Hyundai Azera Maintenance and Repair
lol love the car,though
>> drive the car for two weeks, your battery will be dead---no surprise.
I've had my battery go dead overnight twice on me for no apparent reason. Once recharged, it's fine. It's got to be a dome light or a trunk light. The trunk doesn't always latch unless it's shut with some force.
There's really no excuse for any of this. My bottom-of-the-line 1998 Pontiac Grand Prix had a control function that would turn off ANYTHING draining the battery after 15 minutes of inactivity. Can't tell you how many times that saved my battery from running down.
It also had a turn-signal warning bell when the turn signal was left on too long, and it had an oil remaining life monitor. In addition, I could program when and how I wanted the doors to lock and unlock (I selected shifting in and out of park as my option). Every Hyundai car made over the last 10 years should have had these features as a minimum.
To start with the driver's side bulb, turn the steering wheel hard right to expose the wheel well shield towards the front. You will have to remove the fasteners that hold the shield in place towards the bottom of the wheel well...enough that you can pull it apart and slide your arm in. Once you've accomplished this...reach towards the front and you should be able to reach the back of the fog light. Pull the harness off of the back of the bulb, twist the bulb out of the housing, replace with new bulb and plug the harness back in.
Sorry I don't have pics to post of this procedure. I think it'll make sense once you actually start doing it. Once you get the hang of it, it goes really quickly. If you ever have to change out the fog light housing...that requires a whole lot more more work. Let me know how it goes for you.
Happy Holidays!!!
Seals and gaskets sort of do the same thing, but the seal is used to "seal" fluids in or out. Gaskets are more for keeping metal from rubbing by allowing for expansion and contraction as it's porous. Funny how both are wear and tear items, but one they'll replace while the other the won't. :confuse:
This car seems to eat tires. MY BFG's with 22k on them are starting to get noisy. If they last till 30k, I will be lucky. Plus they have a 60k warranty.I do not drive agressively.
I start it every 6-8 weeks and let it idle for at least 30 minutes. I have never used a fuel stabilizer or a battery charger. The car has 26K miles on it and has no problems and the original battery! The engine is DOHC, aluminum block and heads - the same construction as the Azera motor...Richard
A month ago I installed the top of the line insterstate battery.
2007 Azera with 49k.
If I am now told it is a short in the radio, I am going to demand they replace it or I will call the insurance company and tell them to ask for their money back.Why the hell is the radio only covered for 36 months? :mad:
Did we decide it is better to lock the doors and activate the alarm when you are going to be gone for a week? Will this cause less drain?
My guess is when the Hyundai road side service came and jumped my battery it probably blew the fuse.
Gamel-Ged sez it's (one of) the security sensors located in the doors, hood, and trunk. If one of those switches isn't fully depressed and you use your fob to lock it, the computer will run the battery down overnight by trying repeatedly to arm the car and failing. The give-away on this is you don't get a chirp when you press the fob's lock button.
Turns out these switches can often be insufficiently depressed due to an incompletely closed door/hoot/trunk or a deformed or missing rubber "depressor" that fails to comletely close the switch. That explained a LOT of what I've been observing (trunk open light on the dash that goes out on its own) every now and then.
I'd refer you all to that forum, but my computer crapped out yesterday and this is a new laptop with no internet links yet installed in favorites.
Regards, Gary in Sandy Eggo
First off (particularly in a cold climate), your oil will not warm up enough in 20 minutes of idling to drive off moisture. It needs at least half an hour of operation under load to do this. Frequent starts like this are more harmful than useful. Get a battery tender if the car's going to sit for several months at a time.
I can't remember now what was Second off.
I keep a battery tender on mine...20 minutes will hardly charge a battery,,,in the old days, it took about 7 miles of driving to recharge just the juice that was used to start the car..don't know about todays situations
http://townhall-talk.edmunds.com/direct/view/.f1037a2/25#MSG25
To wit:
TSB 07-90-008
JULY, 2007
AZERA (ALL) & VERACRUZ (ALL)
INCREASED CURRENT DRAW ON AZERA AND
VERACRUZ VEHICLES WITH HOOD OPEN
This bulletin is provided for informational purposes on normal vehicle operation.
DESCRIPTION:
Opening the hood on Azera and Veracruz vehicles will ground the security system’s hood input switch. Grounding the hood input switch places the security system module (incorporated into the BCM) into a readiness standby mode.
While in standby mode, the BCM consumes an increased amount of current that may discharge the vehicle battery if the hood is left open for several hours or overnight.
Displaying or Storing the Vehicle
To avoid discharging the battery while displaying the vehicle on a showroom floor (hood open), a self-regulating automatic trickle charge may be connected to the vehicle battery. If the vehicle is to be left parked with the hood open and accessory power is not required, the Power Connector on the interior fuse panel should be removed.
Anyway with my audi A6 the cost would have been more than double this and they would have insisted on replacing the rotors.Have 50k on the car.
In regards to Audi...I found a great spot that replaced my wife's front rotors & pads (ceramic) for about $350. Audi wanted that price to just replace the rear pads with semi-metallic pads (no rotors).
What puzzles me is that the dealer uses the 5W-20 without asking about my driving and I instruct him to use the 10W-30. I'm assuming he's just 'enhancing the revenue' of the service department.
However, despite the manual, the oil filler cap on my engine says: "See Owner's Manual", "SAE 5W-20 GF3". Does anyone know how this contradiction in instructions has been settled?
