Chrysler Sebring Starting and Stalling Problems
ok, i had to change the water pump on my 96 sebring lx, so i changed the timing belt also since i was there anyway. when i did this i put the timing belt on with the timing being off then tried to start the car ( of course it didn't start but it also didn't breat anything) so i took everything bake off an got some help putting it back together the right way ( with the correct timing) but now my car wont start at first i thought it was the battery because it was low so i replaced it, still no fire i have checked everything i can think of but no idea whats going on. the engine is turning and every once in a while i will hear a putt but other than that no sound other than the engine turning. what do you think it could be?? help please my wife is flipping out because her car isn't working.
See also: Resolving Chrysler Sebring Engine Problems
Everything else is still on like the radio and everything and the local mechanic and the dealer said that without the check engine light coming on its hard to tell whats wrong. I have replaced Fuel pump, auto shutdown relay, some sort of fuel relay, and catylic converter. Throttle body was also cleaned. Chrysler told me they didn't have the tools to fix it and I should try a mitsubishi dealership.
Please help! I have put over $1,000 into this car and I only had it for 1 month. I have seen other posts online with people having this same problem, but no one posts the answer. Thanks
I am new here, and like a lot of you wish I didn't have to search for answers!
I started my 99 Sebring jxi Conv just like I have started it a 100 times before, and then I unhook the front roof clamps and hit the top down button and the car died. I have been trying for the last two days to start it but it just will not. It would crank over the first day, the second day It just clicked. So I jumped it with the van and It will only make a clicking sound. I'm baffled, Any ideas will be greatly appreciated.
Jim
Richard
Since then my wife and I love traveling in our Sebring Convertible and are proud to be a member of the Sebring Convertible club. Young and having a ball at 60
Richard
I just bought a 97 sebring in March and already i am soo frustrated!!! I'm a student so taking care of this car has become the biggest headache. I was driving one day, got to a light and the car simply died on me. It wouldn't start after that. It would crank but not turn over. A driver pulled up next to me and told me to press on the gas and i did and it started.
SInce then its been doing the same thing (starting problem) occasionally. A couple days ago it died on me again while driving. Same thing-pumped gas pedal it started. I decided to tow it to the shop since this seemed like a problem that was not going away. Mechanic told me it was gas filter. Changed that and i went on my merry way.
Today i wake up to go to work and again it will not start. It cranks but no turnover. The mechanic seems to have no clue what is wrong and i just can't afford another "false fix". Please please please, if you've had this same problem and successfully fixed it let me know, so i can give these people some idea of what might be going on.. I'm at my wits end right now.... Thank for the replies in advance.
Chris in Georgia
My other reading at Allpar.com says many/most problems are fairly cheap sensors, especially TPS (throttle position sensor) Crankshaft position sensor, and Camshaft position sensor, and lastly (?) whatever Chrysler calls the speed sensor that tells the computer that car is *moving*.
OH... and on older cars the Coil, and sparkplug wires.
A lot of these apparently won't throw a code, but you can check many with a multimeter.
Lots of problems are almost a joke - stupid corroded connections, and loose connections, things that are cured with umpty hours of thinking *where* the problem might lie, and 2 minutes cleaning the connector up.
There are tons of resources on the WWW to help -- don't throw up your hands and empty you wallet to the Dealer - INSTEAD - do your Research!
TRY (for starters) Click HERE
http://www.allpar.com/forums/
Do a Google search for say: sebring starting problems
People have gone thru this crud before, answers are there, but you might have to devote several hours to finding them .... or luck out 1st try. GOOD LUCK!!
The car was in acceleration mode to pass another car when the car felt like the engine started chugging and like the car wasn't getting any gas. The tank was full. The car will turn but will not fire and crank-then we replaced distributor. Now it won't stay cranked and running.
HELP!!!
Mark
He said his aunt took perfect care of her car and one day at a red light it blew up. The motor had to be replaced because the water lines run through the motor and if they begin to leak, well it's ruined. Replacement was more than $4000.
My mechanic says that can be changed out. He just doesn't like Chrysler products.
I'm willing to buy one if I can make sure that change has been made. Does anyone else know of this problem and the remedy? How can I tell if it has been done already?
Thanks!!!
Has twice blown the Fuel/Start 20A fuse in power distribution center under hood.
Any ideas or fix to this problem?
:confuse:
Ted
I've got a 98 thats acting up, seems it wants to die out sometimes at stop lights or when you decrese the excelleration. I'm pulling a code P0172,I can't seem to find my code explanation book. Does anyone have a good idea what this code is referring to???
Dwayne
I'm not a mechanic either, so maybe someone who does it for a living will jump in here.
You can reset the computer if you think it might have adjusted to being driven in warmer temps for all these years. There is probably a main fuse to do this but the sure way is to disconnect the negative cable to your battery and leave it off for an hour or more. After you reattach it and start the car let it sit and idle for several minutes until the idle RPM settles down.
Other things to consider that might be heat-related are the plug wires. If the wires are going bad heat will magnify the issue. If they are the original wires it's time to replace them anyway.
Do you know when it last had a tune-up? Maybe new plugs while you're replacing the wires. Does the air filter look fairly clean?
I once had a car that ran well most of the time but it stalled out for no apparent reason. A service department discovered debris in the tank and a clogged fuel filter. If I let it sit for a few minutes the debris would settle back down and it would start right up.
You might add a fuel filter to the tune-up list. They're usually not too hard to replace but be sure you depressurize the fuel line before removing the old one or you'll get a fuel bath. Your owner's manual or the fuse box cover should say which fuse goes to the fuel pump. Remove it and let the car idle until it stops from lack of fuel.
Lastly, you might add a can of a quality fuel injector cleaner to your tank.
Dwayne
I don't know very much about cars. But, your problem sounds exactly like the problem that I had recently with my car. It needed a new TTC or something called a torque solenoid. I would call a transmission shop and explain the problem you have been having, mention that you think it might have something to do with the torque solenoid and see what they say. It cost me about $300 to get it fixed in California.
Also, another word of advice, always make sure you have enough antifreeze/coolant in you car. I had a major problem with mine when I let it run dry. The whole lower half of the engine had to be replaced, but at the time it was actually cheaper than buying a new car.
Let me know what you think, and if that is what was wrong with it.
