DAVE Sz.
First started 6/4/07 took car to deal.
Dealer state the sensors is corroded and will not be covered under you extend warranty.
They clean the sensors and charge me $200 dollars. According to the work order I was not charge any parts. So just 200 for labor to clean a sensor
Pick up the car that night the dashboard ati-lock (ABS) light came on and stay on.
Return car back to deal they had the car for almost 2 week and replace the wheel bearing assembly. They state this should fix the dashboard ati-lock (ABS) light .
Pick up the car that night went to stop the car and the ati-lock (ABS) light came back on. Return car back to the dealer had car for 5 days said one of two things the EMC or ECC some ati-lock (ABS) computer or the wires running from the sensor to the computer is shorted out. They “jumped the sensors” by passing the engine wire harness so there is a direct path form the ABS sensor to the ABS computer. The deal state that is was fixed. Currently have the car and test driving it now 6/27/07
Look like a lot of ABS problmes I have a case open with GM right now. Pleas I would like to know if any one had the ABS problem fix correctly
As far as your complaint with GM...Good Luck!!! We did that, went all the way with BBB to file Lemon Law...they agreed the car was lemon and would buy it back, but failed to mention that we would have to pay a "usage fee" determined by our mileage. So we get to the dealer to turn the car in and GM wanted almost $4000.00 from us!!! Money we didn't have, so we had no choice but to keep the car and now it has become one problem after another. If the problem has been listed here on Edmunds, I can almost tell you we've been through it! That is why I would love to find out about a class action suit against GM, there are hundreds of us on here who have the same problems on a daily basis...and quite frankly this whole ABS thing is very unsafe in my opinion...and I have two small children that ride in this vehicle and that makes me very nervous.
Please let us know if they do find a solution for your ABS problem...and we will do the same.
Thanks so much!
been in the whole month of june
I'm sure I speak for many of us when I say that your input on these boards is priceless!!! Thanks again!
I have the same issue many of you have. The fan settings are failing one by one.
now only 4 and 5 work.
From my understanding it is a blower resistor assembly that is causing this.
My question is.
How do i get to this part? Ive heard its in a tight spot but is accessible, but where is it? I can get a new part for $27 but as with everything my mechanic wants $400 to replace it.
How do i do this my self?
Lately, after fueling up, it sputters upon restart, not starting for at least thirty minutes or so after the problem happens. I took it to pepBoys and had the charge system checked and everything was okay. I also replaced tha battery and it was fine, until it started again. Today, after fueling it again stalled and I called and had it towed in. It will sputter and sound like it's out of fuel and so I'm clueless as to what this might be (Fuel pump?)
I also see that it looks like Dexcool is poison for these things and wondering when my gaskets will go out now. I'm thinking I need to have the Dexcool taken out?
ANyone had similar problems with their Aztek? I could use some advice!
Sincerely
David
Blazefighter348@aol.com
The fuel thing sounds familiar too, ours wasn't as drastic but changing the fuel filter might help. We had the fuel system cleaned and then ran a few tanks with the cleaner in it...that helped still have some minor sputtering.
Do yourself a favor and find a local mechanic who is trustworthy to do your repairs...GM will charge you out the wazoo if you are out of warranty. Been there, done that!
Hope this helps!
-Gary.
Does any one have any idea what the problem might be??
Freddie
package that also includes the mattress? The items are brand new, never taken out of the box!
And welcome btw!
They have tried everything with ours and nothing will stop it. The ABS problem has gotten much worse, and is really quite scarey...I really don't know what to do at this point.
Took the car to a dealer who said it would be worth about $3,000.00 and we owe $14,000.00, there's a reality check!!!
And yesterday the radio faceplate went completey out also...so now I can't tell what time it is or what channel I'm on, much less what number song is playing on a cd.
Please post any other info. on the ABS, hopefully we can figure this out without another major expense.
Thanks!!!
I'm keeping my fingers crossed that the new computer did it for my problem.
-Gary.
So glad to hear that your Tek is better!!!
My local mechanic was able to find me one for $300 + $100 to install and bleed the brakes. He said a new one from the dealer would run $900 so it made the choice easy. I don't know where he gets his parts from but he has always done well by me regarding aftermarket and now used parts.
Good luck with your Tek!
-Gary.
Thanks for any help.
Ryan
I've replaced head gasket, intake manifold gasket, condenser, tires, brakes and rotors, pigtail sensor and the above-mentioned parts in the last 6 months. I'm tired of putting cash into my beloved Aztek...
Our newest thing is the fact that you can remove the key from the ignition while the car is running...the other night I thought I had it completely off and removed the key, only to find out that it wasn't all the way off so the lights remained on and that almost drained the battery...
For the hatch (assuming it is happening in warm weather), try this: lift the hatch and you should see a rubber bumper on each side. Turn each out a little bit (counter clockwise) maybe a 1/4 turn or so and see of its better (turning them out to much wouldn't be good, will set ajar ligh on).
Ryan
I had your problem, I found by shear dump luck the problem that fixed mine. Look under your car on drivers side, just a little behind where the front and rear door meet there are 2 (on my 2002) wire connections that plug into floorboard. The connector was corroded, I sprayed electric cleaner and put some electric gell on it, plugged it in and has worked fine eversince. I did this to both, but the connector with the wires going to the fuel tank was the problem.
