Do you currently own a 2019 or newer RAM pickup? A reporter would like to speak with you. Please reach out to [email protected] by 1/27 for more info.
Chevy Blazer/GMC Jimmy
Just wanted to let all the readers know that I
leased my Blazer 2 years ago. I put over 46K on it
already, and not ONE problem yet. The brakes are
still good! Unbelievable!! This is a great truck.
I recommend buying the Blazer. I am going to
purchase one soon.
purchase one soon.
Just goes to show, 46K miles without a problem isn't necessarily a trend...
No tranny problems, and the truck just turned 40K miles.
Oh yes, my alternator and the belt tensioner developed a squealing bearing at 25K miles, so they were replaced under warranty. My '93 Grand Prix had an alternator let go electrically at 36K miles.
My advice: if you own a GM, odds are good you'll replace an alternator at least once before 100K miles. Replace it with a remanufactured aftermarket (quality) alternator, NOT a GM re-man!
I'm going to push another six months on the front end, but it's shot. I need to do the whole works. The good thing is that the old models are easy to work on and parts are cheap. But if you can't do the work yourself, the Blazer is definitely a rather expensive truck to upkeep.
I'd check www.tirerack.com for an AT tire (Michelin & Dunlop come to mind). You probably want the LT rather than the P series tire - gives you better load capability (stiffer sidewall) and 1 or 2 more plys.
It seems the seal on the top of the dipstick is poorly designed; it allows water to get into the tube, and thus, the transmission. The source of the water can be from the passenger windshield washer nozzle/plumbing, or the water leaking past the nozzle seal. The trans dipstick is located right below!
So it's two-fold - water drips into the tranny through the dipstick seal, and the rest of the water corrodes the outsie of the tube. Check the '97 Blazer forum for more instances of this problem.
I would fight the warranty company on this one. As a design flaw, you shouldn't pay to replace the tranny.
Im ready to "lemon law" it!!!
I was wondering if you could maybe help me out, my 1997 Blazer has a problem with its front wipers. The wipers work fine all the time except when we need them, they work almost all of the time but once in a while they go totally dead, including the washers. This has happened 5 times this year almost always when it starts to rain, I have been able to start the wipers by manually pulling on the arm from outside the vehicle and then they work fine, could this be the control module?
If it is the control module where is it located and what is the best way to replace it?
Thank You
Also is there a recall on this problem Thanks again
HAVE A BUT IN THERE CHEVY. CHEVY NEEDS TO LEARN HO
TO MAKE A BLAZER CORRECT. I WAS DRIVING DOWN THE
ROAD AND MY TRUCK TEMP WHEN UP TO 260 AND IT IS
NORMALY AT ROUND 210(RIGHT) WELL I TOOK IT IN TO A
GOODYEAR, AND I WAS WATCHING THEY WORK ON IT. I
DECIDED TO CHECK MY RADIATOR AND GUESS WHAT I
FOUND. MUDD NO WATER JUST WAT MUDD!! SO PISSED OF
I CALLED CHEVY AND THEY SAID IT'S A COMMON
PROBLEM. HERE'S HOW IT HAPPENS. RADIATOR FUILD
NEEDS TO BE CHANGE EVERY 2YEAR. I SAID OK FINE, BUT YOU HAVE TO USE THE SAME LIKED OR FUILD EVERY TIME OR THIS WILL HAPPEN, UNLESS YOU GET A 19.95 BOTTLE OF CLEANER EVERY TIME YOU CHANGE FUILD (2YEARS)NOW HOW MANY PEOPLE KNEW THAT! AND HOW THE HELL AMI GOING TO TELL WHAT KIND(BRAND)SOMEONE PUT IN MY TRUCK IF I BROUGHT IT USED OR IF I GET A SHOP TO CHANGED IT. SO I HAD TO GET A NEW RADIATOR AND $368
CHEVY DEARLSHIP(JERKS) AND BUT BEFORE THAT CHEVY
SAID LETS TRY TO FLUSH IT x2 SO I PAID $222.03 TO
FLUSH IT TWICE AND THEN THEY TELL ME THAT IT NOT
GOING TO WORK, BUT I HAVE TO PAY FOR THE
FLUSHES.(JERKS)AND I NEED A NEW RADIATOR. AND THAT
$368 THAT THE COST OF THE PART NOT THE LABOR. I
HAVE HAD THE OTHER PROBLEMS THAT OTHER PEOPLE TALK
ABOUT TOO.DIPSTICK AND O2CIN AND WINDSHEILD WIPER
MOTOR, AND RUST UNDER THE SEAT. THE A/C DOESN'T
WORK AND I'M NOT FITING THAT UNTIL SUMMER I JUST
PAID $745 DOLLOR TO GET THE DAMN THING ON THE ROAD.I PUT OVER 3,000 DOLLORS INTOP MY TRUCK NOT IN REPLACING PARTS BUT MAKING IT A NICE
TRUCK,TINT,STERIO SYSTEM, REMOTE SARTER, RUNNING
BOARDS, AND EXHAUST AND MUCH MORE. I'M 20 YEARS OLD AND SPENT ALL THAT MONEY TO HAVE A NICE TRUCK ANDI'M STARTING TO THINK I SHOULD OF SPENT 16,000
DOLLORS ON A DIFFRENT SUV AND THEN PUT THE 3000 OR
SOME DOLLORS INTO IT.I LIKE THE LOOK OF THE BLAZER,BUT NOT THEN IT COMES OUT OF MY POCKET. THE
DEALER CALLED IT MISSIPPISSI MUDD IN MY RADIATOR. I LIVE IN VIRGINIA NOT THERE. IF ANYONE HAS HAD
PROBLEMS LIKE THIS PLEASE E-MAIL ME
@[email protected].COM OR [email protected]
WE CAN TALK ABOUT THE PROBLEMS WITH THE BALZERS
AND MAYBE SAVE SOME MONEY.
On the other hand my 98 LS 4door has put me in the dealer waiting room a couple times. At a little under 10,000 miles I had it in to replace some axle bearings.
Just at 36,000 (ok a little over but the dealer was good to me) the alternator left me stranded in the grocery store parking lot.
Then at 39,000 after some highway driving the transmission would slip and shift really hard. Yep they rebuilt the trans. Luckily I did purchase the extended warranty for the drive train(still had a $250 deductable). I wish I would have gotten the full 60month warranty.
Now a few weeks ago and sitting at 45,000miles, Chicago got that 16inches of snow and I'm crawling to work pushing the 4x4 button and the back end is still coming around. NO 4WHEEL DRIVE!!!!! So I'm thinking its from the trans rebuild. Dealer comes back with "the battery wore away a vacuum hose for the 4x4 solenoid." But how can I complain when I leave the dealer and the bill is under $100?
Oh I forgot about the lumbar support that when I was adjusting popped and doesn't move anymore.
And what's up with the 95mph governer? Is someone really trying to corner one of these things at 100mph?
Don't get me wrong, I love this truck. I could go on and on about how this is a great truck, but what happened to reliability?
I have driven both probably have drove the 87 more than the 2000.
87 was a 2wd 2 door 2.7L factory ordered back in 1987. Truck was great first month there was a hose recall (we broke down and had to be towed) but never had a problem after that. It was only in for some minor rust fixing in the late 90's. Truck was solid and we sold it for $1500 early this past summer. I see this truck everyday at school and its still running with 120,000 some miles on it when we sold it.
2000 is an LT 4wd 4 door with about 11K miles. Not a bad suv. It has its pros (4wd, more gadgets,4 doors easier entry exit, sunroof, leather better engine 4.3) and its cons (not as solid seems weaker, doubt it will last 13+ years like the 87 has) over the 87 blazer. The 2000 has been in the shop 3 times. Twice for alignment which was corrected after about the first 2 months and last month a front diff seal was leaking which is now fixed.
I personally would take the strong feeling of the 87 and combine that with the 4wd, 4 dr, and gadgets of the 2000 and it would be a perfect truck.
89N98 i know what you were going through with the snow. I live in indiana and we got a bunch supposed to get more tonight. I think my silverado handles alot better over the blazer in snow (weight wise more than likely)
Ryan
Looking at a Pewter 98 LS 4 Door with 40,000 miles on it. Dealer price $18,000. What is a good price to hit him with? What problems should I look for? Do I gain anything appreciable other than cosmetics by going to a '99? This one has the 5 spoke wheels with worn 235/70R15 tires. What are the biggest tires I can put on these? Can I get 245/75R15 or 255/75R15? How about 30X9.50 or 31X10.50 tires? Do I need a lift kit to mount these? Are lift kits available? I plan on doing some exploring this winter and summer, and want some good clearance. Also, anyone have experience with aftermarket header/exhaust/chip for power/mileage/reliability improvements? Thanks in advance.
Good luck on the mod's, I have no idea. I'm just as happy when my two run
Good luck!
Drew
Vans, SUVs, and Aftermarket and Accessories message boards
Make no mistake, SUVs are not to be driven like sport cars, or sporty sedans for that matter.
Any help?
Mike
_____________________________________________
(1) With driver door closed, hold down power unlock button on door panel (and hold down until step #6)
(2) Turn ignition switch on
(3) Turn ignition switch off
(4) Turn ignition switch on
(5) Turn ignition switch off
(6) Release power door unlock on door panel; the remote receiver will respond by locking the doors and then unlocking them.
(7) Hold down the lock and unlock button on the remote transmitter until the receiver responds by locking and then unlocking the doors (about 7 seconds typically).
(8) Repeat step #7 for each additional transmitter that is to be used with the vehicle
(9) Turn ignition switch on to exit transmitter programming mode. Note that previously programmed transmitters will be deactivated after the programming procedure.
In addition...have you seen the crash tests? Pleeze! Put some pressure on Chevy to redesign this 'death trap' body style. Chevy has lost its edge in the SUV market...big time! Too bad too. Don't buy one... Admittedly they've got some neat bells and whistles...but it's only mirage.
Brandon Morgan
Can someone tell me if there is any hope of a recall on the encoder problem? Another message referenced other people having problems with the 4WD.
I can't get rid of this vehicle soon enough. Buy American again? Maybe, but not Chevy or GMC.
Steve
[email protected]
Original message:
I was thinking of putting together a petition towards a recall of the oil cooling lines, since it seems so many have had this problem. I have created an email address: [email protected] I would like to get one-hundred (100) emails first showing interest in this before I formulate and pass one around. If interested, please send just a short email to that address.
Brandon Morgan
'95 Jimmy
The mechanic told me that the EGR valve needs to be replaced, ok. fine. Then he hands me the estimate. $400+ to replace and install (oh and this included the system check for $78.00 what a deal...NOT). Not today, I told him and had him slap it back together. I wanted a second opinion before jumping into the EGR nightmare that seems common in the Jimmy and Blazer models. I drove away and the SES light was off, nice. The vehicle was running good and everthing seemed o.k.
Well, it has been driven 400 miles since then and everythings appears to be fine. My guess is that the mechanic in the process of taking out the EGR valve nocked out some build up or something. He then reset the computer and presto, wamo good as new. I still feel sceptical though and wonder if this is just a tempory fix (it probably is who are we trying to kid here). Anyways I just thought I add this to the lists of SES and EGR stories and chalk this one up for the good guys (that if there is a good side). The Jimmy has been good to me other than this. With 137,000 miles it still strong and has alot left to offer, I hope. Hang tuff everyone and don't let the man get ya down...peace out.
That's really BAD service... my Olds dealer for my '97 Bravada has been much better... maybe it is time for a different dealer?
THANKS IN ADVANCE HANK
Why did this happen? I keep a close eye on the oil pressure & everything, and it never got crazy high. Hopefully, it was just a defective high-pressure hose. Otherwise, Mr. Chevrolet's going to have to give me a heckuva good reason to keep it. Thankfully, its still under warranty.
