have been busy lately so i have not been on . just a quick thing, when i test for these problems i run water on the cars for a while to allow it to get to all areas.
sometimes it takes a little time to see where it is comming from. windshields are possible as well as sunroof drains, but if you see water coming out the rockers when pouring it through the drain channels it is doubtful that that is your problem.
Left side (drivers) can be a cowl seam under the fender( not fun) body shop will have to remove the fender to acsess the seams.
Rob- I do repair water leaks for a living but i work for comercial accounts, i don't do private work mainly because i don't have time to. I will help you as i can though.
where in philly are you located?
99towncarexec
run water over the windshield and roof on the left side for a while with the carpet back and pillar trim off and watch the areas . with water leaks you have to be patient..
have a good thanksgiving
I live near Villanova, PA 19010- I sealed the fresh air vent and I haven't tested it yet because I'm still waiting for my carpets to dry thoroughly. Once they dry out, I'll probably run the car through a car wash and see what happens since as you know it's gotten cold here and my outdoor hose has started to freeze up.. And yes, if that fresh air vent fix doesn't work, I would appreciate it if you could help me solve the problem, in person if necessary, if you had the time. Let's see what happens first.
Happy thanksgiving to you guys as well.
The good news is that it's been raining hard here today and I'm happy to report that the repair to the fresh air vent seems to have worked since I haven't seen any leaks nor felt any more moisture on my carpets. A few things on the repair-it's important to secure the rubber gasket on the first piece you remove as well(this is the piece that rests on the windshield and is the first line of defense for allowing any water in. Mine was loose so I reattached it. I also made sure the two long black screws that hold it on are firmly connected and I even replaced the rectangular white plastic grommets which they press into on the body. So hopefully this will do it for awhile-by the way, after the carpets get wet, prepare yourself for a long time before they dry out if you don't get them up and dry them out with fans,etc.
Any recommendations would be appreciated.
Oh and any haters out there who want to recommend a Avalon or something save it. I have been test driving for quite sometime.
Well,it felt dry the other day after my 8 hour trip back and forth from Jersey.I'll see how it is this morning and report in.
Lincolns are good just pay attention to tell tale signs of moisture mostly town cars.
jags i don't deal much with as they usually resolve all issues internally at the dealership . if i were to look for a higher end car i would base it on more mechanical and performance reviews and comments. any car can leak and many do. but many don't. a lot of time the higher the price tag the harder to work on
good luck
Should we replace it, I am drawn to the '05 Jaguar XJ8L because it doesn't look like all the other "tear drop" styles on the road and is still RWD.
Again, Thank You for your input.
thanks,
rk
Rob Stone
Hey let me ask you another question- does your car make a sound every once in awhile for the air suspension? I understand it's normal but it's a little annoying.
Glad you found your leak now you don't have to ice skate in your car
i've been busy with work , training a new dog for my daughter and looking for another jeep( since an 18 yr old kid slid across the road on snow and hit my wife's jeep) what fun . if i can be of any more help let me know
merry x-mas all
Good luck with the new car-sorry to hear about the accident- thanks for all your help and guidance with the Lincoln-you really helped me and 99towncarexec- Happy Holidays and New Year. If you're ever near the Villanova, PA area shoot me an e-mail-lunch is on me!
