We have a Ford F-250 Super Duty 6.0 Turbo Diesel Crew Cab Lariet Short Bed with Towing Pkg 87K miles that we used to tow a 25' trailer. When towing uphill, even on minimal grades the engine makes a barking noise, or a chugging noise like a fan blade hitting a shroud. But it's not that simple. If you increase speed it goes away. This only happens when towing uphill at 50 - 57 mph on any grade hill. Increasing speed or entering the hill at a higher rate of speed makes it go away or not happen at all. This is not related to Turbo whine, it doesn't sound at all like that. Last Fall we had the EGR Cooler and Head Gaskets replaced and had studs installed instead of the bolts that caused the head gasket leak. Fortunately the repairs, except for the studs, were covered under the 5 yr 100k warranty. I don't think that repair has any bearing on the 'barking' noise we are hearing. Does anyone have any idea what causes this? And is there any way to stop it?
i have f-250 7.2 power stroke. love it. on cool mornings it starts fine. a little white smoke for maybe 1min. but once she warms up she starts missing & loses a lot of power. have changed oil&filter, air filter, cps,& fuel filter,added injector cleaner to fuel. none of these things has helped. what next??? any suggestions will be appreciated. thanks,jim405
Although I didn't have the same problem as yours, here is what helped me that I would never thought of. There are some electrical plugs under the valve covers that the dealer finally figured out was the cause of my problem (on my 2000 7.3 L). They cleaned and reseated them and problem solved. However it is not guite so easy to get at them so it cost a little. Maybe that will help you. Ask someone knowledgable to see if these plugs may contribute to your problem. Let us know what you finally did to fix it.
Have a 2004 350 powerstroke diesel 6. dies when on and parked. blows black smoke from tailpipe when driving stalls from time to time .Does any one know what the problem is? Help
thanks for the info rodesigner. i'll give this a look. i've read all these posts and they have given me hope.now to find a good and honest mechanic. thanks again. will let you know what happens
I need some advice-this is probably the 6th issues I've had with this truck since I got it, and $8,000 later I'm getting a bit discouraged.
I had replaced the EGR cooler and the Oil cooler when I did the heads on this thing. It runs like a Bear. but now I'm getting the tempeture to go up and down all the time. It runs about 194 degrees and then it will run up to 220 or sometimes even 230, but then it will cool right down to 180. Even if I'm climbing a hill it will go to 230 then cool right down to 180 while Im still going up the hill. I think it use to run about 188 to 190 before I put a bigger turbo on it a few months back.
I put a new Thermostat in, because it was cheap and easy, but no luck. I was going to try a water pump next then maybe a fan clutch. Or should I just take it to the Ford garage and let them tell me what it is?
Have a 99' 7.3 that will boost up to about 20psi and then fall down and loose power with or without the power chip. Have changed the IDM, left bank fuel injector harness, and the exhaust back pressure sensor. Any help with this would be great.
Okay it's finally done, lol. Will it was not totally easy but with basic auto tools I have changed out the O-Rings my 7.3. The problems I was having before hand where No Start after sitting for for a few days when it's 60 plus at night or it fell below 60. Pretty sad when I had to Plug it in during the summer time, lol. Also with out plugging it in you talk about smoke and running a rough till it warmed up oh YEAH it would, lol. When driving down the road and starting up a hill I had to push down on the throttle a lot more than the other 5 - 7.3's I had and it seemed to drag almost acting like it was going to stall if I didn't push it down enough to shift down or almost to the floor. The last thing is once I had close to 2000 miles on the Oil I would have to plug it again, I usually change my oil between 2500 n 3000 miles.
Now when I first got the truck Ford did tell me because of the Oil Pan being pushed up an inch ( whoever had it before tried to run over something or wrecked it, bought it from auction so I don't know ) that the oil could not be picked up fast enough for the High Pressure Oil systems these 7.3's have to run the Injectors and that the Starter was a little weak. Well I have not changed out the Oil Pan only because you pretty much have to pull the motor as most of you know but I have put in 2 Starters in the last 4 years going for my 3rd soon, lol.
Now since I have changed the O-Rings I have very good news to report, the past few days it's been dropping below 40 at night and it starts right up without it being plugged in ( doing the happy dance, lol ), it doesn't smoke and idles smooth from the moment it starts, cruises down the road much better and up the same hills it purr's up them much much better. All that with the same Oil as I am going to wait until I get the full 2500 to 3000 miles on it, I am at about 1800 on it now. It still doesn't start as fast as my others seem to use to do but like I said I am needing another Starter as this one seems to be dragging just a little and I have still not changed the Oil Pan. As soon as I can find a garage to borrow the Oil Pan is getting changed out or pour me a Concrete pad for the Engine Hoist, lol.
If someone is needing to do this to their 7.3 let me know as there are a couple tricks I found while changing them to make it easier and the tools you will need and what will happen afterwards once you try to re start it, thats a lot of fun, lol.
The O-Rings on the Injectors, our Ford Diesel's use a High Pressure Oil System, if Oil gets by the O-Rings on the Injector what I had worte before those are some of the problems you may be having. If the O-Rings are bad enough it won't even start.
i have just purchased a f250 6.0 2005 with 150k have had it for two weeks and love it so far .the only thing i can see is when the engine is under a load at about 40 to 70 mph truck starts to vibrate.where do i start looking?
took my truck to a local diesel mechanic. loose plugs under valve cover which caused burnt pins for 1 injector&2 glow plugs. fixed that problem. started truck. idealed fine but, when he gave it fuel it bogged & black smoke rolled out of exhaust pipe.thats the latest. will post any new developments or progress. jim
After sitting over night, my truck won't start unless it's hot outside but when plugged in, it starts right up. Any one have any ideas? I'd appreciate any help. Thanks!
I had a problem similar to this with my '99 F350. The glow plug relay had stuck closed. That had caused the four glow plugs it sourced to burn out completely. I had to replace all of the glow plugs after replacing the glow plug relay. You can test the resistance of the glow plugs to make sure they are bad before replacing. I think the resistance of the glow plugs on my is around 5 Ohms for good glow plugs. You will have to check around to get the real answer as I don't remember the exact resistance you should see. After replacing my glow plugs, my truck started in below zero weather without needing plugged in. Good luck.
Ours turned out to be the after market alarm system. The brain had gone bad and intermittantly wouldn't letthe truck start. When we wired the alarm back out of the loop there were no more problems
gol my truck back a few days ago. runs fine. problem was just the plugs on the valve cover gaskit and one male plug under the valve cover.contacts burned because of loose connection. thanks again for the help. jim
Have a 1999 F250 Lariat. On startup (warm and cold) and for a mile or two there is a lot of smoke. It is definately diesel not oil. I have done the following over the pass couple of months. Replaced the MAP sensor, 5 of 8 injectors, and had a compression test by Ford (everything came back fine). I plan on replacing the three remaining injectors next month when annuity check comes in. Is there anything else that can be causing this problem? Your help would be appreciated. :confuse:
Hi, I have a 1997 7.3 Diesel F-350 crew cab truck. I have a problem with it. At times it will die out while i am driving and won't start back up. The "wait to start" will flicker inconsistently and the second relay on the driverside under the hood clicks with the flickering of the light. In this relay area there are four relays that are all the same so i changed them around and the relay second to the way still clicks. Also, while this is happening there is a click in the engine on the passengar side top end which clicks but not as often and last there is a solenoid which when clicks, the engine wait to start engine light blicks twice and is ready to start. I did have the camshaft sensor changed with Ford dealership so it's not that.
Guess I should have ask what color of Smoke, Black it good, Blue usually means oil is getting into your Exhaust and White the Turbo is starting to wear out.
I am a shade tree mechanic and definitely not a diesel mechanic although I have worked on my 2004 6.0L more than a few times. I thought white smoke meant that there was coolant leaking into the combustion chamber? oil coover ? or EGR cooler? These are typical failure points. I have a turbo boost gauge on my truck and it is not difficult to check the turbo boost and either it is boosting or not. Any mechanic should be able to easily check that out. Or so I would think. Kinda the reverse of a intake vacuum gauge on a gasoline engine. I also have an exhaust gas temperature gauge. 150,000 miles on truck. Amazing to me how many folks just pull off the highway and shut down their diesel engines--there goes the turbo. Takes mine about 2-4 minutes to cool down enough for me to shut down the engine after running on the highway. Gerald
Most of the posts I read are negative probably because anyone that has an issue is more passionate than someone that has a truck that is running great. I bought an 03 6.0L new. The truck was built in January. I knew better than to buy a first year motor but I needed a truck for my business. After 3 sets of injectors and a couple of sets of hubs I finally have it running right for the last 150,000 miles. However the first 200K were rough and put a dent in my wallet. What I find to help is using fuel improver (Lucas, Texas oil refinery, and others) and blowing the carbon out of the EGR when it starts running rough. I also use An injector cleaner fairly often. The truck now runs great and I average 16 Hwy and 11 towing a 7000 lb trailer. I also change my brake pads when they show 50% wear. I have not had to do anything to my brakes except change pads in the last 120,000 miles. . I hope Ford gets it right on their own diesel. If Toyota ever brings the Hilux to USA they will take over the market.
I don't know if anyone here has found out yet, but the white plumes of smoke & loss of power are due to the faulty fuel cells installed by ford. This problem is known as delaminizing. This occurs when the coating inside of the fuel tank flakes off and contaminates the fuel delivery system. If the vehicle stalls, and it will, you can wait 15 minutes or so and restart. The only fix is to replace the fuel delivery system. Victim,2000 E-350 / 7.3
Hey you're not alone. EGR stands for Exhaust Gas Recirculation, which is a fancy way of saying that the engine sucks exhaust gases in before the turbo and pumps them into the intake, thus inducting the exhaust gases back into the cylinders to be burned again by the engine. This reduces emissions to comply with Federal laws that were put into effect back in 1998 that demanded manufactures make their vehicles burn cleaner. It's a good idea in theory, but wreaks havoc on the engine. Just like the Government!
Because diesels by their nature burn so dirty and create so much carbon, pumping 1,200 degree exhaust into the engine would cause melt downs. The cooler is supposed to cool down this gas, but ends up doing nothing but getting plugged with carbon and if left unchecked will force carbon into the fuel injectors, and give you another $4,000 bill. This problem can be avoided by bypassing the cooler all together.
So by plugging the cooler, you can not only eliminate the cooler from being used, thereby eliminating and chance of it getting plugged, and create a much more efficient, cooler running, more powerful engine. Now your intake will be taking in clean, fresh, cool air free of any exhaust gases.
Unless you live in California, do it ASAP and save yourself a world of headaches down the road. Depending on where you live, I highly recommend taking your truck to Bill Hewitt down in Georgia. The cost of him going through your truck and bullet proofing your engine is a heck of a lot cheaper than pumping EGR coolers, turbos, and injectors into your truck. His website is www.powerstrokehelp.com
have you checked your fuel injection control module (ficm). your injector has two sets of coils. low and high side. during start up the ficm needs to send 48 volts to the high side of the fuel injector. if the module is going bad it will not send the needed voltage to actuate the coil thus very hard start with extreme rough idle along with surging ,sputtering, and sounding like its about to die out. i just went through this several weeks ago and after replacing it made a world of difference.if indeed your ficm is going out you will have trouble codes that will not always throw a check engine light.reading your description of start up sounds i would lean toward this being your problem.
7.3 Diesel has oil leaking on top somewhere, anybody have any idea what to look for, does not appear to be coming from the air charger or turbo. Seems to be towards the front of the motor.
My 99 has 180k miles on it. Starts fine and runs fine after it warms up. If I start it and don't allow it to warm up for about 10 minutes , it will run rough and eventually die,then after cranking for a while it will crank and run rough until it warms up. Does not show a code CONFUSED !!!!! HELP ????
Does anyone have any idea why a 97 7.3 diesel would idle rough and have no power until it warmed up? It has a code PO236 for Turbo Boost Sensor A Circuit Performance. Thanks
Hello everyone, I have just started reading through this. I have a few things to add and a problem maybe you call can help with.
I have a 96 F-250 Extend Cab. Recently it began to give me problems blowing the #31 Fuel Line heater fuse over and over. In the process of getting it back to the yard it also took out my head gaskets. After some length of time, It was in actuality the fuel heater coil inside the fuel filter that become desoldered enough to arc and short the area. I replaced the head gaskets and had to replace the main harness with one from a late year truck. My truck was manufactured prior to Feb of 96. The truck I borrowed the parts from was manufactured after Feb of 96. According to ford the build date is very specific in terms of the fuel filter harness but not the master harness.
I borrowed the Fuel Filter housing from the newer 96 and bought a new harness from the master to the filter housing itself (My companies cost at ford $45.00) Upon completing that nightmare, I had to refill the oil reservior to get it to start. It has been a week since then. Currently my truck (350k miles on body and frame 140k on trany and new crate engine from FORD) will not start without a shot of starting Fluid. On cold mornings when the truck is plugged in it still requires cycling the glow plugs three or four times followed by a shot of fluid. This usually requires two or three repeats to get it started and running.
From everything I have read here I can check the Cam position sensor, When I had it diagnosed it threw a oil code and one about ehaust leak. The exhaust leak has been fixed(tightened the brackets surrounding the turbo and replaced the flat o-ring between the flanges.
Any ideas on what is making this truck such a pain in the [non-permissible content removed] to start? Thanks for your time.
I am replying to your message about oil leak. I have a 02 f250 7,3 diesel with same problem. It is not from air charger or turbo it is the high pressure oil pump which is located right under the fuel filter housing if it same problem. What mine does is leaks out on the center head the it drains down back of motor and comes out the inspection pan for transmission which at first thought it was rear main seal. Then i changed rear seal and did not fix it so i talked to local mechanic at ford garage and he explained to me where to start looking and sure enough it was high pressure oil pump. Now what goes bad is o-rings in the lines. There is 3 of them line 2 on top 1 on bottom. You can change o-rings in top 2 but the bottom 1 you have to change the whole pump and all. My truck has 318000 and is the only problem i ever had with it.
After a year and a half of intermittant surging, faltering and stalling and 3 trips to Ford dealers with no fix, I got a fix for my 2004 6.0 Power Stroke Diesel. I spent hours searching this forum hoping for the answer but didn't find it. Hopefully this will help one of you out there with these symptoms. The engine would run fine all day on the interstate pulling my 12,000# RV trailer. Then when I got in town running at slow speeds it would begin to idle fast, then would surge sometimes making me put it in neutral so I wouldn't smack the guy in front of me at a light. Then after the surge it would begin running rough like it was firing on less than 8 cylinders. On occasion it would just quit. The problem never set a code and Ford could not figure it out, though they replaced injectors a throttle body and several other sensors. My warranty ran out in August so, after 3 stall incidents in traffic a few weeks ago, I took it to a local mechanic who immediately diagnosed it as an intermittant ICP Sensor in the injector system. After a year an a half of wondering when this truck would quit on me, I now have my truck back running perfectly. I gladly paid the $349 to get the truck running right again. I hope this helps one of you out there who, like me, is condemned to own this 6.0 Power Stroke. By the way a "power stroke" is what you get when the engine quits on the roll while pulling 12,000#'s of trailer and you're trying to steer it out of traffic.
Looking for help with diagnosing an issue that has started with my 1997 F250 PowerStroke Diesel. When coming to a complete stop it feels like it doesn't want to stop - have to put into neutral then into drive when able to go (ie at stop lights, stop signs) More often than not the truck will stall and completly shut down. Have replaced upper fuel filter - but truck drives great - until I have to stop and depress brakes - when depressing brakes it's like it doesn't want to stop - any ideas what is going on?? Only happens in drive, not reverse - when taking off from a stop it acts like i'm taking off in 3rd gear, but it's an automatic. thanks.
Hey all I am new to this site. We are having issues with our 04 F250 6.0 Powerstroke. The problems started this past weekend. It started sucking air, lost power and was blowing a lot of black smoke. Any suggestions?
My dad has a 96 f150 5.0 auto 4x4 196,000 miles, and a few months ago it started doing as you explained, but it started not as bad just stalling once in awhile, then it began to stall everytime you put it in drive, but not reverse. At first we thought it was the engine making it shift eraticly. Then we talked to a trany guy and he said it was a torque converter lockup soleniod making it lock the torque converter up like a clutch, which causing it to stall unless giving it alot of gas, then it would go. That didn't work, so everyone said the torque converter so we changed that, which didn't fix it, which makes sence because it doesn't stall in reverse.
The solution was taking it to our local transmission guy which right away after looking at it said the vavle body was leaking fluid to the torque converter lockup. So he seggested a rebuild. Which after he took it apart found that clutch packs for 3rd and 4th gear were burnt from driving the truck in that condition(which caused more money) and a gasket on the vavle body was leaking locking the torque converter up all the time. After changing these parts it shifted beautiful.
So I suggest to stop driving, only move it if nessecary, and to take it to a shop. Unless you have experiance with transmissions. They can tell you if the problem is in the trans. And if the problem is in the trans I would suggest letting the shop take it out and rebuild the entire thing, because it's only a few hundred more, and if anything happens they have to fix it before you take it back. That happen to my dad, we put the trany back in after getting it rebuit and i guess the reverse vavle he replaced failed and burnt the reverse clutches up, and this wkend we had to pull it back out and take it when the shop's open again to have that fix, but no charge. so that's a lesson we learned.
I hope this helps and let us know what you find. Zack
It sounds like your torque converter is bad and locking up. I would check the fluid and add or change of needed, also maby stop by a locol trany shop they will usually test drive and do simple diag for free. But until them I would drive as little as possible to avoid further damage to the trany.
i was goin down the road and my truck suddenly died, the Wait To Start light in the dash wont come on and the truck just turns over and wont start. im thinkin its the GP relay but im not sure dont want to spend money on something i might not have to on. need help fast
found out it was my bowl heater that started to short out and was blowing a fuse in the cab, unplugged the heater and the truck starts up fine, its gunna cost over $550 to fix including labour, atleast the mechanic was nice enough to come to my place to have a look at the problem. :shades:
hello i have a unique problem that is different than any i have read here please help! my truck dies in several different situations such as shutting the doors, a bump in the road and sometimes it dies just for the heck of it and sometimes it drops to an idle and has no throttle response for a few seconds and then takes off . the truck runs fine when running and it always gives a service engine soon light when this happens and in the beginning it would not start until the service engine soon light went out but now sometimes it will re-fire with the light on i have been through a recall at which time they changed the cam sensor and befor the recall i had already changed 2 cam sensors with no result i only have 90.000 miles on it. i also have a intermittent batt light that comes and goes sometimes with the same bump in the road or the doors closing and sometimes i dont get a batt light for quite some time, the whole thing is unexplainable, sure with the door shutting and the bump thing i think elec connection but then sometimes a bump and the doors have nothing to do with it i have tried the "tap test" on the relays under the hood and have found nothing wrong as many of you know the ford mechanics are just parts changers and not real mechanics so i am trying my best to find the problem with out having to ring a service managers neck and save myself alot of money for my problem to still exist. i do have performance upgrades but i dont consider Banks performance upgrades as cheap junk as they know more about fords than does ford i use my truck for towing my race trailer i dont have the extreme upgrades everything i have is to enhance towing performance i hope someone here has or is familiar with the mysterious dieing problem as discribed. i read earlier on here about perhaps something like an ICP sensor on the fuel injection which sounded like a possibility except for the bump in the road thing or even a relay some guy said that was located near the kick panel on the passenger side now something like that i could see would be affected by a slamming door but sometimes it doesnt matter what door. somewhere there is a real real mechanic that can diagnose this in a heart beat, i myself am very mechanical and can handle the repair but i need a place to start
check alarm wires and fuses. also there is a fuel shut off breaker on diesels. make sure u did not put gas in tank. depending on mix they will run for little wile.some stations have green on unleaded.look for the stuiped stuff 1st.i also had a alt.go bad on me that worked most of the time.i had it on the tester.it read good for 5 min. then nothing
Any Ideas? or suggestions?
Thanks in advance! :confuse:
There are 4 - O-Rings per Injector.
Gerald
Hope that helps!
