Lost? Ask a Host for Help!
1272830323355
  • hikehike Member Posts: 2
    I was thinking of replacing the small spare tire in my 2007 CR-V AWD with a full size tire. Will it fit under the floor and still allow you to put the floor cover over it or is it too big?
    You probably want to head for the 2007 Honda CR-V discussion in the Honda CR-V Group.
    kcram - Pickups Host
  • markandjanetmarkandjanet Member Posts: 4
    I am new to this site and i posted for some advise. Don't think i got any, or i don't know how to find it. So, here goes again. I have been quoted $29,476 for an '07 Avalon XLS. Is this a decent price. The Invoice is mid 32K, which invoice should be the same for base XLS. Someone please help me.
  • goofinoffgoofinoff Member Posts: 1
    My Haynes manual is not specific to my particular engine, so it doesn't show the location. Can anyone tell me where this sensor is located, or point me to a free online website that would contain engine specs or diagrams of the 1988 3800 V6 engine??? Thanx!!
  • patpat Member Posts: 10,421
    I think I'd start in Got a Quick, Technical Question? Someone there may be able to help or point you to a better place to ask.
  • j_ingj_ing Member Posts: 10
    Is there any forum on Edmunds that can give me advice on what I should do about the 36,000 mile lease that I am in that ends Dec 30, 2007 of which I am at 35,550 miles now? Do I pay the $1578 to get out of the lease before I go over the miles or pay the $.20 per mile fee and end up paying $1000 when I turn it in for the extra miles?
  • kyfdxkyfdx Moderator Posts: 275,682
    Try posting your question here: Lease Termination Fees and other costs
    regards,
    kyfdx
    Host-Prices Paid Forums
  • clorwigclorwig Member Posts: 1
    I am about to replace the AC Compressor in my 2001 Hondar CR-V for the second time - another $1200+ dollars. I am at about 120,000 miles. Based on previous postings it appears I have nothing to lose by contacting Honda. Except for this problme, I have been very happy with the car. I just wish I had done my homework after replacing the compressor the first time. :(
    It'd be worth opening a case with Honda and seeing what they could do for you. Please post in the CR-V AC Compressor Issues and get some advise on how to approach the dealer and Honda, and good luck!
  • sam86sam86 Member Posts: 1
    Does anyone know what the inlet and outlet position on a subaru legacy legacy limited outback muffler is, and what the diameter of the inlet is?
  • Kirstie_HKirstie_H Administrator Posts: 11,257
    The folks in the Subaru Crew Problems & Solutions discussion are pretty knowledgeable, so I'd try posting there.
    MODERATOR /ADMINISTRATOR
    Review your vehicle
  • iris4iris4 Member Posts: 1
    i need help with my front stablizer bar and linkage (bushing -parts). they need to be replaced. when i tried to order them i gave the make and model but they want the diameter measurment. what does this mean? the bar itself is to the frame of the car the stablizer linkage is to the control arm do the mean the linkage or do they want the bar bushing? iris4
    Try asking in the Cougar Support Group - General Maintenance discussion.
  • cshaheencshaheen Member Posts: 1
    hi i have a 91 ranger with 5 speed overdrive in the mornings when i shift in either gear its okay but after it worms up it doesnt want to shift its hard 2 get into gear and it grinds when i do get it in what could the problem be
    thanx :mad: :mad:
    Head on over to Ford Ranger: Transmission questions
  • rabbit7rabbit7 Member Posts: 1
    I would like to know where to begin , from draning and putting the fluid in? I have a 2000vw jetta. please help. THANKS
    Ask in the Jetta Transmission Issues and Questions discussion and someone should be able to help you.
  • standfaststandfast Member Posts: 1
    My first post,looking for some help.Anyone who has been succesful locating source of rattle could you please tell me.My rattle seems to be coming from front passenger area near glove box or right side of engine area.Any fixes known ?? Car also drifts left and I have the drive by wire problem...what happened to toyota quality ?
    You can check with others who have had the same problem in our Toyota Camry Rattles discussion.
    Review your vehicle
  • durrantdurrant Member Posts: 1
    Hi:
    I live in Brandon Manitoba Canada. Does anyone know where one can purchase a new Chrysler 300 in North or South Dakota or Minnesota to a Canadian.
    Bob
  • john_avogadrojohn_avogadro Member Posts: 2
    My wife remote started our Camry 2006 and upon entering the car hit the brake before putting the key in. That shut down the car completely. The security system was factory installed. Now we can't find a way to start the car. :mad:
    Now when I try to remote start the car, the lights flashes and for a few minutes the battery comes alive, but then everything shuts down again. I get the same results with the key in the ignition. Strangely, even after I remove the key and close the door, I can hear a strange purring sound of the starter from the outside.
    Nothing that's electrical on that vehicle works right now, including the door locks.
    The car dealer wants me to spend $150 to tow the car, which I know will take the dealer 30 seconds to fix. They don't want to offer me any advice over the phone on how I can revive the car for obvious reasons.
    If there's anybody out there that can offer me some simple advice about how I can revive the car I would really be grateful. I don't think there is anything wrong with the electrical system. My gut feeling tells me that somehow we need to kick start the security key system and there must be a simple method involving a few key combinations that will bring the car out of its stupor.
    You might get some leads from other posters in the Importing Car into Canada from US discussion.
  • victor14victor14 Member Posts: 2
    I have Civic LX automatic with 72,000 miles. The cur just stopped while on Freeway. The engine would rev the RPM would go beyond 4000 but it would not move.
    After towing and checking with the mechanic I was told the transmission is shot and will need replacement. The Honda Dealer I called is charging around $3500
    What I do not understand is why the transmission gave up with only 72K miles.
    This is 2001 Civic with VIN 2HGES16541H593143
    Did their 2000 Civic transmission problems were seen on later year cars also?
    Try posting your question in Honda Civic Transmission Questions.
  • bobby22bobby22 Member Posts: 1
    could anyone tell me what the name of this part is the bottom radiator hose goes to it and the heater core hoses go to it. IT'S A 1989 HONDA ACCORD LXI IF YOU COULD HELP ME THAT WOULD BE GREAT
  • donanderdonander Member Posts: 4
    I currently have a 99 Camry which I like but will be replacing it sometime around 2008 or 2009 and buying another used vehicle, about 2 years old so I'd be looking for a 2006-2007 vintage vehicle. Does anyone know if any manufacturers make a reasonably priced 4 door passenger sedan (say $15,000 or so when 2 or 3 years old) that has an instant-on heater? It seems like a simple thing to just put an electric element in the heater system that would come on when you turn the heat on just after you start the car in cold weather. As the engine temperature rises the heating system could transition from the electric element to the engine heat. I know some people are going to say that electric seats accomplish this and I suppose I'd be willing to try that out (I've never had them) but does anyone know if the instant heat thing is on any vehicles?
    Try asking your question here: Got a Quick, Technical Question?
    regards,
    kyfdx
    I've never heard of "instant-on" heat, but I do like heated seats...
    Try asking about that here: Climate Control Problems (Air Conditioning, Heat) - All Cars
    regards,
    kyfdx
  • dandmdandm Member Posts: 2
    I have a 2002 Dodge Intrepid and the check engine light keeps coming on for almost about a week and a half, it goes on then after a bit it will go off. Now I am having problems starting my car some time I have to wait about 5 mins before I can start may car? Help.
    Try asking in the Dodge Intrepid discussion. The "Check Engine" light discussion may help too.
  • jpfannesjpfannes Member Posts: 1
    im trying to drop the tranny in my car and the shift link needs to come out but the bolt is stuck in there good :mad:
  • hollidayholliday Member Posts: 1
    anyone knows why a 1995 maxima cut off when coming to a stop or at low speed
  • volvojinx1volvojinx1 Member Posts: 1
    A/C in my '98 S70 Volvo blows cold air for about 10 minutes then turns to regular uncooled air. Fan stays on. If I turn the system off for a minute or two then turn back on, cooled air comes back. Seems like a bad compressor would NOT produce any cold air? Is there a thermostat control, or temperature sensor, etc. that needs to be replaced? Any advice on what is causing this or how to trouble shoot.. greatly appreciated!
  • agc7agc7 Member Posts: 2
    Hello, I have a 1995 Honda Odyssey EX, 113,000 miles, after a recent 500 mile trip I have noticed that my car turns off when idle. In the mornings it starts easy, its fine when it idles, but as the day progresses and it gets hotter out, the car has difficulty starting. And when it does start, it tends to turn off when idle. Any ideas? Any help out there? Thank you!
  • im trying to drop the tranny in my car and the shift link needs to come out but the bolt is stuck in there good
    Head over to the Mazda Protege Maintenance and Repair discussion. You should find some helpful Pro owners there who may have a solution for you!
  • Best place to ask about this would be the Nissan Maxima Maintenance and Repair discussion.
  • We don't have a specific discussion on S70 AC issues, but you could try posting in the Volvo S70 discussion.
    You might also want to try the Got a Quick, Technical Question? discussion.
  • Hmm... sounds like it could be a fuel issue, but I'd start by posting in the Honda Odyssey Engine Problems discussion.
  • This last week, I must have missed any announcements of chats or are they gone?
  • Chats were just on summer vacation this week:)
    So we'll see you at the Tuesday chat next week then?
  • Ok, cool. :shades:
    This was my first week back after a while, so I wasn't dure if chats were still done.
  • meggie18meggie18 Member Posts: 3
    I am thinking about purchasing a 1996 Eagle Vision, but I am aware that it has a blown head gasket. Does anyone have an approximate idea of how much it would cost to repair this problem?
  • glascoglasco Member Posts: 2
    Here are a list of my troubles ,odometer light is out, gas gauge light is out ,cruise control is out. I checked the fuses cruise control was the only bad one. I replaced it still no cruise control. I had the truck checked out at the shop, They thought it was the ignition switch replaced it ($167). still no cruise or other gauge lights I mention earlier. the oil & water lights work just fine. Help Please
    Try asking in the Got a Quick, Technical Question? discussion for ballpark numbers.
    Please ask in the Chevy Blazer GMC Jimmy Electrical Problems discussion.
  • 96corolla196corolla1 Member Posts: 5
    Hi. I am a poor, broke college student. I've been so stressed this past year that I neglected to change my car oil for a year(yes, I am regretting it big time). Today, as I was driving in the hot weather(90 plus in Sacramento) and came up to a stop light, my car starting shaking like it was going to die. I drove it about 3 blocks and turned it off for about an hour. When I checked the oil, it was totally empty. I drove it another few blocks to buy oil and refilled it but it continues to shake and the check engine light has come on. I've left it at a friend's. Did I totally mess up my engine? I hope not, because I can't afford to buy a car right now. What could be wrong with it? Thanks. :sick:
    Not good! Rush on over to Shifty, I need your help!.
    SUVs and Smart Shopper
  • bizzlebonebizzlebone Member Posts: 1
    I am having starter problems with my 2001 kia sephia. Originally, I had run out of gas and pulled over to the side of the road while I waited for help. At the gas station, got two gallons, and put them in my car. When I went to start it, I was able to reve the engine two or three times and then it died. After that, we were unable to get the engine to catch. It would catch for just a split second and then just turn over. We tried several different methods, but with no success. In the end, we figured that it might be a fuel pump problem. What can I do to check and see if it is in fact a fuel pump problem, and if it turns out that it is, what can I do to try and fix it with out having to go to a mechanic? Where is the fuel switch located? Will letting it sit over night help? Should I pump the gas peddle when turning it over? Thank you so much, I really appreciate the help. With out my car, I may loose my job so the faster you can respond the better! Thanks again!!
    Bizzle
