Jeep Cherokee Grand Cherokee Noises and Sounds
We're consolidating all the mysterious sound and noise issues into this discussion.
See Also: Jeep Forums--Bearing Noises Up Front
I've been searching the net endlessly and have found many others with this same problem, but I haven't found a for sure answer for what is causing the whining noise on the tire. I'll be bringing it back in more than likely so the dealer can listen to the noise himself and maybe figure it out, just would love to find out beforehand what is wrong.. so I don't waste anymore money on repairs.
Any more insight on this is GREATLY appreciated, and I'll definitely post back if I find out what is causing the noise.
Also, I was doing some more research on the net, and came across what I think is the same problem. I don't have the link on hand, but my search brought me to wjjeep.com .. which is basically the jeep dealership site. I looked under the "Technical Service Bulletins" list, and found a topic for "Front Axle Whine". It said that a whine is produced when the ring bearing & pinion bearing fail to engage properly, this was under the solution for the front axle whine problem... so along with the above post, I will probably mention this to the dealer when I bring my Jeep back in. I'm not too fluent in vehicle parts-talk, but that did sound like it could be the problem.
car starts fine runs fine for about 5-10 minutes then all the sudden this loud squilling starts whenever i am idle. When im on the gas.. sound stops! i have replaced the serpentine belt already...not that sounds like its coming right from the genral area of the serpentine belt...car is a 2001 grand jeep cherokee.
Any help would be much appreciate it thank you!!
SUVs and Smart Shopper
Thanks for the quick reply.
I would have that checked out. It could be something in your suspension or shock absorber mounting.
Then a few weeks ago, once it started getting to be 20 above all day, the whining noise suddenly stopped! I couldn't believe it and figured maybe it was just a lucky day for me.. but for the last 3 weeks, my Jeep hasn't whined once!! That was until yesterday, as the weather up here has once again dipped into the negatives, and on my way home last night... the evil whining noise came back. Sucks but now I'm pretty sure that it was just the cold weather causing the noise, because I've found no other reasoning for it. (emailed jeep.com & everything, no help at all)
No, it's a relatively minor problem but I'd have it checked ASAP. The really bad stuff would be if you have a broken rod.
maybe wrong belt?
installed right
when all is right belt is tight and i mean tight
it's got 341,017 miles on it and is an inline 6 if that helps.
oem shocks have been known to klunk and squeek
Thanks a bunch. I will be so stoked if that was the issue, but very sad if my rear diff is damaged due to so much misdiagnosing.
