I was driving in a heavy rain. Noticed what seemed to be a flash of light on the
steering wheel. Wasn't sure, beside it was raining hard and thought maybe just a shadow. I couple of minutes later the charging light (red battery light on dash) came on and stayed on until I got home (about 30 minutes).
The next day it was fine for a while and then came on again. The following day the ,light came on again and the dash lights (odometer, shift lights) started flashing and then were fine.
The rest of the day I didn't have any problems, until I started the car at night, turned the lights on and the engine died. I immediately tried restarting the car and it started fine and ran home fine (about 20 minutes) and nothing seemed wrong. But tomorrow is a new day.
Could rain cause this, or am I looking at something else?
Anyone ave any ideas to repair?
OK///.. If you see a group of wires going to a white rectangular plastic plug but its not connected to anything, thats a wiring bridge. You need to be able to unclip and inspect the colored plastic inserts that plug into the bottom of that bridge. They should be clean and a thin film of white lithium grease is recommended. If you see melting of the clip (or burnt to a crisp in my case lol), then you need to resolder the leads that were bridged together. Then INSULATE the bridge you just made so it will not ground out!
Good luck
Eli
so lisen up here my friendmake like this and i hope work for you to: set the first buton to step 2,then set the midle buton to max. cold air ,then set the 3 buton to window direction air then push the defreeze buton for 10-15 second and the automatic seting for ac start and indicate you the proces on board of the car were you see the kilometers and after finishing your cold air normali is to start working.hope work for you to.scuse me my english but i'm from romania and i don't know to rite very wel in english .good luck my name is Sever.
2002 Sebring sedan 2.7 V6: I already know I need a blower motor resistor which controls fan speed. (Only works on highest setting). Radio acts screwy sometimes works, sometimes just clock and no radio,radio dies sometimes if a preset button is pushed or a cd is inserted. mess w the fuse for radio and keeps it going for awhile or if I shut car off and restart that helps...sometimes...ugh. Also, lights for instrument cluster get flickery if set to highest setting and when I use directional, I turned dimmer down 1 setting and no more flicker??? And now for the final piece of resistance, My heat stays hot as long as my foot is on the gas but if sitting at a light or in traffic it goes cold, the faster I go the hotter it gets, the slower, the cooler, coolant checked at was shown to be fine. If anyone has any helpful advice I would be most grateful!!! :confuse:
Anybody heard of tail lights staying on? Electrical problem?? Any suggestions?
Tim S..
Tim S..
Plan on replacing it as it won't get better just worse over time..
Tim S..
It went out on Tuesday, everything was off except for my interior lights, and my door ajar light...
Nothing happened when I turned the key on... NONE of my gauges worked. Turns out, my Ignition SW Mod Fuse keeps blowing.. not sure why and before I spend the $1100 to get it checked out, does anybody have any suggestions as to why my car would keep doing this...
I had it started today, and driving, but as soon as i got to the bottom of the driveway, it shut off again, and kept blowing the fuse... How i got it started was, took off the negative battery terminal, let the computer reset, replaced the burnt fuse while the computer was resetting (the cable was off), and then put the negative terminal back on, and it started and ran for 15 minutes, w/o a problem... it started a total of 5 times before I moved it...
I do have a friend who is mechanically inclined, thank god!!! I did take it to a garage when it died, they don't want to fix it, so i towed it home...
It's a gorgeous car, and just bought new headlight assemblies for it, which i haven't had a chance to install as it died on me... When I meet Lady Luck, she's getting a C*$K-Meat Sandwich!!!
Any suggestions would be greatly appreciated!!
The first time the car blew the horn steadily, I was driving in a 4-lane, & I started swearing at the guy in the car next to me to knock it off. It took me a minute to realize it was MY car honking.
Fortunately I had a few miles left on my warranty to get it fixed at the dealer.
The car is still haunted a year later. When I turn on the right turn signal, it makes it all go dim. Works itself out after a minute or so.
Looking at other posts, we could be in for some expensive problems down the road with the electric & heater/AC issues. Hope not. Lesson learned. Get rich so I can afford the repairs. I love this car otherwise!
Car's sitting in the garage, I am terribly depressed w/o it...
I miss my car, someone tell me something.
My neighbors 2001 Chrysler Sebring just did the same thing. After checking a few things I came in an searched "starting" on this thread. Replaced the blown 20 amp starter/fuel pump fuse in teh engine compartment and the car started right up.
I assume the fuel pump was the cause and may be on its last legs.
My Problem was a Melted Wire by the EGR Valve. Which caused all my headaches...
My Total Bill: $252.20
Thank you Heim's Garage in Halifax, PA!!!
