GM News, New Models and Market Share
1222223225227228631
  • andres3andres3 Member Posts: 14,145
    I have one question...What matters more, position on the list or actual score?
    I would say position on the list matters more than actual score, since the position is due to the score. Also, if you have quality brands A, B, and C. Why go to companies X, Y, and/or Z if they are lower on the list; regardless of their score. Why wouldn't you want the "BEST" product for your money?
  • dave8697dave8697 Member Posts: 1,498
    You just did a good job of justifying that the Toyota score of 117 is actually very good. At 111, Chev must be great.
  • busirisbusiris Member Posts: 3,490
    edited June 2010
    Actually, I didn't justify anything. I simply explained why Toyota fell, which I though was fairly clear in the article.
    The original (and as yet unanswered) question is what caused GM models to fall.
    At the end of the day, however, if you have a choice between 2 manufacturer's models, and one has a score of 50 and the second has a score of 100, the choice of which one to buy is fairly simple (given all else being equal).
    But, change the scenario a bit, to where one car has a score of 100 and the second one has a score of 110. Gets a bit more difficult to decide now, because you have a 10% higher chance of a problem in the second car. Its really difficult if the 2 models come in at 111 and 113. And, the problems may not be evenly distributed (one particular option set within a model may indeed be the cause of a large % of the problems).
    And, since its not reality to expect 2 models to be identical in every respect, its pretty easy to select the car with the higher number, if it happens to be a nicer looking car, with more options, etc.
    So, a model with 100 problems per 100 vehicles compared to a model with 110, 115 or even 120 problems per 100 cars may be statistically significant, but in the operational world be insignificant. Of course, the range can be exceeded....think Yugo.
    The proof is evident. These ranges exist, yet the manufacturers remain in business. The Big-3 certainly have taken a beating over quality issues (and, IMO, rightfully so), but what bankrupted them was unrealistic labor union contracts, unfunded liabilities and piss-poor management.
  • plektoplekto Member Posts: 3,738
    I think a fairer assessment of the situation is to compare GM to a company like VW. They had a lot of junk in the past(both of them), but they are finally getting their acts together and becoming fairly decent overall.
    Toyota and Honda are suffering from excess and bloat, as well as stagnant designs and philosophies, So their quality is dropping. A good example of this was Mercedes in the 90s/early 2000s. They hit their peak and found it hard to move forward. So they kept adding more options and more tweaks and "refinements" but really stopped innovating. They got caught having to make more and more of the same thing in order to try to stay on top. And it failed, as it always does. Mercedes is still a fine company, to be sure, but it's a shadow of its former self. Toyota is going down this path and while it still will be a decent enough choice for many, there is no shortage of perfectly viable alternatives.
    Case in point - my sister three years ago was looking for a new car. She had it narrowed down to a Corolla, a Civic, and a Mazda 3. The differences on paper as well as functions, options, power, and so on were literally less than ten items different between all three.(body panel styling aside) While Toyota has been trying to stay on top of the heap, others have been moving forward to match them. And, there's really no problem as I see it, either. If Toyota loses some market share, Mazda and Nissan and Honda offer nearly identical alternatives.
    GM - yeah, they have a ways to go. But I think they can do it. It's easier to move up when you are near the bottom than to try to fend off all of the people trying to take your position at the top. GM can take risks without really losing anything. Toyota really can't.
    It should be interesting to see where both companies are in a decade.
  • smarty666smarty666 Member Posts: 1,503
    Mazda and Nissan offer completely different sporty/aggressive alternatives to Toyota so I wouldn't call them identical alternatives, even Hyundai is different from Toyota. Personally, I'm more impressed with Nissan, Hyundai, and Ford then I am with GM, Toyota, and Honda.
    I do agree with you that GM has a long way to go.
    Sure, the styling and marketing is different, but compare a Civic to a Mazda 3. They really are near clones of each other in terms of features, options, and dimensions. The interiors, other than the instrument cluster, appear to be designed by the same group of workers(or more likely, they all hired graduates from the same university in Japan). And a Sentra, aside from the SpecV version, is also nearly identical to the others.
    If the Corolla ceases to exist, there are other alternatives for economy transportation.
    I also think deciding on GM viability based on today and the past is erroneous. Take the comparison to Ford. The latter made some shrewd business decisions several years ago when Mullaly was brought on board. However, Ford wasn't exactly building great vehicles back then. I stopped buying them a few years ago because I got sick and tired of all the nickel and dime crap each one seemed to experience (liked the vehicles, but not the reliability compared to some imports back then). But it appears Ford is now turning the corner and changing that equation. GM just changed management recently, so they need a few years before you can really draw any conclusions, just like it took the new Ford team. The auto business is a long lead time industry and the current GM apparent successes like the new Equinox or Buicks really had most of their development tied to the previous management. I think GM will move closer to Ford in a couple of years, and Ford has already moved closer to companies like Toyota and Honda even while still carrying a number of older models like Escape and the current model Focus. My biggest concern about the bailout these days is that political pressure will force the government to quickly dump their equity stake before it really gains traction from the improvements and newer models leaving too much tax payer payback on the table.
    very well said! that is what I've been trying to tell all these GM fanboys and loyalist and it just goes in one ear and out the other, or in the case of online forums, in one eye and out the other!
    On the other hand, you have Chrysler, an example of history repeating itself. Bailed out late in the 20th Century, they are now being bailed out again for the 2nd time early in the 21st Century.
    History will repeat itself with GM, but hopefully, we won't bail them out a second time and let them die in shame as it should be. I don't think we'll bailout Chrysler 3 times, how long until that is required?
  • torque_rtorque_r Member Posts: 500
    This is true for this year's first three months of ownership when many Toyotas were recalled. It is most likely that these same recalled Toyotas will be very reliable in the long range, which has a different J.D power survey. Unless Toyota goes through another wave of recalls next year, it will mostly likely be back near the top in next year's report.
    At least GM has more in the pipeline than the K car (although Chrysler did get a lot of mediocre vehicles off that platform). I think Iaccoca and crew really thought that tariffs on imports, or making them produce Toyota's in the states would level the playing field (of course the transplants didn't get stuck with the UAW overhang). Chrsyler seemed to always be old school thinking quality wasn't all that important because style sold the metal - just add fake wire wheel covers and vinyl tops.
    I do agree that GM shouldn't get any more bailout money. Chrysler shouldn't have gotten a second bite at the apple either, but take a good look at Cerberus and I think you'll find a lot of movers and shakers in both political parties (in fact, IIRC they are based in the DC area).
    I hope you're wrong about GM because if they can turn it around that is good for our country and economy.
  • circlewcirclew Member Posts: 8,666
    edited June 2010
    OK, even I hope there is a U.S. car company that provides the best cars in the world. That is good for our country and economy.
    Now, comment on the report card of GM. Then Chrysler. Then Ford. It was the end of the school year in June 2009 for GM an C and they got left back.
    Unless a management capable of leading a company to "Best in Class Global" status sits at the helm, failure will re-deploy at some point. Please hold back the "never gonna happen" comments at this point. Even the economic recovery is tentative at best.
    So, as I've said before, a few good products from GM is a start. That's all there is at this point.
    I will wait to see when all the stars align and currently, that is NOT happening at GM. Chrysler? Ahem... Ford...B+.
    OW
    Well, if the economic downturn keeps going down and double dips that will affect a lot of companies. Given the current global situation, I'd actually expect to see a few foreign auto companies drop before GM since some of them don't have as much volume to absorb the market declines and haven't been through a bankruptcy to shed overhead/fixed costs. If it really continues to get bad you will also want to take that B+ you gave to Ford back, because their current leverage is going to maul them in that event. But I don't think it will downturn nearly as bad as the past year (...and certainly hope I'm right!). Car sales are actually improving a bit, but I know that can turn on a dime. I will say that if the new GM management can't handle another major drop then the company should be left to die the next time. I guess I'm just more optimistic than you are ( I think their China operations help), but no way am I going to say "it ain't gonna happen".
    Some of the more vulnerable companies I'm thinking include Mazda, Suzuki, Peugeot/Citroen, Saab, Volvo, Land Rover and maybe even Fiat (despite the giveaway of Chrysler). These firms may shut or pieces may merge with others in the event of a prolonged slump. GM could end up telling Germany to buy them out or otherwise close Opel if the economy doesn't improve because Opel is not profitable and actually hinders GM longer term despite its engineering and development of global platforms like the new Regal. I understand why GM chose to keep them shorter term, but Germany may be over playing their hand longer term. It may get interesting!
  • kernickkernick Member Posts: 4,072
    Well it looks like if you buy the Chevy Malibu, you're a fairly good patriot. But otherwise, GM looks like they're taking more and more of their supplier and assembly business out of the U.S.
    http://content.usatoday.com/communities/driveon/post/2010/06/detroits-pickups-fl- unk-toyota-soars-on-american-made-list/1
    So for our $60B+ in bailout per the GM bankruptcy, I'd guess we good 'ol suckers-of-taxpayers got to save quite a few foreign jobs!
    So, back to my question I posed earlier...
    Is it better for the US for a buyer to purchase a Chevy Aveo made in Korea or a Hyundai made in Georgia?
    I would say it's better to buy a Honda made in Japan or an Audi made in Germany.
    Why support incompetents? They are companies that have proven they won't make any profits and just suck the tax payers dry. The quicker they vanish, the better off we'll all be I say!
    Actually, the best option is to probably buy any car made in the U.S., because the cost to run the plant, pay for the secondary costs(utilities, transportation, local taxes, food for the break rooms, cleaning staff, etc), and pay the salaries - that can run upwards of half a *billion* dollars a year. And 100% of that operating cost is going into the local economy.
    The NUUMI plant in Fremont, CA, for instance, contributed 1 billion a year to the California economy. This was the largest example of such a foreign plant that I know of, and it was a real hit to the economy when it closed this year.
    So the real answer is to figure out what plants are in the U.S., then buy one of the vehicles that is made there. For example, GM only makes about half a dozen vehicles any more in the U.S. - most are now made in Canada or Mexico.
    And, yes, the window sticker says "North American Content" for that reason. They changed it a few years ago, so that content made in Mexico, Canada, and the U.S. is all considered the same. But the VIN doesn't lie.
    I don't know if that's the best thing to do for the consumer though.
    I can vouch that the Honda's we've bought that were made in Japan were better built and put together than the Accord I had from Ohio.
    The Civics have been downright flawless (always VIN starting with a J was sought out), whereas I was forced to buy an Accord that had a VIN starting with a 1 (don't think any coupes are imported from Japan).
    The American built Honda was reliable and dependable, but I had probably 5 or 6 issues that I took it in for "warranty" work on. Most little ticky tack annoying little things, but still, it had it's share of issues on quality, fit & finish, and build.
    The '05 and '07 Civics built in Japan have combined for only 1 warranty visit COMBINED, compared to a half dozen or so for the single American built one.
    My brother can probably vouch that his Japanese built Toyota's are flawless. If Toyota is having problems, I'd wager it's mostly with the American built one's and parts (see CTS throttles made in America).
    You see, those Japanese factory workers have been all-stars doing this for decades now. They are experienced and proven all-stars when it comes to building vehicles. Americans are proven failures, mediocrities, and INEXPERIENCED when it comes to putting cars together. It seems that if you give them good parts, and good design and engineering though, it helps a lot, which is something the Big 3 never did.
    edited June 2010
    True, but you certainly don't want something made in Mexico or offshore someplace. Or if you actually like/want GM and Ford's cars, you do want something made in the U.S, because the stuff that isn't is the same situation as with the Japanese cars.
    That said, yes, the new Acura TSX is stunning. It is an absolute steal for the money and looks as well put together as a Mercedes. That's a good example of when you want it to be made in Japan.
    Humm.. maybe it should be only buy "U.S. and Japanese" made vehicles? Heh.
    Of course, a 60k+ Porsche is a whole other story... no issues with quality there.
    edited June 2010
    For the most part, I'm in agreement with you on this one. As I type this, BMW is finishing it $500 million plant expansion at its SC plant, not too far from where I live. Its been a BIG PLUS for the local (and state) economy.
    Money spent in wages and on plant in production in the US are definitely an asset to the US economy, whereas any potential profits gained by the Big-3 on products made off-shore may or may not remain in the US.
    But, I would also be well-served to make sure the quality, even on a "foreign" make being made here, was up to par.
    Assembled in Oshawa, Canada at an award winning plant. A/c compressor by Denso. Coils by Mitsu. Oil changes and a battery are it for 9 years. One recall for tailgate straps that supposedly could rust. Of course, it isn't a vehicle that Chevy did right. It needed a part within 9 years. If it was a Tundra, it would still be on the original battery.
    But the original point was about economics as well. I know we like to think of Canada as "North U.S.A." in the U.S.( or a lot of our politicians seem to regard it as such), but money sent there is as bad as sending it to Mexico or China when it comes to bleeding jobs and money out of our economy.
    The average manufacturer makes a thousand or two on each car in profit. And the vast vast majority of the rest of its value - goes into constructing it and paying to run the plant to do that. That 20K car costs GM 10K-12K on average(the rest is advertising, R&D, and so on which may or may not be in the U.S.). But too many people think about where the profit goes (corporation) but not enough where the 10-12K to make it goes.
    Where it's made is really important. Especially if the company is losing money - because that "profit" actually is zero. But the plant still pays its workers - that's how the money gets into the economy, no matter what the state of the economy is.
  • dieselonedieselone Member Posts: 5,729
    GM doesn't have a viable replacement for the Northstar and Hyundai is already developing a new v8 for the Genesis. The current Genesis 4.6v8 shames the Northstar, what do you think their new 5.0L with an 8 speed trans in 2012 with 429HP will do?
    Can a pushrod 5.3 or 6.2 be refined enough for Luxury duty? In my opinion, the units I've sampled are not. That doesn't mean it can't be done, the new Bentley sedan uses a big OHV v8.
    What is the 556 HP Cadilac engine that is on tv everyday? Is that the one that the Genesis is shaming? If so, with what?
    Give me a break, the only time I seen one is on TV. I can only recall seeing one late model CTS-V over the last year. I don't have enough fingers and toes to count the v8 Genesis's I've seen on the road. I'm not knocking the CTS-V, as it's a very cool car, but if the superchared 6.2 was ready for luxury duty, why wasn't it used instead of the late supercharged northstar for use in the XLR-V and STS-V?.
    Plus, with gas mileage of 14/19 in a CTS it will never be in anything mainstream. Hyundai's 4.6 already spanks a n/a Northstar and I guarantee the current 6.2's aren't in the ball park with HVH.
    My point is the competition is continuing to develop v8 engines and for luxury use. An OHV 6.2 out of a pickup truck isn't going to win over MB/BMW/Lexus buyers. I've driven several 6.2's and IMO it's no where near good enough for Luxury duty. Maybe it can be revised to do so.
    Now diesel, you just don't get it. Don't you like raw coarse power? That's a hallmark of American muscle cars! Certainly those refined MB or BMW or Audi engines don't show enough macho characteristics! ;)
    Hey, I like all kinds of different cars and I do love raw HP. Nothing like listening to 400+HP big block powered boats run down the lake. It sends chills down my spine. At the same time, that doesn't mean I want the BB in my refined luxury sedan or sports car.
    FYI, I was just kidding!
    Oh I know. I didn't mean to sound offended or anything.
    Shoot, I could have both legs and one arm amputated and 3 fingers and the thumb removed from my remaining hand to count how many V-8 Genesis's I've seen and it was at the Philadelphia Auto Show.
    Oh, God! We're back to the stupid OHV vs OHC argument again!
    I see one every day as my neighbor down the road from me dumped his Cadillac for one. I see several running around here in central Illinois.
    No, I'm not trying to start an OHV vs OHC debate. My point is, do you think something like the 5.3 is good enough for top end Cadillac duty. When all of the competition has v8s with more power and more refinement.
    Lemko, are you telling me you don't appreciate the performance and smoothness of your Northstar powered DTS vs, the 3800? Would you care if your DTS was powered by something like a 3.9v6 or the 5.3?
    I wouldn't have even bought it if it had a V-6. That is why Lincoln is off my shopping list except for the Town Car which I may have just enough time to special order before it becomes extinct. Acura also makes this same mistake.
    I can live with a V-6 in something like my wife's LaCrosse or an everyday beater like my Park Ave. My true, honest-to-God luxury car, however DEMANDS a V-8. I don't care if it's a pushrod or a DOHC like the Northstar. Personally, I think the Northstar is too smooth. I miss that sudden "throw you back into your seat" feel of a pushrod V-8 when the secondaries of that four barrel carb kick in! :shades: Dang, those old Mopar V-8s like the 426 and 440 have an exhaust note that is second to none! They even sound awesome when the car is parked and idling.
    So does that mean if the new XTS is only offered with a 3.6 variation it's off your shopping list?
    I'd imagine if GM finished development on the Northstar replacement, better gearing, improved variable valve timing, and direct injection, would vastly improve off the line performance.
    But sadly the days of the big block are over. I still am around them in the boat world. I just love to listen to a 454 or 8.1L with open exhaust idling out and running full throttle down the lake.
    Oh, good! Then we can move on to horsepower vs. torque!
    edited June 2010
    Yes! If that's the case, I'll be keeping my DTS for the next 20+ years like the Brougham. A 3.6 is fine for the wife's car, but doesn't make the cut for my next ride.
    The 454 is an old Chevy block. It was recently used in the Chevy 454 SS pickup truck. 8.1 litre? What would that translate to in cubic inches? I believe the 472 V-8 that was in the 1969 Cadillac translated to 7.7 litre. I had a 1975 Cadillac with an 8.2 lite (500 cid) V-8. Too bad by that time it was choked down by so much anti-smog crap it only put out a lousy 190 hp. :sick:
    I believe the 8.1 is like a 496 or something. It was used in the trucks until a few years ago and is still available for marine use which it's rated between 375-425hp depending on which you want to pay for.
    The 454 hasn't been available for a long time even in boats, but there are still a lot of them running around.
  • jae5jae5 Member Posts: 1,206
    Correct - it is 496 c.i. It is also used to power large gensets. We used GM 1.8L, 2.2L, 4.3L, 5.7L (gen 1) & the 8.1L & Perkins/CAT 4cyl engines.
    On a trip to the Kohler factory in WI I actually saw an 8.1 that blew a couple pistons out the side of the block :surprise: Workers assembled it into the genset, fired it up on the line and over-revved it - :sick:
    That can happen. I've seen them and other marine engines die a quick death. I know a few years ago, Mercury Marine and Volvo Penta had some head gasket issues with the marinized 8.1. But overall they have a reputation for being durable. Like anything else abuse and poor maintenance is what kills them. You just can't run them up and down the lake wide open all day, but some people due.
    What's shocking is how much they charge for these engines from the boat builders. It can easily cost over $6k to upgrade from a 350 to a base 375hp 8.1. Go to the 420HP version and it can be over $10k more.
    Isn't that just par for the course? Another power blow from Korea to GM.
    May the best Car Win. :D
    The new engine is expected to arrive in early 2011 in the 2012 models, replacing the current 375-horsepower 4.6-liter V-8, which will no longer be offered. While the new 5.0-liter engine shares the same architecture with the current mill, its direct-injection technology, a bore increase, and a compression ratio bumped to 11.5:1 all help account for the estimated performance advantage. An eight-speed automatic that was designed and built in-house at Hyundai will be paired to the engine for maximum efficiency, helping to bump fuel economy roughly 1 mpg to just over 26 mpg (8.9 liters/100km) despite the new engine's increased power.
    Notice how quickly the improvements are integrated compare with the New GM.
    OW
    edited June 2010
    you'd think that GM could quicker-integrate all those wonderful new ideas ta more fully compete with Hyundai, eh?
    Oh, that's right, they're already paying (some) of it back ta Uncle Sam, huh.
    One major flaw in the northstar is the starter motor down in the block V, under the intake manifold. Who wants a 90,000 mile northstar with the original starter motor? probably a $2000 repair if the starter goes out.
    Whether people can afford a vehicle is not a determinant of the validity of using the 3.9 second 0-60 time of a Cadilac in advertising.
    Just because you don't see them, they don't exist?
    I checked an '07 CTS-V specs:
    YOU lie!!!!!
    Fuel Data
    Fuel
    Fuel Tank Capacity: 17 gal.
    EPA Mileage Estimates: (City/Highway/Combined)
    Manual: 14 mpg / 22 mpg / 16 mpg
    Range in Miles:
    Manual: 238 mi. / 374 mi. / 272 mi.
    I know some people getting 26, 27, and sometimes even 28 or 29 on trips in their 6 liter vettes. It has something to do with 70 mph at 1600 rpm.
    edited June 2010
    YOU lie!!!!!
    Fuel Data
    Fuel
    Range in Miles:
    BS I lie. The 2007 was the non supercharged 6.0L version. Check the 2010 model at Cadillac's website. I'll post it for you just in case you can't figure out how to get there!
    CTS-V
    BTW, a ZR1 Corvette is rated for 14/20hwy according to Chevy's website. Yes the standard 6.2 powered Corvette is rated for 26hwy. Not shabby at all, but it is a sleek 3200+lb car with a tall 6th gear.
    edited June 2010
    Yeah, I remember reading that when it was first introduced.
    In 2009, 2,847 CTS-V's were sold, more than I would have guessed. But none were sold in 2008.
    Of course the real problem is that we really don't NEED huge HP. 200-300hp is enough. I'd trade all of the rest for MPG any day.
    Case in point - the best car GM made in the last decade in terms of performance vs MPG (despite the styling being a total "meh") was the 2004 GTO. Why? Because it has a *smaller* LS1 V8. With manual, it gets a legitimate 30mpg highway AND has 350HP.
    I'd love to have more of that. :shades: But what we get is heavier, nastier(looks even MORE like a Transformers toy - and not in a good way), more powerful, and maybe 20mpg.
    What I want GM to do is come out with a 3.0L V8 with a supercharger on it. Get something like 35mpg highway and still get 300+HP. And, yes, that's possible. Ferrari and others specialized in 2.0L V8s for decades. Highway MPG is very closely related to displacement, so small as possible should be the new rule.
    http://www.h1v8.com/page/page/1562069.htm
    Small V8s can still be horrendously powerful. 400HP out of a mere 200lbs. GM could obviously make something larger with less compression and still hit 250+ HP and 30-35mpg.
    Well, why wait for GM? Ford has a V-6 with 300 HP that gets 30 MPG.
    As Lutz already said in 2007:
    "If the government wants a 30-percent improvement in fuel economy for each size class, I can't get Zeta 30 percent more efficient," Lutz said. "It would be like going from 20 mpg to 30 mpg. We don't know how to do it."
    Although they have improved, the B.S. they send regarding highest fuel economy in every class is a lie that will keep their market share low.
    The problem is they really believe the garbage they express! You know where that will lead! :lemon:
    OW
    OW
    plekster, you may be the only one who prefers the 04 GTO aside from modders who find the LS1 is more moddable than the LS2. (btw, these mods do not tend to increase mpg!)
    The Pontiac/GM buffs & other experts and PUNDITS prefer the 05/06 LS2 GTO, thank you. Many GTOs are especially bargain-priced on the used-market now - I thnk there is one out there for you, LS1 or LS2!
    nobody's getting any 30 mpg with any year GTO.
    Camaros couldn't get 30 mpg with LS1 or any other V8,
    and GTO is a much heavier car.
    While I like that idea, small v8's aren't known for their fuel economy. Sure Ferrari gets big power out of their v8's, but they spin 9k rpm too, and their fuel economy is horrible. Then again, Ferrari doesn't have to worry to much about that, they want max performance.
    Ford's Ecoboost 3.5 v6 is putting out over 350hp and 350ft/lbs of torque. It gets similar fuel economy to a n/a 3.5 in a Taurus. So maybe it would get the same mileage as the 3.7 v6 in the Mustang. No it's not a v8, but it seems a v8 under 4 liters runs into having to many moving parts vs a v6 of similar displacement. I've sampled Fords 3.4L v8 in the late 90's SHO. It sounded sweet, had decent power, but fuel efficiency was basically the same as a 4.6 powered mustang.
    Better be putting something like that in a very light vehicle, 245ft-lbs of torque at 7500rpm isn't going to work in something like a large Cadillac or Buick. It would be fun as hell in something like a Lotus Elise though:)
    The engine isn't the only factor. Weight, drag, and gearing. These cars are getting seriously heavy. That's one reason the vette does well, it's fairly light.
    No doubt, it probably can be done driving 40 mph all day. Ford got something like 47mpg out of the 300hp v6 Mustang, but they averaged like 43mph on an oval track.
