They replace Speed sensors Wheel hub
wiring harness and computer. Fort the ABS
Will keep you updated
What you are describeing sounds like a parisitic drain and they can be pretty hard to find, even by the dealer, unless its a known and well documented thing with the vehicle. I have not heard of any common troubles like this with the Teks (other then a limited number of very early ones which should have been fixed a long time ago). Is it the original battery?
I am wanting to do preventative maintenance on the vehicle. Generally I want to try and stay ahead of some problems.
What are the most important things to do.
I am conseidering haveing the tranmission fluid changed w/ filter.
also flushing the raidiator - should I not use Dex Cool to replace the radiotor fluid.
Timing Belt - is this an issue with the Aztek? I know that cetain vehicle you are supposed to change at 100,00k miles.
Fuel Filter- had it changed at 45,000 miles
How long do brakes normaly last, I would think that at 74,000 miles of average city/highway use that they are getting close, rather do it too early than too late.
The owners manuel is somewhat vague about maintance.
rob
armstrong
redbeardtheroadguy@hotmail.com
roba
BTW, I have a 01 Aztek with 66,000 (engine has 46,000)
Lee
Is this a reoccurring problem? If so, I don't have the tools nor the expertise in this area. I wonder how much it is going to cost me (parts + labor)?
Thank you, yet again Ray.
Where To Find Your Car Owner's Manual Online
One other thing I just found in looking around is one case where there was bad contact in big harness to main ABS module under hood. In this case just a change of a wire corrected problem (one more thing to add to laundry list of possibilites listed here and in Vous forum, if not other places)
CapnDave
Dealer did scan the codes (so they said).
Thx for the heads-up on the big harness.
I really hope someone could help me! My 2001 Aztek, 117 000km has been great, compared to some posts read on here tonight, but for the past 6 months my Aztek seems to want to over heat. My husband fixed the Thermo sensor and relay's and it still wants to over heat. A mechanic did a test and the fan does work, but it didn't appear to have full power. The mechanic said, "It's a wiring problem". If anyone has had a similar problem or could suggest what else to check that would be great! Our beloved Aztek may be getting traded in soon, if we can't figure this out.
I have a 2001 Aztek, 117 000km, and during the past week while it's in park, the transmission is making a noise. When I take it out of park you really can't hear it anymore. Any suggestions on what this could be. Also, I've posted a question in the electrical concerns. My Aztek seems to want to overheat. The engine fan won't turn on. We were told it was a wiring problem and from reading all the posts on electrical concerns, it doesn't give me a good vibe. Any suggestions would be wonderful.
My heads up display including the digital speedometer still works, but my analog fuel gauge, tachometer, speedometer and temperature gauge are all dead. Could it be just a fuse or is it likely that something more serious is involved. If it is a fuse, which one is it that need to be replaced? I looked at the underside of the fuse box cover and don't know which one deals with the instrument panel. Help please!
Did your mechanic do anything about it and, if so, did it work?
SUVs and Smart Shopper
