Chevy Silverado - Continued XVIII
BWAHAHAHA!!
..he was so proud of all his past statements ..that he changed his screen name!
I believe GM would be losing money on them....just to help us out
- Tim
Speaking of the filters...just turned 20,000 miles and changed the orginal at 10K...does that mean it's ready to be changed again? Hmmm...better order a set of "HEPA" filters....doh!
- Tim
filter today. Turns out they are going to be
sponsoring the Corvette Club this year & offering
members a 25% discount. So got the filters for
$10 less than was expecting.
Overall was easy to replace, just that one screw
in the middle being hard to remove and install
Other than the obvious strength, the advantage of a receiver hitch is the ability to use a load-leveling hitch. That and a sway controller are the best for heavy loads. If you are going to pull a travel trailer or similar frequently, you should spend the money to do it safely.
- Tim
tucsonjwt "Base Model Pickups - buying, owning, accessorizing" Mar 5, 2001 5:15pm
His name is tucsonjwt.
Mine is a Y2K 2500 with bucket seats and center console.
Directions guys?
seriously, it's hard to describe, but your manual should have fairly decent pics in it. essentially, there are three or so hex-screws you'll need to pull. you gently pull down on a plastic tab and rotate it to one side. all this is located under your glove box. if you want really good pics, let me know, i'll try to take them. kinda hard to, but i can try. anyways, you should be able to find what we're talking about by looking up "cabin air filter" in your manual. once you get the plastic tab off to the side, follow the manual directions to pull the filters. i say filters because there are two separate filter elements in there.
here to help...without having you disassemble your truck!
bco
accord or silverado...lots of gray area in between there, my friend...
bco
I originally looked at the LS 4.8L version, but when I had added in some options (which were standard on the LT) it just made sense (to me) to buy the LT -- price difference ended up only about 1,800 difference. On some cold mornings, the heated leather alone was worth the price of the upgrade from LS.
After about 5 months of hard Minnesota use, I am *extremely* happy with this truck -- it's a willing hauler, pulls like a horse, get's reasonable mileage, and cleans up pretty enough to take Honey to the dance in town on Saturday night. I have not had a single malfunction, and none of the complaints I've heard about like vibration, pinging, etc. My driving is a combination of freeway, rural, and "in town" use, plus a fair amount of ranch/farm use, pulling trailers, etc.
Because of the long wheelbase, the ride is as good as all but the plushest sedans, and the interior room is great.
Go for it! You'll wonder how you ever survived without a truck.
Hans
Most of its life has been at full GVWR (6400lbs) and not a problem.
With a full load I averaged 15.4 mpg and over 20 on the highway empty.
Mike L
Ken
Why did I pay more for one from the dealer? Because it came with the wiring harness that you hardwire into the existing taped to the frame above the spare tire. Also came with a pigtail to hardwire onto a brake module and plugs into a jack below the dash.
The wiring harness also has a line that runs all the way into the engine compartment and hardwires into the power bus that sits on the driverside wheel well, includes a 40 amp fuse.
They wanted 4 hours labor to install. Did it myself. All the holes are predrilled in the frame and bumper and the package includes all the nuts and bolts. Instructions TOO!
'00 GMC Sierra Z71 4dr w/5.3
right If option an LS out its 500 to 1000 less
than just ordering an LT 1500 ext cab. Owners
of these have you found this to be true when
actually buying the vehicle.
I'm just checking now. Its in the thinking
cap that might sell my 2000 LS reg cab
to a family member at a 2004 price that way
if they sell or trade in a couple of years
will get there money back. Really want another
reg cab but don't see a way of ordering leather
seats.
cowboyjohn
Hunter
And I do feel great about my truck and I'm glad you feel good about yours. Wish everyone did.
Mike L
00 2500 4x4 6.0L 5spd
Separate question. Owners manual says change rear diff oil after first 500 miles of towing. Stopped by and picked up 4qts of Synthetic 75W-140 oil for my new locker. Owners manual called for Synthetic 75W-90 which cross referenced to 75W-90 synthetic cold weather front diff lube. Took a little while, but I decided to go with the 75W-140 stuff. Comments???
bco
bco
don't know about the 75w140 you were talking about...no experience there...
bco
Hunter
-David
pop the hex screws at #'s 1, 2, and 3. the plastic cover below the dotted line will drop down slightly. pull it down gently, as it will still be attached in the back. from here, reference your owner's manual, as it has pics that will show you how to disengage the clasp that's holding the filter elements in. there are two elements in there, so make sure you pull two and replace two. it goes back together just like it came out...questions...let me know.
here to help...
bco
bco
BWAHAHAHAHA!!
Tire Size Height/Width Program Size
215x85R16 30.38x8.46 Computer
245x75R16 30.47x9.65 Computer
265x75R16 31.65x10.43 Computer
235x85R16 31.73x9.25 265x75R16
305x70R16 32.81x12.01 245x70R19.5
285x75R16 32.83x11.22 245x70R19.5
245x70R19.5 33.00x9.65 Computer
255x85R16 33.07x10.04 245x70R19.5
I saw the 245x70R19.5 on my 1500 a couple of weeks ago, and had been wondering too. I finally did the math. The most size would be off by my above reccomendation is .19" Your tread will vary over .75" over the life of a tire. (Since you wear off the top and bottom of the tire on height.) There is also more variation than this .19 between brands of tires or with rim widths. My 1500 came from the factory with 245x75R16. When we went into reprogram for 265x75R16, the computer showed 215x85R16. So the factory had it set for an equivalent size when my size was even in there too, the standard size even. Tires can even vary a .5" in height and width amoung brands. Your better brands such as Michelin and BFG run larger than the above and cheap brands run less than the above calculations.
I hope this helps you all and makes sense, so, all the popular sizes from the 215 to 305 can be accomidated with the 245x75R16, 265x75R16 or the 245x70R19.5 program and be dead on accurate as you gm would get if they tried. Or maybee they did.
Hunter
Here to help...
Teeheehee!
who cares about the memory?...but gimme them heated seats any day man!
...a great option here where it's cold.....worth every penny....now if only they had heated steering wheels.......hmmmmmm
- Tim
Thought that was pretty nifty.
day and behind hit the leather. But still prefer,
just can't get used to the cloth. Not sure but
think Navigator has A/C seat, didn't keep mine
long enough to remember.
