I was told that the OEM tires that came on my Outlander were actually designed for a truck setup - and the Outlander is a car based vehicle (like the endeavor). I even swapped all 4 of my tires to a car, touring type tire and it hasn't made a difference with the suspension noises.
By the way, they (dealer) are still searching for the source of the noise, but can hear it.
The Endeavor's owner's manual states that chains cannot be used, presumably due to the possible interference with the struts.
Does anyone have a solution for improving traction in the snow and also to complying with the requirement to carry traction devices and not impacting the vehicle's warranty?
A few people also said that the pressure from the hose at the car wash can sometimes force the rocks out.
I will speak to my dealer about this next time I go there.
If this is the case, I would imagine that the noise would go away for at least a little longer than it does when it's on a lift and then I would be able to tell if that was the problem.
I have a whining noise 40 mph and higher. I took to local dealership and the mechanic took my Endeavor for a drive and came back and said there wasn't any out of the ordinary whine he could hear, that isn't in any of them? I accepted his opinion. It was about two month ago. The noise or whine annoys me, so I was searching for some answers and found these discussions and it appears there is a problem with the drive shaft area with an abnormal whine? Can anyone tell me, how loud their whine or noise was when they were able to have dealership agree? I want to take back to dealership, but I need some ammunition or does anyone have any other ideas? I need to know somehow that my Endeavor's noise is abnormal.
I had a similar whining noise that started at about 40 mph. I took it to the dealer and they had the shaft assembly replaced. The noise is gone.
I really like the body styling of this car and price compared to the other available options in the same price range.
A friend of mine swears that mitsubishi cars suck, but is also a faithful Nissan Maxima supporter. But like i told her cars in general suck, since they are all made of running parts. The same problems that plague the End can also plague a toyota, or nissan.">
The End had just enough options to keep me satisfied, but I also dont want to end up buying a car that is going to be more of a problem in the long run. Honest opions would be greatly appreciated.
Reliability - not a problem for me, and this one is a 3/2003 production date, and I got the XLS 2wd. This vehicle has been great. Also, with the 100k factory warranty on the power-train, not worried about it.
Value - well, not being able to run as well on the 87octane costs a little more, and unless you plan on keeping it more than five years, it takes a bath on resell. I'm keeping mine a long time, and I also like being more unique on the road.
To me this sounds excessive and indicates a short or a surge problems somewhere. Does anyone out there have the same problem or solution?
One of the Edmunds reviews I read about the Endeavor versus the Pilot favored the Endeavor and was one of the reasons I purchased the Endeavor. For this and for other reasons I believe I made the right choice.
I must admit I have read all the post and learned a lot.
I have a 2005 endeavor LS with 3000 miles and absolutely love it. My two questions are is there an easy way instal
a sub woofer in the rear(the LS does not come with one)where the cut out already exists. Also is a slight tapping noise comming from the engine normal. My friend says it's normal in many forien cars. I traded in a Ford ranger v6 and never noticed one in it.
I've never mentioned this to the dealer because it is not an issue for me due to it's infrenquency. Any idea what the Mitsubishi Service Bulliten says about It? Bill C.
Our Endeavor XLS won't turn-over. It sounds healthy during the whole process and sounds like it is going to start, but never turns over. It has been to the dealer twice and they are unable to note any problems or fix it. Each time it is towed to the dealer it starts for them.
The first time to the dealer it started right up and they ran a bunch of tests and reprogrammed the key. They found no errors and we tested all keys for it. They suspect that the ECU (immobilizing unit) was failing, but could not prove it. They asked me to look for specific lights on the dash and around the key ring (the green car in the extreme lower left of the dash and blinking of the green light around the key ring). Neither of these indicators ever came on.
Luckily I paid nothing.
The second time to the dealer they changed the air filter (it was admittedly dirty). Once again they could not isolate any problems. When I went to pick it up, it didn't start. It would just continually sound like it is turning over but never actually start. After several minutes of trying it started. We chalked it up to the air filter.
NOW AGAIN the darned thing wouldn't start. Each time it is towed it starts, so this leads me to believe that something is bumped or jarred and it will magically start. The ECU is several hundred dollars and won't be ready for a week or so as they order (estimated).
The car was 200 miles out of its 36000 mile warranty when I took it in the first time (we bought it BEFORE they extended the warranty).
I'm wondering if anyone has information on this error/problem, what I can do to get the dealer to call in a Mitsubishi Tech expert, or somehow get them to say something other than "We don't know what it is." I am looking to get the situation escalated to the next level of service.
Where else can I look for information regarding this?
This is the second Mitsu I have bought from this dealer, but I will never buy one again, not from them, not from Mitsubishi. They have not tried to accomodate me in the least. You would think that they would offer a courtesy vehicle when our car has been in their shop for over 2 days. The dealer has "courtesy vehicles" about on the parking lot.
Thank you for your time,
justin
Have you asked to talk to a Mitsubishi service rep? DO NOT tell them you will "never buy another so & so car ever again!" You might as well shoot yourself in the arm , it wouldn't help any either!
After giving everyone a reasonable chance to fix the problem, ask about the lemon law in your state,and/or contact the better business bureau for advice. I suspect they don't know what the problem is and they and Mitsubishi are reluctant to just start throwing on new parts that are almost certain not going to fix the problem. It's a bummer, I know. I've been on both side of the counter. Bill C.
And, from what I hear, some of those who do not use Premium in the Endeavor develop spark knock.
If you have the combination of long duration of spark knock + occuring during heavy work load, that can be deadly.
Otherwise, using premium fuel will correct the condition (but not of course prior damage, if any, from pre-ignition).
I own a brand new endeavor 2005. Let me tell you a breif story:
bought it in febr. 06, a week later a stupid driver casued an accident, my car was in the shop until april 18, 2006.
when i drove it home i discovered AIR NOISE. the kind that a window would be open and wind seaping in. annoying to say the least. i called the body shop guy and he said it is common in endeavors. i never noticed it before - in that one week i had it. i think it is something i would have picked up on.
anyone here have that issue or heard of it ?????
please help.
thank you
