What is the deal? You are mountaining a mole hill. Pretty soon you will be saying I am climbing MT Everest. A guy that has a graduate degree in advance statistics should understand what BS that is. But then, a lot of BS IS created by folks with advance degrees.
The highest number I see is 65.42
Really, that's a poor presentation at best.
Of course, that doesn't matter to you, because you only see the things that support your claims...
Interesting in that I never claimed 65.42 mph. let alone 70 mpg+
You don't like my 50 mpg? Works for me. Ignore it !! I certainly do. I actually wish it was more. Even I know it is not going to happen the way I drive it.
The first graph I see is not anywhere near 70 mpg as you claim.
Of course that doesn't matter to you, because you are in the trash mode: i.e., full pissy mode.
We should really move on.
"moderate hyper miling"?
LOL!
There is a vertical blue line immediately over the column labeled 70.
I've never once made any comment on what your mpg has been. I've only commented on the methodology that you use in substantiating your claims.
I may indeed be full of BS most of the time, but this isn't one of those times.
Then you are still blind and still full of it
So like I said, let's move on.
I was never sent an upgrade ( to the new car sticker (now old) by the rating/responsible agency. Evidently, they did not think it important either. They have the address to send this important piece of information if they consider it important. The upgrade would indeed BE important as it could/would change the ranges printed in the small print, of which there are a minimum of 4 sets of data.. So I think it is a more a CYA (35C/44 H). I would assume EPA 35C/44 H is what it would do under the new EPA standard/testing procedures. The additional problem is it can not now be verified in a "new car", aka 2003 MY. But that does not change what I have been getting at all.
You can go on the EPA website and see the newer MPG ratings for most any modern car.
Sure, I know where it can be referenced. I was the one that posted it, indeed several times. www.fueleconomy.gov , you know that same site that you and others have categorically trashed. So now, EPA 35 C/44 H is gospel? :P
Really how do you know that? Do the real world figures change? Do you disavow the real world data posted before the new EPA standards came out? Do you throw out data like mine? Do you throw out data like the TDI Club link I provided? Do you take as gospel gasser owners perspectives?
The trend seems to be the doubt comes from folks who have never owned turbo diesels. Really that explains a lot.
But wait, the calculation I think you are referring to was done with no speedometer. It was done with time, (odometer) miles, gal fill and at separate times and circumstances. 12.1 gals is significant as the low fuel lamp and dinger comes on and one looks for the closest fuel station.
But, you are right ... YOU need to move on...
I'll admit, you would be the fellow I would want to carpool cross-country with... You could take a car of 4 from LA to NY and it would only cost each rider around $12...
http://ursfb.pbworks.com/w/file/fetch/41185073/Graphs.png
Look to the far right... See the 70 column?
Where did the data come from for that vertical bar???
As you probably would agree, some folks (app 2/3) were able to post 70 mpg, just as some folks (4/5) posted 31 mpg, so where do you think the (31 mpg) data came from? . App 20 folks posted 50 mpg.
You really seem to have a problem staying on the subject, you know.
Since you aren't going to concede the obvious errors in the info YOU provided, any further "feeding of the animals" is futile.
Enjoy your illusion. That's all it is....
So illusions? No, I have 2 diesels and its fine if other folks do not buy them or think ill of them.
I am usually done at that point. But after that I might I'll look at something like fuelly and see if they have enough data to make it useful. One guy's experience or fanboy sites - pretty close to zero usefulness and/or credibility to me.
It is just a friendly discussion. No tin foil hats or wild claims necessary.
In fact, I enjoy poking at folks that like to claim they understand data interpretation, when it's blatantly clear they don't.
On a more serious note, I sometimes wonder how many people get turned off by people making such wild claims about thinks like FE, tire mileage, etc.
Think about it... Subway's Jarred(sp) is a spokesman because Subway has a real-life guy who documented losing a ton of weight by using their product. And, it's a very effective advertisement.
Now, if I was at VW, and there were credible VW TDI owners out there getting substantially higher FE numbers than those posted by the EPA, and those numbers could indeed be verified as being obtained by normal, everyday drivers, don't you think I would be all over it in a publicity campaign?
Advertising like that couldn't be any more effective in promoting the model.
Don't you think Honda would be dragging folks out like that to combat the hybrid lawsuits they are currently "enjoying" if they could find normal, everyday drivers that could document their high FE claims?
MaybeI'm way off, but I don't think so...
Interesting that 1 mpg above EPA (2% higher) is considered a "wild claim."
Seriously I think he knows he can't or won't do it on his, so instantly EVERYONE else is making wild claims.
Tire mileage really is not correlated with diesel engine performance. If anyone should know that, it should be him, with his advanced degree and all.
Actually VW has done quite the opposite, they made a TV and ad campaign on 2 drivers who set the record for diesel driving across the USA in a 2009 Jetta TDI @( 55-58 mpg?? ). They I am sure have it documented and certified, etc. Now I don't have it documented and certified, BUT I have NEVER gotten 55 to 58 mpg on the 2009 TDI Jetta.
Rave on...
Now, I can recall NOT seeing the 2 ads you are talking about.
But your numbers, based on an average person doing average driving in an average TDI, are contradictory to the preponderance of the evidence available.
I am NOT making NOR have EVER made claims that any average person can/does/is guaranteed to get what I get.
I only am saying what I have gotten. Does it vary? Absolutely. And I have repeatedly said so. Could I do better? Absolutely! And have repeatedly said so. Could I do worse? Absolutely. And have repeatedly said so. AND with examples. The TDI Club information (monthly only, there are more historical postings) demonstrates beyond a shadow of a doubt there is VARIANCE. In fact, the only guarantee really: there IS variance.
What folks are trying to assert is: I am saying there is no variance. Nothing is further from the truth. If there was no variance, I could not get the 44 to 62 mpg.
Search for "VW diesel advertisement". That should pop them up for you.
BUT WAIT !!! It is actually it is wilder than that !!! (67.9 mpg) (aka not Utube)
This is just a car forum. No one has accused you of telling lies, any crime or other wrongdoing.
You have only been challenged to produce evidence of your claims... Nothing more.
Relax!
Right. "Wild Claim" Claims. 1 mpg above EPA ratings is a wild claim (+2%). So stop already. You won't !! For some reason, this stuff drives you nuts. I'd say get over it. It's ok already.
I bet you didn't even goggle the 67.9 mpg 2009 TDI (reset) record.
2009 Prius, A-B-C coeff. 19.917-0.13911-0.016365, roadload at 70mph=110lbs. At 52mpg, 33.4% fuel conversion efficiency (energy content of fuel from .gov website).
2009 Jetta, A-B-C coeff. 33-0.29-0.0171, roadload at 70mph=137lbs. At 46mpg, 33.3% fuel conversion efficiency (energy content of fuel from .gov website).
2004 Jetta, A-B-C coeff. 23-0.1-0.0194, roadload at 70mph=125lbs. At 50mpg, 33.0% fuel conversion efficiency (energy content of fuel from .gov website).
My 1998 Cummins turbodiesel 4x4, 7 feet tall, 7 feet wide, 7000 lbs , A-B-C coeff. 49.37-0.1381-0.04017, roadload at 70mph=256lbs. At 22mpg, 29.7% fuel conversion efficiency (energy content of fuel from .gov website).
All the diesels are about the same in fuel conversion efficiency (makes sense - same combustion characteristics, etc.) My truck's roadload is likely even higher because of my 36" tires, so thet would bump the efficiency up a bit. The Prius is also about the same (impressive considering the gasoline engine). I assume my mpg figures are reasonable (I can vouch for mine). I think 50mpg is quite reasonable for a 2004 jetta.
By the way, conventional gasoline cars are more like 25% efficient.
To wit, during the Clinton administration, 1.5 B was given to the big three to each come up with a prototype and a spare " engines " of the future. NOBODY was told what fuel or what to do, aka clean slate. Interestingly enough, all THREE came up with prototype turbo diesels. (Toyota was fit to be tied as they were not invited to the project) They were all thanked very much and the results of $ 1.5 B of R& D was put away, literally on the shelf. The unofficial (but official) policy reason was the regulatory agencies et al., did not like diesel.
..."The Clinton Administration’s fuel efficiency research programs program of the 1990s produced a trio of 80-mpg diesel-hybrids."
link title
So easily an 80 mpg diesel hybrid smokes a 50 mpg gasser hybvrid, @ least 60% better.
It is all semantics, I guess. But when you are saying that you only get 2% better than the EPA estimates, you aren't telling the whole story.
So for example in light of the (RE) record set in the 2009 TDI with EPA of 29 C and 40 H.
67.9 mpg (average) is 69.75% better than the highway EPA mpg. I would think it safe to say that most of the driving was highway.
And if you agree with this, I've officially won the internet.
That's your job.
And once again, I have never questioned YOUR mileage, but I have questioned your backup material, especially where there were latent discrepancies.
And, just for the record, I'm not the only one who finds some of what you say difficult to accept.
I'm not interested in attempting to prove or disprove someone can get 75 mpg by hyper miling. I've seen instances where people have exceeded 90 in gas powered cars.
Again, you choose whatever you want to believe. At the end of the day, it matters not. You want to say you get 50+ mpg, then good for you... More fuel for the rest of us to burn.
I'm not in any measuring contest to see who has the longest one.
Are you?
Again you can chose what YOU want to believe. And truly like you say, it matters not. I do understand YOU can NOT get 50 mpg in a car that has EPA of 49 mpg. I truly get it.
Seems you are. This stuff drives you nuts, "Wild Claims" Claims, personal attacks. If it is difficult to accept, that is really your problem. Just move on. I am betting you can't or won't.
So it is just as easy to not report anything over say 15 mpg. So in line with that, no report. Now move on.
(if there's a posting gap, we've zapped without notice)
