After an oil change last year, it started stalling while driving down the road on my way home. I immediately went back to the dealer, where they checked it out and it wouldn't repeat (of course!). I have thought this problem may be due to bad gas, but before I can even treat the gas, it stops. If anyone has the answer to any of these questions, please share with me. I was thinking of selling the car, but not with all these problems. Help??!!
Any suggestions what else I can do before I get it towed to a shop??
I bought the car 4 yrs ago with only 46,000 on it.
I should have known there would have been issues. When i drove it off the lot the sunroof only worked sometimes, so i took it back to where i got it, they tried to fix it, then after getting it back it still didnt work right so they ended up replacing the motor to the sunroof. then everything was fine for awhile.
the next thing that went wrong is my drivers seat heater shorted out, then finally stopped working. Then my fog lights stopped working, and then my instrument light stopped all the sudden. So now i cant see how fast i am going at night.
then the passenger seat heater stopped working, my heater/ac only works on 3 and 4. and now my drivers side back window doesnt roll down. i have bought a new switch and replaced both the back window switch and my main switches. it still doesnt work it has something wrong in the wiring.
The only thing that hasnt gone wrong with my car so far is that it still runs well, knock on wood.
There is a cassette in the tape deck, and wondering whether that got tangled and killed the whole unit, or if that's just coincidence and there might be something else causing that whole unit to malfunction. We checked all of the other electrical components, and the wipers, lights, fan, and everything else is working fine, so it's just isolated to the middle-of-the-dash component. Any ideas before I let her go to the dealership? I'd love to just send her to a cheaper shop, or have my dad fix it.
MODERATOR /ADMINISTRATOR
Review your vehicle
Nice car in fantastic condition but how do I get the problem diagnosed - I can't afford to pay a mechanic to "throw darts" until he hits on the correct problem. I figure it could be the stater/solenoid, fuel pump, or a short somewhere in the car - has anyone had this same problem and gotten it fixed? Seems like this is a common issue in this model - there must be a fix. Thanks
Re: 2001 Sebring Starting issues: dimming interior lights/gages not head lights [darronm] by biged143
ClaireS, Host
Automotive News & Views | Coupes & Convertibles
will certainly NOT be looking at Chryslers when the next car purchase is to be made.
Been a car owner for 30 years and NEVER had this problem. Bad bad bad craftmanship.
I am still carrying a supply of the fuses.
My problem is this:
Approximately 7 or so months ago, my car started honking when I turn it on. 3 quick honks (all 3 lasting a total of less than 1 second together). When my headlights are on, the lighting on the console flickers dim - bright. My dome light can't be manually turned on unless the right turn blinker is on. I've taken it to a mechanic for diagnostics, if there is an error it goes by too fast for the computer to register it. I've been told to take it to a dealership to get it looked at, the dealership wants to block out a 2hr time frame and wants over $100 just to LOOK at my car. OH, and not sure if it's related, but; my car also stalls and sometimes dies when I'm at a complete stop (doesn't seem to be a rhyme or reason for it) and my brakes occasionally lock up when going around a corner with any speed over like 10mph.
I've searched high and low all over the web for issues like mine. I've seen people say their car randomly honks for prolonged periods of time, dash lights go out or flicker...but nothing of them all together, nothing like what I'm experiencing and no idea what to tell a mechanic to look for if I take it to one. Any ideas? anyone else have issues like this? Help! :confuse:
How did you get your propblem solved
Another problem is that the speedo needle occasanally bounces and then operates normally and the tach isn't working. I have found out that the output speed sensor is bad. Could that be causing the speedo and tach problem?
Thanks in advance for your help.
Sam
Sure glad the mystery was solved. Went from a 2003 Saab 9-3 Convertible wirh 36,000 miles on it to my 2001 Chrysler Sebring LXi Convertible with over 95,000 miles on it and I couldn't be happier. I love this Sebring - Just an all around nice vehicle (and no cowl shake like in the Saab)
All of these symptoms were resolved. There was an internal short in the alternator causing an electric field to be applied through the alternator housing to the frame of the car.
The Speedometer kicking up to 15 MPH caused the top interlock to kick in. it caused the transmission to shift while standing still and the ground reference was changed by the field causing low voltage differential through out the vehichle's systems causing everything else.
I just got my car back yesterday and looked here to see if this was a common problem. It appears that almost everyone's electrical problems could be tied back to something like this.
Any one got any ideas?
downhillracer in Az
Good Luck.
downhillracer
1. When driving the door locks are opening and closing (buttons on door going up and down)
2. Interior light is now staying on (rear council).
3. Tach and odometer work when they want.
Any ideas?
Happy Rhodes.
1st. My automatic lock and lock control does not work on the driver side.
2nd. Some dahsboard lights (air, radio) would delay to come on.
3rd. The air blower only blows at highest setting.
4th. 20 Amp fuse to the ignition i dstarting to pop (twice in the past 6 month period).
Problem number 3 sounds like the blower resistor needs to be replaced, this is a fairly common problem on many vehicles which is easily fixed.
Best of luck with getting your Sebring's issues fixed.
As for the check engine light, what is the code? if its the dreaded p0440 or in that area, you can put fuel injector cleaner in the gas tank for the next 2 or 3 fill ups and that will end that cel issue. But you need to let us know the code why the cel light is on before we can actually give you any feedback.
Here is what is Working. The Car Starts and Seems to drive as Normal, I have as I said the E-Brake Light and the Oil Pressure Light on the Dash, The Power Windows, Outside Lights, Turn Signals and Hazards, Reverse Lights, Radio/AMP, Power Mirrors. The Transmission Indicator on the Dash.
I have Posted to every Blog known to man about this. I have Contacted the Dealer that wants $95 just to look at and Diagnose it and If there is Wire repair they will do it for that. But if there is more to it then the Price is More, and That Frightens me immensely when I live on a very fixed monthly income and so does the roomie. I even went as far as emailing Chrysler in order to point out how ridiculous this is at this age of vehicle and the low amount of miles. I also indicated that I never had these kind of issues with any other car including Japanese cars, especially; that I had ever owned and I had explained my financial situation. I then get this very cold form letter back praising their wonderful 5-Star Dealers and their perspective service departments and also the fact that I have no warranty on this vehicle. So No Help with anything thus far and I have an approximately 2500 lb. Paperweight in the driveway. I have Taken this car apart as best as I can with the limited tools and my limited knowledge of cars looking for an obvious frayed of burned wires that I could see. PC/MAC Repair Tech of more years than I care to count, I am. Car Mechanic I know enuff to be Very dangerous. If anyone has any Ideas, Please give me a Shout.
Larry
Mechanic reset dashboard warning and found no faults - now they want to take the engine management system out and check it out
Apart from selling the vehicle when it runs on 6 - is there a quick fix ...????
•P0513 - Theft prevention system misread Sentry Key or you accidentally put the wrong key into or near the ignition.
So I would say something to do with the Sentry/Theft Control Device.
