Pontiac Grand Prix Starting / Stalling Issues
123468
    gatvillegatville Member Posts: 1
    Hello, I currently have an odd electrical issue with my 98 GTP. When i turn on the headlights (or when they come on automatically) there's not enough power for them to turn on, the parking lights work fine though. The daytime running lights do not work. The dome lights/cluster illumination/radio/climate control/info center all dim and brighten intermittantly and continuously, it also seems to effect the idle of the car. First thought was that it was the headlight switch, replaced it and the problem still exists. Now, if i turn the highbeams on.....the problem goes away, the headlights work fine, and all the interior lights work as they should. Any suggestions for this problem?
    ralphie2ralphie2 Member Posts: 7
    Hi!
    I have an 07 GP which develops a hard intermittent miss during acceleration. It isn't necessarily hard acceleration, it happens with with light pedal too. It gets worse when the ambient temp is in the hi 80s lo 90s, especially when sitting in rush hour traffic. In the morning or cool weather there is no problem, which leads me to believe it's a sensor breakdown at hi temp. No check engine light, no code errors, no reading from OnStar real-time diagnosis.
    Any ideas? MAF sensor is my first guess.
    skullman91skullman91 Member Posts: 5
    i noticed today that my car bogs down worse when im barely touching the pedal, like its coughing for more gas. if u read my posts on here Ive tried almost everything except the plugs and wires. try the maf sensor, its worth a shot. but that's how my problems first started, no check engine but started running like crap
    gmcustsvcgmcustsvc Member Posts: 4,252
    ralphie2,
    I would recommend taking the vehicle to your dealer of choice to at least have the vehicle diagnosed. Could you please email me? Please include your VIN and a brief description of your issues or a copy of this post. I hope to hear from you soon.
    Christina
    GM Customer Service
    pontiaclivespontiaclives Member Posts: 19
    Well I had the car checked out at Tires Plus, they didn't see any codes and couldn't make it to stall after keeping it for 2 days. Then I called GM to see if they had anything to say since this is a major safety issue. The car stalls at highway speeds and you have the risk of getting rear ended by a semi or losing your power steering and going off the road if it happens at a sharp turn. They offered no hep but gave me a case number. I took the car to the old Pontiac/GM dealer. They couldn't find anything either but suggested replacing the crankshaft sensor as the first step, the other possibility is the ignition control module but they are saying that crankshaft positioning sensor is more likely to go, which is also supported by this forum so that is the first thing I am going to do, then we'll go from there. I'll keep you posted.
    I had the dealer replace the crankshaft position sensor and so far so good. I drove the car for almost 1000 miles and it hasn''t stalled yet.
    mudrulzmudrulz Member Posts: 1
    I have a 03 grand prix with the 3.1L and has 98K miles. When starting the car it idles rough and has a random miss fire, along with stalling out like the ignition has been shut off. The ignition has to be shut off and turned back on to restart the car. Had someone take a look at it and they scoped and adjusted ses light, but found nothing else.
    Anyone have any suggestions?
    elm225crelm225cr Member Posts: 1
    I´m sorry is your name Mckenzie?
    Ill try that
    darrdunndarrdunn Member Posts: 1
    I have a 2001 w/3.8. I'd loose my Tach and Traction Con. light came on. Replaced Ignition module. Fixed it.
    sovanosusovanosu Member Posts: 2
    My '03 pontiac grand prix GT is not starting.I replaced the battery with a brand new one and have the alternator checked in two different shops (Auto zone and O'reily).There is no problem with the alternator too. I didn't leave any switch open after I turn the ignition off.The car works fine after jump start but the battery is dying after 10 hrs. I believe something is draining the power from the battery while the engine is off.There may be some ground problem too.I checked with a mechanic and he told me that the battery is drawing 0.02 A of current when the engine is off..apparently he couldn't find the problem. I am quite depressed and don't know what to do.
    Could anyone please help me out?
    summersnowsummersnow Member Posts: 1
    I have a 98 pontiac grand prix 3800. It will not start. :confuse: When you turn the key over, no sound at all. complete silence. The car ran fine the day before, i came home, parked it, and the next morning, it wont do anything. The dash lights are on, as well as the inside lights. the power windows and radio all work fine. I cleaned the battery connectors, and still nothing. :cry: I tryed jumping the car..and nothing...it still did not amke a sound. I used my diagnostic machine and no codes come up. I am unemployed at the time and have little money to spare, so if any one knows what could possibly be wrong, i would greatly apprecitate any help. I plan to do the repair myself, but again I am limited on funds so would like to get the right part the first try out....lol...thanks in advanced for any and all help.
    seanmk420seanmk420 Member Posts: 1
    I changed the motor out because no one bothered to change the oil in the vehicle. But now the motors all bolted up and it has no spark for some reason. The harness is all connected up I double checked, I think the computer needs to be reprogrammed at the dealer. If you have any suggestions It would be quite helpful
    dud3iknowdud3iknow Member Posts: 1
    my grand prix had the same problem. i installed a bypass switch from the positive battery cable and ran it into my car just under the dash and when i turned off my car i would just hit the switch and kill all power to the car.
    (great deterent for car theifs too) and it only cost me $10 bucks for the switch and 0 guage wire. hope this helps
    jenn70jenn70 Member Posts: 1
    Im having a problem problem with my 08 Grand Prix - has lost acceleration several times, twice on the highway and twice under 25 mph and check engine/engine power reduced warnings flash. Pull over, turn car off for a few minutes and then start it and it drives ok (can still tell there is something off though). Took it in to be checked out this last time and came up with no codes and no one has any idea of whats wrong, they offered several "possibilities" they are willing to fix for a large sum of money. Not interested in getting in any accidents as all four times have been very random but I cant spend all this money and just cross my fingers ~ Any thoughts or suggestions?
    prochieprochie Member Posts: 11
    Same with the 04. Check the ground cable by the battery. This will fix the loss off acceleration and dash instrumentation.
    We would be happy to look into this for you. In order to do further research and perhaps set up a case, we will need your name, address, phone number, VIN, current mileage, and dealer name sent ot Christina by email. Thank you in advance.
    Tricia, GM Customer Service.
    chrishvrchrishvr Member Posts: 2
    Did you find a fix for this? I have the exact same car with the exact same issues. I had the stalling when trying to start it at first and then just this past weekend it started dying on my when I was accelerating. Just took it in to a mechanic today and they weren't able to pull any codes off of the computer.
    I’m sorry you weren’t able to get a diagnosis with your mechanic – was this a dealership? We can follow up with them, if you like. Email Christina with your name, VIN, contact info, and the name of your involved dealership and we’ll move forward from there.
    Best,
    Sarah
    GM Customer Service
    ls14everls14ever Member Posts: 6
    Does the engine have a camshaft sensor? Maybe it's bad or the parts guy gave you a cam sensor instead of a crank sensor. Some manufacturers use almost the same sensor, just values are different. If it was a bad ECM don't you think GM would have a Update for your problem.
    Was the steering column replaced or dropped down for another type of repair?
    Or was the steering wheel removed/reinstalled for a repair? Where I'm leading to is perhaps if the upper & lower steering column covers were removed possibly on reinstallation one of the 2 mounting screws pierced the anti-theft wires and at times causes the control module to think the car is being tampered with going into failsafe mode and stalls cause the system either doesn't read the resistor on the ignition key or it shuts down the fuel pump. With road vibrations it could be just the right bump or movement of the steering wheel to surface your ghost problem. Good luck! :shades:
    Has a shop run a test on the fuel injectors? If the problem is a failing injector with the kind of mileage consider replacing all of them. It's gonna be pricey but if your keeping the car it's the way to go. :shades:
    Behind the factory radio there's a black box the size of a pack of cigarettes. That is your daytime running light module. The mother board of the module is partially fried by someone who tried replacing a bulb somewhere with the wrong type and shorted out the module. :shades:
    smv1smv1 Member Posts: 14
    thie engine does have a camshaft sensor and a crankshaft sensor.
    adollaradollar Member Posts: 1
    Hey im having the most problems out my car since i paid for it. Well about 3 weeks ago my car started shaking so bad and my exhausted pipe was putting out a horrible smell. I took to the Amoco the man put it on the machine and he said it said that it was my Chore. So my car have three and he checked all three and my first one wasn't giving no fire. So I had it changed but about 2 days later it started doing the same crap over again I took it back and the same Chore had went back out. So it got replace again, now I was taking my little boys to the bus stop and it started shaking again but this time it went dead and when I finally got it started back up it barely would go. Please help me!!!!!!
    Mine issue ended up being the MAP sensor. Haven't had an issue since this was replaced!
    If you have a good diagnostic GM mechaninc tell him to run a fuel injector balance test with a noide light. He may find a bad injector. If so consider replacing all of them. It may be costly but if you have a good car its worth the investment.
    fastredgtpfastredgtp Member Posts: 4
    I had this same problem with my 2003 grand prix gtp - the crank sensor was failing. After replacing that sensor everything works fine.
    I made the original post for this thread about my 2003 Pontiac Grand Prix GTP that dies mysteriously. Posted Jun 08, 2008 (11:11 am)
    What fixed my stalling issue was having the crank sensor replaced.
    You may have your issue resolved by now but if you haven't, here is some info. As you can see multiple folks have different suggestions. I have had both MAP (mass air sensor) and the crankshaft positioning issues. When MAP fails, car chokes a little when you are accelerating, the engine may or may not stop, also your RPM will fluctuate when you are idling occasionally the engine killing. You get a MAP code. The crankshaft sensor figures out the firing order of the cylinders, when it fails, the engine stops at any speed, you could be on the highway doing 70. Fortunately, after you pullover, and put the car in park, it will almost always start. More than likely there won't be a code thrown that's why crankshaft sensor problems are tricky. If you have a failed fuel injector, the car will run rough almost always but it shouldn't stall especially with a 6 cylinder engine.
    prixdicprixdic Member Posts: 1
    The dic is blank checked fuse its good only thing that lights up is low trac, trac off also my gas guage is giving false readings ie; empty when tank is full
    morgan71morgan71 Member Posts: 25
    Hello all,
    I am having what appears to be much of the same problem as many of you are having and I need help. My 2004 Grand Prix GTP has around 73000 miles. Back in november my car wouldnt start. It would crank but didnt fire. My mechanic replaced the fuel pump and the car ran fine up until a week ago. I had my car running idle for about 15 mins with my wife in it, when i came back to the car she told me it started to run rough and a light came on. She turned the car off and couldnt remember what light she saw. A week later as I was driving home locally my car cut off, my traction control warnings came on saying service, I was able to get it to restart only for it to cut off again a short time later with the same results. My mechanic said the fuel pressure was low so they again replaced the pump. Got the car back and it ran fine for 3 days and again driving locally it died again with the same indicators lighting up and wouldnt restart. To make note, I dont even hear the pump hum when the key is turned on. Please tell me my pump has gone out again. Its barely 3 days old. I dont know if it could be the crank and cam sensors or the ignition module or if there is something else going on. Any ideas and advice would be appreciated.
    Get the crank sensor replaced....
    That is what is causing your car to die....
    Hi fastredgtp,
    Thank you for your quick response. I appreciate that. I kinda thought so because I had this same problem with a 99 chrysler 300m but after reading many other posts on here I just want to be sure. Have you had this problem too? If so did this rectify it and did you replace it yourself or take it to a shop?
    sylvester2000sylvester2000 Member Posts: 1
    2000 Grand Prix GT 3.8 non-supercharged engine was randomly stalling when at operating temperature, at any speed, at any rpm, or idling. Ran well when it ran, but RPMs would randomly drop to zero and the engine would stall. Worsening occaisional no-start condition with no spark. All power in the vehicle remained on. Sometimes would start right back up and other times would not start for 3-30 mins.
    No check engine light and so no codes to pull. No traction light issues which sometimes occur when the crankshaft position sensor is failing. I didn't want to change the crankshaft position sensor because, quite frankly, it sucks. Changed the ignition control module. No change. Changed plugs and wires with no change. Finally decided to change the CPS. After much research and finding conflicting information I compiled a procedure with just the truthful parts I found and it worked beautifully and the car runs perfectly now. The CPS on these cars fail. If you have decided to change yours out it is a $35 part and is DIY with the proper information, which follows, some ingenuity, and some mechanical apptitude:
    Jack and secure car. Remove passenger side tire and the plastic wheel well. The clips will probably break, so buy new ones at a hardware store later. Number and remove spark plug wires from the ignition control module so the car won't start. Remove the center bolt (15/16th inch head) from the harmonic balancer. Easiest way to do this without a doubt is to postion a flat wrench on the bolt, rest the boxed end of the wrench on the car frame in front of the harmonic balancer, and tap the starter. Remember to disable the car from starting. Bolt will break loose. To pull off the harmonic balancer use a standard harmonic balancer puller, but you will need special grade 8 bolts and washers. 1/4-28 bolts, 3" long, one inch of thread is o.k. Place a short 3/8" extension in the crank bolt hole to protect the threads. Carefully, by hand, thread the specialty bolts through the puller and into the 3 holes on the balancer that seemingly have no threads. The threads are farther in and not visible. Make sure the bolts are straight, and inserted to an even depth into the harmonic balancer. Use washers or the bolt heads will gouge and pull through the puller. I turned my specialty bolts 15 quarter turns into the harmonic balancer. Turn the puller's main bolt that it is pushing on the 3/8"extension you placed in the crank bolt's hole. Balancer came right out/off. Remove crankshaft position sensor shield. Mine was plastic. Spread the teeth that connect the shield to its bolts with a small standard screwdriver and pull/pry just a bit. No reason to remove the shield from the bolt farthest towards the rear of the car. You'll be using thread glue on the main bolt when you put in in so you can use some of that on the shield where it connects if you mess up the plastic teeth on the shield a bit. Remove the old sensor's two bolts, and save the part to torture in fire later. Bolt in new sensor, replace shield. Line up the harmonic balancer with its cotter key deal and start pulling the balancer back on with a torque wrench. To keep the engine from turning open the smalll access hole to the flywheel on the bottom of the car (two bolts). Place vicegrips on the flywheel or wedge something in the teeth. Tighten your glued main bolt to 112 lbs plus 76 degrees. You now have a car you can count on and need not worry about it dying while driving down the road. I love mine now. Just wish someone would have made these all inclusive and accurate directions for me.
    Hello all,
    well I figured out what my problem was with my car starting and stalling out. It was one of the connectors to my fuel pump. The connector with the four plug connection, a couple of the wires were loose. I simply went to a pull a part yard, found another connector just like it, spliced the wires and crimped em together and tadaa...it fired right up like a champ and has been running smooth and good as new all day. So anyone else that may be having this problem, check the connector to your fuel pump as well. You can let down your rear seat, lift the trunk liner and you'll see the cover with 6 screws, this is where your pump is and is easily acccessible. Hope this helps.
    Kirstie_HKirstie_H Administrator Posts: 11,148
    An automotive organization would like to speak with used car buyers who bought cars that they later found out were not up to date on recall repairs. If you are willing to discuss your experience, please email PR@edmunds.com no later than 10 a.m. Pacific /1 p.m. Eastern Friday, April 20, 2012 with your daytime contact information.
    MODERATOR /ADMINISTRATOR
    Share your vehicle reviews
    shar0513shar0513 Member Posts: 1
    I have an 03 Grand Prix that started making this lovely noise while I was on the freeway, the check eniine light came on, and it wouldn't get above 45, seemed to not be getting any power. I had a mobile mechanic look at it and he hooked his computer up to it. He says it's cyhlinder #2, and after a compression test, he says it's a 30 psi. Anyone else have this problem or have any thoughts? I have been told I am looking at $1500 in repairs.
    Oh wow. Sorry to hear that. Hmmm...I would say try to get a 2nd opinion just in case. If I may ask what kind of sound was it making? If it is the # 2 cylinder, this can be a very expensive job as they will need to get into the internal part of the engine. Here's hoping it may be something else less expensive and worrysome.
    darlajdarlaj Member Posts: 2
    I have a 2007 Pontiac Grand Prix with 49,000 miles. At first the car would just die while driving, like someone unplugged or cut off the engine, no codes, no warnings, nothing. After the car would sit for two or three days it would start, run fine for a week or two and do the same thing. Took the car in several times to a GM mechanic, at first they could not duplicate the problem but when it finally happened to them they first replaced the ignition module, same thing happened again, then the crank sensor module, shaft whatever it's called was replaced, same thing happened again. Now the car won't start at all and "computer system failure" is popping up......can anyone tell me whats wrong?
    First things first. If there's a no start condition but the engine is trying to start. First a good diagnostic mechanic would inspect for ignition spark and fuel delivery. If one of the two is not functioning correctly that's why there's a no start. If there's no spark I would check the ignition coils. If there's no fuel I would check the fuel pump. Does your car have a alarm system? That could also cause the no start. Without no check engine light or codes the mechanic has to go to the basics. A lot of young mechanics with out trouble codes to direct them to the problem are lost. Those kind of mechanics will start installing parts guessing if that's the problem. No diagnostics or confirmation of failed part as you already experienced by a so called GM mechanic. Don't forget if you get that call you need this part your first question is how did you diagnosis the problem. Write down what he said he did to confirm a failed part and get back to me.
    gmcustsvcsarahgmcustsvcsarah Member Posts: 1,964
    darlaj,
    I'm sorry to see that your dealership is perhaps having a bit of difficulty in locating the root of the concern. If we can follow up with them, please email us at socialmedia@gm.com with more information (include your name/Edmunds username, phone and address, the last 8 of your VIN and current mileage, the name of your dealership and appointment details on visits pertaining to the no-start concern).
    Sarah
    GM Customer Service
    STAY AWAY from the dealerships they will fleece you for parts and not resolve the issue.
    Check the ground cable near the battery. Typically, there is build up on the copper eye that is bolted to the frame. Remove the cable from the frame, sand it down to remove the build-up, bolt it back onto the frame, and paint with rust proof paint. There is another ground cable attached to the engine but I routinely just check the one by the battery. If you want a pic, I can send those. Try this before replacing sensors, etc.
    The throttle body also gets significant build-up but this wouldn't keep you from starting - just rough idle. Your issue sound more electrical / ground related.
    My 2005 Grand Prix had the same issue. SIX GM dealerships couldn't tell me why my vehicle would go dead flying down the highway with no gas, pwoer steering, or instrumentation. My initial dealership was Roy Foss in Woodbridge - what a bunch dishonest crooks. I hope they lost their dealership in the cuts. I would buy another GM Vehicle but for my experience with these dealerships. Buy FORD next time they appear to know what they are doing.
    thanks Poochie, I will try it and see what happens. To Sarah, thanks but My issue goes a lot beyond what I would like to discuss on this forum, I'm out a lot of money and have a vehicle I can't drive. I will just leave it at that, I'm just looking for some answers for my own benefit.
    batwranglerbatwrangler Member Posts: 2
    we repaired the ..o2 sencer,,,check eng light went off,,,but D.M.V. says codes read "not ready yet" do you have to drive the car 50 miles before the codes clear?
    nicole586nicole586 Member Posts: 1
    edited July 2012
    i have a 99 grand prix gt. it was running great. then i went outside to leave and it wouldnt start. it turns over and everything just wont stay on. when you first try to start it after it has been sitting it will stay on for about 5 mins then it chokes out. after it broke we changed the spark plugs and wires, we also changed the mass air flow sensor. after we changed the sensor the car did one good drive then it did the exact same thing. the car will sometimes stay on if you keep the rpms over 2k. can anyone please help me so i dont have to take it in. :sick: any questions you have to ask ill answer to the best of my abilities. i just wanna try to fix it. i also just read that when your crank sensor goes your trac light turns on. i would like to know if that is true. cause mine has been on for a week and i cant turn it off :surprise:
    I had a 99 chrysler 300m that did the same thing, it turned out to be the crank and cam sensor. I would suggest you take it to your mechanic and have them retrieve any trouble codes. At least this way they can tell you exactly what the issue is and what it will cost to fix it. It sounds like the same issue to me. Hope this helps.
    begglestonbeggleston Member Posts: 1
    edited July 2012
    sometimes it wont start and sometimes it does...when it does start it runs great...but when it don;t start i have to turn the key over til the radio and lights works...wait until the secruity light goes out...then i turn it off and pull the key out and put it back in and the car starts...can anyone help me with this?
    thanks Bill
