Visitor Agreement.
That is unacceptable. Have you consulted other dealers or mechanics?
SUVs and Smart Shopper
and stop lights. Check eng.light did come on then. If you would turn car off it would run fine again until you slowed to idle speed, this progressively got worse until car will crank but has has extremely rough idle. Only code I ever got was a cylinder misfire and multi cylinder misfire. I have had two mechs try to diagnose the problem but they have been unsusessful, since a dealership has moved in the area I had them look at the car and they said it was the head needed to be rebuilt. Here's what I've done to the car. It only has 60,000 miles on it. It has been a good car and I would like to save it. We rebuilt the head it now has better comp that the manual requires. It did not change a thing. I have replaced the computer twice, replaced the coil packs and spark plugs, replaced the maf sensor. Pulled the fuel rail and checked the injectors. checked the knock sensor and crank sensor. Do not know the voltage for cam sensor. Cannot find a vacuum leak.
Any Ideas, I would be grateful for any ideas or suggestions. If you think I need to revisit something I have already done. Please tell me. Thanks in advance.
http://www.4x4wire.com/forums/postlist.php?Cat=&Board=UBB70
There are some Sportage hardcores there and some are very good mechanically. They if anyone on the net should be able to help you. Go there, get a password and join the group. I highly recommend them!
Give it a shot and come back to say what happened, OK? Good fortune to you.
Just bought a 97 kia sportage today, and so far seems like great vehicle. One problem. It has a fouled plug and needs new spark plug wires. My hubby and I can't find the plugs and can't get a repair manual for it. Looked on kia.com, but can't find it there either. Can anybody help me out? Would really appricate it.
jamesy
Chris
james
I recently traded in a 2001 Kia Sportage 4X4 that never had the problems you're describing. It did blow an alternator at about the 88,000 mile mark and at around 92,000 miles it blew a brake light switch. About a total of $395 to get both of those things fixed at an independent mechanic for the alternator and a Kia dealer to get the brake light switch fixed.
It just sounds like your problem might be an ECM but a person can run tests on their SUV to see if this part needs replacing. And, yes, unfortunately, it will cost you a'plenty to get replaced. You could try replacing it yourself but I'd get a manual and read up well before taking parts apart in there. Good fortune to you getting this problem resolved. Please report back with what you do to get it fixed!
Although in March of '07 I traded my '01 Sportage 4X4 in on a '08 Mitsubishi Lancer GTS, I am not opposed to looking in to another new Kia when the Lancer GTS starts deteriorating. That won't be for a long while, it is also built wonderfully.
But what it does when reading reports like yours is re-affirm my own good experience with Kia and it keeps me ever-interested in all Asian cars(even upstart Chinese-built vehicles). If the right Kia were to come along I might be persuaded.
Watch for the new Soul and C'eed Kia models to come out in the coming months. The new Kia coupe will debut at the Frankfurt Auto Show in September. It looks awesome!
this
Most probably the vacuum solenoid valve leaks..that is some vacuum passes through even if it id supposed to be shut hence some vacuum applies to hubs and they try to engage.....which probably means they are shot now....
Disconnect the hose "vacuum to hubs" THis is located driver side fender.
At least this should stop the grinding but 2WD only now.
The you can try to clean solenoid from internal dust by applying compressed air and using 12v on and off - it helped mine for a while - but anyway the original vacuum hubs, though very convenient when they worked, are due for failure and should be replaced with Warn auto-mechanical or manual
supplier
the price is now almost double what it was 18 months ago....but viewed from Canada, since the appreciation of the C$ (from .65 to 1.02 now), it is not that much.
And the instructions
here
If you elect to change your hubs for the automechanical, there are precautions in their use: they cannot be engaged "on the fly" as the vacuum were. Come back for details if needed.
Last week I was driviing the KIA on and off all day. One time I got in and tryed to star it but nothing. When the key is turned all the dash lights come on the keyless entry works, but when turned to the start position there is nothing. The starter is not even trying to turnover.
I was told by a friend that it might be a problem with the keyless entry not fully disingaging, another told me it may be a block fuse.
Pleas help
Do you mean "there is nothing left", like all the lights turn off, which would be a battery connector problem, or simply, it does not crank ?
Please help me figure this out.... dailydata
Second I want to be sure all of this happens when you run in 2WD, right ?
My reply in post #85 just above is about same case, so look in that direction. Disconnect "vacuum to hubs" hose as indicated here and run the car hence no stray vacuum will try to apply in that condition, then report the findings.
If all is fine then,it means the solenoid conducts the vacuum when it should not, which is a common problem and should have been checked first.
ALso, the hubs might have suffered beyond repair.....but this you will know afterwards.....
Disconnect that hose and tell us what happens.
would it be better to replace the selenoid or change the new hubs to manuel hubs in order to keep my 4x4 working?
how much would it be to replace the selenoid?
dailydata
Of course, while the line is disconnected, you have 2WD only but do it to clear the situation. The other types of hubs (that is, the automechanical) cannot behave in such a random fashion, so I think you do have the vacuum. IN fact, both types ( the vacuum and the mechanical) can be seen in this document
I do think the solenoid is the problem, but my way of doing things is not guessing, but testing. It saves a lot of money.
Down the line, you will have to opt for new hubs, that is, mechanical or manual, instead of vacuum type. Toobad, because the vacuum, when they work well, are the easiest to use on this little truck but by the experience of all, they are totally unreliable and sooner or later, switching to another type is unavoidable....but we'll see to that later.
dailydata
