GM News, New Models and Market Share
1547548550552553631
  • bpizzutibpizzuti Member Posts: 2,743
    Actually yes I am someone from the auto industry after a fashion. But I'm not telling you to accept it, am I? You're criticizing cars for being noisy, yet seem unwilling to take corrective action. if you don't like the noise, do something about it or don't buy the car. Some of us would rather have the option of a low-weight car because we care more about handling and MPGs. That doesn't mean I think ALL cars should be like that (the Bentley isn't, for exampe) but you seemed to be criticizing all cars for being noiser than they used to be.
    edited October 2012
    About the only GM car I get to drive now and then is the in-law's '05 Buick LeSabre. Certainly quieter than my minivan or older wagon. Better mpg than the van too. Doesn't seem to be too much to ask for a little less noise in the cabin for the typical passenger car, even if it's a base econobox. I'm not talking about 150 pounds of Dynamat either.
    Seems like see quite a few people talking about how much better their car rides when they replace the OEM tires while at the same time they notice that their gas mileage falls off a bit. I guess we'll be riding on solid tires soon with the 54 mpg mandate. :P
    I dunno, not all of them use those hard-compound tires to get to 40 MPG. And while I did experience a slight MPG dip when I put G019 Grids on my old Mazda3, I've heard the Conti DWS tires generally get as good MPGs as OEM tires. And I also hear they're quieter than the Grids (not as quiet as a touring tire though). I may go slap a set on the Elantra, if I decide to hold out for something in a 2014.
    The original tires on our 03 Buick were much quieter than our replacements. The originals were Michelin Symmetry; replacements, Harmony by Michelin.
    Not sure if the mileage dropped.
    I think the original tires are specified to have quieter tread patterns for the test drives and to have low rolling resistance for mileage. The resistance comes partly from the belts as well as the rubber itself.
    Anyone remember when "radial" tires were optional? :shades:
  • andre1969andre1969 Member Posts: 26,139
    My '76 LeMans has a badge on the dashboard that says "RTS", for "Radial Tuned Suspension". I'd imagine that by '76 though, just about everything came with radial tires standard.
    When did cars start using the metric sizing system? As in, 215/70/R15? My LeMans still has the original spare in the trunk, and it's listed as an "FR78-15" or something like that. It still holds air, but I don't think I'd trust it very far!
  • uplanderguyuplanderguy Member Posts: 17,143
    Radials started appearing on certain GM cars in the '73 model year. I think only the Monte Carlo and Grand Am and Cutlass Salon had them as standard equipment that year. By '75, all GM products had steel-belted radials as standard equipment...even Vega and Nova.
    I cannot remember them being optional on any GM cars in the '73 or '74 model years, however.
    First of all, I'm not unwilling to take corrective action - I just buy a different product. If noise problems develop later due to a problem, it is then the dealer and manufacturer's responsibility to fix it, not mine.
    In the case of some of them, that's true. But it's no different than you jumping all over people who miss their quiet cars. No way was I saying all cars are noisier today. It's just not there in the print.
    I don't buy your correlation about driving and quiet. That's like saying a noisier cockpit means better aircraft performance and pilot proficiency. I also don't buy your argument that we should lay off the manufacturer if we find their product is noisier because it's safer and it is due to conservation of resources. In some cases that may be true, but in others it may just as well be due to cost cutting or trying to get an edge in buff magazine performance results. To me, that argument is flimsy and really no different than saying if I buy an appliance with a door that doesn't fit real well because of cheap materials, I should thank the manufacturer for his conservation of resources and figure out a way to shim it. As I stated before, buyers should choose the ride they find preferable. Neither one of us and our preferences are superior and frankly, I think you were out of line jumping all over Uplander and his preference for a quiet riding car like you did in your post.
    If people can't handle others giving their opinions, they're probably in the wrong place for one thing. For the other, I detailed some technical reasons why some cars are not as quiet-riding as they used to be, and if you consider that "jumping all over someone" I'd suggest you re-think your definition. Subject closed.
    No it's not, the way you went about it counts as much as the info. You came across rather aggressive. As for facts, sound dampening and design doesn't always add significant weight, ask an acoustical engineer. Opinion is one thing, one sided and closed minded is quite another.
  • andres3andres3 Member Posts: 14,191
    I think one of the differences between the VW GTI and Audi A3 is cabin quietness. If we believe one poster's opinion, it's because VW is skimping and cost cutting on sound dampening design and materials, if we believe another posters opinion, it's because Audi might care less about fuel economy and more about quiet luxury.
    Either way, I think the advantages of my A3 over a GTI were worth every penny, and then some for the premium in cost.
  • circlewcirclew Member Posts: 8,666
    Tires are the most important component to a quiet ride. GM used/uses good tires out of the factory.
    OW
    The Honda OEM tires on the '08 I own had the bottom of the barrel (akaTireRack.com) tires. Lasted 23K and they were toast.
    The Khumo replacements have 34K and still 1/3 tread life left. I'll chuck 'em in Spring '13 as over 30K on any tire is over extended, afaic.
    GM uses better tires out of the box.
    OW
    The hard compound tires on my Optima gave great mpg's but the traction was horrible. Just changed those Nexens ??? for Khumo 4x's and it's a new car but the mileage dropped considerably.
    No more 37MPG hwy but instead 34 mpg. But the ride improvement handling and much lower noise is a huge gain on, otoh. Unbelievable how much difference they made. Traction in the rain is like glue!
    OW
    Yeah, tires do make a huge difference. But generally less rolling resistance also means less sticky, and the trick is to find the right trade-off between the to, or just find a car that gets such good MPGs that you can sacrifice a few to get some traction.
    I think even the Cruze Eco switches to hard-compound tires with low rolling resistance in order to get a couple more MPG. Most hybrids do also. Me, first thing I generally buy for a new car is tires. Every car I've bought that had OE tires they were either noisy had terrible wet traction or both.
    I've heard that the same brand aftermarket tire can differ from the OEM version, even though they may be marked with the same model number or name.
    Might just be an urban legend.
    It was my understanding that manufacturers would specify the characteristics of the tire for their OEM -- such as tread rubber for quiet or grip, rolling resistance for mileage, etc. The Michelin Symmetry that came on my Buick leSabre 2003 may have been just that kind of tire. When I went to look at replacements, the Michelin website had 3 Symmetry tires. From what I remember, one was a Ford spec tire.
    I avoided the problem of which was which because I bought the Harmony model tires.
    I know that sometime people got the same tire that came on their car as their first replacements and those tires never seemed as satisfactory as the original tires were.
    GM had their own specification tires back about 1977. It seems that my Olds had a radial from Goodyear that had a rib running down the middle for better quiet and grip at speed? There was a number on the side of the tire for replacement with the same GM spec tire, IIRC.
  • cooterbfdcooterbfd Member Posts: 2,770
    But this time, they are competing for a customer with the same BRAND!!! Really, the Verano should have been named the Regal, and the current Regal should not have been built. IIRC they are only within a couple inches and 3-400 lbs of one another.
    Actually, what I have come to see on my '10 Lacrosse is excess road noise because the rims are 19's and the tires have such a low profile. The compromise for much more competent handling. In reality, I'd prefer 17's with a higher profile tire to absorb the noise better.
    edited October 2012
    The Voluntary Employee Beneficiary Association, or VEBA, was initiated as a way to get retiree healthcare costs off the books of Detroit’s auto makers. While VEBA makes balance sheets look better, they are still an exorbitant legacy costs for the Big Three, and things are about to get a lot worse.
    Reuters reports that a U.S. Department of Labor document shows that GM’s VEBA obligations were underfunded by 40 percent in 2o11, versus 26 percent in 2010. Ford didn’t fare much better, with a 37 percent deficit in 2011, up from 26 percent the previous year.
    While VEBA was designed to safeguard the health benefits of 824,000 retirees if the Big Three’s fortunes go south, VEBA was forced to take payment in stock rather than cash, something the UAW was opposed to but ultimately complied with. The declining value of the shares is cited as a primary cause of the funding shortfall.
    Increased health care costs are another giant disaster-in-waiting for the Big Three. As Reuters reports
    “The GM VEBA trust said if the rate of health care cost increases moves up by 1 percent, its benefit obligation would increase by $6.4 billion. For the Ford trust, a 1 percent swing would increase the obligation by $3.8 billion.”
    Given the rate of increases in health care costs in America, the automakers are in an extremely precarious position relative to their health care legacy costs – the very same costs that hurt them so badly in the first place, and the very same costs that were supposed to be shed post-bankruptcy.
    What a wasted opportunity. Who takes crdit for this disaster?
    OW
  • busirisbusiris Member Posts: 3,490
    edited October 2012
    The way it's been explained to me by one knowledgeable within the tire industry is that tire characteristics can vary within a particular brand and style tire by size, but within the same size tire, either OEM or bought aftermarket, it is the same composition and construction.
    In other words, a car equipped with a OEM brand and sized tire may or may not get anywhere near the same mileage as one a single size larger, same brand and model tire.
    It is true?
    I can't say for sure. But my personal experience mirrors the supposition. For example...My daughters both ran/run the same model Continentals on their Nissans... 1 Altima and 1 Versa. Neither is a "spirited driver". The Versa tires were all but bald at 30K miles, but the Altima has well over 50K miles with 1/2 the tread left. I service both cars and rotate the tires every 5K oil change.
    I replaced the Versa tires with Generals, which now have over 40K on them and lots of tread left.
    edited October 2012
    Are we talking about Capriracer or maybe you have a "meatspace" friend in the biz? We should try to entice him over to this discussion. Capriracer has lot of interesting posts around here (like this one), not to mention his own informative webpage.
    I've read his input before, and a large part of it agrees with my understanding, which came originally from the father of a guy I went to high-school and college with... He ran the largest tire store in the small town where I grew up.
    Unfortunately, he passed away several years ago...
    What I have seen pretty much gets demonstrated in the Tirerack.com reviews, where its not unusual to see same tire/different size reviews where one guy gets great mileage and another guy (different size tire) gets only a fraction of the same mileage.
    Like I said, I can't swear to the accuracy of the claim, but there's sure no shortage of circumstantial evidence to support it...
    I guess, in the end, when reading tire reviews, make sure the tire review you're reading is for the exact tire you are considering, make, model AND size...
    edited October 2012
    What's interesting to me is how much weaving is involved. (Michelin YouTube)
  • fho2008fho2008 Member Posts: 393
    You ok circle?
    "GM used/uses good tires out of the factory."
    They may now but wasnt my experience with my truck. It came with el cheapo tires, when it rained forget about traction. And yes it is a truck, I know its front heavy and in fact was driving very carefully, those tires were awful.
    A new set of Michelins made a huge difference.
    I drove our Malibu with 21.5K miles yesterday for a longer period than I had in a while, and I think its tires are noisy too...Firestones. And I've rotated faithfully.
    How much tread life is left? What model tire is it? Might be time to replace the rubber with a premium upgrade. The difference will make you smile wide!
    OW
    edited October 2012
    Our Mazda 5 came with Toyo tires that slipped horribly in rain, and didn't last long. They were noisy, too.
    OTOH, my Acura TL came with Michelin Pilot MXM4s, which lasted >70K and were excellent. I was surprised that to replace them would be >$1K for my car. So they were very good OEM tires.
    Yes, if all GM did was make cars where money was made no bankruptcy's or bailouts would have been necessary.
    They just need to make great cars and stop whining about market conditions, gov't interventions into reducing multimillion dollar bonuses, and consumer reports not liking their vehicles.
    '..the rear tires on the GT500 are the same size as the fronts of the ZL1, while the ZL1 has massive 305-width rears under stock fenders. That partly helps to explain the better handling numbers the Camaro produces, but the GT500’s lighter weight might make things equal. After all, they are both riding on the same Goodyear Eagle F1 Supercar G:2 tire, right? Wrong.
    I called our friend Woody Rogers at Tire Rack to investigate. The first thing to realize: The tires on the GT500 are P-metric and the ZL1’s are Euro-metric. This means the tires are dimensionally similar, but each is made to a different set of design constraints. Rogers reported that the construction of both tires appears to be the same, but that the GT500’s rear tire is 2.05 lb. lighter than the ZL1’s front tire, and has a lighter load rating. What’s more, while the Camaro’s tires are marked as ZL1-specific, nothing on the GT500 designates its rubber as unique to Ford. However, SVT says it worked with Goodyear to improve braking power in front and side bite in the rear.'
    http://www.roadandtrack.com/tests/comparison/2013-ford-mustang-shelby-gt500-vs.-- 2012-chevrolet-camaro-zl1/2012_chevrolet_camaro_zl1_page_2
    There are sometimes fairly subtle differences between
    same make, model & size tires.
    - Ray
    Ran into this sort of thing on one GM, a few years back...
    2022 X3 M40i
    edited October 2012
    You ok circle?
    Hosts, quick, dub's password has been hacked! :D
    I just replace the OEMs on the Sienna after 56k miles. Happily avoided the run-flats which last 1/3rd as long and cost twice as much to replace!
    On the subject of tires, the oddest choice I've observed lately is the Prius tires on the FR-S/BRZ. Either they want to facilitate drifting, or they just figure everyone will replace them anyway.
    I was impressed that the OEM tires on my buddy's 2006 Xterra lasted as long as they did...about 75,000 miles. I forget what brand, exactly, they were, but BJ's carried them, and they were good enough in my opinion that I told him he should replace them with the same tire.
    In contrast, my 2000 Intrepid came with Eagle GAs that had a 300 treadwear rating, and they were pretty much racing slicks by around 30,000 miles.
    Kudos to Dunlop (parent company Goodyear), those are the longest lasting tires I've ever owned. To be fair the minivan does a lot of highway miles and it's the car I drive least aggressively, naturally.
    I've worn through sets in 18k miles before.
    https://www.youtube.com/watch?v=_WzeCnXgUn4&feature=g-all-u
    They call it the BMW 3's long lost twin.
    But I thought CR was horribly biased and anti-GM? :P
    The people that think that also think 9/11 was staged and Obama was born in Kenya.
    edited October 2012
    You have to look back over more than two or three years to come to that conclusion. I think most of the auto press has been biased toward imports for three decades. I brought this up before, but GM dustbuster high-mounted stoplights mocked in car mags; identical lights in a Volvo wagon--praised. Same with push-pull headlight switches in domestic versus foreign cars at the time. Pretty obvious stuff.
    Now I know what happened to Skippy Handelman of "Family Ties"...he now works for CR.
    Didn't have anything to do with reality, right? GM, Ford and Chrysler were far and above better than the imports for the last thirty years, right? They all lost market share because of those rags!
    Full bailout-speed ahead, Captain! :)
    OW
    Perhaps what he really meant was "I think most of the auto press has no longer been biased toward domestics for three decades. "
    Lol!
    14000 problem cars from Nissan OMG. That's awful. In the steering rack, no less. If the bolt completely falls out before the customer realizes there's a problem, they can lose control of the car and have an accident. Very serious.
    How could a company that large not assemble the parts correctly? Extreme failure here. Perhaps even worse than the sludge and electronics runaway problems of toyota. How many vehicles may not have been identified as problematic but are in danger because of loose bolts?
    I wonder what the suits have been doing at Nissan for all these years? And the engineers must be crazy: they shouldn't have had a failure on the line assembly. They should have known this would happen. It's all the bean counters faults. Terrible mistake.
    edited October 2012
    What does that have to do with CR's past record? Let's run on CR's past record rather than trying to make the campaign about little points and mockery.
    CR has been injecting their own anti-US manufacturer biases into almost all of their reviews, historically. I recall their 4-5 car comparisons. Read those closely and you'll find word choices that show their bias. CR still suffers the Nader problem and suffers their collegiate journalism school ideals that it's okay to insert bias as long as you have a lofty goal like saving the world of auto buyers from GM (C and F) vehicles. :P
  • greg128greg128 Member Posts: 550
    I completely agree. I remember a review of an Impala years ago that was criticized for having 18MPG combined mileage, but had not one negative comment about the mileage of other import cars with the same exact mileage.
    CR is not alone. I notice the bias in all of the car enthusiast magazines and it is rampant at Edmunds....specifically Inside Line.
    One glaring example: In the "cons" for the 2012 Buick Verano it mentions it is
    "underpowered compared to competitor" and in the review it mentions the 9 sec. 0-60 as "Slow for this class"
    Yet in the review for the Acura ILX that same 9 sec. 0-60 time is "average for a compact economy car" and is not mentioned at all in the "cons" paragraph
    If you read into it enough, that could be taken as sort of an underhanded compliment to the Verano. The Verano is supposed to be something of a premium car, so when I hear "slow for this class", I hear that it's slow for a premium car.
    But then by saying the Acura ILX is "average for a compact economy car", it sounds like CR does NOT classify it as a premium car, but rather something that belongs in with Civics, Corollas, and the like.
    At least, that's one way of looking at it. :P
    Once, CR did a review of an Impala and it was so awesome that in the cons paragraph it read simply "None significant enough to mention". Unfortunately, that was 1977...
    That's surprising. One of the reason's I treat CR as scripture is because of their thorough "CONS" sections. They seem far more negative and willing to insult vehicles a lot more than other publications. I don't think it is a problem with CR being negative (or having bias against bad domestic iron), but a problem with other publications being OVER THE TOP way too positive and lenient with their cons.
  • fintailfintail Member Posts: 58,876
    In 1977, the downsized big GM cars were the most significant new cars on the market. Nothing from any competition came close. In the eyes of reviewers then, there indeed probably weren't any real faults.
    When I think of CR, I think of different ratings for Prizm and Corolla, identical vehicles made in the same factory.
  • dieselonedieselone Member Posts: 5,729
    edited October 2012
    CU certainly has had inconsistencies, but I've found with the vehicles I've owned, the problems I've had are generally reflected in CU's reliability results.
    As for the Prizm vs Corolla debate, who knows. Maybe there are different demographics between those customers and they have different expectations from the car or possibly don't treat it the same. Either the data collected was actually different or CU cooked the results.
    I know personally I notice problems with vehicles that many other don't or at least don't care about, so I know I likely would rate a particular vehicle different than most others.
    Did that really happen, or is it just a story you "heard" from probably some GM fanboy? Did you actually see the review numbers first hand? A link would be awesome.
    The Prizm and Corolla were indeed virtually identical. I give a pass for different reviews if the cars that are almost identical are made in different factories, and/or different countries (unlike some hosts here :P ).
    Maybe it's because I look at domestic cars through my Neon experience colored glasses. I think that kind of bias is fair, since you have a certain amount of patience for problems from vehicles from a certain country. My patience is all used up and emptied out for vehicles from the USA and Mexico (thanks to that Neon). I have plenty of patience left for Japanese and German made vehicles.
    So when I see a Chrysler 300 with LED lights that don't all work going down the road, I immediately criticize and take note and say something like "See, Chrysler's are still all crap, never seen an Audi with dead LED lights" to myself.
    It's a matter of not having ANY patience for domestic car issues left.
    If I were to buy domestic again, I would ream the dealership so hard at the first sign of trouble, I'm just better off avoiding that situation in my lifetime.
