A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
~Lance
Also, I here Buick is coming out with a touring edition that will have the supercharged 3.4, I think making around 225-240hp...Comes from the supercharged Grand Prix, very sweet engine.
We loaded up the RDV with the kids and luggage (and portable crib, sleeping bag, etc.) and set out for the 300 mile (one-way) trip to Spokane.
This trip carried us from Seattle, through the Snoqualmie Pass, which peaks at around 4000', and then across the state to within a few miles of the Idaho border. Some highlights:
1. 22.5 MPG including extended hill climb and strong crosswinds through the flatlands east of Ellensburg.
2. Smooth, silent cruising. We were amazed at how well cabin noise is controlled.
3. Long distance seat comfort.
4. In-car DVD entertainment system for the kids. Don't leave home without it!
Here is a photo of our RDV at the farm in Spokane:
http://home.attbi.com/~fishkin1/wsb/html/view.cgi-photo.html--SiteID-133360.html
Here is our self-installed, in-car DVD entertainment system with 14" screen and 8 speaker sound!
http://home.attbi.com/~fishkin1/wsb/html/view.cgi-photo.html--SiteID-133366.html
The May issue of Popular Science has an automotive emphasis, with a cover photo of the new Pontiac Solstice, and how GM came out with it in record time. Several interesting articles in there for anyone interested, and a full page RDV ad too!
License plate - I don't believe I had any pre-drilled holes either in the front or back area. My dealer just drilled in a few screws and it holds well enough.
Fedlawman - how did you hold the laptop in place? Hope it's not wedged in between the two front seats.
For the record, that's exactly what I've figured I'd do if I want a DVD player in my RDV: install a laptop somehow. That way I can also use a GPS, mapping software, games, and mabye wireless internet.
http://home.attbi.com/~fishkin1/wsb/html/view.cgi-photo.html--SiteID-133636.html
Also, I found a $19.99 power converter at Target and plugged it in below the second row vents.
http://home.attbi.com/~fishkin1/wsb/html/view.cgi-photo.html--SiteID-133637.html
netnerd - I used a cassette adapter from a portable CD player to connect the laptop's headphone jack to the RDV cassette deck. Although it was "8 speaker sound", the headphone jack only outputs stereo, so it was not "surround sound", just stereo. The nice thing about this configuration is that you can then use the RDV rear audio with headphones for the kids movie, and the grownups can listen to CD's or the radio up front.
I too have thought of using a laptop for wireless internet, games, and GPS, although I couldn't use any of these while driving, especially if the kids are watching movies in the back seat. Once the road trip is over and you're at your destination, the laptop could then be used for all of those things...in the car, at grandma's house, or wherever!
Just a thought,
-Sean
After finishing with my business on post, I filed up at the Ft. Lewis gas station, reset all the trip computers to zero, and headed home. The gas station is about 100 yards from the freeway onramp so it was a good test of highway mileage.
I drove between 60 and 70 MPH all the way home, and I was very gentle on speed changes so I never let the car downshift once on the freeway. As I headed home, I closely watched as the "Average MPG" number slowly rose from a starting figure of 6.8 MPG up through 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, and 26 MPG! As I got off the freeway at my exit, the trip computer indicated an "Average MPG" of 27.7! I set a new personal record!
I then took the kids to Burger King, stopped at the post office, and went home. By the time I pulled into my driveway, my "Average MPG" had dropped to 23.5!
City driving takes a significant toll on fuel economy, and I expect by the end of the week, my average will be back down to 16 or 17 again, which is typical for the hilly, stop-and-go driving that we mostly do.
I suspect that the low gearing that allows relatively brisk acceleration around town is the culprit.
The top gear is tall (about 2000 RPM at 75 MPH) to allow good economy on the highway. However, in order for the RDV to perform well around town, the lower gear ratios are designed more for low RPM torque than economy. As a result, folks like us who drive almost exclusively around town see much lower fuel economy.
Considering that my 4 cylinder Honda Accord only averages about 24 MPG, 17 MPG for our V-6 powered, two-ton car still seems pretty impressive.
Also my old car didn't feel like it wanted to accelerate as quickly on hilly terrain with low gas (1/4 remaining) as it did with a full tank. Did you notice anything like that on the RDV?
The needle swinging up and down is most obvious when going up and down hills, or whenever there is a shift in CG (accelerating, braking, cornering).
I'm not an expert, but I believe it is caused by the shape of the gas tank, which tapers down at the bottom, and movement of the fuel in the tank when the level is low. Since the float is at the bottom of the tank (co-located with the pump), the gauge will indicate more sloshing when there is only a little bit of fuel remaining.
The fault code returned was a "evaporation leak" at my gas cap. I've had problems fueling my RDV a few times - the pumps would stop at half-full level many times. The repair was technician tightened cap, found a twisted connection that was corrected, and computer reset. There were no technicians around when I picked her up so I didn't get more details. The service was above average. I liked that they put a plastic cover over my driver's seat so as not to dirty it - nice touch I thought. But I didn't like the fact that I didn't get to talk to a technician and see what was done in person. The dealer had a ticketing system where you get a number and tell the representative what the problem was and they send you out the door until it's fixed. I prefer the set up where there's a glass partition looking into the work area so you can see them working on your car. The only dangerous thing they did was to let me take my car without showing any receipts or ID of who I was. A guy drove my car to me, I pointed it was mines, guy held door open for me, and I drove away - not smart! Besides those little things, the experience was quite pleasant.
I know you RDV owners are rightly proud of your new cars, but while it appears to be a well-thought out and designed concept, it is a first-year, American-made car. I would think it would be a prime candidate for an extended warranty, as protection while first year design/execution glitches are worked out. At least for me, that's a primary reason for caution, at least until the '03s arrive.
Is an extended warranty offered by GM or aftermarket, and if so, at what cost?
I decided that I didn't need to spend money on a warranty I would probably never use, and that if something needs repair after the warranty, I'll just pay to have it done. The best extended warranty only goes seven years and by then, my Buick will probably only have 60,000 miles on the odometer.
Besides, the Rendezvous isn't truly a 1st year vehicle because of it's GM parts bin heritage. The bells and whistles (power windows, rear sonar, memory seats, etc.) are the most likely items to fail in time, and they are the same bits that come on Chevy Tahoes and Caddilac DeVilles, so they've been around the block a few times too.
If it makes you sleep better knowing your covered, then get an extended warranty, otherwise, just cross the bridge when you get to it.
From my previous posts I posted pics of our RDV with the roof top cargo carrier and a hitch mounted carrier. Both worked great. Considering that we were traveling with six in our RDV these external cargo units were essential.
Now for the specs of our trip.
I reset everything on the DIC to 0 except for the oil monitor.
Total miles driven between 4/11/02 - 4/22/02, 2875 miles.
Total miles now on our RDV - 3344.
Oil monitor is reading 52% left. I will be changing the oil this weekend and will use full synthetic.
Average mpg fully loaded, and I mean LOADED, 17.5 mpg for the trip. I find this more than satisfactory.
Average speed for the entire trip, highway and local driving, 67.2 mph, ( we were moving along at a pretty good pace through the Carolina's).
Now for my likes and dislikes.
With six people and all our luggage the RDV was very comfortable. The RDV 's handling and ride was exceptional. The trailer towing package helped keep the RDV "level" even when fully loaded. With the RDV running as everyone was getting in I could here the compressor kick on to compensate for the extra load.
The rear controls for the radio were much appreciated by our two teenage kids.
With the HUD I never looked at the dash other than to check the DIC, (hey Buick, in future models put the DIC info in the HUD), HUD has to be in all my future vehicles.
I had a number of people at rest areas, gas stations, our resort, and at Disney parks ask about the RDV. That is kind of cool. I love to tell people how much we like our new Buick.
Now some dislikes.
As mentioned earlier, the fuel consumption on the DIC only goes to 99.9 gallons.
The engine is fine when the vehicle isn't loaded. I did notice the tranny "hunting" for the right gear uphill and under hard acceleration.
For some reason the moon roof stopped working. I had it in the tilted position and could not get the switch to close it. Both my wife and I tried several times to get it to close. The only remedy was turning the RDV off and restarting it. Go figure. This is being added to my to do list for the dealer.
As my title to this post implies, these are my initial thoughts. I will add more as they come to mind, or will gladly answer any questions. I will add however, that our overall experience with the RDV was positive. We have made this same trip many times and our whole family is in agreement that the RDV was/is the best ride yet.
Note that engine size and power ratings for the Kia Sedona and RDV are very close:
Buick Rendezvous - 3.4L V6 185/210
Kia Sedona - 3.5L V6 195/218
Quotes:
Kia - "...it makes the most of the 195 horses while never feeling slow. Off-the-line power is superb...we can honestly say that it never felt slow, despite the engine's lack of peak horsepower."
RDV - "For 185 ponies to pull the 4,024-pound vehicle is a bit of a drudge; those taxed horses get tired out mighty quickly...in light of the anemic engine..."
Kia - "Performance testing had the van to 60 mph in 10.4 seconds...acceleration is respectable..."
RDV - "Zero-to-60-mph acceleration runs were achieved in 10.7 seconds, one of the slowest times among V6-powered SUVs and minivans."
Kia - "...hustled through the slalom at a rapid 59.6 mph."
RDV - "...ran our 600-foot slalom...at 59.5 mph, a tad slower than most other vehicles in this class."
Here's my recap - two vehicles with virtually identical numbers:
Kia - "hustled", "superb", "respectable", "rapid"
RDV - "anemic", "slowest", "taxed", "drudge"
What did Buick do to earn the enmity of the media?
Steve
I think I will submit it.
Steve
Steve
DD
DD
CX with 1SC package ( versatility) $29,570.00
Sunroof 792.00
trailer package 362.00
freight 900.00
Total $31,702.00
without discount 36,500.00
We ordered white, over the charcoal. Attention other Canadians, as usual we are
being treated as second class customers. In Canada we can only get charcoal on
the bottom of the vehicle, while the American customers have a variety of options to
choose from. Also we are forced to purchase a 2500 dollar option group in order to
get the third seat, while Americans can order it as a stand alone option for about
750 bucks. Are you listening GM, why do you treat Canadians as second class.
The net allows us to compare notes now !
As for the third row seat I only saw it included with packages (like 1SC which I have also). My dealers didn't offer them separately. But I think someone mentioned you can order it from GM and install yourself but not sure if all the mechanisms are in place?
My take on this that the steel frame would support you on a hard surface, but you don't want to get dirt into the latching mechanism, so if you do a lot of camping, you could have someone fairly easily weld up a base for the seat and use that to keep it out of the dirt, but that's probably more work than you want.
DD
The other day I took out the middle seats for the heck of trying it and opened up the third row of seats. It was extremely roomy and comfortable to stretch out on the third row seats and just chill in there. It makes for a great "portable dorm room" as advertised by the concepts like the Honda Element. All I need is a DVD system (maybe like Fedlawman's) and a remote.
We won't get our Rendezvous until July, but I thought I might surprise the wife with some Vanity plates for mothers day. Anyone got any ideas. We can get up to 8 numbers here in Canada. Tell me what you think, my wife's name is Ruby, and she is a Registered Nurse.
So far I have thought of two, RUBYVOUS and this one is harder, let me know if you can figure it out. MYFVRTYF
misterblandings@hotmail.com
Jeff
~Lance
Yes my model was black. After I spend about 2 hours preparing it, it will be like our on order Rendezvous, White over charcoal.
Now I want to address the Toyota Camry issue. As I have said before in this forum, I work for an Auto Shipping yard, I drive everything GM makes or sells, including SAAB, ISUZU and Saturn. What I drive the most are the car's that are made in Oshawa, Impalas, Monte Carlos, and Century's. I drive over 10,000 cars a year, not including my own.
I have never owned an import with the exception of one Austin Mini when I was a teenager.
Because I had so many problems with my last GM purchase (1995 Pontiac Transport) I leased a Chrysler mini van last time. It's been fabulous, but oh so boring. This time I took a whole bunch of vehicles out.
The Camry was wonderful, a quiet ride, a luxurious ride, and handled well. I could get it as a 5 speed if I liked, and the trunk is bigger than the Impala's I drive. Acceleration was fine, and there was only a 4 banger under the hood. The seats were comfortable, the controls intuitive and easy to use. Hell they even throw in both a cassette and CD within the base package.
All this for 23 grand and change. Consumer reports, practically drools over their quality,and reliability. It's hard not to like a full size car that you can have your way.
Jeff
So he's interested in a lot of different cars, I have been guilty of that myself. As for having someone removed, their must have been sufficent reason for the moderator to take that action.
I am sure Dindak is more than capeable of defending himself but I thought I would put my own 2 cents worth in.
Jeff
Steve
http://www.autoweek.com/cat_content.mv?port_code=autoweek&cat_code=autofile&content_code=02114561
Ken
Will Buick carry two SUV's in there line up????
Buick Century is toast in a year or two though.
I thought the reason for the 5 - seater in the Rainier and reduction in 3rd row production of RDVs was the safety concerns of the back row ?
Also, I agree with you on the name Rainier : (
Thanks Steve the Host !
(I rather like "Rainier" ).
Steve
Well if this Rainier makes it to production it will be at a whole different price level than the Rendezvous. Today I saw a extended , 4wd, 7 seater Trail Blazer, and it was $52000.00 Canadian dollars.
Does anyone know a site where I can see how the Rendezvous is selling ? Did they meet their projected first year sales ? The Buick.com site is rather out of date, and besides they wouldn't tell you if sales had been bad.
Jeff
(My comment on Rainier is that the marketing people will nix it, as 97% of the customer base is going to mispronounce it.)
