Usually starts fine when left sitting for a while. If restarted after a short trip, it is more difficult to start. More short trips lead to more difficultly starting. Eventually I start it with the gas petal down and white smoke out the exaust. Last night it didn't start then 30 min later started with no problem. Just did an oil change. Didn't replace fuel filter. Haven't checked battery. Any ideas?
Interestingly, if the problem occurs, I can resolve by turning off the engine and restarting. I have tried primimg the pump on the filter housing with engine running when the problem occurrs, but it does not resolve the issue.
It would be a recall only if there were some real defect. Parts wear out, vehicles need maintenance and some mechanics misdiagnose problems but those are hardly reasons for a recall. I think it's best to find out exactly what the problem is before making an indictment.
Perhaps some of the experts would jump in and offer some guidance. Anyone?
SUVs and Smart Shopper
NHTSA is authorized to order manufacturers to recall and repair vehicles or items of motor vehicle equipment when ODI investigations indicate that they contain serious safety defects in their design, construction, or performance. ODI also monitors the adequacy of manufacturers' recall campaigns. Before initiating an investigation, ODI carefully reviews the body of consumer complaints and other available data to determine whether a defect trend may exist.
so in other words, a breakdown of one car one time, or even one car multiple times, doesn't mean that all or most of that make model have a provable design defect.
BTW, the automaker may also voluntarily issue a recall.
it could also be that their scanning equipment isn't sophisticated enough---not all are created equal. Or it could be a computer glitch, which is a real pain to track down.
No easy answers with an intermittent problem, sometimes you just have to take your best guess or find someone with the patience of a saint and the genius of Sherlock Holmes to track it down inch by inch, component by component, testing each one for proper values---which isn't cheap.
I spent 6 months off and on on a Jeep once before I found the problem.
To check for a plugged filter, hook a vacuum gauge up to the fuel line coimg out of the filter (between filter and fuel pump). If the vacuum reads over 10 in Hg, then the filter is plugged. I found the the vacuum is nearly zero with the new filter. It also pulses a bit in sequence with the fuel pump (a good thing).
A few weeks ago the car just didn't start. I thought it was the classic battery problem, but radio, A/C and all lights worked. It just didn't do anything when I turned the key to start. Since AAA couldn't get the car started, we towed it to a mechanic. They called me the next day, asking what to do with the car, since it started right away. :confuse:
So nothing was done and all was fine for a few days, then the same problem again. But this time I just waited a few hours and the car started again. I did notice, it seems to have something to do with the unlocking of the car. Everytime it wouldn't start, I had the car unlocked for several hours. So I figured it's a problem with the alarm (which was installed by one of the pre-owners) and disabled the alarm.
All worked well for 2 weeks now, untill this morning. I had to grab something out of the car yesterday evening and forgot to unlock it again, this morning the car won't start again. I locked it again and try to find the 'time' I have to wait now until it will start again. I hope this is even the right idea I am having .... I ll keep you updated if it starts again in a few hours ...
anyone else had a problem like this?
As I thought, the car started again in the evening. I think I waited at least 5 hours, car running smooth as if nothing ever happened. I think I need to go to a dealership now, but I wonder what it can be after I disabled my alarm.
Anything from JEEP, that secures the car if you leave it unlocked too long?
The wire connecting the ignition coil to the distributor was oily and not tightly crimped inside it's connector (the wire providing contact to the points).
I was able to find what was causing the problem by manipulating the wire harness while the engine was running because this stopped the engine every time. In your case I think the same approach could be applied.
Approximately 3 seconds after the car dies, the light for the wrong key illuminates. However, I have tried to start it with both original keys, so I do not believe it is the key recognition system.
The check engine light is also illuminated, but it has been illuminated for about a year with no problems. When the check engine light first illuminated, we had a mechanic take a look, and he found no problems.
Has anyone encountered a similar problem?
I think Jeep needs to know everyone is having the same problem, also I am going to contact consumer advocacy groups for help. This is nonsense that everyone is having the same problem. I have two small children that should not be subjected to endangerment due to an unsafe car that dies without notice. Id like to take my family on a summer vacation but am too scared to drive very far away. That's sad.
I owe $10k on the car still, anyone have suggestions? Trade-in value is only around $6500. I don't want to sell it privately cause I would not sell this vehicle to someone else to have them go through what I've gone through.
"I have 2002 Jeep Liberty (Sport).
I drove my vehicle home with no problem. I stopped home for about 20 minutes and then went to drive my Jeep again. It wouldn't start.
- The engine is not turning over.
- The keyless entry (remote) device doesn't seem to be working, ie will not lock doors, but did open the hatch on one occasion.
- First, when I turned the key back, nothing happened at 1st and then gradually the odometer display came on and then the radio.
- As well, at first I could here a continuous "activation" of the lock in the hatch for no reason. It gradually stopped.
- I turn the key forward and the various lights display. First, as normal, but now the (MIL - malfunction indicator light) blinks for 10 seconds. The battery light is also coming on after initially going off.
- Again, when I turn the key the whole way to start, no response from the engine.
What is happening??
- Fuses?
- Computer (ODB) problem?
- Need to boost battery?
- other?
Thanks in advance!"
Anyone else with similar experience?
I'm at my wits end. :confuse: Hopefully i can get some advice here.
Ok I have a 2003 Jeep Liberty v6 3.7l renegade 72000 miles on it. About 1 week ago, It stalled out on me on the freeway doing about 65. i pulled it over and waited about 5 mins and started it again...it started then stalled again about 30yards later. I had it towed. I had a friend of mine come and put his code reader on it and we came to the conclusion that it had something to do with spark. So I began to take off the plugs and coils. I found that 4 of my coils were cracked and one was so bad it was bulging...ok bad plugs and coils..got it. I went and bought all 6 coils and plugs and replaced them. Started it up and it ran for about 10 mins then stalled out again. Now the code read that there was a sensor bad. We couldnt figure out which it was so I had it towed to a mechanic shop. He diagnosed it as the cam and crank sensors and he replaced them for me. He said it still had a small lag on take off but that could be fixed by putting in the correct plugs. Apparently me and my BRILLIANT thought process bought bosch 4-spark plugs (@6bux a pop) and the mechanic suggested regular Champion plugs. so I went and took out a bosch plug and measured it up to a regular champion one. turns out that the champion plug is a little shorter than the ones I put in. so I figured that might be the problem. I raced back to my car and began replacing the plugs. Upon removing the coils, i found that another coil (yes its a new coil) was popped out bulging at the side like the other one was. I attributed this to maybe "bad luck bad part" deal. I went to the parts store and they gave me another new one. I put it in and turned ont he car. It started perfect and ran great!...for the first 10 mins...after that, there was a very small "stutter" in the engine that was intermittent. I didnt think much of it figuring that maybe the engine is just a litle old and may have developed it over time. That was yesterday afternoon. I drove the car across town with my kids and everything in it (thinking my jeep was fixed) and it ran great. Today, i woke up and went to church and ran some errands. the jeep was running fine and still had that minor "stutter" int he idle at the stoplights. but it would take off fine. I didnt think anything of it. I got into a scenario where I had to give it gas so that it would doenshift so I can pass someone. It shifted fine but during the pass, the engine stuttered again. after I [assed, i had t get off the freeway because now the engine was exhibiting signs that it wanted to stall out and die. The check engine light was flashing slowly as I pulled it into the driveway of my parents house (they were closest to where I was at) i had to let it cool down so I left it there and got a ride to my house. My thought is that when it lost power again this time, it felt like it was missing fire on a cylinder which made me think about "what if another coil went bad?" but what are the odds on that? If it is the case, i still need to find out why my coils are going bad? I'm going to have to go and check the coils and plugs (to see what one wasnt firing right). Any suggestions? I bought a main filter for the fuel (for the filter thats on the outside right in front of the gas tank) so i'll be replacing that one.
need some advice. please let me know.
thanks guys (and gals) :sick:
Got home from work went to where my Jeep was at. Turns out the code was flashing "misfire on cylinder 3" so i swapped the coil of cyl3 with the one on cyl1. I reset the code and let it idle.. sure enough after 5 mins of idle, it registered "misfire on cyl1" So i took one of my old original ignition coils (the onlyone that was in decent condition) and placed it in cyl1. The misfire was not apparent anymore. as it was the misfire was barely noticeable however now it was gone. so my conclusion is that maybe i had 2 bad coils? talk about bad luck. Outman, I saw what you had put in there about the throttlebody cleaner. i'll be doing that once i get paid next (this freakin breakdown sucked me dry just about) im sure that will help with keeping things in shape. I'm going to drive it around a bit and update in about a week (or sooner if theres another issue). Anyone think maybe the pcm is shorting the coils? i guess i'll have to see...if it does, that will be bad coil #3...i must really have super bad luck if thatw as the case! i'll still troll the forum in case anyone has anything else to look out for. I love my jeep...but was contemplating trade in for a 4door truck if it kept breaking on me
Knock on wood so far my jeep is running fine.. i'll be checking the hoses as you did this weekend.
