1) You might want to go to a different service garage because it seem your service garage is milking you. Take it to a Pontiac dealer for the repairs because they are very familiar with the problems of the Azteks. You can also take your Aztek to a Buick or other GM dealers because the Aztek, Rendezvous and many other GM vehicles use the same kind of engine. The dealers charge you more, but they can correct the problems.
2) My Aztek's engine probably had a engine head cracked at 130,000 mile, a year after I had paid $900 for the defective of the intake manifold gasket. I decided to get a rebuild engine to eliminate the chronic engine problems and this costs me $3,000. I wanted the new parts for my new engine (betls, sensors, engine rubber blocks, wires, hoses, etc.) at an additional cost of $1,000. Total: $4,000.
I hope I won't have to deal with the engine problems for awhile and I still think that was a well spent money.
I fixed it temporarily by pulling the ABS fuse. Sure enough, all problems gone. Unfortunately, the alarm bell never quits. Knowing that all GM bells/alarms are fed through the radio, I pulled the fuse for the radio too, now all is well. Of course, warning lights are still on and you don't get any warning when you leave your keys in the car.
I plan on inspecting the harness next weekend.
There is a very annoying beeping noise that comes on along with it.Can someone please tell me what to do to stop this madness.
Mike
Thanks Mike
ore trying to change the thermostat. Also you may want to recheck to make s=
ure the fuses are in the correct slots. One for low fan and one for High fa=
n, it is real easy to have them in the wrong locations. Thermostat is under=
the air mixer, or what ever it is called. And it is a real pain to get to.=
1 remove everything that is in the way 2 make any special tools which will=
help 3 say your prayers. I changed mine 3 times, the second time I=A0reali=
zed that I had put the old one back in instead of the new one so had to sta=
rt all over again. The first time I changed it it tool 6 1/2 hours, second =
time 4 hours and the last time 3 hours. There is a small trick for getting =
the rear bolt back in. Cut a 3/4 x 10 inch chunk out of a plastic bottle an=
d drill a hole at one end and slide it over the bolt to hold it in place wh=
ich you make small=A0partial=A0turns with a open end wrench. A socket
will fit on the front bolt because there is room, and use a long extension=
to reach you ratchet at the wheel well. The extension will pass through ev=
erything. You will also need to remove the nut for the pass over line which=
is on the air intake thing. Good Luck, it can be done. Nothing worked for =
my car and dexhell finally killed it. My mistake by mixing the green stuff,=
then tap water, then having it flushed with new dexhell added, still overh=
eated and then added bottle water again and then tap water. My first mistak=
e which may have caused the whole problem was when I added the green coolan=
t. I miss my Tek
SUVs and Smart Shopper
is a dealers computer.
which is essentially the same car and has the exact same drive shaft except however OUR GOOD FRIENDS at GM made sure that the location where it attaches to the frame is just off by 5 inches to ensure that you have to have an AZTEK drive shaft . THANX GM you S.O.B.'s
But hey I still love my Aztek
I do have a new problem now though. The instument lights and all the dome lights don't work anymore. I pulled the fuse from the inside fuse box and it was blown. When I put a new one in it blows as I am inserting it. Now have to figure out where the short could be.
Anyone have any ideas.
Mike
Mike
Mike
