Gregory Shepard
YounGrampy
The first time they recommended I get injector cleaner that didn't fix it.
The 2nd time (today) I got a line of crap about my trainy fluid was due and old fluid would make it do that. Getting the car back today so I will test drive it. But I don't think thats it either.
My old Lumina came with Goodyear Eagle GA's. I thought they were fantastic. They were quiet, lasted forever, and had tremendous traction. I was happy to see the Eagle LS2 on my Impala, because I figured they should be similar. Not so. They were noisy, had poor winter traction, and wore out quickly.
I talked to my dealer, and they said the General Altimax HP was a better tire for the Impala. When it came to replace the Goodyears, I went with the Generals. I have been pleased. They seem to be smoother riding, with no loss in handling, and are quieter. The other detail the dealer said to try was to run the tires at about 35psi as opposed to the 30psi recommended by GM in '07.
The different brand of tires and the higher pressure seems to have made a big difference, because I don't see the uneven wear that plagued the Goodyears. I only have about 10,000 miles on the Generals, but they look promising.
Horrible....I agree with youngrampy that we should all sign a petition stating that we deserve safe vehicles too, not just the police and state since they have deep pockets to dig into to sue Chevrolet! I'm just saying!
Have you spoke with a dealer or customer assistance?
Christina
GM Customer Service
Please feel free to contact me directly via email.
Christina
GM Customer Service
yes, I've seen thr deelership about the tire sensors and they replaced one time out of "good faith" but said for the others that have gone out I would be charged. I've also seen them about the heater issues and it not heating and they said they couldn't find anything and to just add coolant. Later I found out I needed a new thermostat and that there is leaks of both oil and coolant in the rear headgasket.... The other issues have not been looked at by the dealer, however because they are expensive just to have them look at the car. Then once they look at the car, they never know what the specic problem is and then tell you it's out of warranty......???? It's frustrating to deal with the deership repair shops because stealerships care more about selling the cars than repairing issues with the cars they sell.... Once it's off their lot, it's not their problem... On top of that normal people have issues going to other shops in fear that their warranty won't cover the repairs unless they are done at the dealership, one shop completely turned me down!!! What are us as consumers supposed to do?
Not sure what to do at this point.....other than trade the car in for another car...one more reliable and built more dependable.
Good luck!
Took it to the dealer to get my brakes serviced. While there I asked them to check on the hesitation again. This time while test driving it jerked for them.
They diagnosed it as the valve body hanging up inside the transmission. They replaced the valve body assembly, the pressure solenoid, and filter and fluid.
Been driving it for a month now and it works Great!!!
I apologize for your frustrations with the dealership. I would definitely recommend finding a dealership that you trust that works with you. Have you got your concerns fixed? If you would like I can locate a different dealer to look at your vehicle. Please email me and let me know what I can do to assist you. I will need your complete contact information, VIN, current mileage, and Edmunds user name.
Christina
GM Customer Service
Hadn't owned one in 20 years so thought we would try them again, bad idea! should have stayed with Ford.
Sarah
GM Customer Service
Please contact us via email if we can assist.
Sarah
GM Customer Service
I currently have almost 129,000 miles, and I just started to have transmission problems, when staring off, for about the first 10 minutes of drive. This is not all the time, just once in awhile. I'm waiting for it to be more of a daily thing to take into the dealer.
On another note with regards to an above post by myself, I did replace the rotted out factory mufflers in May with some Walker Quiet Flow Stainless mufflers. I coated them in several layers of ceramic paint before the install. Replaced the stock pipe from the mufflers to the cat as well with a new resonator and pipe which also got the ceramic paint treatment. Looks great, sounds quiet!! FTW! Peace, John
I have seen many other instances involving the same symptoms. How has GM gotten by without a recall on these transmissions? This was a $35000 car in 2007. I need to know what I can do about getting a chevrolet dealership to take responsibility to get this replaced. The symptoms? When you are at a light or just leaving your garage in the morning, you hit the gas and the engine revvs up and then there is a thud forward jerking the car into movement. It has its good days and bad days.....Sometimes it drives normally and others comes the lurch. Occasionally just over the last month while in cruise mode you will feel that the gears are trying to make up their mind to work and the car will jolt along a little.
My father would already roll over in his grave if he knew that his beloved former employer had become a shoddy second class car maker. Daddy always honored problems with his customers and did the right thing. Will Chevy do the right thing in this case.? If not, I will never even so much as look at one of these vehicles again. Chevy and GM has left this world along with my father.
Best Regards
Kristen Lance
(My father was C W "Buddy" Lusk of Tullahoma Tennessee Shapard Chevrolet.) Remember the original bald Mr. Goodwrench? My father was the model for that poster. They don't make em like they used to.
We're sorry that you are currently experiencing some transmission concerns with your Impala. If you would like for us to check into this further with you, we're happy to do so. Please email us at socialmedia@gm.com with more details (including your name and Edmunds username, phone and address, the last 8 digits of your VIN and current mileage, and the name of your involved dealership).
Sarah, GM Customer Service
You also asked me which dealership I had taken it to here in Knoxville. Unfortunately, since I brought daddy's car back to Knoxville in 2008, I have taken it to the two closest chevy dealerships to me and I have been very disappointed in the service departments of both of them.
Once when I had an issue of a second battery dying within a year, they checked out the car and refused to believe it was the battery. Their answer to me was to let it die somewhere and have it towed in where they could figure out the problem. Fortunately, I did not fall off the turnip truck yesterday and chose to just get a reputable mechanic to install the new battery. It worked fine. (Reeder)
The other dealership has failed to do the basic maintenance items I asked them to do. (I checked after they finished on things like checking fluids to see if they had been refilled and so forth.) They had not, but yet they had checked off these functions.)(Beaty)
As a result, I am recording this issue with you and ask before I take it in to a dealership, they are made aware in advance of this problem with the Impala so that I do not have to go through a whole new set of hurdles in proving my problem with a car that is no longer in warranty. (Women are treated like idiots in both of these dealerships)
Best Regards
Kristen
We're sorry to hear about this situation. If you would like for us to check into this further with you, please email us at socialmedia@gm.com (include your name and contact information, a summary of the situation, the last 8 digits of your VIN and mileage, and the name of your dealership).
Also, if the problem involves your transmission, do not accept the cheaper option of putting in a new transmission with a three year warranty. You will experience the same problem in a couple of years and pay for it all over again. These transmissions have an unusual flaw that can only be fixed by breaking it down. I have just found this out the hard way.
Do not buy a gm car!! (from a family who worked and owned GM cars for many many years.)
