Chevy Silverado - Continued XVIII
http://www.wheels.com
skip the intro and click on assembly lines
- Tim
..although I do have The Hurst/Olds in the garage....about the last Olds I would want..
- Tim
Anyway, going on a long roadtrip from Dallas to Steamboat at the end of the week, and figured it would be nice to get the alignment right so the tires can start wearing right. When I get back I'll post another data point on fuel mileage for an Ext. Cab, 4x4, 4.10, 6.0L 2500HD.
I do remember way back in something like Silverado VIII someone talking about the knock outs but I'm getting to old to remember the details.
bco
decided to post. Have a 00 Silvarado LS V6,2wd ext
cab 5 spd bought in June of 00.Really checked all
the makes out good,with the fiberglass cap on it
weighs in at a couple hundred lbs more than a 4x4
blazer with the V6 also. Have plenty of get up n
go,and plan on towing a light pop up camper in the future also. Drove it out the door for 21,500
had some problems with it the worst being the tranny needing replaced
but all in all have enjoyed owning it since new.Nothing horrible like
somethings I've read about on the net.My dealer is Jack Whorl Chey in
Manchester Pa.about 7 miles north of York Pa.They're been outstanding
if its wrong they correct it with no fuss or hassles.These are good
trucks and I would recommnd one highly,and give some though to a V6
depending your needs. Thanks
cowboyjohn
Did ya'll know that there are new specs for the alignment on these trucks. Yep, a TSB was issued changing the "SPECS"...so if they tell you that it is within spec, you should ask them if they are referring to the old spec or the new spec. That should throw them for a loop. BTW, I know it works cause I threw it at my shop foreman. He said, "damn internet". So the new question is, does the 10,000 mile limit still hold true. Don't think so, cause GM changed the specs...LMFAO!!
Can't wait to do this same stuff with TSBs and the like.
i was off-roading and messin' around on some fire-breaks this weekend. ran through a couple "tight" spots where some skinny branches ran down the side of my truck. now...i have some light scratches in what looks to be either the wax and/or the clearcoat. definitely not down into the paint...just surface. will these go away after i wash it, wax it, or won't they? any suggestions? thanks...
bco
I'd ask price...and have printed stuff for a back up if need to have a discussion...
BUT..you payed what you wanted to.....so both are happy I guess?
Congrats
- Tim
bco
ps...congrats on your new truck...order that is.
Some clean off, some don't. I look at it like the scars I have from playing sports all my life....Worth the fun!!!!!
If you leave the truck in the garage, it'll stay pretty forever....
Now the rocker panel where the rocks tried to come inside the cab is another story!! That won't wash off or wax away. I guess when the metal is dented and the paint gone you have to visit the body shop.
Mike L
2001 chevy silverado
ls package, 4 wheel drive, 4800 v8, locking diff., z-71 package, automatic, electronic push button 4 wheel drive.
Lists for 26,520 buying for 22,700. And they are changing the wheels to cast aluminum with the different tires, and they are throwing in the receiver hitch and bendliner.
If it is the color you want, and the equipment you want, then it may be the truck for you, get all the deal, stuff they are throwing in and final price, in writting before making your "final decision"
matthew
Q for all: I used to get a catalog for my toyota in the mail that was full of Toyota truck accessories only. Is there a similar company or catalog for Chevy trucks?
Good magazine with alot of parts
http://www.performanceproducts.com
Go there and order a magazine you will get one like every month or 2.
BCO
Last sunday my bedrail cap halfway came off so i thought what a good time to retape it down. Cleaned all the old tape off (damn dealership when they put it back on used a few pieces of new tape and left the original) then cleaned with alcohol (not beer) and reapplied new tape. Really sticks now. Amazing how when you take 30 min and do it right how much better of a job i could do than the body shop that had to fix it when my truck was fixed.
Ryan
Mike L
Mike, thanks. I'll give it another try.
From what i could see they have been on 11 months and with a little wax i doubt there would be that many scratches on the rail itself. Lots of tape marks which can be removed with heat and a little scrubbing.
For them going over the spray in liner im sure they could its not that thick. The tape that is used is probably a lil thicker than the liner.
My suggestion get a pair and try it out (dont glue down) and see how it fits if it fits then actually install them.
Ryan
- Tim
Both had the passenger side out. I still have not seen a Silverado with the driver's side out in the last year.
Mike L
- Tim
best tip i can give you on the pictures is...try "right clicking" on them and copying them. almost all, if not all, should be jpegs if i remember right. if all else fails, copy one, and paste it onto a powerpoint slide, or word document, or something of the sort. then size it and print it - and so on for the rest. not sure why they're printing out that way for you.
as for the brush guard - the brush guard is ALL you have to remove - NOT the skid plate itself - is five 15 mm bolts. it's easy to remember...same socket you'll use to pull the oil pan drain plug and...i THINK to check the transfer case. not sure about the last though.
have fun with it...i know i do.
as for the rail caps...i'll be really surprised if my caps wear my rails down like my drop in liner did on my old truck. see, they attach with 3m double sided tape which is, like, a millimeter thick itself. they really don't move a whole lot.
bco
control is now an option. If same as on other
car sounds like a worthwhile expense.
Any have it ?
In wet weather the back end of my 1500 SB sure
does spin if not careful. But sometimes even in
wet conditions need to give a little more gas to
cross traffic. Have the limited slip but it
doesn't seem to help. Maybe Reg cab are worst
than ext cabs.
Hans
LOL
....I know..better than 4-HI....but it does grunt a little bit when in auto and turning...
...bed rail caps won't wear sides like an over the rail drop in liner.......I had a liner with OTR....and it wore the paint big time.....but never did rust in 12 years......
the liner itself is massive and what causes the rails parts to move so much.......bed rail caps alone won't do that...
I have Stainless rail caps with 3M tape...and they haven't budged a bit.....they also have locker rails (tubes on rails) for additional support...
http://www.teleweb.net/mgdvhman/Rail1.jpg
- Tim
I haven't seen one on a lot yet either.
It was supposed to already be out.
Parts guy at the dealership gave me the bulb for free.
Rear end view of LT285 BFG's
Front Drivers and Passeneger side windows tinted
Many more pics at
http://www.picturetrail.com/ryanbab
P.S. Does anybody know a good tinting place in San Antonio? I am getting conflicting information from people I have talked to down here.
KC
What is the profile of your truck? 2WD or 4WD, reg. cab.or ext. cab, auto or stick, etc.?
Is the vibration in the body or the engine or trans? Do you feel it through the steering wheel or the seat of your pants? What kind of tires do you have?
Use "Silverado V6" on the search feature to see some of the other comments on this.
Also, we have a stripper site under "Base Model Pickups, Buying, Owning, Accessorizing" you might want to check out.
I wouldn't let the dealer off the hook. Vibration on acceleration is one I have not heard about here yet. I'm no mechanic, but it sounds like something is loose (like motor mount/trans mount?) Is this at all related to steering or suspension? I'd try to determine if you can make the vibration go away on acceleration - like accelerating on a right or left turn, uphill or downhill, in 2nd or 3rd gear, etc.
Good luck. Keep us posted. Inquiring minds want to know
A 4x4 for me would be overkill, sold the boat
so no pulling anymore, only off road is road
construction.
As for present truck, its on the 3rd set of
tires in 12000miles. Org were Wrangler ST
and came out of round, 2nd set was even worst,
now its got Wrangler RT\S 255/70.
All was done under warranty so no choice
KCpanther - have used Solar Tint on Nakoma or
Rhapsody? - North Park Lincoln is a big customer.
So far no problem with what was done
I am trading it in for a new Vette and am not happy with current wholesale prices. The best they can give me is $20,500. Thats a big drop for only 2 years.
I am almost paying full MSRP for the Vette, so I know that they have no reason to try to lowball me. I have checked with my other regular dealers and that is about the best anyone could do under the best conditions. They are lucky to turn around and get $22,000 for it once its on their lot. And believe me, there are plenty of them used ones on the lots right now.
Just wanted to share my grief and let you guys know the scoop so you are not as shocked as I was.
I guess I shoulda got a 2500 in the first place, right Tim?
actually 2500's do bring good money used here....as buyers have less to pick from.....unlike a billion used Z-71's...
Good Luck on this one now!
hehe
- Tim
For the $500 certificate, I went to GMC.com and clicked on "Brochure" at the top of the page, and asked for brochures on Sierra and Silverado trucks. The brochures came in the mail, and the certificate came by email a few weeks later. The certificate wasn't advertised, it was a complete surprise. GM TV commercials here in California advertise the $2500 or low apr, I thought that was nationwide, but maybe its just regional.
Gator, you got a great deal, wish I'd been at the Truck Show for that certificate.
What's the deal with the queervette, midlife crisis???
