Chevy Silverado - Continued XVIII
all the manly hood went into the truck?
haha
.....and what did she say Ryan?
- Tim
-Mark
I seem to have a noise from them only going over RR tracks.
Ryan
I remember reading somebody posting that they were around 30 or 35 dollars from the dealer.
My noise was weird, it only did it certain bumps and not always the bigger ones either. It nice and quiet now.
BTW. Bumpers and LOF 1 hour and 2 test drives???
-Mark
I only hear it over two specific rr tracks. Only time i have yet to hear it happen elsewhere.
Probably order them tonight or tomorrow.
Anyone care to purchase some slightly used "Z71" (tennecos) shocks? Tim better jump on this. You can claim you have an offroad LD 2500
You can get an emblem 2500Z71LD
Ryan
Peter
Ryan
My '99 2500 Silverado make a "ticking" or some type of noise usually at cold start. I will probably take it in, but was wondering what you guys thought or if a similar problem was mentioned here... I don't think this has been happening too long. It's a pain to take it to the dealer - (they have to keep it overnight, then cold start it).
If someone could also lead me to a post with this problem that would be great!
Cindy
Check out pickuptruck.com lots of talk going on there
http://forums.pickuptruck.com/Forum11/HTML/005598.html
- Tim
haha
- Tim
"Installed spring insulators as per recall"
I don't know if there is a recall or if thats just how they wrote it up.
-Mark
Probably their excuse
I went to pickuptruck.com - I was reading about the piston knock, it doesn't sound too much like a rod knock, its more like a 'ticking'.
Hmmm, may have to take it in.
Hey, by the way, I had a window motor replaced on the passenger side already.
-Cindy
=Cindy
Ryan
BTW, It was wicked easy to do even with the center console.
-Mark
So TIM ya change yours yet?
Ryan
IMO, I believe it to be something in the heads, ie. the lifters or something not getting proper oil!
Good Luck,
Dano
I have been looking over the forum and it appears to have ALOT of useful info here. I have just purchased a '00 Rado Z71 extended cab. Had the black flares but ten minutes in the driveway and I took care of that! You're right they looked BAAAD. I took it to my hunting camp on Wednesday and was quite disappointed when I was in 4wd.
Symptoms:
1. In 4hi the power was very sluggish.
2. In 4lo when you pressed the gas the motor would rev for a minute and then the truck would start to move forward and then LURCH forward! It was almost like I had my foot on the gas waiting for a the lights to change. Looks like it's time to visit the dealer! Any suggestions? Has anyone noticed this with theirs? When I test drove on pavement the 4wd worked ok. I am really confused about this.
Also The dang OIL CHANGE LIGHT will not go out. Any suggestions (other than change my oil)
Mike
Today, by my lonesome, I changed the oil in my 5.3L engine, on a lift, using dino oil (4400 miles) and a PF59 AC Delco filter. Total cost was $16, plus the opportunity to examine the underside of my rig and see what was stuck to the drain plug magnet. I worked slow and deliberate and it still only took 50 minutes. Can't get that at QuickeeLube.
This is really cool stuff when I get time to do it.
Thanks again.
I'm considering buying a new 01 or 02 extended cab 1500 truck on a family member's GM certificate. I'm wondering what kind of discount dealers will give on the 2001s when the 02s come out, trying to decide which to get. A few dealers have told me to expect no more than a $2500 incentive on the 01s, but someone told me last week that it could be a lot higher, $7000, that doesn't seem possible, what did they offer last year, anyone know?
Sure wish they'd offer a larger gas tank as an option on the standard ext cabs, but don't think they do, do they? Anyone have one of the composite Pro-Tek beds, wondering how they like it, thats only a Z71 option, right? I was thinking of buying from the closest GM dealer here in Los Angeles south bay, for convenience sake, but if there's a better dealer further away that will stand by me if I have problems, I'd rather go to him, anyone have a preferred dealer in the area? Be back tonite, thanks....Chris
Still on the lot didnt look like it was going anywhere.
Bryant chevrolet.
Ryan
Dano
Quad-
You forgot the brain damage....excessively speaking....
pogo11
Welcome to edmund's...but you've been here for half a year...so it's like welcome back...wish I could help with your questions but I don't qualify for the first and live a little too far to recommend a dealership.
In 4-lo, it is kind of jumpy and sensitive to throttle because of the gear ratio vs. power available. It does seem to rev and jump forward but that is just from the tranny shifting. In the lower gears the engine rpm hits the shift point very quickly while the truck is still going slow, then once a ratio is hit where you can get some speed, the truck jumps forward. This is normal.
Where did you go in Southern Indianna?
I fly into Evansville occasionally. Have to look at an ugly Tundra in the airport terminal when I pick up a rental car and luggage.
Today is the day for the rear differential, isn't it? Let us know how it goes.
Tom
The canoe place is right off US 41.
Yep rear diff fluid and oil is getting changed again.
Also might go order shocks at autozone if i get time ($49.95 each)
Ryan
Cant do the rear end yet. Torque wrenchs only goes to 250 inch lbs and 29 n.m. For the rear end i need 30 ft.lbs or 40 n.m so i am waiting to see if my gf's dad has one. If not looks like ill be buying one or waiting till my dad can get one from work.
Ryan
http://www.aeswave.com/Palm/CJ2/
Saturday afternoon storm knocked out power to six buildings.
NO SCHOOL TONIGHT!!!
