Chevy Silverado Problems
cowboyjohn
http://www.acronymsearch.com/
And to those with the fan problem. The lower the temp, when you start your car in the morn, you will hear a sound for about 10 secs to 30 secs depending on how cold it is. It was -5 last night and it made the sound for about 10 secs and then quieted down. Remember that it has been sitting in that all night. It will freeze up and get cold just like the block, so it's not a GM problem it's a weather issue.
support in the drivers seat. I can't believe this.
I only weigh 145 lbs and the thing broke on a mountain access road.
Oh well. The dealer ordered a new seat frame and will relace it when it comes in.
Walter
dch0300 Thanks for the acronym list.
cowboyjohn
AS rube the dope would say good luck on that one for now!
New? Isnt it the same engine they had been using in previous yrs and other models like the blazers?
I don't have to add oil to my Ford F150 Super Crew neither, but it's only 4 months old.
thank gawd I did not purchase one of the little Tundra trucks I looked at. I needed a truck that full size humans would fit into.
I think that Chev has a lot of nerve calling their puny 1500HD "full size". It does make a nice minivan though.
But, while he still has a Toy truck, the only way he can feel better is to try and cut down the ones he is jealous of.
Just remember the reason he is here, and leave him alone..........After he hangs around with the real trucks awhile, he'll buy one!
Mike L
check out
http://www.gm-trucks.com
All gm owners none of this stupid bs
The Tundra outbroke the 1500HD!!! I wonder why anyone would come in here bashing our trucks when their's outbreaks our's! I understand your frustration, everhart. I too am getting tired of people coming in here and being disrupters. If someone likes their Toyota, that's fine by me. But they don't need to come into all the other rooms bragging like there's no tomorrow about their truck, while cutting everyone else down. This thread is really about new style Chevys and GMCs. If someone doesn't own one or isn't interested in one, then they should stay out unless they have something constructive to say. But to constantly come in here to disrupt and be acrimonious is indicative of real life problems that need to dealt with on a professional level. I stay out of Ford, Dodge, Toyota, etc rooms. I would expect the same from others. There, I've said my piece.
I'm just curious, do you mean FAT people? I'm 5'11" and 180lbs, I have a friend who is 6'5" and over 200lbs. No problem fitting in the Tundra. I sat in the back of a GMC Sierra extended cab recently and I couldn't close the rear door with the front seats all the way back because I couldn't get my knee in far enough. As far as front seat room though there isn't much difference between the GMC and the Tundra.
"No problem fitting in the Tundra. I sat in the back of a GMC Sierra extended cab recently and I couldn't close the rear door with the front seats all the way back because I couldn't get my knee in far enough"
Yeah try that in a Tundra with the front seats FORWARD much less all the way back. To bring the subject of rear seat legroom is idiotic comparing the the two trucks. You can't even sit in the back of the Tundra without getting a backache.
The second poster reminds me of this group out of the 70's....called El Chicano...LMFAO!!
New Member
Alexandria, LA Date Posted: Dec 28, 2001 10:46 AM
I am not trying to start a brand war,or an american vs [non-permissible content removed] war, just trying to provide information to other Tundra owners wondering how their truck might tow a 5th wheel.
The Tundra does tow well. I live in flat Louisiana, so I have not had a chance to try in mountains. I recently (this week) bought a 5th wheel. It is a Cougar 278, 28'8", hitch weight 1160, total weight per manufacturer 6,800#, about 12' high.
I took it to the Cat scales. These were the actual weights: Steer axle 2600#, Drive axle 3440#,
Trailer axles 5820#, Gross 11860#
The trailer was lightly loaded, and my wife was not in truck. This is close to GVWR 6200, since GVW was 6040 (2600+3440). Put the wife in and we have a few lbs left. The GCWR was slightly over (60#), but will be within 2-3% with wife and a few other items. Pin is right over the rear axle (have slider hitch).
Have only towed a few hours, but the Tundra pulls it well (OD off, 3100rpm, 68mph mostly). The trailer actally weighs about 250# more than the manufacturer's sticker (hard to imagine). That is why I am a little higher on wieghts than I thought I would be. Will post update after trip this long weekend. The Tundra can well handle its maximum weights on relatively flat land.
All comments are welcome.
cougar5th
New Member
Alexandria, LA Date Posted: Dec 28, 2001 12:35 PM
We thought it(Cougar 278) fit us best, given weight limitations because we did not want to buy another truck to replace a truck only six months old that I like the 95+% of the time I'm not towing. Only time will tell how well it hlds up.
cougar5th
New Member
Alexandria, LA. Date Posted: Feb 19, 2002 2:10PM
I started this thread so I thought I owed it to all concerned (especially potential Tundra owners)to update the situation. While the Tundra did real well in relatively flat land, it struggled some in mountains (Arkansas sized not Colorado sized).
I would recommend Tundra owners stay to 5-5,500 lbs if mountians will be on the agenda. We bought the fifth wheel trailer we really wanted, and Colorado is on our agenda, so we traded the Tundra in for a Ford F250 Crew Cab with PSD. I have yet to pull the fifth-wheel with the new truck, but I think the 7,500# fifth-wheel will be a walk in the park for the PSD.
The Tundra is a great half ton, and I really liked it. But I have to admit that some of you were right (including 5thwheeler) when you said the trailer was too much for a half ton.
I hope some can learn from my experience.
Larry
Anyway, I also can get the driveline to make noise in overdrive with locked torque converter when lugging the engine at a round 1100 to 1200 rpms. I think it is the drive shaft and I have been other trucks that do the same thing (a Diesel Dodge 4x4 I drove made the same noise). Tow/Haul does not allow the engine to lug so there is no noise.
I think the noise is produced by high torque low rpm operation combined with the 60-degree pulses from a 6-cylinder engine. During each power stroke the engine resonates the driveline. A V-8 has 45-degree power pulses. The V-6 driveline is the same as the V-8s so I would expect it to be durable.
FYI, the 4.3 V-6 should feel the same as the 4.8 V-8 and 5.3 V-6 at 1100 to 1200 rpms. The V-6 produces max torque at lower rpms than the V-8s and amazingly produces about the same torque between 1100 and 1200 rpms.
Customer Service says it comes under the part in the warranty exceptions under "cleaning" and the word cleaning is right next to the word "polishing". The carbon has to be cleaned from the throttle plate and the cost is incurred on the owner if it is not done before 12k. This is one of 3 problems that I have not been able to have corrected under warranty. So that tells me it is not worth the paper it is written on.
I'm 5'10" and when I'm driving my Silverado in my normal seat position and my 6'6" friend in the passenger seat, I have no problem with guys around 5'10" sitting in the back seat.
Somewhere on this board is a link to a TSB that tells the dealer to replace your throttle body - to not bother cleaning or trying to adjust it.
I am sure someone here can post this link - print it out and shove it up the guys [non-permissible content removed].
Better yet - find a dealer that will work to help you rather than treating you like dirt.
chev-33.7
tundra-28.6
it don't matter if you're a small child or don't have legs
kip
If you read my post I needed a truck that full size humans would fit in. That probably explains why I now own a Ford F150 Super Crew truck too.
The Tundra is too small for me. The bed is too shallow too.
And I must admit I don't give a rat's patootee what Motor Trend has to say.
The Tundra has some good things going for it.......but the fact is it's too small for my needs. I do not need a 3/4 size truck.
And it cerrtainly is important of the "size" of a tow vehicle to the load being towed.
A little truck pulling a large load is not good.
Anybody got the same? Wanted some other thoughts before it goes to the dealer to get checked out.
havent had my truck in 4wheel hi since last winter. Never recalled it making "alot of noise". Some but barely noticable
I guess if you are 6'5" and everyone else in the truck is 6'5" then the Sierra would have an advantage but I've driven with another couple in my truck with a 6'1" guy in the passenger seat and our wives in the back (they are 5'3"-my wife and 5'5"-his wife) and everyone was plenty comfy.
I also don't think anyone in the first scenario above would be at all comfy because the front seats would have to be so far forward for the rear passengers to fit.
I'm just curious because I always hear people (mostly American truck owners) [non-permissible content removed] about the small back seat in the Tundra. I guess if you regularly have 4 people in your truck you would buy a crew cab but if it's a rarity I don't see the advantage in the Chevy/GMC. Maybe with the new Dodge Ram but not with any other fullsize extended cab truck.
laemt-
So when are you buying your tundra? People may start calling you a Tundra wannabeeeeee.......hehe!
sheesh, why does this board have to contain such hogwash.
a great idea would be to let members of their topic delete the useless ones such as yours. at least that way the interested parties wouldn't have to waste time sorting through the Kaos you two start.
oh well, guess it's back to GM Trucks.
This will work, but at your cost. Around $100 at the dealer. You can do it yourself with a can of cleaner.
Depending on when your truck was built, it may have an updated throttle body. But it is having the same problems as the earlier throttle bodies that GM was replacing them under warranty.
After sitting for awhile, the butterfly will "stick." You have to pop the pedal hard to get it unstuck. It will be fine until the next time the truck sits for awhile.
This is horsesh$t. Mine was replaced at 15000. I now have 40000 on the truck and have not had a problem with the new throttle body.
Increased Accelerator Pedal Effort (Replace Throttle Body) #00-06-04-007B
1999-2000 Chevrolet and GMC C/K Pickup Models (Silverado and Sierra)
with 4.8 L, 5.3 L or 6.0 L V8 Engine (VINs V, T, U -- RPOs LR4, LM7, LQ4)
This bulletin is being revised to include instructions on reading the Date Code, and added text on which Throttle Body Assemblies to replace. Please discard Corporate Bulletin Number 00-06-04-007A (Section 04 -- Engine Controls).
Condition
Some customers may comment on a higher than expected accelerator pedal effort from the idle position.
Cause
Condition may be caused by a tight throttle blade in the throttle body bore when in the closed position.
Correction
Notice
DO NOT adjust the shipping air screw to rotate the throttle body blade away from the throttle body bore. Adjusting the shipping air screw compromises the idle speed control, and may lead to other driveability concerns. Adjusting the shipping air screw may lead to reduced Idle Air Control valve durability.
Verify the cause for this condition is not a damaged or binding throttle cable.
Remove the throttle body from the engine and inspect the 4 digit Julian date code stamped on the bottom edge of the mounting flange. The Julian date code is stamped on the lower edge of the mounting flange, next to the gasket edge, on the side of the throttle position sensor. The stamped 5 digit code is the last 5 digits of the Throttle Body Assembly Part Number. If the Date Code is 2979 , or earlier (Indicating the Throttle Body was built before the 297th day of 1999):
DO NOT clean the Throttle Body Assembly.
Replace the Throttle Body Assembly using the Service Manual procedure.
DO NOT attempt to adjust Throttle Body Assemblies.
Notice
All 1999 models whose Throttle Body has not been replaced will have a date code prior to 2979 and should be replaced for this condition.
Reading The Date Code
The four digit Date Code can be interpreted as follows:
Example -- Date Code 2979
The first 3 digits (297) represent the calendar Julian date. 297 = the 297th day of the calendar year.
The last digit (9) represents the last digit of the year.
8 = the year 1998
9 = the year 1999
0 = the year 2000
1 = the year 2001
Parts Information
Model Year Part Number Description
1999 17113597 Throttle Body, 4.8 L V8 w/Manual Transmission
1999 17113583 Throttle Body, 4.8 L and 5.3 L V8 w/Automatic Transmission
1999 17113558 Throttle Body, 6.0 L V8 w/Automatic Transmission
1999 17113599 Throttle Body, 6.0 L V8 w/Manual Transmission
2000 17113639 Throttle Body, 4.8 L V8 w/Manual Transmission
2000 17113665 Throttle Body, 4.8 L and 5.3 L V8 w/Automatic Transmission and w/o Traction Control
2000 17113640 Throttle Body, 6.0 L V8 w/Manual Transmission
2000 17113652 Throttle Body, 6.0 L V8 w/Automatic Transmission and w/o Traction Control
1999, 2000 17113561 Seal, Throttle body (not shown)
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation Description Labor Time
J5485 Throttle Body - R&R Use Published Labor Time
J5490 Throttle Body Replace Use Published Labor Time
© Copyright General Motors Corporation. All Rights Reserved.
