Hyundai Azera Maintenance and Repair
I know one thing, I am currently knocking on 110k miles for my Azera and i'm still running on the original plugs. The only thing I've been doing is making sure I keep my oil changed, keep the transmission & radiator serviced and replace the air and cabin filters every so often.
Usually, you pay for the mark-up on the dealer parts. I buy my parts through RockAuto.com and have a place that installs them for me.
I haven't upgraded, but what I understand is that the HID's require heavier wiring harnesses and a ballast system......they are essentially like an welding system since they generate a lot of heat to get the gasses to burn in the bulb .....I put Sylvania ultras in my 4 headlights and am very happy....what is the cost of an after market HID kit?
I only paid $32 (free shipping) for my HID kit on eBay. I know what the Sylvania Ultras cost per pair and you'll probably be replacing those before I replace an HID bulb. Also, the output from the HID's is much brighter than the Ultras (I've had those before myself). I'm so glad I finally did it, I'm also glad I waited because when i first wanted to do it, the HID kits were $150 and upwards. What I may do is get a pair of the Ultras for my high beams though.
Just noticed a coolant leak. Have 51k on the car. Purchased 8/2007
Leak coming from under oil filter body housing. also leak coming from water pump housing and oil filter body.. gasket intake man gaskets o rings etc.
Ralph at Camissa motors in Burlingame was excellent as always.
