Visitor Agreement.
1) After reading your post #5873 that basically blames the current Maxima's torque steer on every factor except solar flares, I was about to point out what you'd missed -- until you basically contradicted the implications of your post #5873 in post #5875, by acknowledging that the current Altima owes some of its torque steer reduction to that improved halfshaft geometry. That's the real reason why the current Maxima (built on the previous Altima) has more torque steer than the similarly sized, similarly powered Altima.
2) The '92 Maxima with the top engine had "serious torque steer issues"? Sir, as chance would have it, I own the 190-horsepower 1992 Nissan Maxima SE, which I bought new and have driven (with religious maintenance) for nearly 16 years. It absolutely does not have "serious torque steer issues." In fact, my wife's four-cylinder, four-wheel-drive '03 Honda CR-V has much more torque steer than my Maxima.
On some other notes, I like the interior and looks as the tech packages will be nice. But, why only 9.3GB for the music system? Hard drive space is cheap.
Notice the shifter is offset closer to the driver, (wonder where they got that from?)
Still no nod whether FWD or RWD.
well, then, you have a great car, I got almost 300k on mine before the tranny cratered at which point the $3500.00 to fix the tranny was more than the car was worth. The tranny failure BTW probably due to my own neglect.
However, if you don' think that car has some torque steer issues then I would respectfully suggest that you may not know what it is. It was worse then what it is in my wife's 03 Altima 10 years later, despite the extra 50hp - any test of older or recent Maximas and V6 Altimas will generally always mention this.
As far as the ability to 'engineer out' torque steer - sure it's been happening for years and the difference between the TS in the 92 Maxima vs. the same condition 11 years later in that Altima is a good example. I guess you must be hoping that Hyundai gets around to putting that pumped up 3.8 in the Azera - I would wager they won't and further would guess that they may compromise an otherwise good drivetrain if they do. The key word here is 'may' - but IMO 290 hp engines do not belong in FWD cars and logically the stronger the engine the worse the problem - but there is no 'magic number'- simply too many things that go into it.
If you really want to feel and 'fight' a little torque steer, go out and find a vintage Saab 9-3 Viggen, turbo 4 banger, and more of a handful than a Impala SS or any Nissan product ever thought of being. Or drive the current Aura XR, a little less of the same stuff.
You can as many HP as you want, BTW, and Hyundai may develop some sort of 'cure' that successfully hides all that a high school physics book would teach you - but something that still won't change: you'll still have 60% or your over the driven front wheels and the car will still be a plowing understeering nightmare. Not to worry though you might finally get a car that can 'outdrag' even that Impala.
Having said that.... when Avy is ready to go back I will be test driving the Max and will try not to be so tunnel visioned with the CVT. I hated it in the 500, but that was with an anemic engine. Maybe, the "simulated" shifts along with the "manual" capabilities will be enough to overturn my aversion to CVT
Nissan not known to lose the HP wars.
Since they started the whole thing... it wouldn't be right for them to be at the back of the pack.
2009 Maxima Quick Specs
Like I said, I agree with you in that it isn't the desired configuration one would want to see in order for the Max to be a true sport sedan, but it is what it is and the only thing you can do about it complain about the TS, complain about the FWD and ultimately...not buy one. None of which, will stop Nissan from selling them.
that would be an understatement - the problem is I'm not sure that the 3.5 isn't still, other than at least, now its producing a reasonable number of horses as it 'grinds' away.
This, IMO, is a major problem with CVTs, driving one - the computer interprets your intent (like how fast you want to accelerate) by how hard and fast you hit the accelerator and then will set a 'gear' (more properly a 'gear ratio' ) that will best accomplish what it thinks you intend. In actual practice, after you hit that accelerator, the engine will seemingly stay at some relatively high rpm while the gear ratios continually change behind it. The car seems to be continually 'catching up' and a very non traditional feeling. No rev up- shift/rev up-shift like we all grew up with. The reason I think it was such a tough sell in the 500 is because if you are going to use a CVT that you had better also have an engine that sounds (and feels) happy at those higher rev ranges. The VQ, OTH, is a great engine that IMO is beginning to gray slightly - in applications (like in the M, for example) where the engine is really asked (thru tranny gearing) to put out, it too starts to also feel a bit 'strained'. I worry about 290hp out of the VQ especially in combination with a CVT. The Maxima is, after all, the Nissan semi-lux flagship.We'll see.
With the upgrade of the interior, the Max has definitely leaped into the semi-lux category along with the Avalon and Azera. I really do like the Infiniti-ish interior...it makes one want to be IN the car. Now the only problem would be seeing it in person to see if the exterior makes me feel the same way.
Enough talk about TS, we'll just have to see if Nissan takes enough of the guts of the car away (see Acura TL-S) so that the problem isn't too severe. As much of a Nissan fan as I am, I'm willing to bet that the new Maxima falls short in its '4DSC' revival though - simply because there is a bunch more to a 'sports coupe' than simply being able to get to 60 in something less than 6 seconds.
I can see the new Max pushin 0-60 in the low 6's, don't see it breaking the 6 second mark, ultimately...it has too many luxury appointments that add weight. As you've stated before, the CVT may not be the best way to put the power down on the pavement, so that could hurt it in terms of outright acceleration, as compared to if it had the same 290 hp coupled to it's current tranny.
I guess the one thing we have no choice on, is that we have to wait and see!
Judging by the interior I would say absolutely. The driving dynamic will most likely be more weighted to the sporty end than lux, but that is the case with most Nissans. I must say I am curious about other things such as FE, interior space and of course pricing. I would think this vehicle all loaded up may be only a tad under 40K.
As for the CVT and possible TS issues, the only way to find out is to wait until they hit the lots and drive one.
Watch it here:
http://www.youtube.com/watch?v=JJC0nzzm4xk
(Great commercial too)
I'll have to wait till I get home to view the clip on YouTube...firewall here blocks it.
From all the reviews I read, the G8 is really a poor man's 5-series and on the other hand the 300C/Charger is just a muscle car with 4 doors.
IMO, probably Pontiac and not because of quality perceptions - more like that Pontiac is generally accepted as a source of performance cars (the numbers would indicate that the Pontiac V8 should blow the doors off of the Genesis) , whereas I think Hyundai has got a battle on its hands in terms of quality and/or performance car perceptions.
The Genesis OTOH is trying more to be a luxury car that happens to be fast. Until proven otherwise I don't think this car will be a handler. In the 3.8 form will be plenty fast and would think FE #s in the 18/28 range. As for the V8 they will sell some, but I will be willing to bet the 3.8 is the volume model.
As for quality perceptions I would say Hyundai and Pontiac are about equal here..... which to say isn't that great.
Captain, to paraphrase Forrest Gump: I may not be an intelligent man, but I do know what torque steer is. Which is why, if you re-read my original post, I mentioned my wife's CR-V specifically to provide a comparative context for my evaluation of torque steer in my '92 Maxima.
"I guess you must be hoping that Hyundai gets around to putting that pumped up 3.8 in the Azera... If you really want to feel and 'fight' a little torque steer, go out and find a vintage Saab 9-3 Viggen, turbo 4 banger, and more of a handful than a Impala SS or any Nissan product ever thought of being. Or drive the current Aura XR, a little less of the same stuff."
Yes, I agree, anyone who reads Car and Driver knows that. I never said I was in favor of torque steer. You're raising a red herring argument here.
"You can as many HP as you want, BTW, and Hyundai may develop some sort of 'cure' that successfully hides all that a high school physics book would teach you - but something that still won't change: you'll still have 60% or your over the driven front wheels and the car will still be a plowing understeering nightmare. Not to worry though you might finally get a car that can 'outdrag' even that Impala. I hate to think that the evaluation of any car has sunk to the depths of how many HP it has - because it is only a small part of what a good car is - especially in this class."
I don't recall ever saying anything to the effect that I was extolling the virtues of an overpowered, torque-steering FWD car either. Where do you get these straw men I didn't say? And why?
All I ever said was that I can definitively rebut your claims about "serious torque steer issues" in the 190-horsepower 1992 Maxima by virtue of having driven a well-maintained example this morning. Feeling a little defensive?
Comparing FE to another GM full-size car, the Pontiac looks really good FE wise. If the 360+ hp Pontiac has 15/24, consider that the
197 hp Lucerne has 16/25, and the 275 hp Lucerne has 15/23.
250 hp Charger has 17/24, and the 340 hp Charger has 15/23
255 hp Maxima has 19/25
224hp Grand Marquis has 15/23
Suddenly, the Pontiac doesn't look so bad with that 24 hwy number, does it? :shades:
That's an undstatement!
I would generally agree with this, I feel that the Koreans are making a 'better' car than 'Detroit', and have been for at least the last 5 years or so. BUT, I'm not so sure that the average (uninformed) carbuyer Joe thinks so. Performance perceptions, Pontiac 'wins', hands down
and I guess it depends on how close to Hyundai's amusing claims (about the Germans looking over their shoulder) that the Genesis actually is.
It's all about the steering response and handling, my captain.
From Inside Line's Comparison Test: 2008 Dodge Charger R/T vs. 2008 Pontiac G8 GT:
- First of all, these are not small cars. But the Charger is even bigger than the G8. Slightly.
- When the two are parked side by side, the Charger appears even larger than it is relative to the G8. It also drives bigger.
- Just because the Charger is rear-wheel drive doesn't mean it's at home in the twisties. Hard cornering in the Charger is all about plenty of steering input and body roll. The steering is relatively slow and absolutely numb, but the front tires scream and squeal enough to let you and the world know they're struggling under the weight of this 4,135-pound sedan.
- In contrast, the G8's suspension could be a direct lift from the BMW 5 Series. It isn't, but the G8's MacPherson strut front and four-link rear suspension with progressive-rate coil-over shocks is very similar to the BMW's traditional 5 Series design. As a result, the Pontiac G8 GT rides a lot like, yup, a BMW.
- Sure it rides more stiffly than the Dodge, but that hardly means it's uncomfortable.
- The steering feels much quicker than the Mopar's and the tires feel sutured to the road.
- On a mountain road, the G8 GT will simply run away from the Charger R/T.
Like I've said, it's a battle between an Australian 5er and an American 4-door muscle car.
I "kinda" agree here but really what is it? It't not a luxury car and not really a family sedan either. Maybe "performance sedan" would be appropriate. Heck maybe we can even stick one of Nissan's "4DSC" stickers on it :P
Still don't think the Pontiac is going to appeal to many prospective 5/7 series buyers - much in the same way the Genesis won't.
Why? It would be cheaper to just have one engine among the trim levels. Even if that raised the base price $500 look at how more competitive the car would be.
I agree that the Pontiac wouldn't appeal to the prospective 5er buyers just like the Genesis wouldn't. However, there are those people who are lusting after the 5er but couldn't afford one and I think they are the main potential customers for the both 5er-wannabes (Genesis more luxurious and G8 more performance).
