However, just recently the transmission has been having problems. I switched out another relay and it seemed to work for a while but is now having problems again. Not sure now if this is an electrical problem or not...
Thank you for taking the time to post your concerns. Have you spoke with your dealer of choice yet? If not, I would recommend starting there. Please feel free to email me directly with any questions comments or concerns.
Christina
GM Customer Service
SocialMedia@GM.com
Have you been able to get the vehicle into a GM dealer? If not, I recommend starting there. Please keep us updated!
Christina
GM Customer Service
SocialMedia@GM.com
(after buying a new battery and paying $50 to remove the after-market alarm system. which neither probably had to be done)
This is exactly the problems i started having with my 08 vue in may 2012. It so frustrating because it could be months betweeen "episodes" and it usually resolves itself in a matter of minutes. That would be all fine except i cant afford the safety risk when it lose power/doesnt accelerate when i am drivin on the highway.
did you ever find out what the problem was and how much did it cost to fix it.
about to trade it in! rrrgh!
Thanks for your help!
Vue_Knew
Were you ever able to have a dealership duplicate this concern and provide any sort of diagnosis? Just checking! If you have and you would like for us to check into this further with them, please let us know by contacting us at socialmedia@gm.com (include your name and contact information and the last 8 digits of your VIN).
Sarah, GM Customer Service
Where is the chassis wire located? I can have my husband clean that and see if that fixes it.
I responded to you with the requested info via my personal email account: gjensen_vi@yahoo.com.
Vue Knew
I don't know about anybody else, but here are the exact symptoms from beginning to end:
1. In the beginning, when I would turn the key to start the car, it wouldn't just start right up, a few months ago, I started having to turn the key, but not all the way count to three, then finish turning it and it would turn over a couple times, then start.
2. The Air Conditioning would only get cold after reaching 45 or 50 miles per hour
3. One day my speedometer did not work at all. The next time I drove, it was fine
4. All the dash lights would flicker from time to time, causing a brief loss of power steering, A/C, and radio.
5. All the dash lights would come on for longer periods of time, and cause longer periods without power steering, A/C and Radio, also when driving at night, the headlights would fail.
6. After a couple of months, the issue was pretty much constant with brief intermittent periods where the dash light were not on, and the car would behave correctly.
7. After replacing fuses, relays, and the ECM, it appears that we are starting all over again. I have spent several hundred dollars so far with no resolution in sight.
Help us Oby One, You are our only hope! (Starwars)
As the ECM replacement and programming did not resolve the issue, we're available to help you continue working through this with your dealership. Please send us more information at socialmedia@gm.com (including your name, Edmunds username, phone and address, the last 8 of your VIN and mileage, and the name of your dealer).
1) a battery for the onstar system needed to be replaced
2) the air bag system needed to be checked
3) the car needed to be serviced asap.
The rep on the other end said that they were all "green and yellow" problems but that it should be ok to drive for a couple of days until it can be seen at the dealership. Ok, great we thought.
Well the hang up button doesn't work anymore either so she had to turn off the car to disconnect from onstar. Well now the car will not start but all of the cabin lights turn on.
These are the worst problems that she has had since owning her car (she bought new). Has anyone experienced these problems? Is it all down hill from here?
S.O.S. Help!
Many have gotten diagnostics performed by their dealers, and the outcome in most instances has varied. Various parts have been replaced, (such as the ECM), wires cleaned, batteries, relays and fuses replaced. And in the end, the same issue still persists. In some instances, the problem appeared to be resolved right after the repair, but returned within days or a couple of weeks. Nobody can say for sure if this repair you have done will resolve your issue once and for all. You just have to wait and see.
I wish you all the luck in the world on this. If this takes care of your particular problem, will you please let us know. I don't know if any of these Vue owners has the Onstar, I know I do not.
Best regards
Toni
We're sorry to hear that your sister's Vue won't start for you. Have you been able to get this checked out since your post yesterday? If you would like to contact us, we can be reached via email at socialmedia@gm.com (include your name and contact information, a summary of the situation, the last 8 digits of the VIN and mileage, and the name of your dealership).
We're sorry to hear that you are having troubles with your door locks and hope that you're able to get this resolved with your mechanic. If there is anything you would like for us to check into for you, please don't hesitate to contact us at socialmedia@gm.com (include your name, contact information, and the last 8 digits of your VIN with your inquiry).
driver door will not lock or unlock with my remote, all of the others power locked doors work fine remotely so i know its not a remote issue . My Saturn Vue purchased brand new and had 44,000km ( 27,300 miles on it ) on it just got back from the dealer , will cost almost $300 to fix anyone else with this problem
Purchase 2009 Vue , brand new , drove it off the parking lot 2 days later battery died. battery replaced and now at 27,OOO told that my battery needs to be replaced again...it there an issue with the battery, have thay been recalled?
I see that you use kilometers - are you writing from Canada? If you need information on how to connect with Customer Service in your region, let us know!
when somone that does not know what there doing is working on a car
thats when this happens. every car has its own problems for some resone. people write everyday . or you can talk in the dealer and maybe that they can fix it for free. you have to call the custmer service. not everybody can fix the electrical issue. there is nothing to worry about.
If you would like for us to check into this further with you, please contact us via email at socialmedia@gm.com with more information (including your name, contact information, the last 8 digits of your VIN and mileage, and a summary of the situation).
