Visitor Agreement.
If you have any questions comments or concerns feel free to email me.
Christina
GM Customer Service
I understand. If you have any questions or concerns please feel free to contact us directly.
Thank you,
Caron, GM Customer Service
Have you spoken with GM Customer Assistance? If so, do you have a case set up?
Thank you,
I picked up the car on April 4, 2011 and was told everything was fixed and the new "program" was downloaded for the tranny, so i should expect a different feel in shifting. Fast forward to April 17, 2011 - same exact issue but now the RPMs jump between 1st and 2nd gears, and 2nd and 3rd gears. The car is back in the shop, and I am waiting an answer. Was told last time their best transmission guy was working on the car, I don't have much faith anymore.
I looked for about 15-20 minutes on the forums and did not see this "up shifting" spike being mentioned. Anyone else out there experiencing this?
I took this problem to my purchasing dealer and was told that everything was normal and there was not service bulletin on this. As a retired powertrain engineer, I know it is definitely not normal. I hate to see this problem become wide-spread and destroy a vehicle that I like a lot.
Similar to some other posts here, I also have experienced regularly the same problem of seeing blurred images from my rearview mirror while driving on highway under normal conditions.
Please keep us updated when you call GM Customer Assistance.
Thank you,
I would like to set up case with GM Customer Assistance. In order to set up a case I will need the VIN, current mileage, full name, address and best contact number for our records sent to me in an email. Also, what dealership are you currently working with? Any assistance you can provide would be greatly appreciated. Thank you.
By chance, have you contacted GM Customer Assistance?
Thank you,
Please keep us updated when you have taken the vehicle into the dealership.
Thank you,
I have noticed the enginer running rougher when cold lately, but no check engine light. Given the comments about the High Pressure Fuel pump failing and leaking fuel into the oil, I am speculating that fuel contamination may be the root cause of oil consumption either from increased wear, or vicsosity reduction. I sent an oil sample to a laboratory to test for fuel contamination.
I have not found a TSB on HPFP failure in the 2.4L 4cyl; only for the 3.0L V6. For those that got their fuel pump replaced on the 4cyl, what were the symptoms that caused them to diagnose it?
No I have not, could you provide the necessary information to do so? Is there a form that I should fill out?
Thanks for your prompt reply
I would be happy to assist in setting up the case with GM Customer Assistance. In order to start the process I will need the VIN, current mileage, full name, address and best contact number for our records sent to me in an email. Or you can contact Customer Assistance at 800-222-1020. Hours: Mon to Sat, 8am to 9pm ET; Closed Sunday.
Thank you,
Thanks for your response, I called Gm and they have contacted the dealer and have cleared everything up. I'm to bring my Equinox in to the dealer when oil is needed and they will measure and keep track. No more confusion.
And this past Friday I had an engine light come on, contacted On-Star and they gave me the code and went to my usual dealer and had a Fuel Tank Pressure Sensor replaced and Camshaft Actuator replaced, both were bulletins.
Glad to hear everything is getting cleared up for you! Please keep us posted on any information regarding the vehicle. If you have any questions or concerns please feel free to contact us directly.
Thank you,
Have you contacted GM Customer Assistance?
Thank you,
I'm going to call GM customer service tomorrow. In my opinion, a large part of the blame in not being able to diagnose the sticky steering problem rests on the Chevrolet service dept, mainly the service advisor who heard what I was telling him, but wasn't listening. In order for the problem to occur, the vehicle must be operated for at least 45 minutes, and driven at highway speeds on a smooth road surface. That is exactly what I told him and this is the way he wrote up the work invoice: "Customer states steering feels stiff after driving for a while." When I confronted him about this I was told not to worry about it and that they would have to talk to GM about this problem anyway. The bottom line, is that my Equinox was not driven for 45 minutes, and was not driven on the highway but only driven around on local bumpy, pot hole ridden city streets which would never allow the problem to manifest itself. And because the service advisor thought he knew what I was trying to say better than I did, I get to waste taking a day off from work and wasting all of my time for absolutely nothing. I'm hopeing that my call to GM customer assistance tomorrow will help.
I thank you for your concern Caron.
I completely understand. Please keep me posted on information after contacting GM Customer Assistance.
Thank you,
Thanks for your suggestion. I agree that it's probably the best way to handle this.
Thanks for the prompt reply. Could you provide an email address that I can send the information to you directly? I prefer not to post these data openly.
I apologize for your frustrations. Can you please email me with your VIN and contact information? I look forward to your response.
Christina
GM Customer Service
If you haven't been to the dealer yet I would recommend doing so very soon due to your mileage. Please email me directly so we can discuss how to proceed with this further.
Christina
GM Customer Service
Great! I look forward to hearing from you after the dealership visit.
Thank you and have a great weekend!
1) Tire pressure sensors were programmed for the wrong tires.
2) Lumbar suport on driver side popped (had te go for service 2x on this one)
3) all my weather stripping in the doors fell off this winter when I simply opened the doors one morning. Alse cost me 2 more service visits.
4) temperature gauage stopped working and screen told me "AC off due to high engine temp". On this particular day it was 45 degrees out and the car had not been running for 3 hrs. Temp guage was below cold so why did the car think it was overheating. Fan ran even when I turned car off and then 4 hrsl ater - suddenly stopped and all went back to "normal" Dealership cant find problem or reproduce problem and no engine codes to history again. They had my car three days.
5) Passenger seat warnign has gone off telling me to put the seatbelt on even though its only my purse in the car. This mysteriously stopped after a few weeks.
6) Car sounds like its diseil - loud and choppy.
I feel unsafe in this car and have no idea if anything else will fail or if my airbags will even work. Two major probelsm as far as I am concerned and neither have or can be fixed per the dealers service shop. I dont want my car anymore. I am convinced I have a lemon.
Where do I start? Who do I call? This car is 14 months old. First problem reported at 7k miles.
thank you!
I have sticky steering on the highway....add me on that ever LONG list
I have a 2010 4cyl.
timing was all off, there's a weird noise coming from my vents when the heat is on (window-part)-no one can seem to locate the issue, my weather stripping was crooked and need to be re aligned, my car VIBRATES so hard that I can't make out in my rear view mirror what kind make or model of vehicle is behind me, my noxs bucks and very hesitant-some say it's because I have a 4cyl.-I don't but that, sometimes my radio doesn't work-the volume, I will have it on and turn it down all the way then when I turn it back up it takes a few. it's up but nothing comes out, the scariest for me is the sticky steering -especially on the highway I have fear when it sticks it feels like for that split sec I have no control at that point in time-and it happens all the time!!!! I really DON"T like the bucking either that's scary. AND last but not least I don't like how loud and obnoxious my car is it sounds like a diesel and that IS VERY irrating...I don't know maybe I am just being too picky
I've started to run the car with the "ECO" function off, and it runs a bit better. There is a bit of vibration, but not as much. If GM could come out with a new program that would remove the vibration, I would gladly give up a few MPG for it.
it is an Idle Chain (?) problem. So I have a rental
until...? I, too, had vibration and stalling issues, along with
Noise and sticky wheel.
I would like to set up a case with GM Customer Assistance. Could you please email me with your complete contact information, VIN, current mileage and involved dealership?
Thank you,
Unfortunately, I am unable to assist customers located outside of the United States. I would encourage you to contact GM of Canada at 1-800-263-3777. Hours: M-F 7:30am - 11:30pm, Sat 7:30am - 6:00 EST.
Thank you,
Thank you for the updates, please keep us posted. If you have any questions ro concerns please feel free to contact us directly.
Thank you,
Thank you for the update! I hope this resolves the issues as well. Please update me after you get the vehicle back on Friday.
Thank you,
Have you contacted GM Customer Assistance? If so, do you have a case set up?
Thank you,
