Visitor Agreement.
That's the American way. I'm a K&N fan, some are not - no big deal either way.
Will a K & N air filter help ?
How much does it cost ( approx ) ?
Can I purchase one at a a local parts store ?
What makes this filter better at saving gas than an original equipment air filter ?
Thanks in advance-
Unlike the "Tornado", K&N doesn't make up ficticious dyno results or make wild claims.
I have K&N filters in my cars because they flow better, I never replace them, and they gave me cool stickers for my quarter windows.
Sounds like you do not think much of the Tornado.
I was able to get free shipping & a lower price than the auto parts stores near my house.
Thanks again for your help-
I think the website is:
www.ajusa.com
1-800-877-1911
A coworker had similar gains when he bought a K&N intake kit for his Explorer.
Just thought I'd let everyone know what we have experienced. Our experiences were with the full K&N intake kits though instead of just a K&N filter.
The instructions make no mention of this, but I thought I read somewhere that the engine computers need to adjust to the increased airflow.
Rumors abound about studies done by manufacturers (usually Mercedes) that the K&N can let more dirt into the engine, but I haven't seen any of those either.
Occasionally you'll read about someone having to replace a MAP or O2 sensor because of oil fouling. K&N fans attribute this to sloppy oiling of the filter.
I personally prefer to just pop a paper filter in every 15,000 miles or so and not have to fool with oiling up the filter. I'm frugal but I don't think the payback with a K&N is quick enough or low maintenance enough to justify switching from the $8 paper filter I can get at Wally World. Just my opinion, ymmv.
tom
We thought about renaming this discussion to K AND N but that probably would make things worse... maybe K&N will rename themselves to KNFilters like their web link one day and solve the problem for us.
Glad you were finally able to find us!
A couple of years ago I was doing some towing, total load was in the 2000-pound range. I made several 200-mile one way trips. The truck is long-legged with a 3.27 rear end. Anything heavier than an empty trailer and overdrive is out. The problem is that the engine would be quite buzzy above 2500 rpms (about 65 mph in Drive (not OD)). Not much fun cruising at 65 mph when you have 200 miles ahead of you.
I installed a simple K&N filter charger, about $40 at the local auto parts place. I didn't notice an overwhelming increase in power, although the engine is a little more spirited when accelerating. I also didn't notice any improvement in mileage.
However, I did notice a dramatic improvement in towing ability. I still tow in Drive (not OD), but the engine is now smooth and strong at 75 mph (2800 rpms). The engine is no longer buzzy above 2500 rpms.
I think you said that your highway mileage improved 4 mpg to 22....isn't that what a Liberty is supposed to get anyways ???
I put the stock filter back in for now. The Liberty has 3,400 miles on it & the dealer says that it should be broken in by now.
I am changing gas stations to see if that makes any difference.
I have a trip coming up & will try the stock filter one way & the K & N on the way back. That is about as controlled an experiment that I can come up with.
There are slight performance gains.
My biggest issue is the cost savings - a Toyota that I owned used air filters that were $16 (Wal-Mart) for a Fram and $24 at the dealer for a Toyota filter.
I paid $28 for a K&N a few weeks after buying the car and never changed the filter - I just cleaned it a re-oiled it at every oil change. In 6 or 7 vehicles, also, I've only been through two cleaning and oiling kits.
In the Toyota alone, figuring on changing the air filter every 10,000 miles, and I kept it for 98,000 miles, I saved $130 or so.
Hey, it's $130 I wouldn't have had otherwise.
Sounds mean when you're next to the wall at the Wendy's drive-thru.
I probably only gained 10-15 hp with everything, but it's burning cleaner than it was and the sound and power difference make huge personal reasons for making the changes.
Question, will it take the engine long to adjust on that trip when I fill up & put the K & N filter in for the trip home ?
Heck, you can improve your mpg 10% just by replacing your clogged air filter - and that's probably one reason for the testimonial stuff.
"Gas-Saving" Advertising Claims
Tom
I have not disconnected the battery when the K & N filter went in or when it came out.
How long should it take my 2003 Jeep Liberty engine to re-adjust to the new filter ?
KSU-PS
Thanks for Terrence Newman...we Cowboys fans love him !
Tom
Also, since I put the stock filter back in last week, I did not disconnect the battery...should I do that now ?
Finally, how long do I need to leave the battery disconnected & why ( which terminal should I disconnect, both positive, negative ???)
Thanks in advance for your help.
