Read this and do not ignore.
After 8 months and $3000.00 paid to Caroll Pontiac in Halifax N.S. they were unable to find the source of my electrical problems which include but are not limited to:
- key stuck in ignition (Check fuse # 44 and 42 under your shifter center console)
- Corroded wires leading to fuel pump
- shorted out starter
- switches in shifter disallowing me to turn car off or remove keys
- all the brake related warning light come on a beep when going uphill
- Warning light for transfer case, traction control, brakes, ABS, security system, door ajar and many others
Many other electrical problems and to many to type.
Now I was about to install a new Body Control Module costing $400. just for parts, after Caroll pontiac informed me that the must install it at $80/hr because it had to be pre-programed 1st I decided to get a second opinion from McPhee Pontiac (a separate business in Dartmouth N.S.)
After 60sec on the phone he offered me this solution and saved me over $400.00.
What the supposedly qulified Automotive Techs at Caroll Pontiac were unable to tell me is this:
The Aztec has a HISTORY of leaking from various points into the interior of your car. This water ingress finds its way through the frame and gets under your carpet. Right behind your drivers seat there is a huge electrical connection with about 25 diffetent wires going into it. The water will seep into this connection and cause electical shorts to MANY of your systems. Do not think because your carpet appears dry you do not have this problem. The carpet has a vapor barrior on it. I had many puddles of water throughout the floor of my car. All the electrical connections behind my seat are coated with corrosion and the water forms a electrical bridge between the various connectors causing shorts.
I advise every aztec owner to pull the carpet back and feel under the drivers seat and expose the connector to see evidence of water. I have yet to fully determine the area where water is getting in to my car. I currently have the entire interior ripped out of my car and have determined it is either my roof rack or from arounf the frame of the rear hatch. LOOK INTO THIS IMMEDIATLY BEFORE IS ALSO COSTS YOU THOUSANDS OF DOLLARS.
I had it towed to Caroll Pontiac in Halifax N.S., I reported to their service area and explained the senerio. They decided to leave it out all night with the keys still locked in the car. After the sun went down the headlights came on and stayed on all night, well until it drained the battery. The temperature that night was -10deg C and it froze my battery solid. The next day I was charged almost $400.00 to replace a fuse (#44 which is for the Accessory Voltage from the Body Control Module) which blew and resulted in the keys being locked in the ignition and unable to shift. They also charged me to replace the battery that froze over night due to their negligence.
Oh and yes I have told them I was reporting them to the better business bureau, GM Canada, the Media and so on. Their reply was "Oh, well have a nice day."
I am sad to report I dont have a sun roof so I am still looking for the source.
You didn't mention anything similar to that in your first post but why would anyone have anticipated the headlights coming on by themselves when the Sun sets? Had you mentioned that autonomous behavior to the dealer beforehand?
Just curious.
I will have to lift the carpet and check where "gmhater" suggested. Hopefully, this is the cause and I can stop up the leaks and dry out the connections!
My dealer ran a diagnostic on my computer and checked a few connections, but did not find anything. They certainly did not check under the carpet inside the car!
My hatch will not open either, and has been like this for a couple of months, could this also be caused by a short from water leakage to the same area? It will not open via the remote or the key, so I suppose it could just be jammed. Does anyone know how to remove the plastic trim from the tailgate while it is closed?
The connector problem I believe is related to wiring that goes from inside cabin to underneath vehicle just behind drivers seat and can have ramifcations to anything towards the rea of vehicle I think
The vehicle, I named EXZUR, is a yellow 2001 Pontiac AZTEK GT AWD. The car already has almost 104,000 miles on the odometer.
Also, anybody knows when to service the carrier assembly - differntial(rear drive module) and transfer case(power transfer unit)? I mean replace the fluid.
Responses will be appreciated.
Thanks Ray80. What I saw in the manual, is the check up interval for the Versatrak fluid. Add the fluid if there is a need to. There's no mention of fluid replacement.
The fuel filter that I had replaced at 100,000 miles is almost clogged. The power steering fluid is dirty, so I had it flushed and replaced too. These two issues are not in the 2001 Pontiac Aztek Operation Manual.
I did find an owner that had it replaced. $144
Why, I want to get it done is because I heard whining noise which I think is coming from the rear axle.
My other concern is I feel like the transmision takes a longer time to shift into overdrive.
I see a few Aztek owners here. I have an 2001, nothing to fancy, would have love to have the Rally. I loved the funky design since it's release and bought one 2 1/2 years ago. I've never had any problems with mine and I just recently added remote starter too it.
CaliberChic
Wagons Host
Both my Mother and myself own an Aztek and both had/have the same problem. She had hers fixed under her warranty as she had a 03' but I've never taken mine in. I just :mad: and
Could be a few things I now of that could cause it. Assuming you don't have the spare tire on (which will turn those lights on), it could be something as simple as a tire(s) that are low on pressure, I would check that first (its cheap). Other things it could be are a bad sensor in wheel hub assembly (or perhaps the connector to one came loose) or there is a wiring harness connector that runs under drivers seat and down under and to the rear of vehicle that in some cases gets some corrosion and creates troubles. I'll see if I can find any other possibilites.
I am not driving the car until I have it checked. Any idea what the problem is?
The car is a 2001 Aztek AWD GT with 105,000 miles.
The Dexcool coolant was drained and replaced with a different brand. That fixes the problem.
Dont't rely on the looks of the coolant in the plastic container. The level may look good but it's not, specifically if the dexcool stuff is in there.
It's $27.50
I read #70 and #40 message on maint. and repairs for the Azteks.. I have the same problem My light has gone out and I was wondering if anyone had this problem and how they fixed it. I can read mine with a flashlight too and my traction control acts up once in a while ( there is no ice - it's spring)This happened just before my light went out. I wonder if it is affiliated in any way. Anyone out there who can give me some advice?
