at will. This would permit you to select face and feet and still permit your wife to shut off the face level ducts on her side. Each person would still have independent temperature control for their side. This functionality is also available for the second row passengers who have a shared (but separate from the front) temperature control, but passengers there can also independently turn on or off their face level vents on each side.
I bought an AWD Limited with Saddle as a birthday surprise for my wife (her primary vehicle- was driving an Accord). She loves driving the VC. It's a refined pleasant ride. I hope your wife thinks so too. Good luck.
I just got back from a test drive of a Veracruz. Really nice!
My question is that I can't find any info on the corporate web site that explains the 4 wheel drive system. To add to my confusion, there is a button on the dash above your left knee that locks the 4 wheel drive system. I don't know if it is AWD all the time and when you push the button to lock, that it changes to true 4 wheel drive or if it is two wheel drive until you push the button, etc,etc. If some one could point me to a link that would be great. My salesman was so new he really wasn't much help. Thanks in advance. Jack
has anyone experienced a clunking noise when your veracruz downshifts between 20mph and 0mph. i noticed this more when it's cold ,but i don't think it should do it. i'll take it to the dealer when i get time. it's a 2007 v6 veracruz thanks Randy
haven't noticed a clunk but then again our Veracruz has only 75 miles.
It appears there is no way of checking Transmission fluid???? can anyone confirm this? I checked the manual and engine compartment....No dipstick for tranny found.
Just got back from a trip in this first snowstorm to hit the midwest this year. There's about 5 inches out, blowing and now ice and freezing rain. This thing (07 GLS AWD) handles phenomenally in the snow. The combination of AWD, ECS and Traction control make this one of the best handling snow vehicles I've ever driven. Wow, am I ever glad I bought this vehicle.
Hey rottencar.....are you by any chance a Toyota salesman that has lost a few deals to Hyundai?
Just curious....
I have had my VC for four months and think the quality and engineering is great. I have had no problems whatsoever.
Coming from a Lexus RX 300 and also having a Toyota 4Runner, I have a frame of reference and a basis for my opinion. Both are great cars, and not perfect. I would say that my VC stacks up very nicely to my RX 300 and then some even with the 350 at about $9K less.
Have you heard about the oil foaming/sludge problem on Toyota and Lexus engines? THAT to me is far more serious risk/defect than a downshifting thump or a keyless entry that activates in your pocket. They had to extend the warranty on the engines due to that very problem.
According to Korean website similar to this site, VC is all time AWD.
Basically, if you don't push the buttion to lock, VC automatically controls distribution of power between rear wheel and front wheel in accordance with road conditon. I remember that maximum ratio is 50(rear):50(front) and minimum is 10(rear):90(front)
However, If you push the button to lock, VC maintains distribution of power between rear wheel and front wheel as 50:50 until its speed goes up to around 30 miles but if its speed exceeds 30 miles, the lock is automatically released and VC automatically controls the distribution again.
The JTEKT system is supposed to offer "more sensitive and accurate control for all driving conditions. Due to tighter tolerances, the need for a Steering Angle Sensor was eliminated. Updated control module logic was used, and the hardware was reinforced for better performance and durability." Seeing as how the Veracruz is basically a stretched, more refined and upmarket Santa Fe with a larger engine, it would seem that Hyundai didn't think that the BW unit met its NVH requirements so went with the Japanese.
I've had several opportunities to run my VC through the snow in some pretty severe conditions over the last 2 weeks and it's nothing short of outstanding. My last AWD vehicle was a Honda CRV which I thought was terrible in the snow. In that vehicle you could easily detect when the AWD engaged as the front wheels had to slip before the rear kicked in. In the VC you never notice anything and it just walks right through the snow. The ESC is great too. Very sophisticated system. The wife has Stabilitrak in her Vibe, which is good, but it's nothing compared to the system in the VC. Hyundai really has a winner here. I'm extremely happy with it. 10K miles and no problems to speak of yet.
I am 6'1" tall and I too have the same problem. I purchased the VC GLS (cloth manual seats) in July '07. We only have 5000 miles on it and I absolutely hate the driver seat position. Unfortunately, when we went to first buy it, our local dealer had no other VC models in stock. I so wish I bought the power seat option.
I am completely unable to find a position that is comfortable, except by pumping the seat all the way down. Even then, my legs and thighs are way out front of the seat.
I called Hyundai consumer affairs and they would not do anything because, as my service advisor said, the seat is operating as designed. I would even pay to have the seat swapped for the power one, but they would not do it.
I am very, very close to trading this in for another non-hyundai vehicle. The difficult thing is that the car is for my wife and she likes it. SHe only wishes I bought her the Lexus RX model, but we do not have the cash.
I am 6'1" tall and I have had a touch time with adjusting my front driver seat position. I purchased the VC GLS (cloth manual seats) in July '07. We only have 5000 miles on it and I absolutely hate the driver seat position. Unfortunately, when we went to first buy it, our local dealer had no other VC models in stock.
I am completely unable to find a position that is comfortable, except by pumping the seat all the way down. Even then, my legs and thighs are way out front of the seat. I always feel that I am sliding forward.
I am very, very close to trading this in for another non-hyundai vehicle. The difficult thing is that the car is for my wife and she likes it. SHe only wishes I bought her the Lexus RX model, but we do not have the cash for anything like that.
I have a 2007 VC limited and had to bring my car twice to the dealer because a thug sound (like the traction control kicks in and giving a locking feeling) when I downshift around 15mph. I was told then that it was just normal because of the type of engine for this vehicle. Did you have the same experience from the dealer? Is there anyone out there having the same experience....Thanks ////////Ford
All due respect, this isn't an issue with the VC. The seats are working as designed and you elected to purchase a vehicle from the inventory available in July rather than wait until a model with the options you really wanted (power seats) was available or could be located for you.
If this is primarily your wife's vehicle, how does SHE like the seats? That would seem to me to be the question.
You can find a used RX 350/330/300 for about what you paid for your VC GLS new. Shop around more with your next purchase and I'm sure things will work out better.
Kevanriese, I decided to raise the front of my seat by adding 3 large nuts between the floor and the seat frame. I can't remember the size of the nuts, but I made sure that they were big enough to slide over the bolt without having to worry about the thread pitch.
I could still use another bolt's worth of height, but could not fit it because the mounting bolt would not align with the hole in the floor at the correct angle to engage the threads without stripping.
It's not ideal, but it has kept my sciatic nerve from acting up too much.
Even with the power seat, I still feel the driving position is too high and I am only 5'11". At first I thought the seat was broken because it appears the seat should go down even furthur. I have gotten used to it but at 6'1, you must have a hard time with visability.
Hi, I have one with power seat, but I have the exactly same problem that you have. I am only 5'10 but I was totally unable to find a comfort driving position. I tried all kind of cushion, none of them worked.
Your experience of adjusting the mounting nut is eye opening for me. For me, the problem is the front end of the butt cushion is too high. I could either raise the rear end by putting more nut or lower the front end by removing some.
I am wondering where do you get the intruction on how to do this or you just did intuitively. Any input will be grateful.
hoo320, i just came up with this idea myself. I cannot guarantee that this mod is completely safe, as there may be some impact on the stability of the seat frame if you are in an accident.
On ebay there is a 2008 model with navigation. Looks nice. No CD changer or rear seat dvd player. It does however play DVD movies in park. Comes with the 605w Infinity Logic7 stereo. The rear seat DVD package also comes with it. The navi system has radio info on FM. Of course you get XM. No backup camera and integrated bluetooth. Thats a port installed option. No navtraffic as well. A nice unit none the less.
I just bought a 2008 Limited with the navigation system, and I'm extremely happy with this vehicle.
I have a Cadillac CTS, which is a very good car, but I need more visibility, cargo room, and comfort for my back, so I test drove quite a few CUVs/SUVs in a search for the vehicle which suits my needs..
After weeks of internet and in-person shopping, my decision came down to the Lexus RX350 and the Veracruz.
After comparing both vehicles feature for feature, I chose the Veracruz. It has been in my driveway for two days now, and several neighbors have come over to look at it.
The response is generally along the lines of "That's a Hyundai???"
I took some of them for a drive in it, and they were highly impressed with the quietness, the smooth ride, the features, etc.
Aside from the obvious delight I take in the Veracruz and my neighbors' appreciation of its features, I'm extremely pleased with the dealership.
I live 35 miles from the dealership, and the service manager and salesman drove that distance (and back to the dealership) to help me get my new Veracruz home.
I didn't trade my Cadillac, and I'm a single woman who didn't take a buddy with me to the dealership. Thus, without my asking, the sales manager offered to have the two men help me get across the bay back to my home in Baldwin County, AL.
In addition to getting a good deal on the car, the dealer also filled my gas tank. How's that for service?
I have a 2007 GLS (love it!) with KUMHO 798 Plus tires. I live in the midwest and these tires suck on ice and wet snow! I have been stuck several times this winter. Has anyone with these tires experienced this. I'm thinking about replacing the tires but they only have 4000 miles on them and I hate the idea of the extra expense. What kind of tractions are other owners getting? Do you have a different brand on your VC?
The tranny is computer controlled thats why it down shifts its kind of odd but does not seem to effect mpg
You can have the dealer program the door locks to open all doors when the drivers door is unlocked or conversly lock them. I'm not sure if the key fob can be programmed this way through.
Yesterday we had the heaviest snowfall in 20 years, 16" in blizzard whiteout conditions. I was responsible for picking up our medical staff. The VC performed flawlessly and the tires were no problem. I was actually a bit surprised they performed as good as they did. Today I had a lot of vibration on the highway but it turned out to be snow in the wheels causing the "imbalance". It quickly went away when the snow melted. Can't say enough about the vehicle. Most of the staff I carried marveled at how it performed as well. They couldn't believe it was a Hyundai.
What brand of tire do you have on your VC. The KUMHO's are not doing it for me on ice. Snows not a problem but we get a lot of snow that melts then freezes then it snows on top of that making driving a bit tricky. Thank goodness for the auto stick!
I bought a new VC in Feb. and just had to have the fuel pump replaced along with my steering wheel fixed due to a grinding sound. I mentioned I had to crank up the engine to get it started and that wasn't like that when I bought 3 mos. ago. I noticed it after 2 mos. They mentioned that there was a problem with a some VC's made at a certain plant that they had fuel pump problems with, but didn't tell me the plant. Did you notice the MPG improved after it was replaced. I only get 15.7 on the average mostly around town.
Does anyone know if the veracruz has that electronic throttle linkage ( which I know nothing about ). There doesn't seem to be an immediate response when I press the accelerator but just a (very short) delay. I think I read somewhere that that was characteristic of the electronic throttle linkage. Anybody got any info?????
Hey folks. My wife & I are looking at SUV's and have it narrowed down to two. The Nissan Murano and the VeraCruz. Does anyone know when Hyandai will add the back up camera to the Veracruz? My wife really likes the feature, but as far as we can tell, it has not been added yet. But, we hear about it!
Just found out Yesterday (drove my Limited 08 VC home on Friday two days ago) that when I press the ESC Off button, the icon will not illuminate where it is suppose to illuminate.
Though I do hear a click whenever I press the ESC off button. Is that normal?
When I start the engine, both ESC - ESC Off illuminates as normal.
I just passed 27K mi. on my 07 VC GLS AWD and it's doing great. Had several long trips from WI to FL and WI to UT. Avg. mileage on those trips was about 25 mpg, usually with a full load and going speed limit or slightly above. Most recent "issue" was a seat track that needed to be replaced on the drivers seat. Other than that it's been a joy to have and drive. It's just a great vehicle, plain and simple.
Craig
I'm over 6' and thought I could find a comfortable position with my manual seat, but after a week I've decided i need a power seat.
Anyone know of where/how i might find a used one? Anyone want to trade a power seat for a manual one???? Tee hee...
Tx
John in Nashville
is adding aftermarket xenon kit for headlights on new Veracruz a recipe for trouble/voiding a warranty?? Thanks.
thanks Randy
Craig
It is not the same system as the Santa Fe uses, which is a Borg Warner.
http://www.jtekt.co.jp/e/products/drive02.html
Just curious....
http://www.consumeraffairs.com/automotive/lexus.html
Even the "big boys" have their problems....and, nothing is perfect.
Here's the intro:
Long-Term Test: 2008 Hyundai Veracruz SE AWD
http://www.hyundai-blog.com/index.php/kelley-blue-book-named-the-2008-hyundai-ve- racruz-to-its-list-of-best-new-family-vehicles/
Disgruntled winter driver
Personally I'd invest a set of dedicated snows and rims if you drive in snow often and save the OEM's for summer use.
The midsize SUV segment featured the most Top Safety Pick vehicles, including the Hyundai Veracruz.
editorial.autos.msn.com/article.aspx?cp-documentid=435432&page=2
Any and all help on this would be appreciated.
Dave
I am bringing it to the dealer today.
ESC Off indication is shown when pressed.
