1174175177179180473
    edited April 2013
    > why doesn't Prius build a model that one can hook up a plow and tow with?
    Seems like there used to be light duty plow that hooked to Subaru sized cars a decade or two ago. For a Prius, you'd need the electric blower option. For a TDI, you'd want the flame thrower version.:-)
    The guy with the Kubota said his wife has only gotten stuck once in the snow. Be nice to have a smidge bit more ground clearance. Oh, and his problematic diesel pickup was purchased used and he should have known better. It was a bit tricky to start in warm weather when he test drove but he thought he would be able to nurse it along.
    (And the formatting issues have been reported).
    edited April 2013
    Steve, on the FACE of it, I realized even before I posted the question that it might seem a joking one. HOWEVER, going on a decade and half, there are very few big city taxicabs that are hybrids (% wise) or pizza delivery hybrids. (If folks are going what the F????) Arguably either of these applications are tailor made for the hybrid. Diesels have long since done @ least the taxicab (world wide) and for many decades. We can go on and on with just this one point, so I will leave it at that.
    The macro point here is/are hybrids are having a very hard time finding its way into both national policy driven and practical applications. Now since I am acquainted with plug in electric towing applications, (39 years ago as a minimum) we are really talking, going on MULTIPLE generations.
  • michaellnomichaellno Member Posts: 4,120
    As one who works part time delivering pizzas, I agree with your statement. Currently, I drive an '06 Saturn ION that gets between 23 and 25 MPG with mostly city driving. (I work from home during the day, so the car is used primarily for delivery and other in-town errand running).
    I've often thought a Volt would be a great delivery vehicle. My shifts are usually 2-4 hours long, and I drive between 40-80 miles a shift - so, most of the time, I'd be on electric power and use just a little bit of gas.
    A Prius C is rated at 53/50, so would get 2x the mileage I'm currently seeing.
    However, I can't justify spending $20-35K for something new just for this purpose.
    edited April 2013
    A short response would be why would you not want a VW diesel (POLO not available here) that can post 75 mpg?
    To plug into your post, (yes I know...) one of the ways DIESELS' are "DIS" incentivized IS economic. It would seem the same tool in the quiver is being used by the same regulatory arm to DISINCENTIVIZE hybrids, even as they give hybrids the so called "blessings" and diesels the "curse".
    The DISINCENTIVIZATION can be vertically and horizontally integrated.
    So for example, if I bought a Tesla and wanted to put in a home and office charger, the sunk or overhead costs would easily be 10,000. This would not be counting permit costs. KWH costs would exceed .29 cents and is locked stepped to rise.(I am sure this comes as a surprise)
    OK want to be even MORE envirocon? 30,000 per station to set up a passive solar station in each location. Now because of the increased scale, IF you could indeed get permits for those locations, AGAIN the silliness goes on and on.
    Of course those very same envirocons would be at the municipal meetings PROTESTING YOUR proposed envirocon PROJECT !!!! The (French style) anti business attitude is already incorporated into our regulations. Makes one wonder what this would do to a $10.00 piazza?
    After eavesdropping on oil guys on the plane rides last week, I think the EV adoption rate studies may be a bit optimistic.
    Then again, the oil guys think that there's enough oil and gas in the ground just in Alaska to run the world forever.:-)
    Study Predicts at Least 5 Million Electric Vehicles by 2035
    Well if you ever needed a clear warning sign that something's not right with a diesel, it's a diesel that doesn't start up instantly. It is characteristic of the diesel engine to fire up pretty fast, so if one grinds and grinds, you got problems, sometimes bad problems.
    edited April 2013
    Well if you trace the REAL issue it is the electrical issue that is @ issue. If the electrical power and cranking ability could be better scaled (for the grueling winter electrical draw) it ceases to be an issue.
    Lots (?) of people think you have to finagle a glow plug for a minute before you can push the start button on a diesel. I was always reminded of the hassle trying to start model airplane engines back in the 50s/60s. Nowadays the models are mostly electric so it's plug and play (as are modern diesels).
    Could also be low compression or fuel contamination/gelling. Some folks think of diesels as "simpler" than gas engines but they really aren't---just "different" in their technology. Injection timing is quite critical, the fuel is more sensitive, and glow plugs wear out just like spark plugs.
    Battery technology (really more like expectation of its enviromental correctness) is really WANTING. To wit the lithium battery in a Boeing 787.
    edited April 2013
    Nobody has made the case that diesels are maintenance (unscheduled especially) free. Nor has the case been made for REPAIR free. Indeed I posted a preventative change of glow plug wiring harness and glow plugs @ app 180,000 miles.
    Indeed a case has been made that passenger vehicles have improved to the point where ANY new vehicle (gasser/diesel/hybrid/plug in) has a minimum of 100,000 miles as the first "major tune point" aka, BETTER.
    Salespeople sometimes pitch diesels as "never needs a tune up!" or "these babies are known to go 500,000 miles!"
    Naturally, these statements sound good, but are in fact full of potholes.
    edited April 2013
    Defacto anything over 100k miles (much better than old school back in the day) needs repair/maint etc. To expect anything different is illusionary.
    So for example in the first 100k miles on a diesel, I can expect to do a min of 4 oil and filter changes.
  • crkyolfrtcrkyolfrt Member Posts: 2,345
    edited April 2013
    You guys have $10 pizzas down there? Delivered? :green:
    Something else I have always been curious about, although knew the answer during the years I ran the south eastern seaboard in the truck a couple decades ago..is..are there any States that charge sales tax on meals? Here we only get a break (on sales tax of 8%...we STILL have to pay GST of 5%) if it is under $4.00. One cent over 4 bucks and we pay the full 13% on top.
    Becomes a pretty BIG deal if you are at KFC or Swiss Chalet (wor$e) and you're picking up for a feast. You could literally buy extra dinners..plural...just with what is paid extra in tax :sick:
    edited April 2013
    LIFE is GUUD !
    The answer to your second question is selective and depends on STATE. We went to MC Dee's in OR for a .99 egg mc muffin (2 actually) and got back .02 cents on two dollars in payment. Some states will have the vendor ask: for here or to go? To go, .... NO tax. Sit down or here, YES tax. Opaque to the customer some states see cooking as value added and may impose a tax that you pay and dont really know that you do even as food is not supposed to be taxed. And yes, I agree with you, it IS a BIG DEAL on seemingly such a SMALL point.
    edited April 2013
    That is...usually.. and especially in the cold. If you're really lucky, the reason for a hard start, is poor battery performance. But if you have new batteries and all the connections are good and the lines aren't thinned down within inches of their life (something that usually diesels destined for cold climates still avoid) and if it has to turn a lot then worn rings and all the other compression-related components, valves etc although rings being far more common...in the hands of those who think because it's a diesel it never needs an oil change...don't cry...I've talked with this level of ignorance in the past :sick: are usally behind the hard or no start. if you get a bit of a gallop then can be an injector and/or glow plug related. If it starts and (a 4 cyl) runs on 3 and then as it warms, the 4th starts to fire, that usually a glow plug more often than a bad injector. Galloping can also be related to injection timing, but in those cases it is more likely to be a gradual degradation and doesn't just start doing it overnight (unless was fussed with the day prior of course).
    I'd love to have the no tax on 'to go' stuff. There'd be a lot more chomping down while people watching in the parking lot from the comfort of the car...playing The Doors or SRV instead of Muzak half off frequency.. haha
    Here, places like Swiss Chalet..you have those right? They are owned by...forget...but the same owners as Harvey's..will charge you more even pre-tax for sitdown meals than togo.
    Kara foods I think??
    edited April 2013
    In one home town, we just had another and new Starbuck's put in with a drive through. So for a host of reasons, it seems to pencil out as economically viable, or is part of a new modified Starbucks going forward vision. As you know, you really have to buy (rent, lease, get approvals, build) far more "non productive" land etc. to run a drive through.
    As for the Swiss Chalet South Tahoe, CA DID have one for oh,...(I am told) 60 or so years. Sadly IT closed. I am not too much up on the actual ownership.
    edited April 2013
    ..."Several European automakers, long diesel proponents, have figured this out and started installing them in their SUV lineups. Mercedes-Benz is the first one to put a diesel in its smallest SUV. (Read our Mercedes GLK350 road test.)"...
    The above quote OBVIOUSLY was not vetted. MB might be first to market for a so called small "CUV/SUV"
    I told automakers YEARS AGO to put diesels in SUVs and Jeeps, not cars, for the American market.
    edited April 2013
    It is SO logical as to defy logic, why they took SO long !
    Sort of an interesting example, VW Touareg also comes in a (supercharged) gasser hybrid. It is app 18k more than the TDI. The power approaches a V8 (428 # ft vs a weak 406 # ft TDI :)) . However for what most CUV/SUV drivers want it for, the TDI gets better fuel mileage over the hybrid.
    Diesels are best for hauling weight around. That's where they can beat the gas engine hands down...in lightweight little cars the match-up is so close, and the profit margins so small, that it's simply not a great idea to put a diesel engine in a tiny little car.
    edited April 2013
    Over 180,000 miles, the so called smaller (1.9 L) diesel power plant has proved itself. 90 hp/155# ft of torque in a 2,950# body, 50 mpg
  • stickguystickguy Member Posts: 54,229
    In NJ,. you pay sales tax (7%) on restautant food, eat in or take out.
    but, we don't pay any tax on clothes. go figure.
    and still some of the lowest gas taxes of any state.
    too bad we have the highest property taxes in the nation. I would gladly drop 10K from my property taxes in exchange for sales tax on my underwear.
  • scurvydog42scurvydog42 Member Posts: 2
    I am a diesel proponet. I currenly own a 2005 VW Golf with a 1.9 L TDI deisel. It was purchased new. At 5000 miles the oil presure sending unit was moved/extended to accomodate the installation of a high efficiency oil by pass filter. This also increased the volume of oil by one, (1), quart. From the first oil change and every one since, Amsoil European Synthetic has been in the crankcase. Fuel consuption typically averages in excess of 50 mpg around town and better than 57 mpg long hauling. The worst fuel milage has been 47 mpg during brutal New England cold spells.
    If America would build a solid small 1/2 ton pick up truck with a straight 4 cylinder or 6 straight cylinder diesel engine, I would buy it. Tomorrow. The Indian company, Mahindra, wanted to import just such a diesel truck, but they could not pass the EPA requiremnts. It was rumored the test was performed while carrying a payload of 100 environmentalists and attornies.
    What up GM? If you build it, it will sell. I'll take a dozen.
    That is a big factor in my looking for a place to move from CA. All our taxes are high here. Though Prop 13 kind of protects the home owner from bubbles in home values. You may move to a state that has no income tax like TX and find they have very high property taxes. Look at the positive. Your high property taxes are a direct write-off from the Feds. Sales taxes are not a write-off. We pay 9.75% sales tax on food that is prepared. Not at the grocery store. Just about everything else is taxed including gas. Making US 1 or 2 for high fuel tax.
    I have been screaming that on Edmunds for 16 years. The D3 have been protected by the Chicken tax on small PU trucks and CA has successfully held back small diesel engines. Which tells US fuel economy in this country is not a factor to the folks running the show.
    Welcome to the forum.......:-)
    What Is the Chicken Tax refered to in post 8955?
    What configuration would you like to see in a small American PU? (and I mean an all American diesel, not some Italian made clang banger as in the Liberty)
    We may have to build our own...
    I know my TDI cost a hefty additional $1800 upfront, but, it has paid dividends every day since. Savings in fuel costs paid for the vehicle and any fuel consumed in less than 100K. (Cost avoidance/savings in going from 17 mpg to 50 mpg was significant)
    edited April 2013
    The so called "chicken tax" was PROBABLY a vernacular reference to the 25% duty the US levies on ill defined EVERCHANGING and rubber ban ruling of FOREIGN cars. Indeed a duty/ies might STILL be levied on specific "FOREIGN" components, but not on the whole unit.
    My like for like (4800 to 4974#) SUV for CUV (14-17 mpg to 29 to 32 mpg) spans 27 years (hope for change) has so called significant difference in FE (12 to 15 mpg vs 30 mpg) 100% BETTER FE (50% savings). Of course a few to many on this board has labeled this INsignificant.
    Now both of the 90's TLC SUV's have clicked 200K + miles, so lets just use 225k each or 450,000 miles @ 15-30 mpg. Over the course of these two SUV's 450,000 miles, I have used 30,000 gals vs 15,000 gals that I would rather it had been.
    Those same folks, labeling it insignificant can punch in the numbers @ the current RUG/PUG/D2 prices to see how insignificant 60,000 dollars might be to their budgets.
    But that's nothing that a similar or even smaller gas engine car couldn't do. Gas engines can go 225,000 or more, no problem. So those stats don't "prove' anything really. And besides, most small diesel cars don't get 50 mpg. More like 40. And you go slower, pay more for fuel and have smelly hands....:)
    At least in a big truck or SUV or 6 passenger sedan, you're hauling weight or people, and can take advantage of larger diesels, to offset these disadvantages.
    edited April 2013
    Your assertion is contradicted by www.fuelly.com, unless you count yourself among those that assert 46.5 mpg (diesel) is the SAME as 27.5 mpg (2.0 turbo PUG)?? !! IF so, then I am ok with agreeing to disagree.
    (leaving out my TDI results as I have no results for 180,000 miles in a GASSER 2003 VW Jetta) I have of course posted 38-42 mpg in a Honda Civic, but I think we both would agree those are FAR different cars.
    Thank you for YOUR vote of confidence, as even I do not think I could get 50 mpg on a GASSER VW Jetta 2003 for a consistent 180,000 miles !! Indeed all I did for the diesel VW Jetta 2003 was understand the parameters ( that particular diesel but turns out to be most to all diesels) and driven AGGRESSIVELY in them. So in truth, I really was able to do FAR better, (again I swag 52 to 55) even as I only posted app 50 mpg. Another way of saying that would be (I swag) that if I drove the VW Jetta 03 GASSER like I did the diesel I (swag) I would have done far worse than 27.5 mpg.
    True Delta reports owners getting an average of 42.3 mpg. That sounds about right to me.
    Right, since you are using different statistics? You might as well post the delta for the gasser to complete the comparison.
    The chicken tax is the main reason we no longer have small diesel PU trucks sold in the USA. The D3 are not interested in building any vehicle that could take sales from their full size gas hogs. And the full size diesel trucks are in a league all their own.
    The chicken tax is a 25% tariff on potato starch, dextrin, brandy, and light trucks imposed in 1963 by the United States under President Lyndon B. Johnson in response to tariffs placed by France and West Germany on importation of U.S. chicken.
    Eventually, the tariffs on potato starch, dextrin, and brandy were lifted,[4] but over the next 48 years the light truck tax ossified, remaining in place to protect U.S. domestic automakers from foreign light truck production (e.g., from Japan and Thailand).[5] Though concern remains about its repeal,[6][7] a 2003 Cato Institute study called the tariff "a policy in search of a rationale."[4]
    As an unintended consequence several importers of light trucks have circumvented the tariff via loopholes—including Ford (ostensibly a company the tax was designed to protect), which imports the Transit Connect light trucks as "passenger vehicles" to the U.S. from Turkey and immediately strips and shreds portions of their interiors in a warehouse outside Baltimore.[
    Those are owner-entered stats, averaged out.
    edited April 2013
    So you are saying that figure (42.3 mpg) is the average combination of both diesel and gasser ?
    edited April 2013
    http://www.youtube.com/watch?v=ODVcjl3S90k
    MT likes the Jeep EcoDiesel SLIGHTLY better.
    For me, the question is whether or not the $20k extra stuff is really worth $12 to $15k MORE? If I were chosing again today, the dynamics really haven't changed much. As Gagrice has mentioned in an earlier post, Jeep ETDI does not offer as many ETDI variants.
    Another is Jeep EcoDiesel was clearly designed for more serious off roaring as befitting its American off road DNA. The tester even acknowledges that 99% of likely Jeep CTDI buyers will probably NOT engage in that level of SERIOUS off roaring. Touareg started out as a serious as a heart attack off road (Dakar type) vehicle that oh by the ways can seriously cruse the Autobahn. Due to customer input, it has redesigned a few times and has morfed into a serious mostly on road, albeit autobahn cruiser that can do some serious off roaring. Even at that the Jeep eTDI only slightly beats out the Touareg.
    Its all good ! However to me the more choice the merrier !!
    No, the 42.3 is the average MPG reported by all VW Golf TDI owners who reported in.
    Right, that is what I thought. BUT your response was unclear to me. So now, if I can repeat the original request, what say you is/are the GASSER VW Golf's delta, for comparison?
    27.6 average for the gasser.
    edited April 2013
    So TOTALLY independent of ME, ( what my results or thoughts are, indeed the figures you posted are not mine), the difference for TDI's (AVERAGE) is/are 53.3% BETTER mpg than gassers.
    So buying fuels @ a 96150 resort location: 3.69 RUG/3.89 PUG/3.89 D2
    The price per mile driven are:
    PUG (3.89/27.6 mpg)= .141 cents per mile driven
    D2 (3.89/42.3 mpg)= .092 cents per mile driven
    RUG being (also) 53.3% MORE per mile driven.
    I am thinking you are not thinking or even really saying they are equal, but I am projecting here.
    Well I think it terms of gallonage per year, not percentages.
    So for the average driver it's about 160 gallons a year difference.
    So clearly there is no great advantage to owning a TDI vs. a gas engine equivalent because the payoff is too long.
    edited April 2013
    The average US consumer (average yearly mileage driven) is 12,000 to 15,000. (Steve has indicated in a past post) European average mileage @ 9,000 (converted from kms of course and with lower average mileage diesel would make even less counterintuitive sense? ) would again contradict your opinion.
    There has been HUGE cut backs in (US) consumer use, in bought RUG/PUG, as prices have hit record levels. Indeed if the reelected BO administations has its way ever closer to $10.00 per gal RUG/PUG. Part of the (food chains) legislative to regulatory call for even higher prices per (gallonage) or a tax on MILEAGE is due to the decrease revenues (gallonage) in even higher cost per mile driven costs !!!! ???? Not to get political but the mideast as long since been chosen as the bellweather of stability or lack there of , on the issue.
    So yes, it is an agree to disagree, even as I understand 95% of the passenger vehicle fleet owners will pay more per mile driven. Basically there are HUGE DISCONNECTS. (the talk does not follow the walk or the walk does not follow the talk).
    So in effect (given the diesel vs gasser Golf example), I am just one of the outliers (less than 5%) that has chosen to pay less per mile driven, acutally USE LESS "gallonage", as most folks (95% of the vehicle fleet that own gassers) chose to pay more and actually use MORE gallonage (55% MORE) : specific to the example 53%+ MORE.
    I am ok with that, as are most of the folks that chose to pay more seem to be.
    I had to pay off $236 in extra cost/s for the 2003 VW Jetta TDI, over the 1.8 turbo gasser. Again, just running the numbers on edmunds.com, the TDI resale values are $1,435 TI, $1,653 PP, $2,037 DC MORE for the TDI. Defacto those figures will turn out to be an INVESTMENT??? Right now the return is 608%/10 years or 61% a year. I wish I could do that in the stock market !!!! :)
    This is not even counting the extra cost of fuel difference. So @ today's prices $3.89, $3.89, 27.6mpg/42.3 mpg/180,000 miles (gallonage) is 6,522 - 4,255 gals or 2,267 gals (3.89) MORE or $8,818 more.
    So in that sense, you are 100% correct (for that 95% of US gasser owners). Most gassers owners are willing (to project past the VW Golf gassers case) willing to pay $10,000+ MORE for the same mileage (180,000) driven.
  • canewhitecanewhite Member Posts: 4
    We mostly consider price, look, size and performance while deciding to buy a car. The price of gas is quickly reaching the price of diesel gas, helping make diesel an attractive alternative for prospective car buyers. Another factor that might make diesel a more attractive option is the fact that they tend to fetch a better resale value than their gas powered counterpart. Today you will find most of the high end car makers are offering diesel options making it a favorite choice of masses.
    What is the price of gas in India where you are compared with diesel?
  • jayriderjayrider Member Posts: 3,602
    I agree with your conclusion Shifty but folks believe what they want to believe. Nothing wrong with that, it's the human condition. Folks should buy a diesel because they like the way a diesel drives. Forget the economics -- buy it cause you like it and enjoy the difference from gassers.
    I bought my Prius in the fall of 2010 when gas prices were dropping so I got a great deal. I didn't buy it for the mpg [nice bonus], I wanted a roomy hatchback with comfy seats. I probably will never live long enough to break even considering I could have bought a Versa for 7k less. I didn't like the Nissan or any other hatch on the market. Personal preference. Critics hammer the way it handles but it drives fine for me. Smooth, quiet comfortable. I doubt anyone's lifestyle is improved from an economic standpoint by driving a VW diesel vs a VW gasser.
    edited April 2013
    Stuff like that adds up over the years though. I've spend ~$21k on gas for my '99 minivan that gets 21 combined. Double the mpg and we're talking ten grand in savings over a decade or so.
    "Indeed if the reelected BO administations has its way ever closer to $10.00 per gal RUG/PUG. "
    The U. S. government doesn't set the price of gasoline and can't really affect it very much. If the office of president were abolished tomorrow, it wouldn't affect the price of gasoline.
    RE: Resale value of diesels ----depends on the manufacturer
    RE: "The Payoff" --- 12,000 miles per year over 10 years saves a TDI owner about $6500 in fuel, so the first 5 years are for paying off the extra cost of the diesel engine, and the next five years are actually "savings".
    So in ten years you save about $3200 in fuel costs, or $320 a year.
    edited April 2013
    Well on just one level it makes one wonder why don't they just get out of the oil regulation bit ness!! ?? The government is actually involved in and @ EVERY level of the oil food chain. The truth is at the macro level is the governments make more monies from oil than the oil companies for as much money as oil companies make !!
