The mechanic determined the fuse was blown so he puts in a 25 instead of a 20, which gets it working again. I drive it almost home and I start to lose acceleration power as if I shifted into neutral. I also hear sparking by the fuse box. I immediately shut off the a/c and the car gets power to accelerate again plus the sparking sound stops. The blower is not working again and after hours of having it parked I go to start the Tracker and the engine won't turn over. WTH? Please help on this miserable Sunday morning, I'm ready to buy a new vehicle if I can't get this beast working right again.
Found a local tire/suspension shop - part of a Louisville area chain (Ken Towery) - that did the job for $217 and change, got the whole axle overnight and installed it in 20 minutes, with a 1 year warranty. I am pleased!
The also gave me a heck of a good quote to replace my ac compressor and redo the whole system. I'll post that under another topic heading.
I would be interested in knowing how that kit installation works out for you!
2000 Chevy Tracker, 2.0 liter engine.
Talked with NAPA & Chevy dealer, nothing.
I see a lot of Trackers around town & I gotta believe they've not blown up & had the engine replaced.
HELP!!!!!
I found a PS hose that was leaking & fixed that
If you find the problem please let us know.
This has stumped more than a few mechanics already. I'm sure the solution is something simple, but nobody can find it.
I've got a 2001 Chevy Tracker (aka Vitara). 2.0L, automatic, A/C, power everything.
Occasionally the interior fan and running lights will stay on, even after I have shut off the vehicle and removed the key.
This only happens during extended periods of really wet weather. It is sporadic and not predictable. Often the interior fan and running lights will come on hours after I have parked the vehicle. The lights seem to be triggered by the night sensor on the dash, because they won't come on by themselves during the day. This results in a dead battery when I try to start the truck in the morning. I have resorted to disconnecting the battery when I park.
This is a problem I need to resolve because I would like to give the Tracker to my wife to drive our daughter around. I don't want to give them a vehicle that is likely to leave them stranded.
Any thoughts?
thx
99 - 04 Tracker 4WD Squeak Squeal Front Hub or CV Joint Area at Cold Temperatures - kw 1.6 2.0 2.5 axle cvjoint differential L34 LE8 LQ4 lubrication noise seal suspension #PIP3278 - (Dec 27, 2004)
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in the PI.
Condition/Concern:
Squeal or squeak type noise from the front axle area during cold ambient temperatures. The noise disappears after a few miles of driving. The condition will occur in 2WD or 4WD. The noise can occur at the left or right front hub assembly area.
Recommendation/Instructions:
Operating characteristic. No repairs should be performed.
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Models:
(99 Chevrolet Tracker 4WD) and (00 Chevrolet Tracker 4WD) and (01 Chevrolet Tracker 4WD) and (02 Chevrolet Tracker 4WD) and (03 Chevrolet Tracker 4WD) and (04 Chevrolet Tracker 4WD )
its def not a cruise control servo...lol
trackers pretty much powerless, catylatic converter smells often, but there is exaust flow at end of tail pipe. ive ran a few cleaners only one that helped was marvel mystery oil.
i have two codes for low voltage on bank 1, but light went off when i ran marvel, was only off for a day.
Also, can anyone provide instructions on how to replace the exterior door handles?
Thanks in advance for any guidance.
Jean
